path: root/Documentation/RCU
2011-03-04rcu: add documentation saying which RCU flavor to choosePaul E. McKenney
Reported-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: update documentation/comments for Lai's adoption patchPaul E. McKenney
Lai's RCU-callback immediate-adoption patch changes the RCU tracing output, so update tracing.txt. Also update a few comments to clarify the synchronization design. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: document TINY_RCU and TINY_PREEMPT_RCU tracing.Paul E. McKenney
Add the required verbiage to Documentation/RCU/trace.txt. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-09-23rcu: Add tracing data to support queueing modelsPaul E. McKenney
The current tracing data is not sufficient to deduce the average time that a callback spends waiting for a grace period to end. Add three per-CPU counters recording the number of callbacks invoked (ci), the number of callbacks orphaned (co), and the number of callbacks adopted (ca). Given the existing callback queue length (ql), the average wait time in absence of CPU hotplug operations is ql/ci. The units of wait time will be in terms of the duration over which ci was measured. In the presence of CPU hotplug operations, there is room for argument, but ql/(ci-co+ca) won't steer you too far wrong. Also fixes a typo called out by Lucas De Marchi <lucas.de.marchi@gmail.com>. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-23rcu: upgrade stallwarn.txt documentation for CPU-bound RT processesPaul E. McKenney
CPU-bound real-time processes can cause RCU CPU stall warnings, and much other trouble as well. Document the fact that they can cause RCU CPU stall warnings. Suggested-by: Darren Hart <dvhltc@us.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: document ways of stalling updates in low-memory situationsPaul E. McKenney
2010-08-19rcu: add shiny new debug assists to Documentation/RCU/checklist.txtPaul E. McKenney
Add a section describing PROVE_RCU, DEBUG_OBJECTS_RCU_HEAD, and the __rcu sparse checking to the RCU checklist. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-18Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits) stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback() sched, wait: Use wrapper functions sched: Remove a stale comment ondemand: Make the iowait-is-busy time a sysfs tunable ondemand: Solve a big performance issue by counting IOWAIT time as busy sched: Intoduce get_cpu_iowait_time_us() sched: Eliminate the ts->idle_lastupdate field sched: Fold updating of the last_update_time_info into update_ts_time_stats() sched: Update the idle statistics in get_cpu_idle_time_us() sched: Introduce a function to update the idle statistics sched: Add a comment to get_cpu_idle_time_us() cpu_stop: add dummy implementation for UP sched: Remove rq argument to the tracepoints rcu: need barrier() in UP synchronize_sched_expedited() sched: correctly place paranioa memory barriers in synchronize_sched_expedited() sched: kill paranoia check in synchronize_sched_expedited() sched: replace migration_thread with cpu_stop stop_machine: reimplement using cpu_stop cpu_stop: implement stop_cpu[s]() sched: Fix select_idle_sibling() logic in select_task_rq_fair() ...
2010-05-10rcu: improve the RCU CPU-stall warning documentationPaul E. McKenney
The existing Documentation/RCU/stallwarn.txt has proven unhelpful, so rework it a bit. In particular, show how to interpret the stall-warning messages. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: reduce the number of spurious RCU_SOFTIRQ invocationsPaul E. McKenney
Lai Jiangshan noted that up to 10% of the RCU_SOFTIRQ are spurious, and traced this down to the fact that the current grace-period machinery will uselessly raise RCU_SOFTIRQ when a given CPU needs to go through a quiescent state, but has not yet done so. In this situation, there might well be nothing that RCU_SOFTIRQ can do, and the overhead can be worth worrying about in the ksoftirqd case. This patch therefore avoids raising RCU_SOFTIRQ in this situation. Changes since v1 (http://lkml.org/lkml/2010/3/30/122 from Lai Jiangshan): o Omit the rcu_qs_pending() prechecks, as they aren't that much less expensive than the quiescent-state checks. o Merge with the set_need_resched() patch that reduces IPIs. o Add the new n_rp_report_qs field to the rcu_pending tracing output. o Update the tracing documentation accordingly. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-08Merge branch 'cpu_stop' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into sched/core
2010-05-06sched: replace migration_thread with cpu_stopTejun Heo
Currently migration_thread is serving three purposes - migration pusher, context to execute active_load_balance() and forced context switcher for expedited RCU synchronize_sched. All three roles are hardcoded into migration_thread() and determining which job is scheduled is slightly messy. This patch kills migration_thread and replaces all three uses with cpu_stop. The three different roles of migration_thread() are splitted into three separate cpu_stop callbacks - migration_cpu_stop(), active_load_balance_cpu_stop() and synchronize_sched_expedited_cpu_stop() - and each use case now simply asks cpu_stop to execute the callback as necessary. synchronize_sched_expedited() was implemented with private preallocated resources and custom multi-cpu queueing and waiting logic, both of which are provided by cpu_stop. synchronize_sched_expedited_count is made atomic and all other shared resources along with the mutex are dropped. synchronize_sched_expedited() also implemented a check to detect cases where not all the callback got executed on their assigned cpus and fall back to synchronize_sched(). If called with cpu hotplug blocked, cpu_stop already guarantees that and the condition cannot happen; otherwise, stop_machine() would break. However, this patch preserves the paranoid check using a cpumask to record on which cpus the stopper ran so that it can serve as a bisection point if something actually goes wrong theree. Because the internal execution state is no longer visible, rcu_expedited_torture_stats() is removed. This patch also renames cpu_stop threads to from "stopper/%d" to "migration/%d". The names of these threads ultimately don't matter and there's no reason to make unnecessary userland visible changes. With this patch applied, stop_machine() and sched now share the same resources. stop_machine() is faster without wasting any resources and sched migration users are much cleaner. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-04-14rcu: Update docs for rcu_access_pointer and rcu_dereference_protectedPaul E. McKenney
Update examples and lists of APIs to include these new primitives. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <1270852752-25278-3-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Use canonical URL for Mathieu's dissertationPaul E. McKenney
The version numbers change too quickly, so use a canonical URL that represents the most recent version. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-16-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Fix citation of Mathieu's dissertationPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-14-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Documentation update for CONFIG_PROVE_RCUPaul E. McKenney
Adds a lockdep.txt file and updates checklist.txt and whatisRCU.txt to reflect the new lockdep-enabled capabilities of RCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-13-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-16rcu: 1Q2010 update for RCU documentationPaul E. McKenney
Add expedited functions. Review documentation and update obsolete verbiage. Also fix the advice for the RCU CPU-stall kernel configuration parameter, and document RCU CPU-stall warnings. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12635142581866-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Add synchronize_srcu_expedited() to the documentationPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226354176-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15rcu: Update trace.txt documentation for blocked-tasks listsPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: npiggin@suse.de Cc: jens.axboe@oracle.com LKML-Reference: <12555405592804-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15rcu: Update trace.txt documentation to reflect recent changesPaul E. McKenney
o Remove the CONFIG_PREEMPT_RCU documentation since this config option has now been removed. o Change the now-incorrect references to "rcu" labels to instead be "rcu_sched". o Add notes stating that CONFIG_TREE_PREEMPT_RCU kernels will have additional "rcu_preempt" output. o Note the new "oqlen" field in the rcuhier output (for RCU callbacks orphaned by an offlined CPU). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: npiggin@suse.de Cc: jens.axboe@oracle.com LKML-Reference: <1255540559799-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Renamings to increase RCU clarityPaul E. McKenney
Make RCU-sched, RCU-bh, and RCU-preempt be underlying implementations, with "RCU" defined in terms of one of the three. Update the outdated rcu_qsctr_inc() names, as these functions no longer increment anything. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746132696-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-15Merge commit 'v2.6.31-rc6' into core/rcuIngo Molnar
Merge reason: the branch was on pre-rc1 .30, update to latest. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-16netfilter: nf_conntrack: nf_conntrack_alloc() fixesEric Dumazet
When a slab cache uses SLAB_DESTROY_BY_RCU, we must be careful when allocating objects, since slab allocator could give a freed object still used by lockless readers. In particular, nf_conntrack RCU lookups rely on ct->tuplehash[xxx].hnnode.next being always valid (ie containing a valid 'nulls' value, or a valid pointer to next object in hash chain.) kmem_cache_zalloc() setups object with NULL values, but a NULL value is not valid for ct->tuplehash[xxx].hnnode.next. Fix is to call kmem_cache_alloc() and do the zeroing ourself. As spotted by Patrick, we also need to make sure lookup keys are committed to memory before setting refcount to 1, or a lockless reader could get a reference on the old version of the object. Its key re-check could then pass the barrier. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-07-03rcu: Add synchronize_sched_expedited() rcutorture doc + updatesPaul E. McKenney
This patch updates the rcutorture documentation to include updated output format. It also brings the RCU documentation up to date. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: dada1@cosmosbay.com Cc: zbr@ioremap.net Cc: jeff.chua.linux@gmail.com Cc: paulus@samba.org Cc: laijs@cn.fujitsu.com Cc: jengelh@medozas.de Cc: r000n@r000n.net Cc: benh@kernel.crashing.org Cc: mathieu.desnoyers@polymtl.ca LKML-Reference: <12459460983193-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-14rcu: Update RCU tracing documentation for __rcu_pendingPaul E. McKenney
This patch updates the RCU documentation to reflect the changes in tracing made in the previous patch in the set. Located-by: Anton Blanchard <anton@au1.ibm.com> Tested-by: Anton Blanchard <anton@au1.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: anton@samba.org Cc: akpm@linux-foundation.org Cc: dipankar@in.ibm.com Cc: manfred@colorfullife.com Cc: cl@linux-foundation.org Cc: josht@linux.vnet.ibm.com Cc: schamp@sgi.com Cc: niv@us.ibm.com Cc: dvhltc@us.ibm.com Cc: ego@in.ibm.com Cc: laijs@cn.fujitsu.com Cc: rostedt@goodmis.org Cc: peterz@infradead.org Cc: penberg@cs.helsinki.fi Cc: andi@firstfloor.org Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <12396834792865-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Doc: Fix spelling in RCU/rculist_nulls.txt.Jesper Dangaard Brouer
Doc: Fix spelling in RCU/rculist_nulls.txt. Trival spelling fixes in RCU/rculist_nulls.txt. Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Tested-by: Jarek Poplawski <jarkao2@gmail.com;-> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02Doc: Fix wrong API example usage of call_rcu().Jesper Dangaard Brouer
At some point the API of call_rcu() changed from three parameters to two parameters, correct the documentation. One confusing thing in RCU/listRCU.txt, which is NOT fixed in this patch, is that no reason or explaination is given for using call_rcu() instead of the normal synchronize_rcu() call. Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02Doc: Fix missing whitespaces in RCU documentation.Jesper Dangaard Brouer
Trivial fix while reading through the RCU docs. Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10rcu: documentation 1Q09 updatePaul E. McKenney
Update the RCU documentation to call out the need for callers of primitives like call_rcu() and synchronize_rcu() to prevent subsequent RCU readers from hazard. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08Merge branch 'docs-next' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs-next' of git://git.lwn.net/linux-2.6: Fix a typo in the development process document. Document handling of bad memory Document RCU and unloadable modules
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-18"Tree RCU": scalable classic RCU implementationPaul E. McKenney
This patch fixes a long-standing performance bug in classic RCU that results in massive internal-to-RCU lock contention on systems with more than a few hundred CPUs. Although this patch creates a separate flavor of RCU for ease of review and patch maintenance, it is intended to replace classic RCU. This patch still handles stress better than does mainline, so I am still calling it ready for inclusion. This patch is against the -tip tree. Nevertheless, experience on an actual 1000+ CPU machine would still be most welcome. Most of the changes noted below were found while creating an rcutiny (which should permit ejecting the current rcuclassic) and while doing detailed line-by-line documentation. Updates from v9 (http://lkml.org/lkml/2008/12/2/334): o Fixes from remainder of line-by-line code walkthrough, including comment spelling, initialization, undesirable narrowing due to type conversion, removing redundant memory barriers, removing redundant local-variable initialization, and removing redundant local variables. I do not believe that any of these fixes address the CPU-hotplug issues that Andi Kleen was seeing, but please do give it a whirl in case the machine is smarter than I am. A writeup from the walkthrough may be found at the following URL, in case you are suffering from terminal insomnia or masochism: http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf o Made rcutree tracing use seq_file, as suggested some time ago by Lai Jiangshan. o Added a .csv variant of the rcudata debugfs trace file, to allow people having thousands of CPUs to drop the data into a spreadsheet. Tested with oocalc and gnumeric. Updated documentation to suit. Updates from v8 (http://lkml.org/lkml/2008/11/15/139): o Fix a theoretical race between grace-period initialization and force_quiescent_state() that could occur if more than three jiffies were required to carry out the grace-period initialization. Which it might, if you had enough CPUs. o Apply Ingo's printk-standardization patch. o Substitute local variables for repeated accesses to global variables. o Fix comment misspellings and redundant (but harmless) increments of ->n_rcu_pending (this latter after having explicitly added it). o Apply checkpatch fixes. Updates from v7 (http://lkml.org/lkml/2008/10/10/291): o Fixed a number of problems noted by Gautham Shenoy, including the cpu-stall-detection bug that he was having difficulty convincing me was real. ;-) o Changed cpu-stall detection to wait for ten seconds rather than three in order to reduce false positive, as suggested by Ingo Molnar. o Produced a design document (http://lwn.net/Articles/305782/). The act of writing this document uncovered a number of both theoretical and "here and now" bugs as noted below. o Fix dynticks_nesting accounting confusion, simplify WARN_ON() condition, fix kerneldoc comments, and add memory barriers in dynticks interface functions. o Add more data to tracing. o Remove unused "rcu_barrier" field from rcu_data structure. o Count calls to rcu_pending() from scheduling-clock interrupt to use as a surrogate timebase should jiffies stop counting. o Fix a theoretical race between force_quiescent_state() and grace-period initialization. Yes, initialization does have to go on for some jiffies for this race to occur, but given enough CPUs... Updates from v6 (http://lkml.org/lkml/2008/9/23/448): o Fix a number of checkpatch.pl complaints. o Apply review comments from Ingo Molnar and Lai Jiangshan on the stall-detection code. o Fix several bugs in !CONFIG_SMP builds. o Fix a misspelled config-parameter name so that RCU now announces at boot time if stall detection is configured. o Run tests on numerous combinations of configurations parameters, which after the fixes above, now build and run correctly. Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line): o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a changeset some time ago, and finally got around to retesting this option). o Fix some tracing bugs in rcupreempt that caused incorrect totals to be printed. o I now test with a more brutal random-selection online/offline script (attached). Probably more brutal than it needs to be on the people reading it as well, but so it goes. o A number of optimizations and usability improvements: o Make rcu_pending() ignore the grace-period timeout when there is no grace period in progress. o Make force_quiescent_state() avoid going for a global lock in the case where there is no grace period in progress. o Rearrange struct fields to improve struct layout. o Make call_rcu() initiate a grace period if RCU was idle, rather than waiting for the next scheduling clock interrupt. o Invoke rcu_irq_enter() and rcu_irq_exit() only when idle, as suggested by Andi Kleen. I still don't completely trust this change, and might back it out. o Make CONFIG_RCU_TRACE be the single config variable manipulated for all forms of RCU, instead of the prior confusion. o Document tracing files and formats for both rcupreempt and rcutree. Updates from v4 for those missing v5 given its bad subject line: o Separated dynticks interface so that NMIs and irqs call separate functions, greatly simplifying it. In particular, this code no longer requires a proof of correctness. ;-) o Separated dynticks state out into its own per-CPU structure, avoiding the duplicated accounting. o The case where a dynticks-idle CPU runs an irq handler that invokes call_rcu() is now correctly handled, forcing that CPU out of dynticks-idle mode. o Review comments have been applied (thank you all!!!). For but one example, fixed the dynticks-ordering issue that Manfred pointed out, saving me much debugging. ;-) o Adjusted rcuclassic and rcupreempt to handle dynticks changes. Attached is an updated patch to Classic RCU that applies a hierarchy, greatly reducing the contention on the top-level lock for large machines. This passes 10-hour concurrent rcutorture and online-offline testing on 128-CPU ppc64 without dynticks enabled, and exposes some timekeeping bugs in presence of dynticks (exciting working on a system where "sleep 1" hangs until interrupted...), which were fixed in the 2.6.27 kernel. It is getting more reliable than mainline by some measures, so the next version will be against -tip for inclusion. See also Manfred Spraul's recent patches (or his earlier work from 2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2). We will converge onto a common patch in the fullness of time, but are currently exploring different regions of the design space. That said, I have already gratefully stolen quite a few of Manfred's ideas. This patch provides CONFIG_RCU_FANOUT, which controls the bushiness of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on 64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT, there is no hierarchy. By default, the RCU initialization code will adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable this balancing, allowing the hierarchy to be exactly aligned to the underlying hardware. Up to two levels of hierarchy are permitted (in addition to the root node), allowing up to 16,384 CPUs on 32-bit systems and up to 262,144 CPUs on 64-bit systems. I just know that I am going to regret saying this, but this seems more than sufficient for the foreseeable future. (Some architectures might wish to set CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs. If this becomes a real problem, additional levels can be added, but I doubt that it will make a significant difference on real hardware.) In the common case, a given CPU will manipulate its private rcu_data structure and the rcu_node structure that it shares with its immediate neighbors. This can reduce both lock and memory contention by multiple orders of magnitude, which should eliminate the need for the strange manipulations that are reported to be required when running Linux on very large systems. Some shortcomings: o More bugs will probably surface as a result of an ongoing line-by-line code inspection. Patches will be provided as required. o There are probably hangs, rcutorture failures, &c. Seems quite stable on a 128-CPU machine, but that is kind of small compared to 4096 CPUs. However, seems to do better than mainline. Patches will be provided as required. o The memory footprint of this version is several KB larger than rcuclassic. A separate UP-only rcutiny patch will be provided, which will reduce the memory footprint significantly, even compared to the old rcuclassic. One such patch passes light testing, and has a memory footprint smaller even than rcuclassic. Initial reaction from various embedded guys was "it is not worth it", so am putting it aside. Credits: o Manfred Spraul for ideas, review comments, and bugs spotted, as well as some good friendly competition. ;-) o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers, Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton for reviews and comments. o Thomas Gleixner for much-needed help with some timer issues (see patches below). o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos, Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines alive despite my heavy abuse^Wtesting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03Document RCU and unloadable modulesPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-11-16rcu: documents rculist_nullsEric Dumazet
Adds Documentation/RCU/rculist_nulls.txt file to describe how 'nulls' end-of-list can help in some RCU algos. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-10doc/RCU: fix pseudocode in rcuref.txtLai Jiangshan
atomic_inc_not_zero(v) return 0 if *v = 0. use spin_lock instead of write_lock for update lock. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15rcu: remove list_for_each_rcu()Paul E. McKenney
All of the in-tree uses of list_for_each_rcu() have been converted to list_for_each_entry_rcu(), so list_for_each_rcu() can now be removed. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26rcu: make rcutorture even more vicious: invoke RCU readers from irq handlers ↵Paul E. McKenney
(timers) This patch allows torturing RCU from irq handlers (timers, in this case). A new module parameter irqreader enables such additional torturing, and is enabled by default. Variants of RCU that do not tolerate readers being called from irq handlers (e.g., SRCU) ignore irqreader. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: josh@freedesktop.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: dino@in.ibm.com Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: vegard.nossum@gmail.com Cc: adobriyan@gmail.com Cc: oleg@tv-sign.ru Cc: bunk@kernel.org Cc: rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19rcu: make rcutorture more vicious: reinstate boot-time testingPaul E. McKenney
This patch re-institutes the ability to build rcutorture directly into the Linux kernel. The reason that this capability was removed was that this could result in your kernel being pretty much useless, as rcutorture would be running starting from early boot. This problem has been avoided by (1) making rcutorture run only three seconds of every six by default, (2) adding a CONFIG_RCU_TORTURE_TEST_RUNNABLE that permits rcutorture to be quiesced at boot time, and (3) adding a sysctl in /proc named /proc/sys/kernel/rcutorture_runnable that permits rcutorture to be quiesced and unquiesced when built into the kernel. Please note that this /proc file is -not- available when rcutorture is built as a module. Please also note that to get the earlier take-no-prisoners behavior, you must use the boot command line to set rcutorture's "stutter" parameter to zero. The rcutorture quiescing mechanism is currently quite crude: loops in each rcutorture process that poll a global variable once per tick. Suggestions for improvement are welcome. The default action will be to reduce the polling rate to a few times per second. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18rcu: make rcutorture more vicious: add stutter featurePaul E. McKenney
This patch takes a step towards making rcutorture more brutal by allowing the test to be automatically periodically paused, with the default being to run the test for five seconds then pause for five seconds and repeat. This behavior can be controlled using a new "stutter" module parameter, so that "stutter=0" gives the old default behavior of running continuously. Starting and stopping rcutorture more heavily stresses RCU's interaction with the scheduler, as well as exercising more paths through the grace-period detection code. Note that the default to "shuffle_interval" has also been adjusted from 5 seconds to 3 seconds to provide varying overlap with the "stutter" interval. I am still unable to provoke the failures that Alexey has been seeing, even with this patch, but will be doing a few additional things to beef up rcutorture. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-19sched: 1Q08 RCU doc update, add call_rcu_sched()Paul E. McKenney
Long-delayed update to the RCU documentation, including adding the new call_rcu_sched() and rcu_barrier_sched() APIs. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-13remove final fastcall usersHarvey Harrison
fastcall always expands to empty, remove it. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25Preempt-RCU: update RCU Documentation.Paul E. McKenney
This patch updates the RCU documentation to reflect preemptible RCU as well as recent publications. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Add Documentation/RCU/00-IndexRob Landley
Add Documentation/RCU/00-INDEX Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Document the fact that RCU callbacks can run in parallelPaul E. McKenney
Add an item to the RCU documentation checklist noting that RCU callbacks can run in parallel. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PATCH] rcu: add sched torture type to rcutortureJosh Triplett
Implement torture testing for the "sched" variant of RCU, which uses preempt_disable, preempt_enable, and synchronize_sched. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] rcu: add rcu_bh_sync torture type to rcutortureJosh Triplett
Use the newly-generic synchronous deferred free function to implement torture testing for rcu_bh using synchronize_rcu_bh rather than the asynchronous call_rcu_bh. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] rcu: add rcu_sync torture type to rcutortureJosh Triplett
Use the newly-generic synchronous deferred free function to implement torture testing for RCU using synchronize_rcu rather than the asynchronous call_rcu. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
