path: root/Documentation/DocBook/v4l
2011-07-27[media] DocBook: Move all media docbook stuff into its own directoryMauro Carvalho Chehab
This patch addresses several issues pointed by Randy Dunlap <rdunlap@xenotime.net> at changeset ece722c: - In the generated index.html file, "media" is listed first, but it should be listed in alphabetical order, not first. - The generated files are (hidden) in .tmpmedia/ - The link from the top-level index.html file to "media" is to media/index.html, but the file is actually in .tmpmedia/media/index.html - Please build docs with and without using "O=builddir" and test that. - Would it be possible for media to have its own Makefile instead of merging into this one? Due to the way cleandocs target works, I had to rename the media DocBook to media_api, otherwise cleandocs would remove the /media directory. Thanks-to: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] DocBook: Add rules to auto-generate some media docbookMauro Carvalho Chehab
Auto-generate the videodev2.h.xml,frontend.h.xml and the indexes. Some logic at the Makefile helps us to identify when a symbol is missing, like for example: Error: no ID for constraint linkend: V4L2-PIX-FMT-JPGL. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-25[media] add V4L2-PIX-FMT-SRGGB12 & friends to docbookMauro Carvalho Chehab
The xml with those guys are there, but they weren't included on the docbook. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-25[media] Documentation/DocBook: Rename media fops xml filesMauro Carvalho Chehab
By convention, the name of the XML file should match the references declared at media-entities.tmpl, as, otherwise, some validation scripts break. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-25[media] Media DocBook: fix validation errorsHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Add M420 format definitionHans de Goede
M420 is a hybrid YUV 4:2:0 packet/planar format. Two Y lines are followed by an interleaved U/V line. Signed-off-by: Hans de Goede <hdegoede@redhat.com> [laurent.pinchart@ideasonboard.com: split into v4l/uvcvideo patches] [laurent.pinchart@ideasonboard.com: add documentation] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Add V4L2_MBUS_FMT_JPEG_1X8 media bus formatSylwester Nawrocki
Add V4L2_MBUS_FMT_JPEG_1X8 format and the corresponding Docbook documentation. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] Add Y10B, a 10 bpp bit-packed greyscale formatAntonio Ospite
Add a 10 bits per pixel greyscale format in a bit-packed array representation, naming it Y10B. Such pixel format is supplied for instance by the Kinect sensor device. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-27Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits) [media] media: vb2: correct queue initialization order [media] media: vb2: fix incorrect v4l2_buffer->flags handling [media] s5p-fimc: Add support for the buffer timestamps and sequence [media] s5p-fimc: Fix bytesperline and plane payload setup [media] s5p-fimc: Do not allow changing format after REQBUFS [media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4 [media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet [media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet [media] tda18271: fix bad calculation of main post divider byte [media] tda18271: prog_cal and prog_tab variables should be s32, not u8 [media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init [media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails [media] v4l: Don't register media entities for subdev device nodes [media] omap3isp: Don't increment node entity use count when poweron fails [media] omap3isp: lane shifter support [media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts [media] media: add missing 8-bit bayer formats and Y12 [media] v4l: add V4L2_PIX_FMT_Y12 format cx23885: Fix stv0367 Kconfig dependency [media] omap3isp: Use isp xclk defines ... Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
2011-04-19[media] media: add missing 8-bit bayer formats and Y12Michael Jones
8-bit SGBRG and SRGGB media bus formats are missing, as well as the 12-bit grey format. Add them. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] v4l: add V4L2_PIX_FMT_Y12 formatMichael Jones
Y12 is a grey-scale format with a depth of 12 bits per pixel stored in 16-bit words. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-13[media] media: Use correct ioctl name in MEDIA_IOC_SETUP_LINK documentationLaurent Pinchart
The documentation incorrectly refers to MEDIA_IOC_ENUM_LINKS, fix it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] docs: fix typo in lirc_device_interface.xmlJarod Wilson
Reported-by: Daniel Burr <dburr@topcon.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] Make 2.6.39 not 2.6.38 the version when Multi-planar API was addedPawel Osciak
Multi-planar API was added to 2.6.39 version of Video for Linux 2 API. Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] Fix 'ID nv12mt already defined' errorHans Verkuil
DocBook validation fix. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] V4L DocBook: update V4L2 versionHans Verkuil
2011-03-22[media] V4L doc fixesHans Verkuil
The xmlto validation produced a number of errors that are now fixed. Sadly, the DocBook/Makefile still adds --skip-validation to xmlto, so these errors are missed during a normal compile. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Documentation for the NV12MT formatKamil Debski
Added documentation for V4L2_PIX_FMT_NV12MT format. This is a YUV 4:2:0 format with macro block size of 64x32 and specific order of macro blocks in the memory. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add 12 bits bayer pixel formatsLaurent Pinchart
Add FCCs for the following pixel formats: - V4L2_PIX_FMT_SBGGR12 - V4L2_PIX_FMT_SGBRG12 - V4L2_PIX_FMT_SGRBG12 - V4L2_PIX_FMT_SRGGB12 Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add missing 12 bits bayer media bus formatsLaurent Pinchart
Add codes and documentation for the following media bus formats: - V4L2_MBUS_FMT_SGBRG12_1X12 - V4L2_MBUS_FMT_SGRBG12_1X12 - V4L2_MBUS_FMT_SRGGB12_1X12 Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: v4l2_subdev userspace crop APIAntti Koskipaa
This patch adds the VIDIOC_SUBDEV_S_CROP and G_CROP ioctls to the userland API. CROPCAP is not implemented because it's redundant. Signed-off-by: Antti Koskipaa <akoskipa@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: v4l2_subdev userspace frame interval APILaurent Pinchart
The three new ioctl VIDIOC_SUBDEV_ENUM_FRAME_INTERVAL, VIDIOC_SUBDEV_G_FRAME_INTERVAL and VIDIOC_SUBDEV_S_FRAME_INTERVAL can be used to enumerate and configure a subdev's frame rate from userspace. Two new video::g/s_frame_interval subdev operations are introduced to support those ioctls. The existing video::g/s_parm operations are deprecated and shouldn't be used anymore. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: v4l2_subdev userspace format APILaurent Pinchart
Add a userspace API to get, set and enumerate the media format on a subdev pad. The format at the output of a subdev usually depends on the format at its input(s). The try format operation is thus not suitable for probing format at individual pads, as it can't modify the device state and thus can't remember the format tried at the input to compute the output format. To fix the problem, pass an extra argument to the get/set format operations to select the 'try' or 'active' format. The try format is used when probing the subdev. Setting the try format must not change the device configuration but can store data for later reuse. Data storage is provided at the file-handle level so applications probing the subdev concurently won't interfere with each other. The active format is used when configuring the subdev. It's identical to the format handled by the usual get/set operations. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: v4l2_subdev userspace format API - documentation binary filesLaurent Pinchart
Add images used by the V4L2 subdev userspace format API documentation. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Pipelines and media streamsLaurent Pinchart
Drivers often need to associate pipeline objects to entities, and to take stream state into account when configuring entities and links. The pipeline API helps drivers manage that information. When starting streaming, drivers call media_entity_pipeline_start(). The function marks all entities connected to the given entity through enabled links, either directly or indirectly, as streaming. Similarly, when stopping the stream, drivers call media_entity_pipeline_stop(). The media_entity_pipeline_start() function takes a pointer to a media pipeline and stores it in every entity in the graph. Drivers should embed the media_pipeline structure in higher-level pipeline structures and can then access the pipeline through the media_entity structure. Link configuration will fail with -EBUSY by default if either end of the link is a streaming entity, unless the link is marked with the MEDIA_LNK_FL_DYNAMIC flag. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Links setupLaurent Pinchart
Create the following ioctl and implement it at the media device level to setup links. - MEDIA_IOC_SETUP_LINK: Modify the properties of a given link The only property that can currently be modified is the ENABLED link flag to enable/disable a link. Links marked with the IMMUTABLE link flag can not be enabled or disabled. Enabling or disabling a link has effects on entities' use count. Those changes are automatically propagated through the graph. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Entities, pads and links enumerationLaurent Pinchart
Create the following two ioctls and implement them at the media device level to enumerate entities, pads and links. - MEDIA_IOC_ENUM_ENTITIES: Enumerate entities and their properties - MEDIA_IOC_ENUM_LINKS: Enumerate all pads and links for a given entity Entity IDs can be non-contiguous. Userspace applications should enumerate entities using the MEDIA_ENT_ID_FLAG_NEXT flag. When the flag is set in the entity ID, the MEDIA_IOC_ENUM_ENTITIES will return the next entity with an ID bigger than the requested one. Only forward links that originate at one of the entity's source pads are returned during the enumeration process. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Media device information queryLaurent Pinchart
Create the following ioctl and implement it at the media device level to query device information. - MEDIA_IOC_DEVICE_INFO: Query media device information The ioctl and its data structure are defined in the new kernel header linux/media.h available to userspace applications. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Entities, pads and linksLaurent Pinchart
As video hardware pipelines become increasingly complex and configurable, the current hardware description through v4l2 subdevices reaches its limits. In addition to enumerating and configuring subdevices, video camera drivers need a way to discover and modify at runtime how those subdevices are connected. This is done through new elements called entities, pads and links. An entity is a basic media hardware building block. It can correspond to a large variety of logical blocks such as physical hardware devices (CMOS sensor for instance), logical hardware devices (a building block in a System-on-Chip image processing pipeline), DMA channels or physical connectors. A pad is a connection endpoint through which an entity can interact with other entities. Data (not restricted to video) produced by an entity flows from the entity's output to one or more entity inputs. Pads should not be confused with physical pins at chip boundaries. A link is a point-to-point oriented connection between two pads, either on the same entity or on different entities. Data flows from a source pad to a sink pad. Links are stored in the source entity. To make backwards graph walk faster, a copy of all links is also stored in the sink entity. The copy is known as a backlink and is only used to help graph traversal. The entity API is made of three functions: - media_entity_init() initializes an entity. The caller must provide an array of pads as well as an estimated number of links. The links array is allocated dynamically and will be reallocated if it grows beyond the initial estimate. - media_entity_cleanup() frees resources allocated for an entity. It must be called during the cleanup phase after unregistering the entity and before freeing it. - media_entity_create_link() creates a link between two entities. An entry in the link array of each entity is allocated and stores pointers to source and sink pads. When a media device is unregistered, all its entities are unregistered automatically. The code is based on Hans Verkuil <hverkuil@xs4all.nl> initial work. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Media deviceLaurent Pinchart
The media_device structure abstracts functions common to all kind of media devices (v4l2, dvb, alsa, ...). It manages media entities and offers a userspace API to discover and configure the media device internal topology. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DocBook/v4l2.xml: Update version of the specMauro Carvalho Chehab
2011-03-21[media] DocBook: Document the removal of the old VIDIOC_*_OLD ioctlsMauro Carvalho Chehab
Those ioctls passed away. Properly documented it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] videodev2.h.xml: Update to reflect videodev2.h changesMauro Carvalho Chehab
A few changes happened at videodev2.h: - Addition of multiplane API; - removal of VIDIOC_*_OLD ioctls; - a few more video standards. Update the file to reflect the latest changes. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Remove compatibility layer from multi-planar API documentationPawel Osciak
This feature will probably be moved to libv4l2. Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DocBook/v4l: fix validation errorsHans Verkuil
2011-03-21[media] v4l: Add DocBook documentation for YU12M, NV12M image formatsSylwester Nawrocki
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Add multi-planar API documentationPawel Osciak
Add DocBook documentation for the new multi-planar API extensions to the Video for Linux 2 API DocBook. Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Fix mmap() example in the V4L2 API DocBookPawel Osciak
Correct ioctl return value handling and fix coding style issues. [mchehab@redhat.com: return -1 is OK, according with ioctl manpages. Reverting ioctl changes] Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] DocBook/v4l: update V4L2 revision and update copyright yearsHans Verkuil
2011-01-19[media] DocBook/v4l: fix validation error in dev-rds.xmlHans Verkuil
2010-12-29[media] Fix videodev.h references at the V4L DocBookMauro Carvalho Chehab
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-23videodev2.h.xml: Update to reflect the latest changes at videodev2.hMauro Carvalho Chehab
2010-10-23[media] v4l: document new Bayer and monochrome pixel formatsGuennadi Liakhovetski
Document all four 10-bit Bayer formats, 10-bit monochrome and a missing 8-bit Bayer formats. create mode 100644 Documentation/DocBook/v4l/pixfmt-srggb10.xml create mode 100644 Documentation/DocBook/v4l/pixfmt-srggb8.xml create mode 100644 Documentation/DocBook/v4l/pixfmt-y10.xml [mchehab@redhat.com: remove duplicated symbol for V4L2-PIX-FMT-SGRBG10 and added the corresponding entries at media-entities.tmpl] Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-23[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028Mauro Carvalho Chehab
2010-10-22[media] Documentation: v4l: Add hw_seek spacing and two TUNER_RDS_CAP flagsMatti Aaltonen
Add a couple of words about the spacing field in the HW seek struct, also a few words about the new RDS tuner capability flags V4L2_TUNER_CAP_RDS_BLOCK-IO and V4L2_TUNER_CAP_RDS_CONTROLS. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: V4L Doc: removed duplicate linkHans Verkuil
2010-10-21V4L/DVB: V4L Doc: correct the documentation for VIDIOC_QUERYMENUHans Verkuil
The VIDIOC_QUERYMENU documentation was not correct. EINVAL can be returned if the driver does not support some of the menu items. I.e. in a list of MPEG bitrates a driver generally supports only a subset of these. This behavior has been in place for years, but was never properly documented. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: V4L Doc: document V4L2_CAP_RDS_OUTPUT capabilityHans Verkuil
We forgot to add this capability to the QUERYCAP documentation. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: V4L Doc: fix DocBook syntax errorsHans Verkuil
