path: root/Documentation/DocBook
2011-11-21Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: drivers/base/node.c: fix compilation error with older versions of gcc uio: documentation fixups device.h: Fix struct member documentation
2011-11-15uio: documentation fixupsGeoff Thorpe
The 'name' attribute of struct uio_mem wasn't documented, and the note about 'kobj' is stale and needs to be changed to 'map'. Signed-off-by: Geoff Thorpe <geoff@geoffthorpe.net> Signed-off-by: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-08Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: (45 commits) DocBook/drm: Clean up a todo-note DocBook/drm: `device aware' -> `device-aware' DocBook/drm: `(device|driver) specific' -> `(device|driver)-specific' DocBook/drm: Clean up the paragraph on framebuffer objects DocBook/drm: Use `; otherwise,' DocBook/drm: Better flow with `, and then' DocBook/drm: Refer to the domain-setting function as a device-specific ioctl DocBook/drm: Improve flow of GPU/CPU coherence sentence DocBook/drm: Use an <itemizelist> for fundamental GEM operations DocBook/drm: Insert a comma DocBook/drm: Use a <variablelist> for vblank ioctls DocBook/drm: Use an itemizedlist for what an encoder needs to provide DocBook/drm: Insert `the' for readability, and change `set' to `setting' DocBook/drm: Remove extraneous commas DocBook/drm: Use a colon DocBook/drm: Clarify `final initialization' via better formatting DocBook/drm: Remove redundancy DocBook/drm: Insert `it' for smooth reading DocBook/drm: The word `so-called'; I do not think it connotes what you think it connotes DocBook/drm: Use a singular subject for grammatical cleanliness ...
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-11-06Merge branch 'docs/docbook/drm' of git://github.com/mfwitten/linux into ↵Randy Dunlap
docs-move
2011-11-03[media] v4l: Add AUTO option for the V4L2_CID_POWER_LINE_FREQUENCY controlSylwester Nawrocki
V4L2_CID_POWER_LINE_FREQUENCY control allows applications to instruct a driver what is the power line frequency so an appropriate filter can be used by the device to cancel flicker by compensating the light intensity ripple. Currently in the menu we have entries for 50 Hz and 60 Hz and for entirely disabling the anti-flicker filter. However some devices are capable of automatically detecting the frequency, so add V4L2_CID_POWER_LINE_FREQUENCY_AUTO entry for them. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] V4L: document the new VIDIOC_CREATE_BUFS and VIDIOC_PREPARE_BUF ioctl()sGuennadi Liakhovetski
[mchehab@redhat.com: remove emacs format crap at the end of the new files] Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-10-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (348 commits) [media] pctv452e: Remove bogus code [media] adv7175: Make use of media bus pixel codes [media] media: vb2: fix incorrect return value [media] em28xx: implement VIDIOC_ENUM_FRAMESIZES [media] cx23885: Stop the risc video fifo before reconfiguring it [media] cx23885: Avoid incorrect error handling and reporting [media] cx23885: Avoid stopping the risc engine during buffer timeout [media] cx23885: Removed a spurious function cx23885_set_scale() [media] cx23885: v4l2 api compliance, set the audioset field correctly [media] cx23885: hook the audio selection functions into the main driver [media] cx23885: add generic functions for dealing with audio input selection [media] cx23885: fixes related to maximum number of inputs and range checking [media] cx23885: Initial support for the MPX-885 mini-card [media] cx25840: Ensure AUDIO6 and AUDIO7 trigger line-in baseband use [media] cx23885: Enable audio line in support from the back panel [media] cx23885: Allow the audio mux config to be specified on a per input basis [media] cx25840: Enable support for non-tuner LR1/LR2 audio inputs [media] cx23885: Name an internal i2c part and declare a bitfield by name [media] cx23885: Ensure VBI buffers timeout quickly - bugfix for vbi hangs during streaming [media] cx23885: remove channel dump diagnostics when a vbi buffer times out ... Fix up trivial conflicts in drivers/misc/altera-stapl/altera.c (header file rename vs add)
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-18uio: Support physical addresses >32 bits on 32-bit systemsKai Jiang
To support >32-bit physical addresses for UIO_MEM_PHYS type we need to extend the width of 'addr' in struct uio_mem. Numerous platforms like embedded PPC, ARM, and X86 have support for systems with larger physical address than logical. Since 'addr' may contain a physical, logical, or virtual address the easiest solution is to just change the type to 'phys_addr_t' which should always be greater than or equal to the sizeof(void *) such that it can properly hold any of the address types. For physical address we can support up to a 44-bit physical address on a typical 32-bit system as we utilize remap_pfn_range() for the mapping of the memory region and pfn's are represnted by shifting the address by the page size (typically 4k). Signed-off-by: Kai Jiang <Kai.Jiang@freescale.com> Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-11Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: Documentation/feature-removal-schedule.txt
2011-09-30mac80211: document client powersaveJohannes Berg
With the addition of uAPSD and driver buffering the powersave handling has gotten quite complex. Add a section to the documentation to explain it for anyone wanting to implement it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-27[media] media: DocBook: Fix trivial typo in Sub-device InterfaceJonghun Han
When satisfied with the try results, applications can set the active formats by setting the which argument to V4L2_SUBDEV_FORMAT_ACTIVE not V4L2_SUBDEV_FORMAT_TRY. Signed-off-by: Jonghun Han <jonghun.han@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] videodev2.h: add V4L2_CTRL_FLAG_VOLATILEHans Verkuil
Add a new VOLATILE control flag that is set for volatile controls. That way applications know whether the value of the control is volatile (i.e. can change continuously) or not. Until now this was an internal property, but it is useful to know in userspace as well. A typical use case is the gain value when autogain is on. In that case the hardware will continuously adjust the gain based various environmental factors. This patch just adds and documents the flag, it's not yet used. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-17Merge tag 'v3.1-rc6' into staging/for_v3.2Mauro Carvalho Chehab
* tag 'v3.1-rc6': (1902 commits) Linux 3.1-rc6 ioctl: register LTTng ioctl fuse: fix memory leak fuse: fix flock breakage Btrfs: add dummy extent if dst offset excceeds file end in Btrfs: calc file extent num_bytes correctly in file clone btrfs: xattr: fix attribute removal Btrfs: fix wrong nbytes information of the inode Btrfs: fix the file extent gap when doing direct IO Btrfs: fix unclosed transaction handle in btrfs_cont_expand Btrfs: fix misuse of trans block rsv Btrfs: reset to appropriate block rsv after orphan operations Btrfs: skip locking if searching the commit root in csum lookup btrfs: fix warning in iput for bad-inode Btrfs: fix an oops when deleting snapshots [media] vp7045: fix buffer setup [media] nuvoton-cir: simplify raw IR sample handling [media] [Resend] viacam: Don't explode if pci_find_bus() returns NULL [media] v4l2: Fix documentation of the codec device controls [media] gspca - sonixj: Fix the darkness of sensor om6802 in 320x240 ...
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-11[media] v4l2: Fix documentation of the codec device controlsKamil Debski
Fixed missing ids of the codec controls description in the controls.xml file. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11mtd: doc: remove mention of MEMSETOOBSELBrian Norris
It's been gone for a while. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-09-11mtd: nand: rename NAND_USE_FLASH_BBTBrian Norris
Recall the recently added prefix requirements: * "NAND_" for flags in nand.h, used in nand_chip.options * "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options or in nand_bbt_descr.options Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH. Again, this flag is found in bbm.h and so should NOT be used in the "nand_chip.options" field. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: nand: consolidate redundant flash-based BBT flagsBrian Norris
This patch works with the following three flags from two headers (nand.h and bbm.h): (1) NAND_USE_FLASH_BBT (nand.h) (2) NAND_USE_FLASH_BBT_NO_OOB (nand.h) (3) NAND_BBT_NO_OOB (bbm.h) These flags are all related and interdependent, yet they were in different headers. Flag (2) is simply the combination of (1) and (3) and can be eliminated. This patch accomplishes the following: * eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2)) * move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h It's important to note that because (1) and (3) are now both found in bbm.h, they should NOT be used in the "nand_chip.options" field. I removed a small section from the mtdnand DocBook because it referes to NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-03[media] DVB: Change API version in documentation: 3 -> 5.4Andreas Oberritter
Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-03[media] DVB: improve documentation for satellite delivery systemsAndreas Oberritter
- Move voltage and tone to DVB-S. - Add turbo code. - In DVB-S2 and turbo code sections, refer to DVB-S, as both are extensions to DVB-S. - Add modulation to DVB-S2. Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-03[media] DVB: Add SYS_TURBO for north american turbo code FECAndreas Oberritter
2011-08-29DocBook/drm: Clean up a todo-noteMichael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com>
2011-08-29DocBook/drm: `device aware' -> `device-aware'Michael Witten
2011-08-29DocBook/drm: `(device|driver) specific' -> `(device|driver)-specific'Michael Witten
2011-08-29DocBook/drm: Clean up the paragraph on framebuffer objectsMichael Witten
2011-08-29DocBook/drm: Use `; otherwise,'Michael Witten
2011-08-29DocBook/drm: Better flow with `, and then'Michael Witten
2011-08-29DocBook/drm: Refer to the domain-setting function as a device-specific ioctlMichael Witten
2011-08-29DocBook/drm: Improve flow of GPU/CPU coherence sentenceMichael Witten
2011-08-29DocBook/drm: Use an <itemizelist> for fundamental GEM operationsMichael Witten
2011-08-29DocBook/drm: Insert a commaMichael Witten
2011-08-29DocBook/drm: Use a <variablelist> for vblank ioctlsMichael Witten
2011-08-29DocBook/drm: Use an itemizedlist for what an encoder needs to provideMichael Witten
2011-08-29DocBook/drm: Insert `the' for readability, and change `set' to `setting'Michael Witten
2011-08-29DocBook/drm: Remove extraneous commasMichael Witten
2011-08-29DocBook/drm: Use a colonMichael Witten
2011-08-29DocBook/drm: Clarify `final initialization' via better formattingMichael Witten
2011-08-29DocBook/drm: Remove redundancyMichael Witten
2011-08-29DocBook/drm: Insert `it' for smooth readingMichael Witten
2011-08-29DocBook/drm: The word `so-called'; I do not think it connotes what you think ↵Michael Witten
it connotes From Webster's Revised Unabridged Dictionary (1913) [web1913]: So-called \So"-called`\, a. So named; called by such a name (but perhaps called thus with doubtful propriety). From WordNet (r) 2.0 [wn]: so-called adj : doubtful or suspect; "these so-called experts are no help" [syn: {alleged(a)}, {supposed}] My strong conviction is that widespread use of 'so gennant' or 'sogennant' in German has led to the creeping misuse of 'so-called' in English (especially through technical writings). In English, it would be better to use: what is called or a better translation of 'so gennant': so named Signed-off-by: Michael Witten <mfwitten@gmail.com>
2011-08-29DocBook/drm: Use a singular subject for grammatical cleanlinessMichael Witten
2011-08-29DocBook/drm: basic -> coreMichael Witten
2011-08-29DocBook/drm: Streamline wording of GEM initializationMichael Witten
2011-08-29DocBook/drm: Insert `()' after function nameMichael Witten
2011-08-29DocBook/drm: Remove parentheses and unnecessary repetitionMichael Witten
2011-08-29DocBook/drm: Insert missing commaMichael Witten
