path: root/Documentation/blockdev
2018-06-07zram: introduce zram memory trackingMinchan Kim
zRam as swap is useful for small memory device. However, swap means those pages on zram are mostly cold pages due to VM's LRU algorithm. Especially, once init data for application are touched for launching, they tend to be not accessed any more and finally swapped out. zRAM can store such cold pages as compressed form but it's pointless to keep in memory. Better idea is app developers free them directly rather than remaining them on heap. This patch tell us last access time of each block of zram via "cat /sys/kernel/debug/zram/zram0/block_state". The output is as follows, 300 75.033841 .wh 301 63.806904 s.. 302 63.806919 ..h First column is zram's block index and 3rh one represents symbol (s: same page w: written page to backing store h: huge page) of the block state. Second column represents usec time unit of the block was last accessed. So above example means the 300th block is accessed at 75.033851 second and it was huge so it was written to the backing store. Admin can leverage this information to catch cold|incompressible pages of process with *pagemap* once part of heaps are swapped out. I used the feature a few years ago to find memory hoggers in userspace to notify them what memory they have wasted without touch for a long time. With it, they could reduce unnecessary memory space. However, at that time, I hacked up zram for the feature but now I need the feature again so I decided it would be better to upstream rather than keeping it alone. I hope I submit the userspace tool to use the feature soon. [akpm@linux-foundation.org: fix i386 printk warning] [minchan@kernel.org: use ktime_get_boottime() instead of sched_clock()] Link: http://lkml.kernel.org/r/20180420063525.GA253739@rodete-desktop-imager.corp.google.com [akpm@linux-foundation.org: documentation tweak] [akpm@linux-foundation.org: fix i386 printk warning] [minchan@kernel.org: fix compile warning] Link: http://lkml.kernel.org/r/20180508104849.GA8209@rodete-desktop-imager.corp.google.com [rdunlap@infradead.org: fix printk formats] Link: http://lkml.kernel.org/r/3652ccb1-96ef-0b0b-05d1-f661d7733dcc@infradead.org Link: http://lkml.kernel.org/r/20180416090946.63057-5-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-07zram: mark incompressible page as ZRAM_HUGEMinchan Kim
Mark incompressible pages so that we could investigate who is the owner of the incompressible pages once the page is swapped out via using upcoming zram memory tracker feature. With it, we could prevent such pages to be swapped out by using mlock. Otherwise we might remove them. This patch exposes new stat for huge pages via mm_stat. Link: http://lkml.kernel.org/r/20180416090946.63057-3-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-07Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly updates of the usual suspects: lpfc, qla2xxx, hisi_sas, megaraid_sas, zfcp and a host of minor updates. The major driver change here is the elimination of the block based cciss driver in favour of the SCSI based hpsa driver (which now drives all the legacy cases cciss used to be required for). Plus a reset handler clean up and the redo of the SAS SMP handler to use bsg lib" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (279 commits) scsi: scsi-mq: Always unprepare before requeuing a request scsi: Show .retries and .jiffies_at_alloc in debugfs scsi: Improve requeuing behavior scsi: Call scsi_initialize_rq() for filesystem requests scsi: qla2xxx: Reset the logo flag, after target re-login. scsi: qla2xxx: Fix slow mem alloc behind lock scsi: qla2xxx: Clear fc4f_nvme flag scsi: qla2xxx: add missing includes for qla_isr scsi: qla2xxx: Fix an integer overflow in sysfs code scsi: aacraid: report -ENOMEM to upper layer from aac_convert_sgraw2() scsi: aacraid: get rid of one level of indentation scsi: aacraid: fix indentation errors scsi: storvsc: fix memory leak on ring buffer busy scsi: scsi_transport_sas: switch to bsg-lib for SMP passthrough scsi: smartpqi: remove the smp_handler stub scsi: hpsa: remove the smp_handler stub scsi: bsg-lib: pass the release callback through bsg_setup_queue scsi: Rework handling of scsi_device.vpd_pg8[03] scsi: Rework the code for caching Vital Product Data (VPD) scsi: rcu: Introduce rcu_swap_protected() ...
2017-09-06zram: add config and doc file for writeback featureMinchan Kim
This patch adds document and kconfig for using of writeback feature. Link: http://lkml.kernel.org/r/1498459987-24562-10-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Juneho Choi <juno.choi@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-24scsi: cciss: Drop obsolete driverHannes Reinecke
The hpsa driver now has support for all boards the cciss driver used to support, so this patch removes the cciss driver and make hpsa an alias to cciss. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Don Brace <don.brace@microsemi.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-04-14remove the mg_disk driverChristoph Hellwig
This drivers was added in 2008, but as far as a I can tell we never had a single platform that actually registered resources for the platform driver. It's also been unmaintained for a long time and apparently has a ATA mode that can be driven using the IDE/libata subsystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-02-27scripts/spelling.txt: add "followings" pattern and fix typo instancesMasahiro Yamada
Fix typos and add the following to the scripts/spelling.txt: followings||following While we are here, add a missing colon in the boilerplate in DT binding documents. The "you SoC" in allwinner,sunxi-pinctrl.txt was fixed as well. I reworded "as the followings:" to "as follows:" for drivers/usb/gadget/udc/renesas_usb3.c. Link: http://lkml.kernel.org/r/1481573103-11329-32-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24zram: extend zero pages to same element pageszhouxianrong
The idea is that without doing more calculations we extend zero pages to same element pages for zram. zero page is special case of same element page with zero element. 1. the test is done under android 7.0 2. startup too many applications circularly 3. sample the zero pages, same pages (none-zero element) and total pages in function page_zero_filled the result is listed as below: ZERO SAME TOTAL 36214 17842 598196 ZERO/TOTAL SAME/TOTAL (ZERO+SAME)/TOTAL ZERO/SAME AVERAGE 0.060631909 0.024990816 0.085622726 2.663825038 STDEV 0.00674612 0.005887625 0.009707034 2.115881328 MAX 0.069698422 0.030046087 0.094975336 7.56043956 MIN 0.03959586 0.007332205 0.056055193 1.928985507 from the above data, the benefit is about 2.5% and up to 3% of total swapout pages. The defect of the patch is that when we recovery a page from non-zero element the operations are low efficient for partial read. This patch extends zero_page to same_page so if there is any user to have monitored zero_pages, he will be surprised if the number is increased but it's not harmful, I believe. [minchan@kernel.org: do not free same element pages in zram_meta_free] Link: http://lkml.kernel.org/r/20170207065741.GA2567@bbox Link: http://lkml.kernel.org/r/1483692145-75357-1-git-send-email-zhouxianrong@huawei.com Link: http://lkml.kernel.org/r/1486307804-27903-1-git-send-email-minchan@kernel.org Signed-off-by: zhouxianrong <zhouxianrong@huawei.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22zram: remove obsolete sysfs attrsSergey Senozhatsky
We had a deprecated_attr_warn() warning for 2 years and now the time has come and we finally can do the cleanup. The plan was as follows: : per-stat sysfs attributes are considered to be deprecated. : The basic strategy is: : -- the existing RW nodes will be downgraded to WO nodes (in linux 4.11) : -- deprecated RO sysfs nodes will eventually be removed (in linux 4.11) : : The list of deprecated attributes can be found here: : Documentation/ABI/obsolete/sysfs-block-zram : : Basically, every attribute that has its own read accessible sysfs : node (e.g. num_reads) *AND* is accessible via one of the stat files : (zram<id>/stat or zram<id>/io_stat or zram<id>/mm_stat) is considered : to be deprecated. The patch also removes `obsolete/sysfs-block-zram', clean ups `testing/sysfs-block-zram' and tweaks zram.txt files. Link: http://lkml.kernel.org/r/20170118035838.11090-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-24docs: fix locations of several documents that got movedMauro Carvalho Chehab
The previous patch renamed several files that are cross-referenced along the Kernel documentation. Adjust the links to point to the right places. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-10-21Doc: cciss: Fix a typo in cciss.txtMasanari Iida
This patch fix a spelling typo in cciss.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Don Brace <don.brace@microsemi.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-07-26zram: cosmetic: cleanup documentationSergey Senozhatsky
zram documentation is a mix of different styles: spaces, tabs, tabs + spaces, etc. Clean it up. Link: http://lkml.kernel.org/r/20160531122017.2878-6-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zram: use crypto api to check alg availabilitySergey Senozhatsky
There is no way to get a string with all the crypto comp algorithms supported by the crypto comp engine, so we need to maintain our own backends list. At the same time we additionally need to use crypto_has_comp() to make sure that the user has requested a compression algorithm that is recognized by the crypto comp engine. Relying on /proc/crypto is not an options here, because it does not show not-yet-inserted compression modules. Example: modprobe zram cat /proc/crypto | grep -i lz4 modprobe lz4 cat /proc/crypto | grep -i lz4 name : lz4 driver : lz4-generic module : lz4 So the user can't tell exactly if the lz4 is really supported from /proc/crypto output, unless someone or something has loaded it. This patch also adds crypto_has_comp() to zcomp_available_show(). We store all the compression algorithms names in zcomp's `backends' array, regardless the CONFIG_CRYPTO_FOO configuration, but show only those that are also supported by crypto engine. This helps user to know the exact list of compression algorithms that can be used. Example: module lz4 is not loaded yet, but is supported by the crypto engine. /proc/crypto has no information on this module, while zram's `comp_algorithm' lists it: cat /proc/crypto | grep -i lz4 cat /sys/block/zram0/comp_algorithm [lzo] lz4 deflate lz4hc 842 We still use the `backends' array to determine if the requested compression backend is known to crypto api. This array, however, may not contain some entries, therefore as the last step we call crypto_has_comp() function which attempts to insmod the requested compression algorithm to determine if crypto api supports it. The advantage of this method is that now we permit the usage of out-of-tree crypto compression modules (implementing S/W or H/W compression). [sergey.senozhatsky@gmail.com: zram-use-crypto-api-to-check-alg-availability-v3] Link: http://lkml.kernel.org/r/20160604024902.11778-4-sergey.senozhatsky@gmail.com Link: http://lkml.kernel.org/r/20160531122017.2878-5-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20zram: introduce per-device debug_stat sysfs nodeSergey Senozhatsky
debug_stat sysfs is read-only and represents various debugging data that zram developers may need. This file is not meant to be used by anyone else: its content is not documented and will change any time w/o any notice. Therefore, the output of debug_stat file contains a version string. To avoid any confusion, we will increase the version number every time we modify the output. At the moment this file exports only one value -- the number of re-compressions, IOW, the number of times compression fast path has failed. This stat is temporary any will be useful in case if any per-cpu compression streams regressions will be reported. Link: http://lkml.kernel.org/r/20160513230834.GB26763@bbox Link: http://lkml.kernel.org/r/20160511134553.12655-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20zram: remove max_comp_streams internalsSergey Senozhatsky
Remove the internal part of max_comp_streams interface, since we switched to per-cpu streams. We will keep RW max_comp_streams attr around, because: a) we may (silently) switch back to idle compression streams list and don't want to disturb user space b) max_comp_streams attr must wait for the next 'lay off cycle'; we give user space 2 years to adjust before we remove/downgrade the attr, and there are already several attrs scheduled for removal in 4.11, so it's too late for max_comp_streams. This slightly change a user visible behaviour: - First, reading from max_comp_stream file now will always return the number of online CPUs. - Second, writing to max_comp_stream will not take any effect. Link: http://lkml.kernel.org/r/20160503165546.25201-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-14cpqarray: remove it from the kernelJens Axboe
We disabled the ability to enable this driver back in October of 2013, we should be able to safely remove it at this point. The initial goal was to remove it in 3.15, so now is the time. Signed-off-by: Jens Axboe <axboe@fb.com>
2015-09-24zram: update documentationSergey SENOZHATSKY
Several documentation changes. First, we never mentioned any errors and never required any error checks in documentation. Second, mention that there is another way to configure and manage zram devices -- zramctl, provided by util-linux. Third, add a bit of clarification on why `mem_used_max' attr is RW and correct some typos. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-09-08zsmalloc: account the number of compacted pagesSergey Senozhatsky
Compaction returns back to zram the number of migrated objects, which is quite uninformative -- we have objects of different sizes so user space cannot obtain any valuable data from that number. Change compaction to operate in terms of pages and return back to compaction issuer the number of pages that were freed during compaction. So from now on we will export more meaningful value in zram<id>/mm_stat -- the number of freed (compacted) pages. This requires: (a) a rename of `num_migrated' to 'pages_compacted' (b) a internal API change -- return first_page's fullness_group from putback_zspage(), so we know when putback_zspage() did free_zspage(). It helps us to account compaction stats correctly. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zram: add dynamic device add/remove functionalitySergey Senozhatsky
We currently don't support on-demand device creation. The one and only way to have N zram devices is to specify num_devices module parameter (default value: 1). IOW if, for some reason, at some point, user wants to have N + 1 devies he/she must umount all the existing devices, unload the module, load the module passing num_devices equals to N + 1. And do this again, if needed. This patch introduces zram control sysfs class, which has two sysfs attrs: - hot_add -- add a new zram device - hot_remove -- remove a specific (device_id) zram device hot_add sysfs attr is read-only and has only automatic device id assignment mode (as requested by Minchan Kim). read operation performed on this attr creates a new zram device and returns back its device_id or error status. Usage example: # add a new specific zram device cat /sys/class/zram-control/hot_add 2 # remove a specific zram device echo 4 > /sys/class/zram-control/hot_remove Returning zram_add() error code back to user (-ENOMEM in this case) cat /sys/class/zram-control/hot_add cat: /sys/class/zram-control/hot_add: Cannot allocate memory NOTE, there might be users who already depend on the fact that at least zram0 device gets always created by zram_init(). Preserve this behavior. [minchan@kernel.org: use zram->claim to avoid lockdep splat] Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zram: remove max_num_devices limitationSergey Senozhatsky
Limiting the number of zram devices to 32 (default max_num_devices value) is confusing, let's drop it. A user with 2TB or 4TB of RAM, for example, can request as many devices as he can handle. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zram: add `compact` sysfs entry to documentationSergey Senozhatsky
We currently don't support zram on-demand device creation. The only way to have N zram devices is to specify num_devices module parameter (default value 1). That means that if, for some reason, at some point, user wants to have N + 1 devies he/she must umount all the existing devices, unload the module, load the module passing num_devices equals to N + 1. This patchset introduces zram-control sysfs class, which has two sysfs attrs: - hot_add -- add a new zram device - hot_remove -- remove a specific (device_id) zram device Usage example: # add a new specific zram device cat /sys/class/zram-control/hot_add 1 # remove a specific zram device echo 4 > /sys/class/zram-control/hot_remove This patch (of 10): Briefly describe missing `compact` sysfs entry. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-16Merge branch 'for-4.1/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "This is the block driver pull request for 4.1. As with the core bits, this is a relatively slow round. This pull request contains: - Various fixes and cleanups for NVMe, from Alexey Khoroshilov, Chong Yuan, myself, Keith Busch, and Murali Iyer. - Documentation and code cleanups for nbd from Markus Pargmann. - Change of brd maintainer to me, from Ross Zwisler. At least the email doesn't bounce anymore then. - Two xen-blkback fixes from Tao Chen" * 'for-4.1/drivers' of git://git.kernel.dk/linux-block: (23 commits) NVMe: Meta data handling through submit io ioctl NVMe: Add translation for block limits NVMe: Remove check for null NVMe: Fix error handling of class_create("nvme") xen-blkback: define pr_fmt macro to avoid the duplication of DRV_PFX xen-blkback: enlarge the array size of blkback name nbd: Return error pointer directly nbd: Return error code directly nbd: Remove fixme that was already fixed nbd: Restructure debugging prints nbd: Fix device bytesize type nbd: Replace kthread_create with kthread_run nbd: Remove kernel internal header Documentation: nbd: Add list of module parameters Documentation: nbd: Reformat to allow more documentation NVMe: increase depth of admin queue nvme: Fix PRP list calculation for non-4k system page size NVMe: Fix blk-mq hot cpu notification NVMe: embedded iod mask cleanup NVMe: Freeze admin queue on device failure ...
2015-04-15zram: deprecate zram attrs sysfs nodesSergey Senozhatsky
Add Documentation/ABI/obsolete/sysfs-block-zram file and list obsolete and deprecated attributes there. The patch also adds additional information to zram documentation and describes the basic strategy: - the existing RW nodes will be downgraded to WO nodes (in 4.11) - deprecated RO sysfs nodes will eventually be removed (in 4.11) Users will be additionally notified about deprecated attr usage by pr_warn_once() (added to every deprecated attr _show()), as suggested by Minchan Kim. User space is advised to use zram<id>/stat, zram<id>/io_stat and zram<id>/mm_stat files. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15zram: export new 'mm_stat' sysfs attrsSergey Senozhatsky
Per-device `zram<id>/mm_stat' file provides mm statistics of a particular zram device in a format similar to block layer statistics. The file consists of a single line and represents the following stats (separated by whitespace): orig_data_size compr_data_size mem_used_total mem_limit mem_used_max zero_pages num_migrated Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15zram: export new 'io_stat' sysfs attrsSergey Senozhatsky
Per-device `zram<id>/io_stat' file provides accumulated I/O statistics of particular zram device in a format similar to block layer statistics. The file consists of a single line and represents the following stats (separated by whitespace): failed_reads failed_writes invalid_io notify_free Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15zram: describe device attrs in documentationSergey Senozhatsky
Briefly describe exported device stat attrs in zram documentation. We will eventually get rid of per-stat sysfs nodes and, thus, clean up Documentation/ABI/testing/sysfs-block-zram file, which is the only source of information about device sysfs nodes. Add `num_migrated' description, since there is no independent `num_migrated' sysfs node (and no corresponding sysfs-block-zram entry), it will be exported via zram<id>/mm_stat file. At this point we can provide minimal description, because sysfs-block-zram still contains detailed information. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-02Documentation: nbd: Add list of module parametersMarkus Pargmann
Add a list of available module parameters as attachment to the documentation. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-02Documentation: nbd: Reformat to allow more documentationMarkus Pargmann
Reformat the existing documentation to have more structure. This allows for more documentation seperated from the existing paragraphs. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-09zram: report maximum used memoryMinchan Kim
Normally, zram user could get maximum memory usage zram consumed via polling mem_used_total with sysfs in userspace. But it has a critical problem because user can miss peak memory usage during update inverval of polling. For avoiding that, user should poll it with shorter interval(ie, 0.0000000001s) with mlocking to avoid page fault delay when memory pressure is heavy. It would be troublesome. This patch adds new knob "mem_used_max" so user could see the maximum memory usage easily via reading the knob and reset it via "echo 0 > /sys/block/zram0/mem_used_max". Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Dan Streetman <ddstreet@ieee.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: <juno.choi@lge.com> Cc: <seungho1.park@lge.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Seth Jennings <sjennings@variantweb.net> Reviewed-by: David Horner <ds2horner@gmail.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09zram: zram memory size limitationMinchan Kim
Since zram has no control feature to limit memory usage, it makes hard to manage system memrory. This patch adds new knob "mem_limit" via sysfs to set up the a limit so that zram could fail allocation once it reaches the limit. In addition, user could change the limit in runtime so that he could manage the memory more dynamically. Initial state is no limit so it doesn't break old behavior. [akpm@linux-foundation.org: fix typo, per Sergey] Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: <juno.choi@lge.com> Cc: <seungho1.park@lge.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Seth Jennings <sjennings@variantweb.net> Cc: David Horner <ds2horner@gmail.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07zram: propagate error to userMinchan Kim
When we initialized zcomp with single, we couldn't change max_comp_streams without zram reset but current interface doesn't show any error to user and even it changes max_comp_streams's value without any effect so it would make user very confusing. This patch prevents max_comp_streams's change when zcomp was initialized as single zcomp and emit the error to user(ex, echo). [akpm@linux-foundation.org: don't return with the lock held, per Sergey] [fengguang.wu@intel.com: fix coccinelle warnings] Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchan@redhat.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07zram: make compression algorithm selection possibleSergey Senozhatsky
Add and document `comp_algorithm' device attribute. This attribute allows to show supported compression and currently selected compression algorithms: cat /sys/block/zram0/comp_algorithm [lzo] lz4 and change selected compression algorithm: echo lzo > /sys/block/zram0/comp_algorithm Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07zram: add multi stream functionalitySergey Senozhatsky
Existing zram (zcomp) implementation has only one compression stream (buffer and algorithm private part), so in order to prevent data corruption only one write (compress operation) can use this compression stream, forcing all concurrent write operations to wait for stream lock to be released. This patch changes zcomp to keep a compression streams list of user-defined size (via sysfs device attr). Each write operation still exclusively holds compression stream, the difference is that we can have N write operations (depending on size of streams list) executing in parallel. See TEST section later in commit message for performance data. Introduce struct zcomp_strm_multi and a set of functions to manage zcomp_strm stream access. zcomp_strm_multi has a list of idle zcomp_strm structs, spinlock to protect idle list and wait queue, making it possible to perform parallel compressions. The following set of functions added: - zcomp_strm_multi_find()/zcomp_strm_multi_release() find and release a compression stream, implement required locking - zcomp_strm_multi_create()/zcomp_strm_multi_destroy() create and destroy zcomp_strm_multi zcomp ->strm_find() and ->strm_release() callbacks are set during initialisation to zcomp_strm_multi_find()/zcomp_strm_multi_release() correspondingly. Each time zcomp issues a zcomp_strm_multi_find() call, the following set of operations performed: - spin lock strm_lock - if idle list is not empty, remove zcomp_strm from idle list, spin unlock and return zcomp stream pointer to caller - if idle list is empty, current adds itself to wait queue. it will be awaken by zcomp_strm_multi_release() caller. zcomp_strm_multi_release(): - spin lock strm_lock - add zcomp stream to idle list - spin unlock, wake up sleeper Minchan Kim reported that spinlock-based locking scheme has demonstrated a severe perfomance regression for single compression stream case, comparing to mutex-based (see https://lkml.org/lkml/2014/2/18/16) base spinlock mutex ==Initial write ==Initial write ==Initial write records: 5 records: 5 records: 5 avg: 1642424.35 avg: 699610.40 avg: 1655583.71 std: 39890.95(2.43%) std: 232014.19(33.16%) std: 52293.96 max: 1690170.94 max: 1163473.45 max: 1697164.75 min: 1568669.52 min: 573429.88 min: 1553410.23 ==Rewrite ==Rewrite ==Rewrite records: 5 records: 5 records: 5 avg: 1611775.39 avg: 501406.64 avg: 1684419.11 std: 17144.58(1.06%) std: 15354.41(3.06%) std: 18367.42 max: 1641800.95 max: 531356.78 max: 1706445.84 min: 1593515.27 min: 488817.78 min: 1655335.73 When only one compression stream available, mutex with spin on owner tends to perform much better than frequent wait_event()/wake_up(). This is why single stream implemented as a special case with mutex locking. Introduce and document zram device attribute max_comp_streams. This attr shows and stores current zcomp's max number of zcomp streams (max_strm). Extend zcomp's zcomp_create() with `max_strm' parameter. `max_strm' limits the number of zcomp_strm structs in compression backend's idle list (max_comp_streams). max_comp_streams used during initialisation as follows: -- passing to zcomp_create() max_strm equals to 1 will initialise zcomp using single compression stream zcomp_strm_single (mutex-based locking). -- passing to zcomp_create() max_strm greater than 1 will initialise zcomp using multi compression stream zcomp_strm_multi (spinlock-based locking). default max_comp_streams value is 1, meaning that zram with single stream will be initialised. Later patch will introduce configuration knob to change max_comp_streams on already initialised and used zcomp. TEST iozone -t 3 -R -r 16K -s 60M -I +Z test base 1 strm (mutex) 3 strm (spinlock) ----------------------------------------------------------------------- Initial write 589286.78 583518.39 718011.05 Rewrite 604837.97 596776.38 1515125.72 Random write 584120.11 595714.58 1388850.25 Pwrite 535731.17 541117.38 739295.27 Fwrite 1418083.88 1478612.72 1484927.06 Usage example: set max_comp_streams to 4 echo 4 > /sys/block/zram0/max_comp_streams show current max_comp_streams (default value is 1). cat /sys/block/zram0/max_comp_streams Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07zram: document failed_reads, failed_writes statsSergey Senozhatsky
Document `failed_reads' and `failed_writes' device attributes. Remove info about `discard' - there is no such zram attr. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07zram: move zram size warning to documentationSergey Senozhatsky
Move zram warning about disksize and size of memory correlation to zram documentation. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-17drbd: Describe the future high-level structure of DRBDAndreas Gruenbacher
The following commits will successively transform DRBD into the structure described here. Signed-off-by: Andreas Gruenbacher <agruen@linbit.com> Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
2014-01-30zram: remove old private project commentMinchan Kim
Remove the old private compcache project address so upcoming patches should be sent to LKML because we Linux kernel community will take care. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: promote zram from stagingMinchan Kim
Zram has lived in staging for a LONG LONG time and have been fixed/improved by many contributors so code is clean and stable now. Of course, there are lots of product using zram in real practice. The major TV companys have used zram as swap since two years ago and recently our production team released android smart phone with zram which is used as swap, too and recently Android Kitkat start to use zram for small memory smart phone. And there was a report Google released their ChromeOS with zram, too and cyanogenmod have been used zram long time ago. And I heard some disto have used zram block device for tmpfs. In addition, I saw many report from many other peoples. For example, Lubuntu start to use it. The benefit of zram is very clear. With my experience, one of the benefit was to remove jitter of video application with backgroud memory pressure. It would be effect of efficient memory usage by compression but more issue is whether swap is there or not in the system. Recent mobile platforms have used JAVA so there are many anonymous pages. But embedded system normally are reluctant to use eMMC or SDCard as swap because there is wear-leveling and latency issues so if we do not use swap, it means we can't reclaim anoymous pages and at last, we could encounter OOM kill. :( Although we have real storage as swap, it was a problem, too. Because it sometime ends up making system very unresponsible caused by slow swap storage performance. Quote from Luigi on Google "Since Chrome OS was mentioned: the main reason why we don't use swap to a disk (rotating or SSD) is because it doesn't degrade gracefully and leads to a bad interactive experience. Generally we prefer to manage RAM at a higher level, by transparently killing and restarting processes. But we noticed that zram is fast enough to be competitive with the latter, and it lets us make more efficient use of the available RAM. " and he announced. http://www.spinics.net/lists/linux-mm/msg57717.html Other uses case is to use zram for block device. Zram is block device so anyone can format the block device and mount on it so some guys on the internet start zram as /var/tmp. http://forums.gentoo.org/viewtopic-t-838198-start-0.html Let's promote zram and enhance/maintain it instead of removing. Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/blockdev/ramdisk.txt: updatesFabian Frederick
- ramdisk_blocksize doesn't exist anymore - Module parameters added to documentation Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-08floppy: Correct documentation of driver options when used as a module.Ben Harris
The options have to be passed space-separated and prefixed by "floppy=", rather than separately and unprefixed. This fixes <http://bugs.debian.org/726655>. Signed-off-by: Ben Harris <bjh21@cam.ac.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-27nbd: update documentation and link to mailinglistWouter Verhelst
Documentation/blockdev/nbd.txt contained some documentation which was horribly outdated and probably still dates from the original patch that added NBD support to the kernel. This patch removes the useless and outdated bits. The tools on nbd.sf.net are fully documented in manpages, which is where documentation for the non-kernel bits should live. Additionally, add a reference to the MAINTAINERS file for the nbd-general mailinglist that is used for discussion of the userland tools and the kernel module already. Signed-off-by: Wouter Verhelst <w@uter.be> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-16cciss: auto engage SCSI mid layer at driver load timeStephen M. Cameron
A long time ago, probably in 2002, one of the distros, or maybe more than one, loaded block drivers prior to loading the SCSI mid layer. This meant that the cciss driver, being a block driver, could not engage the SCSI mid layer at init time without panicking, and relied on being poked by a userland program after the system was up (and the SCSI mid layer was therefore present) to engage the SCSI mid layer. This is no longer the case, and cciss can safely rely on the SCSI mid layer being present at init time and engage the SCSI mid layer straight away. This means that users will see their tape drives and medium changers at driver load time without need for a script in /etc/rc.d that does this: for x in /proc/driver/cciss/cciss* do echo "engage scsi" > $x done However, if no tape drives or medium changers are detected, the SCSI mid layer will not be engaged. If a tape drive or medium change is later hot-added to the system it will then be necessary to use the above script or similar for the device(s) to be acceesible. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-08cciss: Adds simple mode functionalityJoseph Handzik
Signed-off-by: Joseph Handzik <joseph.t.handzik@beardog.cce.hp.com> Acked-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-13doc: fix wrong arch/i386 referencesWanlong Gao
Change all "arch/i386" to "arch/x86" in Documentaion/, since the directory has changed. Also update the files which have changed their filename in the meantime accordingly. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> [jkosina@suse.cz: reword changelog] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-06cciss: add cciss_tape_cmds module paramterStephen M. Cameron
This is to allow number of commands reserved for use by SCSI tape drives and medium changers to be adjusted at driver load time via the kernel parameter cciss_tape_cmds, with a default value of 6, and a range of 2 - 16 inclusive. Previously, the driver limited the number of commands which could be queued to the SCSI half of the the driver to only 2. This is to fix the problem that if you had more than two tape drives, you couldn't, for example, erase or rewind them all at the same time. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-01The DRBD driverPhilipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2009-04-07mflash: initial supportunsik Kim
This driver supports mflash IO mode for linux. Mflash is embedded flash drive and mainly targeted mobile and consumer electronic devices. Internally, mflash has nand flash and other hardware logics and supports 2 different operation (ATA, IO) modes. ATA mode doesn't need any new driver and currently works well under standard IDE subsystem. Actually it's one chip SSD. IO mode is ATA-like custom mode for the host that doesn't have IDE interface. Followings are brief descriptions about IO mode. A. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) B. IO mode uses SRAM bus interface. C. IO mode supports 4kB boot area, so host can boot from mflash. This driver is quitely similar to a standard ATA driver, but because of following reasons it is currently seperated with ATA layer. 1. ATA layer deals standard ATA protocol. ATA layer have many low- level device specific interface, but data transfer keeps ATA rule. But, mflash IO mode doesn't. 2. Even though currently not used in mflash driver code, mflash has some custom command and modes. (nand fusing, firmware patch, etc) If this feature supported in linux kernel, ATA layer more altered. 3. Currently PATA platform device driver doesn't support interrupt. (I'm not sure) But, mflash uses interrupt (polling mode is just for debug). 4. mflash is somewhat under-develop product. Even though some company already using mflash their own product, I think more time is needed for standardization of custom command and mode. That time (maybe October) I will talk to with ATA people. If they accept integration, I will integrate. Signed-off-by: unsik Kim <donari75@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
