path: root/Documentation/arm
2011-07-25Merge branch 'next/deletion' of ↵Linus Torvalds
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-loki: delete ARM: mach-s3c2400: delete ARM: mach-s3c24a0: delete
2011-07-22Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/kernel/entry-armv.S
2011-07-19ARM: 6999/1: head, zImage: Always Enter the kernel in ARM stateDave Martin
Currently, the documented kernel entry requirements are not explicit about whether the kernel should be entered in ARM or Thumb, leading to an ambiguitity about how to enter Thumb-2 kernels. As a result, the kernel is reliant on the zImage decompressor to enter the kernel proper in the correct instruction set state. This patch changes the boot entry protocol for head.S and Image to be the same as for zImage: in all cases, the kernel is now entered in ARM. Documentation/arm/Booting is updated to reflect this new policy. A different rule will be needed for Cortex-M class CPUs as and when support for those lands in mainline, since these CPUs don't support the ARM instruction set at all: a note is added to the effect that the kernel must be entered in Thumb on such systems. Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-18ARM: mach-s3c2400: deleteNicolas Pitre
On Tue, 28 Jun 2011, Ben Dooks wrote: > On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote: > > > On a related note, what about mach-s3c2400? It seems to be even more > > incomplete. > > Probably the same fate awaits that. It is so old that there's little > incentive to do anything with it. So out it goes as well. The PORT_S3C2400 definition in include/linux/serial_core.h is left there to prevent a reuse of the same number for another port type. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-29ARM: 6886/1: mmc, Add zboot from eSD support for SuperH Mobile ARMSimon Horman
This allows a ROM-able zImage to be written to eSD and for SuperH Mobile ARM to boot directly from the SDHI hardware block. This is achieved by the MaskROM loading the first portion of the image into MERAM and then jumping to it. This portion contains loader code which copies the entire image to SDRAM and jumps to it. From there the zImage boot code proceeds as normal, uncompressing the image into its final location and then jumping to it. Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-28ARM: add a kuser_cmpxchg64 user space helperNicolas Pitre
Some user space applications are designed around the ability to perform atomic operations on 64 bit values. Since this is natively possible only with ARMv6k and above, let's provide a new kuser helper to perform the operation with kernel supervision on pre ARMv6k hardware. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Dave Martin <dave.martin@linaro.org>
2011-06-20ARM: kuser: move interface documentation out of the source codeNicolas Pitre
Digging into some assembly file in order to get information about the kuser helpers is not that convivial. Let's move that information to a better formatted file in Documentation/arm/ and improve on it a bit. Thanks to Dave Martin <dave.martin@linaro.org> for the initial cleanup and clarifications. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Dave Martin <dave.martin@linaro.org>
2011-05-25Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/Kconfig arch/arm/mach-exynos4/mach-nuri.c
2011-05-23dt: add documentation of ARM dt boot interfaceGrant Likely
v6: typo fixes v5: clarified that dtb should be aligned on a 64 bit boundary in RAM. v3: added details to Documentation/arm/Booting Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-12ARM: S5P6442: Removing ARCH_S5P6442Kukjin Kim
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-16Merge branch 'remove' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'remove' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6629/2: aaec2000: remove support for mach-aaec2000 ARM: lh7a40x: remove unmaintained platform support Fix up trivial conflicts in - arch/arm/mach-{aaec2000,lh7a40x}/include/mach/memory.h (removed) - drivers/usb/gadget/Kconfig (USB_[GADGET_]LH7A40X removed, others added)
2011-01-25ARM: 6617/1: mmc, Add zboot from MMC support for SuperH Mobile ARMSimon Horman
This allows a ROM-able zImage to be written to MMC and for SuperH Mobile ARM to boot directly from the MMCIF hardware block. This is achieved by the MaskROM loading the first portion of the image into MERAM and then jumping to it. This portion contains loader code which copies the entire image to SDRAM and jumps to it. From there the zImage boot code proceeds as normal, uncompressing the image into its final location and then jumping to it. Cc: Magnus Damm <magnus.damm@gmail.com> Russell, please consider merging this for 2.6.38. This patch depends on: * "mmc, sh: Move MMCIF_PROGRESS_* into sh_mmcif.h" which will be merged though Paul Mundt's rmobile sh-2.6. The absence of this patch will break the build if the (new) CONFIG_ZBOOT_ROM_MMCIF option is set. There are no subtle side-effects. v2: Addressed comments by Magnus Damm * Fix copyright in vrl4.c * Fix use of #define CONFIG_ZBOOT_ROM_MMCIF in mmcif-sh7372.c * Initialise LED GPIO lines in head-ap4evb.txt instead of mmcif-sh7372.c as this is considered board-specific. v3: Addressed comments made in person by Magnus Damm * Move mmcif_loader to be earlier in the image and reduce the number of blocks of boot program loaded by the MaskRom from 40 to 8 accordingly. * Move LED GPIO initialisation into mmcif_progress_init - This leaves the partner jet script unbloated Other * inline mmcif_update_progress so it is a static inline in a header file v4: * Use htole16() and htole32() in v4rl.c to ensure that the output is little endian v5: Addressed comments by Russell King * Simplify assembly code * Jump to code rather than an address <- bug fix * Use (void __iomem *) as appropriate Roll in mackerel support * This was previously a separate patch, only because of the order in which this code was developed Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-24ARM: lh7a40x: remove unmaintained platform supportRussell King
lh7a40x has only been receiving updates for updates to generic code. The last involvement from the maintainer according to the git logs was in 2006. As such, it is a maintainence burden with no benefit. This gets rid of two defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (243 commits) omap2: Make OMAP2PLUS select OMAP_DM_TIMER OMAP4: hwmod data: Fix alignment and end of line in structurefields OMAP4: hwmod data: Move the DMA structures OMAP4: hwmod data: Move the smartreflex structures OMAP4: hwmod data: Fix missing SIDLE_SMART_WKUP in smartreflexsysc arm: omap: tusb6010: add name for MUSB IRQ arm: omap: craneboard: Add USB EHCI support omap2+: Initialize serial port for dynamic remuxing for n8x0 omap2+: Add struct omap_board_data and use it for platform level serial init omap2+: Allow hwmod state changes to mux pads based on the state changes omap2+: Add support for hwmod specific muxing of devices omap2+: Add omap_mux_get_by_name OMAP2: PM: fix compile error when !CONFIG_SUSPEND MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainership OMAP4: Smartreflex framework extensions OMAP4: hwmod: Add inital data for smartreflex modules. OMAP4: PM: Program correct init voltages for scalable VDDs OMAP4: Adding voltage driver support OMAP4: Register voltage PMIC parameters with the voltage layer OMAP3: PM: Program correct init voltages for VDD1 and VDD2 ... Fix up trivial conflict in arch/arm/plat-omap/Kconfig
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2010-12-21omap: opp: add OMAP3 OPP table data and common initNishanth Menon
Add OPP data for OMAP34xx and OMAP36xx and initialization functions to populate OPP tables based on current SoC. introduce an OMAP generic opp initialization routine which OMAP3 and OMAP4+ SoCs can use to register their OPP definitions. Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-11-10OMAP: DSS: Fix documentation regarding 'vram' kernel parameterTomi Valkeinen
The DSS documentation didn't mention the option to give the VRAM start address. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-04ARM: 6396/1: Add SWP/SWPB emulation for ARMv7 processorsLeif Lindholm
The SWP instruction was deprecated in the ARMv6 architecture, superseded by the LDREX/STREX family of instructions for load-linked/store-conditional operations. The ARMv7 multiprocessing extensions mandate that SWP/SWPB instructions are treated as undefined from reset, with the ability to enable them through the System Control Register SW bit. This patch adds the alternative solution to emulate the SWP and SWPB instructions using LDREX/STREX sequences, and log statistics to /proc/cpu/swp_emulation. To correctly deal with copy-on-write, it also modifies cpu_v7_set_pte_ext to change the mappings to priviliged RO when user RO. Signed-off-by: Leif Lindholm <leif.lindholm@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-06msm: documentation: add gpiomux documentation.Gregory Bean
Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-08-10Doc: Fix spellingStefan Weil
Legned -> Legend mainatined -> maintained Legend is now Lenovo, so more fixes (text and url) would be possible, too. Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-doc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-27ARM: 6225/1: make TCM allocation static and common for all archsLinus Walleij
This changes the TCM handling so that a fixed area is reserved at 0xfffe0000-0xfffeffff for TCM. This areas is used by XScale but XScale does not have TCM so the mechanisms are mutually exclusive. This change is needed to make TCM detection more dynamic while still being able to compile code into it, and is a must for the unified ARM goals: the current TCM allocation at different places in memory for each machine would be a nightmare if you want to compile a single image for more than one machine with TCM so it has to be nailed down in one place. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-28ARM: SAMSUNG: Documentation: add documentation on GPIO codeBen Dooks
Add some documentation in Documentation/arm/Samsung for the GPIO code and where to look for the necessary functions. Update the S3C24XX case as well. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: S3C24XX: Documentation: add section on gpiolib changesBen Dooks
Add section to the S3C24XX GPIO documentation on the recent changes to move towards gpiolib integration. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: S3C24XX: Documentation: update GPIO documentationBen Dooks
Upate the S3C24XX GPIO documentation after the changes for gpiolib and show which calls are being replaced by gpiolib or the new s3c generic calls. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: S3C24XX: Documentation: update documentation overviewBen Dooks
Add the two new SoCs added in this release cycle and update the notes on the gpiolib conversion. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: SAMSUNG: Documentation: update directory layoutBen Dooks
Update the directory layout in Documentation/arm/Samsung/Overview.txt to reflect the changes that have been made in the latest kernel updates. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: SAMSUNG: Documentation: update the list of SoCs supportedBen Dooks
Update the list of SoCs supported for the plat-s5p range. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-14ARM: 6018/1: ST SPEAr: Updated Maintainers and added Documentation/arm/SPEArviresh kumar
Reviewed-by: Linus Walleij <linux.walleij@stericsson.com> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-15ARM: 5930/1: Add PKMAP area description to memory.txt.Fenkart/Bostandzhyan
Also adapts delimiters of neighbouring modules area. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-19ARM: SAMSUNG: Add initial documentation directory and overviewBen Dooks
Start Documentation/arm/Samsung and add an initial overview file which whilst is not complete, is better than nothing. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-15ARM: SAMSUNG: Add script to change old clksrc_clk to new register defsBen Dooks
This script is used to change the old style clksrc_clk as originally found in plat-s3c64xx to the new style. It is here for reference if needed for future code merges. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-09OMAP: DSS2: Documentation for DSS2Tomi Valkeinen
2009-12-01ARM: S3C: Update Simtec copyright statements from , to -Ben Dooks
There are a number of statements of the form A, B or A, B, C where the numbers A,B,C are consecutive. Tidy these up to be A-B or A-C as appropriate and to comply better with copyright standards [1] [1] http://www.copyrightservice.co.uk/copyright/p03_copyright_notices section 4iii 'Year of publication' Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-01ARM: S3C: Fix Simtec copyright statements in Documentation/S3C24XXBen Dooks
The (c) alone is not a sufficient copyright statement, nor is it a good replacement for the proper encircled &copy; symbol [1]. Add the word copyright to the apropriate places and remove the (c) symbol. [1] http://www.copyrightservice.co.uk/copyright/p03_copyright_notices section 4 'What does a notice consist of?' Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-10-01ARM: 5738/1: Correct TCM documentationLinus Walleij
It turns out that the TCM memory can be remap:ed by the MMU just like any other memory. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
2009-09-22Merge branch 'master' into for-linusRussell King
2009-09-18Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (47 commits) OMAP clock: use debugfs_remove_recursive() for rewinding OMAP2/3/4 core: create omap_device layer OMAP: omap_hwmod: call omap_hwmod init at boot; create interconnects OMAP2/3/4: create omap_hwmod layer OMAP2/3 board-*.c files: read bootloader configuration earlier OMAP2/3/4 PRCM: add module IDLEST wait code OMAP2/3 PM: create the OMAP PM interface and add a default OMAP PM no-op layer OMAP3 clock: remove superfluous calls to omap2_init_clk_clkdm OMAP clock: associate MPU clocks with the mpu_clkdm OMAP3 clock: Fixed processing of bootarg 'mpurate' OMAP: SDRC: Add several new register definitions OMAP: powerdomain: Fix overflow when doing powerdomain deps lookups. OMAP: PM: Added suspend target state control to debugfs for OMAP3 OMAP: PM debug: Add PRCM register dump support OMAP: PM debug: make powerdomains use PM-debug counters OMAP: PM: Add pm-debug counters OMAP: PM: Add closures to clkdm_for_each and pwrdm_for_each. OMAP: PM: Hook into PM counters OMAP: PM counter infrastructure. OMAP3: PM: fix lockdep warning caused by omap3_pm_init ...
2009-09-15ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3Linus Walleij
This adds the TCM interface to Linux, when active, it will detect and report TCM memories and sizes early in boot if present, introduce generic TCM memory handling, provide a generic TCM memory pool and select TCM memory for the U300 platform. See the Documentation/arm/tcm.txt for documentation. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12Merge branch 'master' into develRussell King
