path: root/Documentation/PCI
2010-07-11Documentation: pci.txt: fix typoKulikov Vasiliy
Doubled 'not'. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-21Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (36 commits) PCI: hotplug: pciehp: Removed check for hotplug of display devices PCI: read memory ranges out of Broadcom CNB20LE host bridge PCI: Allow manual resource allocation for PCI hotplug bridges x86/PCI: make ACPI MCFG reserved error messages ACPI specific PCI hotplug: Use kmemdup PM/PCI: Update PCI power management documentation PCI: output FW warning in pci_read/write_vpd PCI: fix typos pci_device_dis/enable to pci_dis/enable_device in comments PCI quirks: disable msi on AMD rs4xx internal gfx bridges PCI: Disable MSI for MCP55 on P5N32-E SLI x86/PCI: irq and pci_ids patch for additional Intel Cougar Point DeviceIDs PCI: aerdrv: trivial cleanup for aerdrv_core.c PCI: aerdrv: trivial cleanup for aerdrv.c PCI: aerdrv: introduce default_downstream_reset_link PCI: aerdrv: rework find_aer_service PCI: aerdrv: remove is_downstream PCI: aerdrv: remove magical ROOT_ERR_STATUS_MASKS PCI: aerdrv: redefine PCI_ERR_ROOT_*_SRC PCI: aerdrv: rework do_recovery PCI: aerdrv: rework get_e_source() ...
2010-05-11PCI: aerdrv: introduce default_downstream_reset_linkHidetoshi Seto
I noticed that when I inject a fatal error to an endpoint via aer-inject, aer_root_reset() is called as reset_link for a downstream port at upstream of the endpoint: pcieport 0000:00:06.0: AER: Uncorrected (Fatal) error received: id=5401 : pcieport 0000:52:02.0: Root Port link has been reset It externally appears to be working, but internally issues some accesses to PCI_ERR_ROOT_COMMAND/STATUS registers that is for root port so not available on downstream port. This patch introduces default_downstream_reset_link that is a version of aer_root_reset() with no accesses to root port's register. It is used for downstream ports that has no reset_link function its specific. This patch also updates related description in pcieaer-howto.txt. Some minor fixes are included. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-11PCI: aerdrv, doc: update example output in pcieaer-howto.txtHidetoshi Seto
Follow new format. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-24Documentation: rename PCI/PCI-DMA-mapping.txt to DMA-API-HOWTO.txtFUJITA Tomonori
This patch renames PCI/PCI-DMA-mapping.txt to DMA-API-HOWTO.txt. The commit 51e7364ef281e540371f084008732b13292622f0 "Documentation: rename PCI-DMA-mapping.txt to DMA-API-HOWTO.txt" was supposed to do this but it didn't. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Documentation: convert PCI-DMA-mapping.txt to use the generic DMA APIFUJITA Tomonori
- replace the PCI DMA API (i.e. pci_dma_*) with the generic DMA API. - make the document more generic (use the PCI specific explanation as an example). [akpm@linux-foundation.org: fix things Randy noticed] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: "David S. Miller" <davem@davemloft.net> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-02Documentation: Rename Documentation/DMA-mapping.txtKusanagi Kouichi
It seems that Documentation/DMA-mapping.txt was supposed to be renamed to Documentation/PCI/PCI-DMA-mapping.txt. Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09PCI: document PCIe fundamental reset interfacesMike Mason
The attached patch updates the Documentation/PCI/pci-error-recovery.txt file with changes related to this new bit field, as well a few unrelated updates. Signed-off-by: Linas Vepstas <linasvepstas@gmail.com> Signed-off-by: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Richard Lary <rlary@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI AER: software error injectionHuang Ying
Debugging PCIE AER code can be very difficult because it is hard to trigger various real hardware errors. This patch provide a software based error injection tool, which can fake various PCIE errors with a user space helper tool named "aer-inject". Which can be gotten from: http://www.kernel.org/pub/linux/kernel/people/yhuang/ The patch fakes AER error by faking some PCIE AER related registers and an AER interrupt for specified the PCIE device. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI AER: support invalid error source IDsZhang, Yanmin
When the bus id part of error source id is equal to 0 or nosourceid=1, make the kernel probe the AER status registers of all devices under the root port to find the initial error reporter. Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI: PCIE AER: Document for PCIE AER software error injectionHuang Ying
This patch adds a minimal HOWTO for PCIE AER software error injection in Documentation/PCI/pcieaer-howto.txt. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Add example request loop to MSI-HOWTO.txtMichael Ellerman
Encourage driver writers to think about supporting a variable number of MSI-X interrupts, and give an example of how to do such a request. Acked-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: manual for SR-IOV user and driver developerYu Zhao
Reviewed-by: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Add support for multiple MSIMatthew Wilcox
Add the new API pci_enable_msi_block() to allow drivers to request multiple MSI and reimplement pci_enable_msi in terms of pci_enable_msi_block. Ensure that the architecture back ends don't have to know about multiple MSI. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20Rewrite MSI-HOWTOMatthew Wilcox
I didn't find the previous version very useful, so I rewrote it. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Grant Grundler <grundler@parisc-linunx.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI: Documentation: fix minor PCIe HOWTO thinkoAlex Chiang
Update doc to correctly refer to replacing the pci_register_driver API, and not the non-existent "pci_module_init" API. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Add pci_clear_master() as opposite of pci_set_master()Ben Hutchings
During an online device reset it may be useful to disable bus-mastering. pci_disable_device() does that, and far more besides, so is not suitable for an online reset. Add pci_clear_master() which does just this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-10-20PCI: fix AER capability checkYu Zhao
The 'use pci_find_ext_capability everywhere' cleanup brought a new bug, which makes the AER stop working. Fix it by actually using find_ext_cap instead of just find_cap. Drop the unused config space size define while we're at it. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: Check dynids driver_data value for validityJean Delvare
Only accept dynids whose driver_data value matches one of the driver's pci_driver_id entries. This prevents the user from accidentally passing values the drivers do not expect. Cc: Milton Miller <miltonm@bga.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: doc/pci: create Documentation/PCI/ and move files into itRandy Dunlap
Create Documentation/PCI/ and move PCI-related files to it. Fix a few instances of trailing whitespace. Update references to the new file locations. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
