path: root/Documentation/acpi
2008-11-07ACPI: update debug parameter documentationBjorn Helgaas
Reformat acpi.debug_layer and acpi.debug_level documentation so it's more readable, add some clues about how to figure out the mask bits that enable a specific ACPI_DEBUG_PRINT statement, and include some useful examples. Move the list of masks to Documentation/acpi/debug.txt (these are copies of the authoritative values in acoutput.h and acpi_drivers.h). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-15ACPI: Remove ACPI_CUSTOM_DSDT_INITRD optionLinus Torvalds
This essentially reverts commit 71fc47a9adf8ee89e5c96a47222915c5485ac437 ("ACPI: basic initramfs DSDT override support"), because the code simply isn't ready. It did ugly things to the init sequence to populate the rootfs image early, but that just ended up showing other problems with the whole approach. The fact is, the VFS layer simply isn't initialized this early, and the relevant ACPI code should either run much later, or this shouldn't be done at all. For 2.6.25, we'll just pick the latter option. We can revisit this concept later if necessary. Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Renninger <trenn@suse.de> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Len Brown <len.brown@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Markus Gaugusch <dsdt@gaugusch.at> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'dsdt-override' into releaseLen Brown
2008-02-07ACPI: update DSDT override documentationLen Brown
2008-02-06ACPI: basic initramfs DSDT override supportMarkus Gaugusch
The basics of DSDT from initramfs. In case this option is selected, populate_rootfs() is called a bit earlier to have the initramfs content available during ACPI initialization. This is a very similar path to the one available at http://gaugusch.at/kernel.shtml but with some update in the documentation, default set to No and the change of populate_rootfs() the "Jeff Mahony way" (which avoids reading the initramfs twice). Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-19ACPI: document method tracing hooksLen Brown
