path: root/Documentation/block
2008-07-03block: Data integrity infrastructure documentationMartin K. Petersen
Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2007-10-16Add Documentation/block/00-INDEXRob Landley
Add Documentation/block/00-INDEX Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16Some IO scheduler cleanup in Documentation/blockAlan D. Brunelle
as-iosched.txt: o Changed IO scheduler selection text to a reference to the switching-sched.txt file. o Fixed typo: 'for up time...' -> 'for up to...' o Added short description of the est_time file. deadline-iosched.txt: o Changed IO scheduler selection text to a reference to the switching-sched.txt file. o Removed references to non-existent seek-cost and stream_unit. o Fixed typo: 'write_starved' -> 'writes_starved' switching-sched.txt: o Added in boot-time argument to set the default IO scheduler. (From as-iosched.txt) o Added in sysfs mount instructions. (From deadline-iosched.txt) Signed-off-by: Alan D. Brunelle <Alan.Brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16Update Jens Axboe's email in Documentation/*Rob Landley
Jens Axboe's old email address bounces. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10Corrections in Documentation/block/ioprio.txtDhaval Giani
The newer glibc does not allow system calls to be made via _syscallN() wrapper. They have to be made through syscall(). The ionice code used the older interface. Correcting it to use syscall. Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10Introduce rq_for_each_segment replacing rq_for_each_bioNeilBrown
Every usage of rq_for_each_bio wraps a usage of bio_for_each_segment, so these can be combined into rq_for_each_segment. We define "struct req_iterator" to hold the 'bio' and 'index' that are needed for the double iteration. Signed-off-by: Neil Brown <neilb@suse.de> Various compile fixes by me... Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10Documentation/block/barrier.txt is not in sync with the actual code: - ↵Geert Uytterhoeven
blk_queue_ordered() no longer has a gfp_mask parameter - blk_queue_ordered_locked() no longer exists - sd_prepare_flush() looks slightly different Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-23genhd: expose AN to user spaceKristen Carlson Accardi
Allow user space to determine if a disk supports Asynchronous Notification of media changes. This is done by adding a new sysfs file "capability_flags", which is documented in (insert file name). This sysfs file will export all disk capabilities flags to user space. We also define a new flag to define the media change notification capability. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-20[PATCH] block: document io scheduler allow_merge_fn hookJens Axboe
2006-12-07[PATCH] io/storage: Documentation update to as-iosched.txtFilipe
Documentation update, adding references to CFQ scheduler and to another document about selecting IO Schedulers. Signed-off-by: Filipe Lautert <filipe@icewall.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix typos in /Documentation : 'U-Z'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letters 'U-Z'. Looks like I made it through the alphabet...just in time to start over again +too! Maybe I can fit more profound fixes into the next round...? Time will +tell. :) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-20[PATCH] Document online io scheduler switchingValdis Kletnieks
We added the ability to change a block device's IO elevator scheduler both at kernel boot and on-the-fly, but we only documented the elevator= boot parameter. Add a quick how-to on doing it on the fly. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-27[PATCH] update max_sectors documentationMike Christie
The max_sectors has been split into max_hw_sectors and max_sectors for some time. A patch to have blk_queue_max_sectors enforce this was sent by me and it broke IDE. This patch updates the documentation. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-16barrier.txt got lost while the new barrier patchset was climbing upTejun Heo
the ladder to the mainline. Add it back. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-08[PATCH] block/stat.txtAndy Isaacson
I couldn't find any docs explaining the contents of /sys/block/<dev>/stat, so I wrote up the following. I'm not completely sure it's accurate - Jens, could you give a yea or nay on this? In particular, the counts of read/write IOs and read/write sectors are incremented in different places - it looks like they both increment as the request is being finished, but I'm not completely sure of that. Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[BLOCK] I/O barrier documentation updateTejun Heo
Update documentation to match new barrier implementation. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-03update the email address of Randy DunlapAdrian Bunk
This patch removes all references to the bouncing address rddunlap@osdl.org and one dead web page from the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2005-11-15[PATCH] Update location of ll_rw_blk.c in docsBen Collins
Picked from the ubuntu-2.6 tree The change in location for ll_rw_blk.c from drivers/block/ to block/ caused failure to generate documentation. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] 05/05 update biodoc to match new generic dispatch apiTejun Heo
Updates biodoc to reflect changes in elevator API Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-06-27[PATCH] CFQ io scheduler, add ioprio documentationJens Axboe
Add ioprio documentation Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
