path: root/Documentation/SubmittingDrivers
2011-08-13Documentation: SubmittingDrivers: fix Linus's git tree URLRalf Thielow
Change resource URL to new git tree - (http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git). Signed-off-by: Ralf Thielow <ralf.thielow@googlemail.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27Documentation: SubmittingDrivers: ResourcesArce, Abraham
- Add additional location (Git) for the kernel master tree - Add reference to Git Project Signed-off-by: Abraham Arce <x0066660@ti.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20Update 2.4 maintainer in documentLi Yang
Update the maintainer of 2.4 kernel in Documentations/SubmittingPatches. Signed-off-by: Li Yang <leo@zh-kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-08Documentation: Ask driver writers to provide PM supportRafael J. Wysocki
Add a paragraph in Documentation/SubmittingDrivers requesting that the basic PM support be provided by new device drivers. Add two new documents in Documentation/power/ giving general instructions on debugging the suspend/resume functionality and testing the suspend and resume support in device drivers. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: David Brownell <david-b@pacbell.net> Cc: Nigel Cunningham <ncunningham@linuxmail.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Documentation/SubmittingDrivers: minor updateAlexey Dobriyan
* fix copright typo * remove trailing whitespace * remove Kernel Traffic from Resources. Zack, it was great reading! * Name Arjan by name and fix URL of "How to NOT" paper. * Remove "Last updated" tag. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] docs: update some updated code docsXose Vazquez Perez
Based on comments from Randy Dunlap on my previous commit 5b0ed2c64d8fdafb5fcfb3baabdd288628b1ff9b Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] docs: updated some code docsXose Vazquez Perez
2005-06-28[PATCH] Doc/Submitting: corrections, additionsRandy Dunlap
Corrections to Documentation/Submitting{Drivers,Patches} - update LANANA info. - fix some typos - update 2.2 kernel maintainer info. - update 'dontdiff' info. - update URLs for patch scripts - add Trivial Patch Monkey URL - add more references for submitting patches Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
