path: root/Documentation/DocBook/kernel-locking.tmpl
2008-05-23doc: add a chapter about trylock functions [Bug 9011]Matti Linnanvuori
Add a chapter about trylock functions. http://bugzilla.kernel.org/show_bug.cgi?id=9011 Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed down_trylock)
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-21DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-06docs: kernel-locking: Convert semaphore referencesDaniel Walker
I converted some of the document to reflect mutex usage instead of semaphore usage. Since we shouldin't be promoting semaphore usage when it's on it's way out.. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22DocBook: Change a headline in kernel-locking to list all three main types of ↵Linus Nilsson
locking. Change a headline to reflect that there are three main types of kernel locking, not two. Signed-off-by: Linus Nilsson <lajnold@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17docbook: make kernel-locking table readableRandy Dunlap
Andi Kleen pointed out to me that the kernel locking cheat sheet table entries are unreadable. Make table entries smaller so that pdf and ps output is readable (columns were being overwritten and garbled) by using abbreviations. This allows the tables to fit on one page cleanly. Add a Legend for the abbreviations: SLIS: spin_lock_irqsave SLI: spin_lock_irq SL: spin_lock SLBH: spin_lock_bh DI: down_interruptible Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-26typo fixesolecom@mail.ru
2006-01-09[PATCH] mutex subsystem, documentationIngo Molnar
Add mutex design related documentation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
