path: root/Documentation/RCU
2009-01-08Merge branch 'docs-next' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs-next' of git://git.lwn.net/linux-2.6: Fix a typo in the development process document. Document handling of bad memory Document RCU and unloadable modules
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-18"Tree RCU": scalable classic RCU implementationPaul E. McKenney
This patch fixes a long-standing performance bug in classic RCU that results in massive internal-to-RCU lock contention on systems with more than a few hundred CPUs. Although this patch creates a separate flavor of RCU for ease of review and patch maintenance, it is intended to replace classic RCU. This patch still handles stress better than does mainline, so I am still calling it ready for inclusion. This patch is against the -tip tree. Nevertheless, experience on an actual 1000+ CPU machine would still be most welcome. Most of the changes noted below were found while creating an rcutiny (which should permit ejecting the current rcuclassic) and while doing detailed line-by-line documentation. Updates from v9 (http://lkml.org/lkml/2008/12/2/334): o Fixes from remainder of line-by-line code walkthrough, including comment spelling, initialization, undesirable narrowing due to type conversion, removing redundant memory barriers, removing redundant local-variable initialization, and removing redundant local variables. I do not believe that any of these fixes address the CPU-hotplug issues that Andi Kleen was seeing, but please do give it a whirl in case the machine is smarter than I am. A writeup from the walkthrough may be found at the following URL, in case you are suffering from terminal insomnia or masochism: http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf o Made rcutree tracing use seq_file, as suggested some time ago by Lai Jiangshan. o Added a .csv variant of the rcudata debugfs trace file, to allow people having thousands of CPUs to drop the data into a spreadsheet. Tested with oocalc and gnumeric. Updated documentation to suit. Updates from v8 (http://lkml.org/lkml/2008/11/15/139): o Fix a theoretical race between grace-period initialization and force_quiescent_state() that could occur if more than three jiffies were required to carry out the grace-period initialization. Which it might, if you had enough CPUs. o Apply Ingo's printk-standardization patch. o Substitute local variables for repeated accesses to global variables. o Fix comment misspellings and redundant (but harmless) increments of ->n_rcu_pending (this latter after having explicitly added it). o Apply checkpatch fixes. Updates from v7 (http://lkml.org/lkml/2008/10/10/291): o Fixed a number of problems noted by Gautham Shenoy, including the cpu-stall-detection bug that he was having difficulty convincing me was real. ;-) o Changed cpu-stall detection to wait for ten seconds rather than three in order to reduce false positive, as suggested by Ingo Molnar. o Produced a design document (http://lwn.net/Articles/305782/). The act of writing this document uncovered a number of both theoretical and "here and now" bugs as noted below. o Fix dynticks_nesting accounting confusion, simplify WARN_ON() condition, fix kerneldoc comments, and add memory barriers in dynticks interface functions. o Add more data to tracing. o Remove unused "rcu_barrier" field from rcu_data structure. o Count calls to rcu_pending() from scheduling-clock interrupt to use as a surrogate timebase should jiffies stop counting. o Fix a theoretical race between force_quiescent_state() and grace-period initialization. Yes, initialization does have to go on for some jiffies for this race to occur, but given enough CPUs... Updates from v6 (http://lkml.org/lkml/2008/9/23/448): o Fix a number of checkpatch.pl complaints. o Apply review comments from Ingo Molnar and Lai Jiangshan on the stall-detection code. o Fix several bugs in !CONFIG_SMP builds. o Fix a misspelled config-parameter name so that RCU now announces at boot time if stall detection is configured. o Run tests on numerous combinations of configurations parameters, which after the fixes above, now build and run correctly. Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line): o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a changeset some time ago, and finally got around to retesting this option). o Fix some tracing bugs in rcupreempt that caused incorrect totals to be printed. o I now test with a more brutal random-selection online/offline script (attached). Probably more brutal than it needs to be on the people reading it as well, but so it goes. o A number of optimizations and usability improvements: o Make rcu_pending() ignore the grace-period timeout when there is no grace period in progress. o Make force_quiescent_state() avoid going for a global lock in the case where there is no grace period in progress. o Rearrange struct fields to improve struct layout. o Make call_rcu() initiate a grace period if RCU was idle, rather than waiting for the next scheduling clock interrupt. o Invoke rcu_irq_enter() and rcu_irq_exit() only when idle, as suggested by Andi Kleen. I still don't completely trust this change, and might back it out. o Make CONFIG_RCU_TRACE be the single config variable manipulated for all forms of RCU, instead of the prior confusion. o Document tracing files and formats for both rcupreempt and rcutree. Updates from v4 for those missing v5 given its bad subject line: o Separated dynticks interface so that NMIs and irqs call separate functions, greatly simplifying it. In particular, this code no longer requires a proof of correctness. ;-) o Separated dynticks state out into its own per-CPU structure, avoiding the duplicated accounting. o The case where a dynticks-idle CPU runs an irq handler that invokes call_rcu() is now correctly handled, forcing that CPU out of dynticks-idle mode. o Review comments have been applied (thank you all!!!). For but one example, fixed the dynticks-ordering issue that Manfred pointed out, saving me much debugging. ;-) o Adjusted rcuclassic and rcupreempt to handle dynticks changes. Attached is an updated patch to Classic RCU that applies a hierarchy, greatly reducing the contention on the top-level lock for large machines. This passes 10-hour concurrent rcutorture and online-offline testing on 128-CPU ppc64 without dynticks enabled, and exposes some timekeeping bugs in presence of dynticks (exciting working on a system where "sleep 1" hangs until interrupted...), which were fixed in the 2.6.27 kernel. It is getting more reliable than mainline by some measures, so the next version will be against -tip for inclusion. See also Manfred Spraul's recent patches (or his earlier work from 2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2). We will converge onto a common patch in the fullness of time, but are currently exploring different regions of the design space. That said, I have already gratefully stolen quite a few of Manfred's ideas. This patch provides CONFIG_RCU_FANOUT, which controls the bushiness of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on 64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT, there is no hierarchy. By default, the RCU initialization code will adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable this balancing, allowing the hierarchy to be exactly aligned to the underlying hardware. Up to two levels of hierarchy are permitted (in addition to the root node), allowing up to 16,384 CPUs on 32-bit systems and up to 262,144 CPUs on 64-bit systems. I just know that I am going to regret saying this, but this seems more than sufficient for the foreseeable future. (Some architectures might wish to set CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs. If this becomes a real problem, additional levels can be added, but I doubt that it will make a significant difference on real hardware.) In the common case, a given CPU will manipulate its private rcu_data structure and the rcu_node structure that it shares with its immediate neighbors. This can reduce both lock and memory contention by multiple orders of magnitude, which should eliminate the need for the strange manipulations that are reported to be required when running Linux on very large systems. Some shortcomings: o More bugs will probably surface as a result of an ongoing line-by-line code inspection. Patches will be provided as required. o There are probably hangs, rcutorture failures, &c. Seems quite stable on a 128-CPU machine, but that is kind of small compared to 4096 CPUs. However, seems to do better than mainline. Patches will be provided as required. o The memory footprint of this version is several KB larger than rcuclassic. A separate UP-only rcutiny patch will be provided, which will reduce the memory footprint significantly, even compared to the old rcuclassic. One such patch passes light testing, and has a memory footprint smaller even than rcuclassic. Initial reaction from various embedded guys was "it is not worth it", so am putting it aside. Credits: o Manfred Spraul for ideas, review comments, and bugs spotted, as well as some good friendly competition. ;-) o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers, Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton for reviews and comments. o Thomas Gleixner for much-needed help with some timer issues (see patches below). o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos, Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines alive despite my heavy abuse^Wtesting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03Document RCU and unloadable modulesPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-11-16rcu: documents rculist_nullsEric Dumazet
Adds Documentation/RCU/rculist_nulls.txt file to describe how 'nulls' end-of-list can help in some RCU algos. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-10doc/RCU: fix pseudocode in rcuref.txtLai Jiangshan
atomic_inc_not_zero(v) return 0 if *v = 0. use spin_lock instead of write_lock for update lock. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15rcu: remove list_for_each_rcu()Paul E. McKenney
All of the in-tree uses of list_for_each_rcu() have been converted to list_for_each_entry_rcu(), so list_for_each_rcu() can now be removed. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26rcu: make rcutorture even more vicious: invoke RCU readers from irq handlers ↵Paul E. McKenney
(timers) This patch allows torturing RCU from irq handlers (timers, in this case). A new module parameter irqreader enables such additional torturing, and is enabled by default. Variants of RCU that do not tolerate readers being called from irq handlers (e.g., SRCU) ignore irqreader. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: josh@freedesktop.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: dino@in.ibm.com Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: vegard.nossum@gmail.com Cc: adobriyan@gmail.com Cc: oleg@tv-sign.ru Cc: bunk@kernel.org Cc: rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19rcu: make rcutorture more vicious: reinstate boot-time testingPaul E. McKenney
This patch re-institutes the ability to build rcutorture directly into the Linux kernel. The reason that this capability was removed was that this could result in your kernel being pretty much useless, as rcutorture would be running starting from early boot. This problem has been avoided by (1) making rcutorture run only three seconds of every six by default, (2) adding a CONFIG_RCU_TORTURE_TEST_RUNNABLE that permits rcutorture to be quiesced at boot time, and (3) adding a sysctl in /proc named /proc/sys/kernel/rcutorture_runnable that permits rcutorture to be quiesced and unquiesced when built into the kernel. Please note that this /proc file is -not- available when rcutorture is built as a module. Please also note that to get the earlier take-no-prisoners behavior, you must use the boot command line to set rcutorture's "stutter" parameter to zero. The rcutorture quiescing mechanism is currently quite crude: loops in each rcutorture process that poll a global variable once per tick. Suggestions for improvement are welcome. The default action will be to reduce the polling rate to a few times per second. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18rcu: make rcutorture more vicious: add stutter featurePaul E. McKenney
This patch takes a step towards making rcutorture more brutal by allowing the test to be automatically periodically paused, with the default being to run the test for five seconds then pause for five seconds and repeat. This behavior can be controlled using a new "stutter" module parameter, so that "stutter=0" gives the old default behavior of running continuously. Starting and stopping rcutorture more heavily stresses RCU's interaction with the scheduler, as well as exercising more paths through the grace-period detection code. Note that the default to "shuffle_interval" has also been adjusted from 5 seconds to 3 seconds to provide varying overlap with the "stutter" interval. I am still unable to provoke the failures that Alexey has been seeing, even with this patch, but will be doing a few additional things to beef up rcutorture. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-19sched: 1Q08 RCU doc update, add call_rcu_sched()Paul E. McKenney
Long-delayed update to the RCU documentation, including adding the new call_rcu_sched() and rcu_barrier_sched() APIs. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-13remove final fastcall usersHarvey Harrison
fastcall always expands to empty, remove it. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25Preempt-RCU: update RCU Documentation.Paul E. McKenney
This patch updates the RCU documentation to reflect preemptible RCU as well as recent publications. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Add Documentation/RCU/00-IndexRob Landley
Add Documentation/RCU/00-INDEX Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Document the fact that RCU callbacks can run in parallelPaul E. McKenney
Add an item to the RCU documentation checklist noting that RCU callbacks can run in parallel. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PATCH] rcu: add sched torture type to rcutortureJosh Triplett
Implement torture testing for the "sched" variant of RCU, which uses preempt_disable, preempt_enable, and synchronize_sched. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] rcu: add rcu_bh_sync torture type to rcutortureJosh Triplett
Use the newly-generic synchronous deferred free function to implement torture testing for rcu_bh using synchronize_rcu_bh rather than the asynchronous call_rcu_bh. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] rcu: add rcu_sync torture type to rcutortureJosh Triplett
Use the newly-generic synchronous deferred free function to implement torture testing for RCU using synchronize_rcu rather than the asynchronous call_rcu. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] RCU: add fake writers to rcutortureJosh Triplett
rcutorture currently has one writer and an arbitrary number of readers. To better exercise some of the code paths in RCU implementations, add fake writer threads which call the synchronize function for the RCU variant in a loop, with a delay between calls to arrange for different numbers of writers running in parallel. [bunk@stusta.de: cleanup] Acked-by: Paul McKenney <paulmck@us.ibm.com> Cc: Dipkanar Sarma <dipankar@in.ibm.com> Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] srcu-3: add SRCU operations to rcutorturePaul E. McKenney
Adds SRCU operations to rcutorture and updates rcutorture documentation. Also increases the stress imposed by the rcutorture test. [bunk@stusta.de: make needlessly global code static] Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Cc: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] srcu-3: RCU variant permitting read-side blockingPaul E. McKenney
Updated patch adding a variant of RCU that permits sleeping in read-side critical sections. SRCU is as follows: o Each use of SRCU creates its own srcu_struct, and each srcu_struct has its own set of grace periods. This is critical, as it prevents one subsystem with a blocking reader from holding up SRCU grace periods for other subsystems. o The SRCU primitives (srcu_read_lock(), srcu_read_unlock(), and synchronize_srcu()) all take a pointer to a srcu_struct. o The SRCU primitives must be called from process context. o srcu_read_lock() returns an int that must be passed to the matching srcu_read_unlock(). Realtime RCU avoids the need for this by storing the state in the task struct, but SRCU needs to allow a given code path to pass through multiple SRCU domains -- storing state in the task struct would therefore require either arbitrary space in the task struct or arbitrary limits on SRCU nesting. So I kicked the state-storage problem up to the caller. Of course, it is not permitted to call synchronize_srcu() while in an SRCU read-side critical section. o There is no call_srcu(). It would not be hard to implement one, but it seems like too easy a way to OOM the system. (Hey, we have enough trouble with call_rcu(), which does -not- permit readers to sleep!!!) So, if you want it, please tell me why... [josht@us.ibm.com: sparse notation] Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-07-10[PATCH] RCU Documentation fixUrs Thuermann
Updater should use _rcu variant of list_del(). Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rcutorture: add ops vector and Classic RCU opsPaul E. McKenney
Add an ops vector to rcutorture, and add the ops for Classic RCU. Update the rcutorture documentation to reflect slight change to the dmesg formats. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rcutorture: catchup doc fixes for idle-hz testsPaul E. McKenney
This just catches the RCU torture documentation up with the recent fixes that test RCU for architectures that turn of the scheduling-clock interrupt for idle CPUs and the addition of a SUCCESS/FAILURE indication, fixing up an obsolete comment as well. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RCU documentation: self-limiting updates and call_rcu()Paul E. McKenney
An update to the RCU documentation calling out the self-limiting-update-rate advantages of synchronize_rcu(), and describing how to use call_rcu() in a way that results in self-limiting updates. Self-limiting updates are important to avoiding RCU-induced OOM in face of denial-of-service attacks. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Make RCU API inaccessible to non-GPL Linux kernel modulesPaul E. McKenney
Remove synchronize_kernel() (deprecated 2-APR-2005 in http://lkml.org/lkml/2005/4/3/11) and makes the RCU API inaccessible to non-GPL Linux kernel modules (as was announced more than one year ago in http://lkml.org/lkml/2005/4/3/8). Tested on x86 and ppc64. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] for_each_possible_cpu: documentaionKAMEZAWA Hiroyuki
Replace for_each_cpu with for_each_possible_cpu. Modifies occurences in documentaion. for_each_cpu in whatisRCU.txt should be for_each_online_cpu ??? (I'm not sure..) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24rcu: undeclared variable used in documentationBaruch Even
The RCU documentation uses an fp variable which is not declared in the code snippets. Use the new_fp variable instead. Signed-Off-By: Baruch Even <baruch@ev-en.org> Acked-by: <paulmck@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-01[PATCH] RCU documentation fixes (January 2006 update)Paul E. McKenney
Updates to in-tree RCU documentation based on comments over the past few months. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] rcu file: use atomic primitivesNick Piggin
Use atomic_inc_not_zero for rcu files instead of special case rcuref. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Remove hlist_for_each_rcu() API, convert existing use to ↵Paul E. McKenney
hlist_for_each_entry_rcu Remove the hlist_for_each_rcu() API, which is used only in one place, and is trivially converted to hlist_for_each_entry_rcu(), making the code shorter and more readable. Any out-of-tree uses may be similarly converted. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] RCU torture-testing kernel modulePaul E. McKenney
This patch is a rewrite of the one submitted on October 1st, using modules (http://marc.theaimsgroup.com/?l=linux-kernel&m=112819093522998&w=2). This rewrite adds a tristate CONFIG_RCU_TORTURE_TEST, which enables an intense torture test of the RCU infratructure. This is needed due to the continued changes to the RCU infrastructure to accommodate dynamic ticks, CPU hotplug, realtime, and so on. Most of the code is in a separate file that is compiled only if the CONFIG variable is set. Documentation on how to run the test and interpret the output is also included. This code has been tested on i386 and ppc64, and an earlier version of the code has received extensive testing on a number of architectures as part of the PREEMPT_RT patchset. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] Yet another RCU documentation updatePaul E. McKenney
Update RCU documentation based on discussions and review of RCU-based tree patches. Add an introductory whatisRCU.txt file. Signed-off-by: <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: rcuref APIsDipankar Sarma
Adds a set of primitives to do reference counting for objects that are looked up without locks using RCU. Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NMI: Update NMI users of RCU to use new APIPaul E. McKenney
Uses of RCU for dynamically changeable NMI handlers need to use the new rcu_dereference() and rcu_assign_pointer() facilities. This change makes it clear that these uses are safe from a memory-barrier viewpoint, but the main purpose is to document exactly what operations are being protected by RCU. This has been tested on x86 and x86-64, which are the only architectures affected by this change. Signed-off-by: <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Update RCU documentationPaul E. McKenney
Update the RCU documentation to allow for the new synchronize_rcu() and synchronize_sched() primitives. Fix a few other nits as well. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
