path: root/Documentation/acpi
2014-11-04ACPI / GPIO: Document ACPI GPIO mappings APIRafael J. Wysocki
Document the previously introduced method that can be used by device drivers to provide the GPIO subsystem with mappings between GPIO names (connection IDs) and GpioIo()/GpioInt() resources in _CRS. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2014-11-04gpio / ACPI: Add support for _DSD device propertiesMika Westerberg
With release of ACPI 5.1 and _DSD method we can finally name GPIOs (and other things as well) returned by _CRS. Previously we were only able to use integer index to find the corresponding GPIO, which is pretty error prone if the order changes. With _DSD we can now query GPIOs using name instead of an integer index, like the below example shows: // Bluetooth device with reset and shutdown GPIOs Device (BTH) { Name (_HID, ...) Name (_CRS, ResourceTemplate () { GpioIo (Exclusive, PullUp, 0, 0, IoRestrictionInputOnly, "\\_SB.GPO0", 0, ResourceConsumer) {15} GpioIo (Exclusive, PullUp, 0, 0, IoRestrictionInputOnly, "\\_SB.GPO0", 0, ResourceConsumer) {27, 31} }) Name (_DSD, Package () { ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), Package () { Package () {"reset-gpio", Package() {^BTH, 1, 1, 0 }}, Package () {"shutdown-gpio", Package() {^BTH, 0, 0, 0 }}, } }) } The format of the supported GPIO property is: Package () { "name", Package () { ref, index, pin, active_low }} ref - The device that has _CRS containing GpioIo()/GpioInt() resources, typically this is the device itself (BTH in our case). index - Index of the GpioIo()/GpioInt() resource in _CRS starting from zero. pin - Pin in the GpioIo()/GpioInt() resource. Typically this is zero. active_low - If 1 the GPIO is marked as active_low. Since ACPI GpioIo() resource does not have field saying whether it is active low or high, the "active_low" argument can be used here. Setting it to 1 marks the GPIO as active low. In our Bluetooth example the "reset-gpio" refers to the second GpioIo() resource, second pin in that resource with the GPIO number of 31. This patch implements necessary support to gpiolib for extracting GPIOs using _DSD device properties. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-26mfd: Add ACPI supportMika Westerberg
If an MFD device is backed by ACPI namespace, we should allow subdevice drivers to access their corresponding ACPI companion devices through normal means (e.g using ACPI_COMPANION()). This patch adds such support to the MFD core. If the MFD parent device does not specify any ACPI _HID/_CID for the child device, the child device will share the parent ACPI companion device. Otherwise the child device will be assigned with the corresponding ACPI companion, if found in the namespace below the parent. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-12ACPI / documentation: Remove reference to acpi_platform_device_ids from ↵Darren Hart
enumeration.txt As of: 4845934 ACPI / scan: use platform bus type by default for _HID enumeration ACPI uses the platform bus by default, changing the opt-in to an opt-out policy, eliminating the acpi_platform_device_ids table and replacing it with forbidden_id_list[]. Remove the qualifying paragraph from the acpi/enumeration documentation as it no longer applies. Reported-by: Max Eliaser <max@meliaserlow.dyndns.tv> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-23Documentation / ACPI: Fix location of GPIO documentationJarkko Nikula
Commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") moved Documentation/gpio.txt to Documentation/gpio/gpio-legacy.txt and added new documents for descriptor-based interface so fix the the location here to point Documentation/gpio/ since that what commit ccb6fbb99020 ("Documentation / ACPI: update to GPIO descriptor API") was looking for. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-24Merge tag 'pm+acpi-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "As far as the number of commits goes, the top spot belongs to ACPI this time with cpufreq in the second position and a handful of PM core, PNP and cpuidle updates. They are fixes and cleanups mostly, as usual, with a couple of new features in the mix. The most visible change is probably that we will create struct acpi_device objects (visible in sysfs) for all devices represented in the ACPI tables regardless of their status and there will be a new sysfs attribute under those objects allowing user space to check that status via _STA. Consequently, ACPI device eject or generally hot-removal will not delete those objects, unless the table containing the corresponding namespace nodes is unloaded, which is extremely rare. Also ACPI container hotplug will be handled quite a bit differently and cpufreq will support CPU boost ("turbo") generically and not only in the acpi-cpufreq driver. Specifics: - ACPI core changes to make it create a struct acpi_device object for every device represented in the ACPI tables during all namespace scans regardless of the current status of that device. In accordance with this, ACPI hotplug operations will not delete those objects, unless the underlying ACPI tables go away. - On top of the above, new sysfs attribute for ACPI device objects allowing user space to check device status by triggering the execution of _STA for its ACPI object. From Srinivas Pandruvada. - ACPI core hotplug changes reducing code duplication, integrating the PCI root hotplug with the core and reworking container hotplug. - ACPI core simplifications making it use ACPI_COMPANION() in the code "glueing" ACPI device objects to "physical" devices. - ACPICA update to upstream version 20131218. This adds support for the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves debug facilities. From Bob Moore, Lv Zheng and Betty Dall. - Init code change to carry out the early ACPI initialization earlier. That should allow us to use ACPI during the timekeeping initialization and possibly to simplify the EFI initialization too. From Chun-Yi Lee. - Clenups of the inclusions of ACPI headers in many places all over from Lv Zheng and Rashika Kheria (work in progress). - New helper for ACPI _DSM execution and rework of the code in drivers that uses _DSM to execute it via the new helper. From Jiang Liu. - New Win8 OSI blacklist entries from Takashi Iwai. - Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava, Rashika Kheria, Tang Chen, Zhang Rui. - intel_pstate driver updates, including proper Baytrail support, from Dirk Brandewie and intel_pstate documentation from Ramkumar Ramachandra. - Generic CPU boost ("turbo") support for cpufreq from Lukasz Majewski. - powernow-k6 cpufreq driver fixes from Mikulas Patocka. - cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark Brown. - Assorted cpufreq drivers fixes and cleanups from Anson Huang, John Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh Kumar. - cpuidle cleanups from Bartlomiej Zolnierkiewicz. - Support for hibernation APM events from Bin Shi. - Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC disabled during thaw transitions from Bjørn Mork. - PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf Hansson. - PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente Kurusa, Rashika Kheria. - New tool for profiling system suspend from Todd E Brandt and a cpupower tool cleanup from One Thousand Gnomes" * tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits) thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412) cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ Documentation: cpufreq / boost: Update BOOST documentation cpufreq: exynos: Extend Exynos cpufreq driver to support boost cpufreq / boost: Kconfig: Support for software-managed BOOST acpi-cpufreq: Adjust the code to use the common boost attribute cpufreq: Add boost frequency support in core intel_pstate: Add trace point to report internal state. cpufreq: introduce cpufreq_generic_get() routine ARM: SA1100: Create dummy clk_get_rate() to avoid build failures cpufreq: stats: create sysfs entries when cpufreq_stats is a module cpufreq: stats: free table and remove sysfs entry in a single routine cpufreq: stats: remove hotplug notifiers cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly cpufreq: speedstep: remove unused speedstep_get_state platform: introduce OF style 'modalias' support for platform bus PM / tools: new tool for suspend/resume performance optimization ACPI: fix module autoloading for ACPI enumerated devices ACPI: add module autoloading support for ACPI enumerated devices ACPI: fix create_modalias() return value handling ...
2014-01-21Merge tag 'gpio-v3.14-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO tree bulk changes from Linus Walleij: "A big set this merge window, as we have much going on in this subsystem. The changes to other subsystems (notably a slew of ARM machines as I am doing away with their custom APIs) have all been ACKed to the extent possible. Major changes this time: - Some core improvements and cleanups to the new GPIO descriptor API. This seems to be working now so we can start the exodus to this API, moving gradually away from the global GPIO numberspace. - Incremental improvements to the ACPI GPIO core, and move the few GPIO ACPI clients we have to the GPIO descriptor API right *now* before we go any further. We actually managed to contain this *before* we started to litter the kernel with yet another hackish global numberspace for the ACPI GPIOs, which is a big win. - The RFkill GPIO driver and all platforms using it have been migrated to use the GPIO descriptors rather than fixed number assignments. Tegra machine has been migrated as part of this. - New drivers for MOXA ART, Xtensa GPIO32 and SMSC SCH311x. Those should be really good examples of how I expect a nice GPIO driver to look these days. - Do away with custom GPIO implementations on a major part of the ARM machines: ks8695, lpc32xx, mv78xx0. Make a first step towards the same in the horribly convoluted Samsung S3C include forest. We expect to continue to clean this up as we move forward. - Flag GPIO lines used for IRQ on adnp, bcm-kona, em, intel-mid and lynxpoint. This makes the GPIOlib core aware that a certain GPIO line is used for IRQs and can then enforce some semantics such as disallowing a GPIO line marked as in use for IRQ to be switched to output mode. - Drop all use of irq_set_chip_and_handler_name(). The name provided in these cases were just unhelpful tags like "mux" or "demux". - Extend the MCP23s08 driver to handle interrupts. - Minor incremental improvements for rcar, lynxpoint, em 74x164 and msm drivers. - Some non-urgent bug fixes here and there, duplicate #includes and that usual kind of cleanups" Fix up broken Kconfig file manually to make this all compile. * tag 'gpio-v3.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits) gpio: mcp23s08: fix casting caused build warning gpio: mcp23s08: depend on OF_GPIO gpio: mcp23s08: Add irq functionality for i2c chips ARM: S5P[v210|c100|64x0]: Fix build error gpio: pxa: clamp gpio get value to [0,1] ARM: s3c24xx: explicit dependency on <plat/gpio-cfg.h> ARM: S3C[24|64]xx: move includes back under <mach/> scope Documentation / ACPI: update to GPIO descriptor API gpio / ACPI: get rid of acpi_gpio.h gpio / ACPI: register to ACPI events automatically mmc: sdhci-acpi: convert to use GPIO descriptor API ARM: s3c24xx: fix build error gpio: f7188x: set can_sleep attribute gpio: samsung: Update documentation gpio: samsung: Remove hardware.h inclusion gpio: xtensa: depend on HAVE_XTENSA_GPIO32 gpio: clps711x: Enable driver compilation with COMPILE_TEST gpio: clps711x: Use of_match_ptr() net: rfkill: gpio: convert to descriptor-based GPIO interface leds: s3c24xx: Fix build failure ...
2014-01-08Documentation / ACPI: update to GPIO descriptor APIMika Westerberg
Update the documentation also to reflect the fact that there are no ACPI specific GPIO interfaces anymore but drivers should instead use the descriptor based GPIO APIs. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-17ACPI, APEI, EINJ: Changes to the ACPI/APEI/EINJ debugfs interfaceLuck, Tony
When I added support for ACPI5 I made the assumption that injected processor errors would just need to know the APICID, memory errors just the address and mask, and PCIe errors just the segment/bus/device/function. So I had the code check the type of injection and multiplex the "param1" value appropriately. This was not a good assumption :-( There are injection scenarios where we need to specify more than one of these items. E.g. injecting a cache error we need to specify an APICID of the cpu that owns the cache, and also an address (so that we can trip the error by accessing the address). Add a "flags" file to give the user direct access to specify which items are valid in the ACPI SET_ERROR_TYPE_WITH_ADDRESS structure. Also add new files param3 and param4 to hold all these values. For backwards compatability with old injection scripts we maintain the old behaviour if flags remains set at zero (or is reset to 0). Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-11-22ACPI / scan: Add acpi_device objects for all device nodes in the namespaceRafael J. Wysocki
Modify the ACPI namespace scanning code to register a struct acpi_device object for every namespace node representing a device, processor and so on, even if the device represented by that namespace node is reported to be not present and not functional by _STA. There are multiple reasons to do that. First of all, it avoids quite a lot of overhead when struct acpi_device objects are deleted every time acpi_bus_trim() is run and then added again by a subsequent acpi_bus_scan() for the same scope, although the namespace objects they correspond to stay in memory all the time (which always is the case on a vast majority of systems). Second, it will allow user space to see that there are namespace nodes representing devices that are not present at the moment and may be added to the system. It will also allow user space to evaluate _SUN for those nodes to check what physical slots the "missing" devices may be put into and it will make sense to add a sysfs attribute for _STA evaluation after this change (that will be useful for thermal management on some systems). Next, it will help to consolidate the ACPI hotplug handling among subsystems by making it possible to store hotplug-related information in struct acpi_device objects in a standard common way. Finally, it will help to avoid a race condition related to the deletion of ACPI namespace nodes. Namely, namespace nodes may be deleted as a result of a table unload triggered by _EJ0 or _DCK. If a hotplug notification for one of those nodes is triggered right before the deletion and it executes a hotplug callback via acpi_hotplug_execute(), the ACPI handle passed to that callback may be stale when the callback actually runs. One way to work around that is to always pass struct acpi_device pointers to hotplug callbacks after doing a get_device() on the objects in question which eliminates the use-after-free possibility (the ACPI handles in those objects are invalidated by acpi_scan_drop_device(), so they will trigger ACPICA errors on attempts to use them). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2013-10-19gpiolib / ACPI: document the GPIO descriptor based interfaceMika Westerberg
In addition to the existing ACPI specific GPIO interface, document the new descriptor based GPIO interface in Documentation/acpi/enumeration.txt, so it is clear that this new interface is preferred over the ACPI specific version. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-11ACPI / PM / Documentation: Replace outdated project links and addressesRafael J. Wysocki
Some links to projects web pages and e-mail addresses in ACPI/PM documentation and Kconfig are outdated, so update them. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-23i2c: move ACPI helpers into the coreMika Westerberg
This follows what has already been done for the DeviceTree helpers. Move the ACPI helpers from drivers/acpi/acpi_i2c.c to the I2C core and update documentation accordingly. This also solves a problem reported by Jerry Snitselaar that we can't build the ACPI I2C helpers as a module. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-08-23i2c: move OF helpers into the coreWolfram Sang
I2C of helpers used to live in of_i2c.c but experience (from SPI) shows that it is much cleaner to have this in the core. This also removes a circular dependency between the helpers and the core, and so we can finally register child nodes in the core instead of doing this manually in each driver. So, fix the drivers and documentation, too. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-08-20Documentation/acpi/enumeration.txt fix a typoStefan Huber
Corrected the word configation to configuration. Signed-off-by: Stefan Huber <steffhip@gmail.com> Signed-off-by: Matthias Schid <aircrach115@gmail.com> Signed-off-by: Simon Puels <simon.puels@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-03Merge tag 'pm+acpi-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "This time the total number of ACPI commits is slightly greater than the number of cpufreq commits, but Viresh Kumar (who works on cpufreq) remains the most active patch submitter. To me, the most significant change is the addition of offline/online device operations to the driver core (with the Greg's blessing) and the related modifications of the ACPI core hotplug code. Next are the freezer updates from Colin Cross that should make the freezing of tasks a bit less heavy weight. We also have a couple of regression fixes, a number of fixes for issues that have not been identified as regressions, two new drivers and a bunch of cleanups all over. Highlights: - Hotplug changes to support graceful hot-removal failures. It sometimes is necessary to fail device hot-removal operations gracefully if they cannot be carried out completely. For example, if memory from a memory module being hot-removed has been allocated for the kernel's own use and cannot be moved elsewhere, it's desirable to fail the hot-removal operation in a graceful way rather than to crash the kernel, but currenty a success or a kernel crash are the only possible outcomes of an attempted memory hot-removal. Needless to say, that is not a very attractive alternative and it had to be addressed. However, in order to make it work for memory, I first had to make it work for CPUs and for this purpose I needed to modify the ACPI processor driver. It's been split into two parts, a resident one handling the low-level initialization/cleanup and a modular one playing the actual driver's role (but it binds to the CPU system device objects rather than to the ACPI device objects representing processors). That's been sort of like a live brain surgery on a patient who's riding a bike. So this is a little scary, but since we found and fixed a couple of regressions it caused to happen during the early linux-next testing (a month ago), nobody has complained. As a bonus we remove some duplicated ACPI hotplug code, because the ACPI-based CPU hotplug is now going to use the common ACPI hotplug code. - Lighter weight freezing of tasks. These changes from Colin Cross and Mandeep Singh Baines are targeted at making the freezing of tasks a bit less heavy weight operation. They reduce the number of tasks woken up every time during the freezing, by using the observation that the freezer simply doesn't need to wake up some of them and wait for them all to call refrigerator(). The time needed for the freezer to decide to report a failure is reduced too. Also reintroduced is the check causing a lockdep warining to trigger when try_to_freeze() is called with locks held (which is generally unsafe and shouldn't happen). - cpufreq updates First off, a commit from Srivatsa S Bhat fixes a resume regression introduced during the 3.10 cycle causing some cpufreq sysfs attributes to return wrong values to user space after resume. The fix is kind of fresh, but also it's pretty obvious once Srivatsa has identified the root cause. Second, we have a new freqdomain_cpus sysfs attribute for the acpi-cpufreq driver to provide information previously available via related_cpus. From Lan Tianyu. Finally, we fix a number of issues, mostly related to the CPUFREQ_POSTCHANGE notifier and cpufreq Kconfig options and clean up some code. The majority of changes from Viresh Kumar with bits from Jacob Shin, Heiko Stübner, Xiaoguang Chen, Ezequiel Garcia, Arnd Bergmann, and Tang Yuantian. - ACPICA update A usual bunch of updates from the ACPICA upstream. During the 3.4 cycle we introduced support for ACPI 5 extended sleep registers, but they are only supposed to be used if the HW-reduced mode bit is set in the FADT flags and the code attempted to use them without checking that bit. That caused suspend/resume regressions to happen on some systems. Fix from Lv Zheng causes those registers to be used only if the HW-reduced mode bit is set. Apart from this some other ACPICA bugs are fixed and code cleanups are made by Bob Moore, Tomasz Nowicki, Lv Zheng, Chao Guan, and Zhang Rui. - cpuidle updates New driver for Xilinx Zynq processors is added by Michal Simek. Multidriver support simplification, addition of some missing kerneldoc comments and Kconfig-related fixes come from Daniel Lezcano. - ACPI power management updates Changes to make suspend/resume work correctly in Xen guests from Konrad Rzeszutek Wilk, sparse warning fix from Fengguang Wu and cleanups and fixes of the ACPI device power state selection routine. - ACPI documentation updates Some previously missing pieces of ACPI documentation are added by Lv Zheng and Aaron Lu (hopefully, that will help people to uderstand how the ACPI subsystem works) and one outdated doc is updated by Hanjun Guo. - Assorted ACPI updates We finally nailed down the IA-64 issue that was the reason for reverting commit 9f29ab11ddbf ("ACPI / scan: do not match drivers against objects having scan handlers"), so we can fix it and move the ACPI scan handler check added to the ACPI video driver back to the core. A mechanism for adding CMOS RTC address space handlers is introduced by Lan Tianyu to allow some EC-related breakage to be fixed on some systems. A spec-compliant implementation of acpi_os_get_timer() is added by Mika Westerberg. The evaluation of _STA is added to do_acpi_find_child() to avoid situations in which a pointer to a disabled device object is returned instead of an enabled one with the same _ADR value. From Jeff Wu. Intel BayTrail PCH (Platform Controller Hub) support is added to the ACPI driver for Intel Low-Power Subsystems (LPSS) and that driver is modified to work around a couple of known BIOS issues. Changes from Mika Westerberg and Heikki Krogerus. The EC driver is fixed by Vasiliy Kulikov to use get_user() and put_user() instead of dereferencing user space pointers blindly. Code cleanups are made by Bjorn Helgaas, Nicholas Mazzuca and Toshi Kani. - Assorted power management updates The "runtime idle" helper routine is changed to take the return values of the callbacks executed by it into account and to call rpm_suspend() if they return 0, which allows us to reduce the overall code bloat a bit (by dropping some code that's not necessary any more after that modification). The runtime PM documentation is updated by Alan Stern (to reflect the "runtime idle" behavior change). New trace points for PM QoS are added by Sahara (<keun-o.park@windriver.com>). PM QoS documentation is updated by Lan Tianyu. Code cleanups are made and minor issues are addressed by Bernie Thompson, Bjorn Helgaas, Julius Werner, and Shuah Khan. - devfreq updates New driver for the Exynos5-bus device from Abhilash Kesavan. Minor cleanups, fixes and MAINTAINERS update from MyungJoo Ham, Abhilash Kesavan, Paul Bolle, Rajagopal Venkat, and Wei Yongjun. - OMAP power management updates Adaptive Voltage Scaling (AVS) SmartReflex voltage control driver updates from Andrii Tseglytskyi and Nishanth Menon." * tag 'pm+acpi-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits) cpufreq: Fix cpufreq regression after suspend/resume ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state() PM / Sleep: Warn about system time after resume with pm_trace cpufreq: don't leave stale policy pointer in cdbs->cur_policy acpi-cpufreq: Add new sysfs attribute freqdomain_cpus cpufreq: make sure frequency transitions are serialized ACPI: implement acpi_os_get_timer() according the spec ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan ACPI: Add CMOS RTC Operation Region handler support ACPI / processor: Drop unused variable from processor_perflib.c cpufreq: tegra: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: s3c64xx: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: omap: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: imx6q: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: exynos: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: dbx500: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: davinci: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: arm-big-little: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: powernow-k8: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: pcc: call CPUFREQ_POSTCHANGE notfier in error cases ...
2013-06-21ACPI / video: update video_extension.txt for backlight controlAaron Lu
The ACPI video driver has changed a lot, and it doesn't export interfaces in /proc any more, so the documentation for it should be updated. This update focuses on ACPI video driver's backlight control. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-21ACPI / video: move video_extension.txt to Documentation/acpiAaron Lu
ACPI video driver is written according to ACPI spec, appendix B: Video Extensions. So it better be put under the acpi directory instead of the power directory. This patch moves the file there without any other change. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-21ACPI: Add ACPI namespace documentationLv Zheng
ACPI is implemented as a subsystem in Linux, it creates a device tree by mapping specific ACPI namespace objects (Device/Processor/PowerResource/ThermalZone) into Linux device objects. This patch adds documentation for the ACPI device tree. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-06ACPI/APEI: Update einj documentation for param1/param2Chen Gong
To ensure EINJ working well when injecting errors via EINJ table, add some restrictions: param1 must be a valid physical RAM address and param2 must specify page granularity or narrower. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-05-09Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This time we have dmatest improvements from Andy along with dw_dmac fixes. He has also done support for acpi for dmanegine. Also we have bunch of fixes going in DT support for dmanegine for various folks. Then Haswell and other ioat changes from Dave and SUDMAC support from Shimoda." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) dma: tegra: implement suspend/resume callbacks dma:of: Use a mutex to protect the of_dma_list dma: of: Fix of_node reference leak dmaengine: sirf: move driver init from module_init to subsys_initcall sudmac: add support for SUDMAC dma: sh: add Kconfig at_hdmac: move to generic DMA binding ioatdma: ioat3_alloc_sed can be static ioatdma: Adding write back descriptor error status support for ioatdma 3.3 ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap ioatdma: Adding support for 16 src PQ ops and super extended descriptors ioatdma: Removing hw bug workaround for CB3.x .2 and earlier dw_dmac: add ACPI support dmaengine: call acpi_dma_request_slave_channel as well dma: acpi-dma: introduce ACPI DMA helpers dma: of: Remove unnecessary list_empty check DMA: OF: Check properties value before running be32_to_cpup() on it DMA: of: Constant names ioatdma: skip silicon bug workaround for pq_align for cb3.3 ioatdma: Removing PQ val disable for cb3.3 ...
2013-04-15dma: acpi-dma: introduce ACPI DMA helpersAndy Shevchenko
There is a new generic API to get a DMA channel for a slave device (commit 9a6cecc8 "dmaengine: add helper function to request a slave DMA channel"). In similar fashion to the DT case (commit aa3da644 "of: Add generic device tree DMA helpers") we introduce helpers to the DMAC drivers which are enumerated by ACPI. The proposed extension provides the following API calls: acpi_dma_controller_register(), devm_acpi_dma_controller_register() acpi_dma_controller_free(), devm_acpi_dma_controller_free() acpi_dma_simple_xlate() acpi_dma_request_slave_chan_by_index() acpi_dma_request_slave_chan_by_name() The first two should be used, for example, at probe() and remove() of the corresponding DMAC driver. At the register stage the DMAC driver supplies a custom xlate() function to translate a struct dma_spec into struct dma_chan. Accordingly to the ACPI Fixed DMA resource specification the only two pieces of information the slave device has are the channel id and the request line (slave id). Those two are represented by struct dma_spec. The acpi_dma_request_slave_chan_by_index() provides access to the specifix FixedDMA resource by its index. Whereas dma_request_slave_channel() takes a string parameter to identify the DMA resources required by the slave device. To make a slave device driver work with both DeviceTree and ACPI enumeration a simple convention is established: "tx" corresponds to the index 0 and "rx" to the index 1. In case of robust configuration the slave device driver unfortunately needs to call acpi_dma_request_slave_chan_by_index() directly. Additionally the patch provides "managed" version of the register/free pair i.e. devm_acpi_dma_controller_register() and devm_acpi_dma_controller_free(). Usually, the driver uses only devm_acpi_dma_controller_register(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-12gpiolib-acpi: introduce acpi_get_gpio_by_index() helperMika Westerberg
Instead of open-coding ACPI GPIO resource lookup in each driver, we provide a helper function analogous to Device Tree version that allows drivers to specify which GPIO resource they are interested (using an index to the GPIO resources). The function then finds out the correct resource, translates the ACPI GPIO number to the corresponding Linux GPIO number and returns that. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-13ACPI / Documentation: refer to correct file for acpi_platform_device_ids[] tableMika Westerberg
When the ACPI platform device code was converted to the new ACPI scan handler facility, the the acpi_platform_device_ids[] was moved to drivers/acpi/acpi_platform.c. Update the documentation accordingly. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-30ACPI / scan: Introduce struct acpi_scan_handlerRafael J. Wysocki
Introduce struct acpi_scan_handler for representing objects that will do configuration tasks depending on ACPI device nodes' hardware IDs (HIDs). Currently, those tasks are done either directly by the ACPI namespace scanning code or by ACPI device drivers designed specifically for this purpose. None of the above is desirable, however, because doing that directly in the namespace scanning code makes that code overly complicated and difficult to follow and doing that in "special" device drivers leads to a great deal of confusion about their role and to confusing interactions with the driver core (for example, sysfs directories are created for those drivers, but they are completely unnecessary and only increase the kernel's memory footprint in vain). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-01-03Documentation: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from the kernel documentation. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-14Merge branch 'x86-acpi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 ACPI update from Peter Anvin: "This is a patchset which didn't make the last merge window. It adds a debugging capability to feed ACPI tables via the initramfs. On a grander scope, it formalizes using the initramfs protocol for feeding arbitrary blobs which need to be accessed early to the kernel: they are fed first in the initramfs blob (lots of bootloaders can concatenate this at boot time, others can use a single file) in an uncompressed cpio archive using filenames starting with "kernel/". The ACPI maintainers requested that this patchset be fed via the x86 tree rather than the ACPI tree as the footprint in the general x86 code is much bigger than in the ACPI code proper." * 'x86-acpi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: X86 ACPI: Use #ifdef not #if for CONFIG_X86 check ACPI: Fix build when disabled ACPI: Document ACPI table overriding via initrd ACPI: Create acpi_table_taint() function to avoid code duplication ACPI: Implement physical address table override ACPI: Store valid ACPI tables passed via early initrd in reserved memblock areas x86, acpi: Introduce x86 arch specific arch_reserve_mem_area() for e820 handling lib: Add early cpio decoder
2012-12-07ACPI: add documentation about ACPI 5 enumerationMika Westerberg
Add a document that describes how to take advantage of ACPI enumeration for buses like platform, I2C and SPI. In addition to that we document how to translate ACPI GpioIo and GpioInt resources to be useful in Linux device drivers. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-30ACPI: Document ACPI table overriding via initrdThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Link: http://lkml.kernel.org/r/1349043837-22659-7-git-send-email-trenn@suse.de Cc: Len Brown <lenb@kernel.org> Cc: Robert Moore <robert.moore@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-03-30Update documentation for parameter *notrigger* in einj.txtChen Gong
Add description of parameter notrigger in the einj.txt. One can utilize this new parameter to do some SRAR injection test. Pay attention, the operation is highly depended on the BIOS implementation. If no proper BIOS supports it, even if enabling this parameter, expected result will not happen. v2: Update the documentation suggested by Tony Suggested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi specTony Luck
ACPI 5.0 provides extensions to the EINJ mechanism to specify the target for the error injection - by APICID for cpu related errors, by address for memory related errors, and by segment/bus/device/function for PCIe related errors. Also extensions for vendor specific error injections. Tested-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03ACPI, APEI, EINJ Param support is disabled by defaultHuang Ying
EINJ parameter support is only usable for some specific BIOS. Originally, it is expected to have no harm for BIOS does not support it. But now, we found it will cause issue (memory overwriting) for some BIOS. So param support is disabled by default and only enabled when newly added module parameter named "param_extension" is explicitly specified. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Matthew Garrett <mjg@redhat.com> Acked-by: Don Zickus <dzickus@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: Split out custom_method functionality into an own driverThomas Renninger
With /sys/kernel/debug/acpi/custom_method root can write to arbitrary memory and increase his priveleges, even if these are restricted. -> Make this an own debug .config option and warn about the security issue in the config description. -> Still keep acpi/debugfs.c which now only creates an empty /sys/kernel/debug/acpi directory. There might be other users of it later. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: rui.zhang@intel.com Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-21ACPI, APEI, Add PCIe AER error information printing supportHuang Ying
The AER error information printing support is implemented in drivers/pci/pcie/aer/aer_print.c. So some string constants, functions and macros definitions can be re-used without being exported. The original PCIe AER error information printing function is not re-used directly because the overall format is quite different. And changing the original printing format may make some original users' scripts broken. Signed-off-by: Huang Ying <ying.huang@intel.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-13ACPI, APEI, Add APEI generic error status printing supportHuang Ying
In APEI, Hardware error information reported by firmware to Linux kernel is in the data structure of APEI generic error status (struct acpi_hes_generic_status). While now printk is used by Linux kernel to report hardware error information to user space. So, this patch adds printing support for the data structure, so that the corresponding hardware error information can be reported to user space via printk. PCIe AER information printing is not implemented yet. Will refactor the original PCIe AER information printing code to avoid code duplicating. The output format is as follow: <error record> := APEI generic hardware error status severity: <integer>, <severity string> section: <integer>, severity: <integer>, <severity string> flags: <integer> <section flags strings> fru_id: <uuid string> fru_text: <string> section_type: <section type string> <section data> <severity string>* := recoverable | fatal | corrected | info <section flags strings># := [primary][, containment warning][, reset][, threshold exceeded]\ [, resource not accessible][, latent error] <section type string> := generic processor error | memory error | \ PCIe error | unknown, <uuid string> <section data> := <generic processor section data> | <memory section data> | \ <pcie section data> | <null> <generic processor section data> := [processor_type: <integer>, <proc type string>] [processor_isa: <integer>, <proc isa string>] [error_type: <integer> <proc error type strings>] [operation: <integer>, <proc operation string>] [flags: <integer> <proc flags strings>] [level: <integer>] [version_info: <integer>] [processor_id: <integer>] [target_address: <integer>] [requestor_id: <integer>] [responder_id: <integer>] [IP: <integer>] <proc type string>* := IA32/X64 | IA64 <proc isa string>* := IA32 | IA64 | X64 <processor error type strings># := [cache error][, TLB error][, bus error][, micro-architectural error] <proc operation string>* := unknown or generic | data read | data write | \ instruction execution <proc flags strings># := [restartable][, precise IP][, overflow][, corrected] <memory section data> := [error_status: <integer>] [physical_address: <integer>] [physical_address_mask: <integer>] [node: <integer>] [card: <integer>] [module: <integer>] [bank: <integer>] [device: <integer>] [row: <integer>] [column: <integer>] [bit_position: <integer>] [requestor_id: <integer>] [responder_id: <integer>] [target_id: <integer>] [error_type: <integer>, <mem error type string>] <mem error type string>* := unknown | no error | single-bit ECC | multi-bit ECC | \ single-symbol chipkill ECC | multi-symbol chipkill ECC | master abort | \ target abort | parity error | watchdog timeout | invalid address | \ mirror Broken | memory sparing | scrub corrected error | \ scrub uncorrected error <pcie section data> := [port_type: <integer>, <pcie port type string>] [version: <integer>.<integer>] [command: <integer>, status: <integer>] [device_id: <integer>:<integer>:<integer>.<integer> slot: <integer> secondary_bus: <integer> vendor_id: <integer>, device_id: <integer> class_code: <integer>] [serial number: <integer>, <integer>] [bridge: secondary_status: <integer>, control: <integer>] <pcie port type string>* := PCIe end point | legacy PCI end point | \ unknown | unknown | root port | upstream switch port | \ downstream switch port | PCIe to PCI/PCI-X bridge | \ PCI/PCI-X to PCIe bridge | root complex integrated endpoint device | \ root complex event collector Where, [] designate corresponding content is optional All <field string> description with * has the following format: field: <integer>, <field string> Where value of <integer> should be the position of "string" in <field string> description. Otherwise, <field string> will be "unknown". All <field strings> description with # has the following format: field: <integer> <field strings> Where each string in <fields strings> corresponding to one set bit of <integer>. The bit position is the position of "string" in <field strings> description. For more detailed explanation of every field, please refer to UEFI specification version 2.3 or later, section Appendix N: Common Platform Error Record. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14ACPI: introduce module parameter acpi.aml_debug_outputZhang Rui
Introduce module parameter acpi.aml_debug_output. With acpi.aml_debug_output set, we can get AML debug object output (Store (AAA, Debug)), even with CONFIG_ACPI_DEBUG cleared. Together with the runtime custom method mechanism, we can debug AML code problems without rebuilding the kernel. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-19ACPI, APEI, EINJ injection parameters supportHuang Ying
Some hardware error injection needs parameters, for example, it is useful to specify memory address and memory address mask for memory errors. Some BIOSes allow parameters to be specified via an unpublished extension. This patch adds support to it. The parameters will be ignored on machines without necessary BIOS support. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-19ACPI, APEI, Document for APEIHuang Ying
Add document for APEI, including kernel parameters and EINJ debug file sytem interface. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-11ACPI: support customizing ACPI control methods at runtimeZhang Rui
Introduce a new debugfs I/F (/sys/kernel/debug/acpi/custom_method) for ACPI, which can be used to customize the ACPI control methods at runtime. We can use this to debug the AML code level bugs instead of overriding the whole DSDT table, without rebuilding/rebooting kernel any more. Detailed description about how to use this debugfs I/F is stated in Documentation/acpi/method-customizing.txt Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-07ACPI: update debug parameter documentationBjorn Helgaas
Reformat acpi.debug_layer and acpi.debug_level documentation so it's more readable, add some clues about how to figure out the mask bits that enable a specific ACPI_DEBUG_PRINT statement, and include some useful examples. Move the list of masks to Documentation/acpi/debug.txt (these are copies of the authoritative values in acoutput.h and acpi_drivers.h). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-15ACPI: Remove ACPI_CUSTOM_DSDT_INITRD optionLinus Torvalds
This essentially reverts commit 71fc47a9adf8ee89e5c96a47222915c5485ac437 ("ACPI: basic initramfs DSDT override support"), because the code simply isn't ready. It did ugly things to the init sequence to populate the rootfs image early, but that just ended up showing other problems with the whole approach. The fact is, the VFS layer simply isn't initialized this early, and the relevant ACPI code should either run much later, or this shouldn't be done at all. For 2.6.25, we'll just pick the latter option. We can revisit this concept later if necessary. Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Renninger <trenn@suse.de> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Len Brown <len.brown@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Markus Gaugusch <dsdt@gaugusch.at> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'dsdt-override' into releaseLen Brown
2008-02-07ACPI: update DSDT override documentationLen Brown
2008-02-06ACPI: basic initramfs DSDT override supportMarkus Gaugusch
The basics of DSDT from initramfs. In case this option is selected, populate_rootfs() is called a bit earlier to have the initramfs content available during ACPI initialization. This is a very similar path to the one available at http://gaugusch.at/kernel.shtml but with some update in the documentation, default set to No and the change of populate_rootfs() the "Jeff Mahony way" (which avoids reading the initramfs twice). Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-19ACPI: document method tracing hooksLen Brown
