path: root/Documentation/cciss.txt
2007-05-08Documentation: cciss: detecting failed drivesStephen M. Cameron
Document how to detect drive failures for cciss Signed-off-by: Stephen M. Cameron <steve.cameron@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-13[PATCH] cciss: version update, new hwMike Miller
Add support for new hardware and bumps the version to 3.6.10. It seems there were several changes introduced including soft_irq. I decided to bump the major number to reflect these changes. Since we're still supporting older vendor kernels I need some way differentiate between kernel versions <=2.6.10 and newer kernels >=2.6.16. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06[SCSI] cciss: scsi error handlingmike.miller@hp.com
This patch adds SCSI error handling code to the SCSI portion of the cciss driver. Signed-off-by: Stephen M. Cameron <steve.cameron@hp.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-13[PATCH] cciss: new controller pci/subsystem idsMike Miller
This patch adds new PCI and subsystem ID's that finally made the spec. It also include a name change for one controller. I know there's a lot of duplicat names but the fw folks wanted this for the different implementations. Even though the same ASIC is used it may be embedded on some platforms, standup card in others, and a mezzanine in other servers. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] cciss: pci id fixMike Miller
This patch fixes a PCI ID I got wrong before. It also adds support for another new SAS controller due out this summer. I didn't have a marketing name prior to my last submission. Also modifies the copyright date range. Signed-off-by: Mike Miller <mike.miller@hp.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
