path: root/Documentation/SubmittingPatches
2008-06-05doc: add suggestions about good practises for maintainersWilly Tarreau
Suggest how to deal with patch modifications caused by merging or back-porting when you're a maintainer. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Correct a few trivial tree details in Documentation/SubmittingPatchesJesper Juhl
Correct maintainer name and URL. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-11Merge branch 'docs' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs' of git://git.lwn.net/linux-2.6: Add additional examples in Documentation/spinlocks.txt Move sched-rt-group.txt to scheduler/ Documentation: move rpc-cache.txt to filesystems/ Documentation: move nfsroot.txt to filesystems/ Spell out behavior of atomic_dec_and_lock() in kerneldoc Fix a typo in highres.txt Fixes to the seq_file document Fill out information on patch tags in SubmittingPatches Add the seq_file documentation
2008-04-02doc: fix typo in SubmittingPatchesJim Meyering
Signed-off-by: Jim Meyering <meyering@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30Fill out information on patch tags in SubmittingPatchesJonathan Corbet
Add more information about the various patch tags in use, and try to establish a meaning for Reviewed-by: Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-02-03Documentation: mention email-clients.txt in SubmittingPatchesMichael Opdenacker
I was struggling to get my email-client no to mangle my patch files, and I didn't find enough information in the SubmittingPatches file. By looking for more information on the web, I eventually found the email-clients.txt file, and it answered all my needs This patch adds a reference to email-clients.txt in SubmittingPatches, and Mozilla related information which is no longer accurate (as opposed to the details found in email-clients.txt). This should be helpful for people sending their first patches, or not sending patches on a frequent basis. Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-30fix typo in SubmittingPatchesKeiichi Kii
Fix typo. Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11fix typo in Documentation/SubmittingPatchesAndre Haupt
Signed-off-by: Andre Haupt <andre@finow14.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22HOWTO: latest lxr url address changedQi Yong
Hello, I've noticed that in Document/HOWTO the url address: http://sosdg.org/~coywolf/lxr/ has changed to http://users.sosdg.org/~qiyong/lxr/ from the website. -- qiyong Signed-off-by: Qi Yong <qiyong@fc-cn.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-22Documentation: Fix a mispelt "probably" in SubmittingPatches.Linus Nilsson
Fix a typo in SubmittingPatches where "probably" was spelt "probabally". Signed-off-by: Linus Nilsson <lajnold@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16update checkpatch.pl to version 0.07Andy Whitcroft
This version brings a number of new checks, fixes for flase positives, plus a clarification of the output to better guide use. Of note: - checks for documentation for new __setup calls - clearer reporting where braces and parenthesis are involved - reports for closing brace and semi-colon spacing - reports on unwanted externs This patch includes an update to the documentation on checkpatch.pl itself to clarify when it should be used and to indicate that it is not intended as the final arbitor of style. Full changelog: Andy Whitcroft (19): Version: 0.07 ensure we do not apply control brace checks to preprocesor directives add {u,s}{8,16,32,64} to the type matcher accept lack of spacing after the semicolons in for (;;) report new externs in .c files fix up typedef exclusion for function prototypes else trailing statements check need to account for \ at end of line add enums to the type matcher add missing check descriptions suppress double reporting of ** spacing report on do{ spacing issues include an example of the brace/parenthesis in output check for spacing after closing braces prevent double reports on pointer spacing issues handle blank continuation lines on macros classify all reports error, warning, or check revamp hanging { checks and apply in context no spaces after the last ; in a for is ok check __setup has a corresponding addition to documentation David Woodhouse (1): limit character set used in patches and descriptions to UTF-8 Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08document Acked-by:Andrew Morton
Explain what we use Acked-by: for, and how it differs from Signed-off-by: Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01add a trivial patch style checkerAndy Whitcroft
We are seeing increasing levels of minor patch style violations in submissions to the mailing lists as well as making it into the tree. These detract from the quality of the submission and cause unnessary work for reviewers. As a first step package up the current state of the patch style checker and include it in the kernel tree. Add instructions suggesting running it on submissions. This adds version v0.01 of the checkpatch.pl script. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09doc: what a patch series isRandy Dunlap
It seems that we need to clarify that a patch series is a series of related patches rather than "here are some of my patches as multiple (numbered) emails." Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23Change Linus' email address tooLinus Torvalds
This changes a few mentions of my email address to point to the new one, leaving things like old copyright messages alone. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] SubmittingPatches: add a note about "format=flowed" when sending patchesKirill Korotaev
Add a note about "format=flowed" when sending patches and explain how to fix mozilla. Thunderbird has the similar options. Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] SubmittingPatches cleanupsPavel Machek
This cleans up SubmittingPatches a bit. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] We can not allow anonymous contributions to the kernelGreg KH
The DCO does not mean anything if we allow anonymous contributors to the kernel. As this is an open source project, we need to do everything in the open. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] Doc/SubmittingPatches cleanupsRandy Dunlap
A few cleanups to SubmittingPatches: - mention SubmitChecklist - remove mention of my simple patch script tools - remove last-updated line Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] docs: update some updated code docsXose Vazquez Perez
Based on comments from Randy Dunlap on my previous commit 5b0ed2c64d8fdafb5fcfb3baabdd288628b1ff9b Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] SubmittingPatches: diffstat optionsRandy Dunlap
Add desired 'diffstat' options to use for kernel patches. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] docs: updated some code docsXose Vazquez Perez
2006-01-03Documentation/SubmittingPatches: update Trivial Patch Monkey informationKees Cook
While looking for where to send trivial patches, I found old contact information in Documentation/SubmittingPatches. Signed-off-by: Kees Cook <kees@outflux.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-10-03[PATCH] Document patch subject line betterPaul Jackson
Improve explanation of the Subject line fields in Documentation/SubmittingPatches Canonical Patch Format. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-02[PATCH] Document from line in patch formatPaul Jackson
Document more details of patch format such as the "from" line and the "---" marker line, and provide more references for patch guidelines. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] plug MAN-PAGES maintainer in Documentation/SubmittingPatchesPaul Jackson
Improve the likelihood that someone submitting a patch will notify the MAN-PAGES maintainer. This is a follow-up to comments on the July 29 lkml email thread: "Broke nice range for RLIMIT NICE" Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Michael Kerrisk" <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] Doc/Submitting: corrections, additionsRandy Dunlap
Corrections to Documentation/Submitting{Drivers,Patches} - update LANANA info. - fix some typos - update 2.2 kernel maintainer info. - update 'dontdiff' info. - update URLs for patch scripts - add Trivial Patch Monkey URL - add more references for submitting patches Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26[PATCH] remove redundant info from SubmittingPatchesAdrian Bunk
Since the Trivial Patch Monkey is mentioned both in steps 4. and 5., I removed it from step4 (Select e-mail destination), since it should go under 'Select your CC list'. Signed-off-by: Cosmin Nicolaescu <cos@camelot.homelinux.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] DCO: use IANA-reserved second level domain nameAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-13Update DCO ("signoff") rules to 1.1Linus Torvalds
This adds a clause that notes explicitly that the person doing the sign-off knows that the project (and his sign-off) is public and will possibly get archived and re-distributed.
