Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
This example file uses the old V4L1 API. It also doesn't use libv4l.
So, it is completely obsolete. A good example already exists at
v4l-utils (v4l2grab.c):
http://git.linuxtv.org/v4l-utils.git
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Make dnotify_test.c source file and add it to Makefile so that
bitrot can be prevented.
Documentation/laptops/laptop-mode.txt:
Expose example and tool source files in the Documentation/ directory in
their own files instead of being buried (almost hidden) in readme/txt files.
This should help to prevent bitrot.
This will make them more visible/usable to users who may need
to use them, to developers who may need to test with them, and
to anyone who would fix/update them if they were more visible.
Also, if any of these possibly should not be in the kernel tree at
all, it will be clearer that they are here and we can discuss if
they should be removed.
Documentation/timers/hpet.txt:
Expose example and tool source files in the Documentation/timers/ directory in
Currently source files in the Documentation/ sub-dir can easily bit-rot
since they are not generally buildable, either because they are hidden in
text files or because there are no Makefile rules for them. This needs to
be fixed so that the source files remain usable and good examples of code
instead of bad examples.
Add the ability to build source files that are in the Documentation/ dir.
Add to Kconfig as "BUILD_DOCSRC" config symbol.
Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the
Documentation/ sources. Or enable BUILD_DOCSRC in the *config system.
However, this symbol depends on HEADERS_CHECK since the header files need
to be installed (for userspace builds).
Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32,
sparc64, powerpc, sh, m68k, & mips.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
