path: root/Documentation/DocBook/mtdnand.tmpl
2011-05-25mtd: kill CONFIG_MTD_PARTITIONSJamie Iles
Now that none of the drivers use CONFIG_MTD_PARTITIONS we can remove it from Kconfig and the last remaining uses. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24docbook: make mtd nand module init staticH Hartley Sweeten
In the example the module_init function should be static. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-02DocBook: fix ioremap return typeH Hartley Sweeten
ioremap() returns a void __iomem * not an unsigned long. Update the Documentation file to reflect this. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-02-07Add section IDs to mtdnand.tmplRob Landley
Add section IDs to mtdnand.tmpl Signed-off-by: Rob Landley <rob@landley.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: Documentation/Simon Arlott
Spelling fixes in Documentation/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-01Documentation/DocBook/mtdnand.tmpl: kmalloc + memset conversion to kzallocMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-07-03Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [JFFS2][XATTR] Fix memory leak in POSIX-ACL support fs/jffs2/: make 2 functions static [MTD] NAND: Fix broken sharpsl driver [JFFS2][XATTR] Fix xd->refcnt race condition MTD: kernel-doc fixes + additions MTD: fix all kernel-doc warnings [MTD] DOC: Fixup read functions and do a little cleanup
2006-06-30Documentation/DocBook/mtdnand.tmpl: typo fixesPatrick Pletscher
2006-06-29MTD: kernel-doc fixes + additionsRandy Dunlap
Fix some kernel-doc typos/spellos. Use kernel-doc syntax in places where it was almost used. Correct/add struct, struct field, and function param names where needed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-29MTD: fix all kernel-doc warningsRandy Dunlap
Fix all kernel-doc warnings in MTD headers and source files: - add some missing struct fields; - correct some function parameter names; - use kernel-doc format for function doc. headers; - nand_ecc.c contains only exported interfaces, no internal ones; Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
