path: root/Documentation/PCI
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-10-20PCI: fix AER capability checkYu Zhao
The 'use pci_find_ext_capability everywhere' cleanup brought a new bug, which makes the AER stop working. Fix it by actually using find_ext_cap instead of just find_cap. Drop the unused config space size define while we're at it. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: Check dynids driver_data value for validityJean Delvare
Only accept dynids whose driver_data value matches one of the driver's pci_driver_id entries. This prevents the user from accidentally passing values the drivers do not expect. Cc: Milton Miller <miltonm@bga.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: doc/pci: create Documentation/PCI/ and move files into itRandy Dunlap
Create Documentation/PCI/ and move PCI-related files to it. Fix a few instances of trailing whitespace. Update references to the new file locations. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
