path: root/Documentation/cgroups
2010-05-27memcg: update documentationKAMEZAWA Hiroyuki
Some information are old, and I think current document doesn't work as "a guide for users". We need summary of all of our controls, at least. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: move charge of file pagesDaisuke Nishimura
This patch adds support for moving charge of file pages, which include normal file, tmpfs file and swaps of tmpfs file. It's enabled by setting bit 1 of <target cgroup>/memory.move_charge_at_immigrate. Unlike the case of anonymous pages, file pages(and swaps) in the range mmapped by the task will be moved even if the task hasn't done page fault, i.e. they might not be the task's "RSS", but other task's "RSS" that maps the same file. And mapcount of the page is ignored(the page can be moved even if page_mapcount(page) > 1). So, conditions that the page/swap should be met to be moved is that it must be in the range mmapped by the target task and it must be charged to the old cgroup. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix warning] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: oom kill disable and oom statusKAMEZAWA Hiroyuki
This adds a feature to disable oom-killer for memcg, if disabled, of course, tasks under memcg will stop. But now, we have oom-notifier for memcg. And the world around memcg is not under out-of-memory. memcg's out-of-memory just shows memcg hits limit. Then, administrator or management daemon can recover the situation by - kill some process - enlarge limit, add more swap. - migrate some tasks - remove file cache on tmps (difficult ?) Unlike oom-killer, you can take enough information before killing tasks. (by gcore, or, ps etc.) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: oom notifierKAMEZAWA Hiroyuki
Considering containers or other resource management softwares in userland, event notification of OOM in memcg should be implemented. Now, memcg has "threshold" notifier which uses eventfd, we can make use of it for oom notification. This patch adds oom notification eventfd callback for memcg. The usage is very similar to threshold notifier, but control file is memory.oom_control and no arguments other than eventfd is required. % cgroup_event_notifier /cgroup/A/memory.oom_control dummy (About cgroup_event_notifier, see Documentation/cgroup/) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27Documentation/cgroups/cgroups.txt: fix reference to "numtasks"Trevor Woerner
Signed-off-by: Trevor Woerner <twoerner@gmail.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-04-29Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/block_dev.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blk-cgroup: config options re-arrangementVivek Goyal
This patch fixes few usability and configurability issues. o All the cgroup based controller options are configurable from "Genral Setup/Control Group Support/" menu. blkio is the only exception. Hence make this option visible in above menu and make it configurable from there to bring it inline with rest of the cgroup based controllers. o Get rid of CONFIG_DEBUG_CFQ_IOSCHED. This option currently does two things. - Enable printing of cgroup paths in blktrace - Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat files in cgroup. If we are using group scheduling, blktrace data is of not really much use if cgroup information is not present. To get this data, currently one has to also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of all the additional debug stat files which is not desired. Hence, this patch moves printing of cgroup paths under CONFIG_CFQ_GROUP_IOSCHED. This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which can be enabled through config menu. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-24cgroups: fix procs documentationKAMEZAWA Hiroyuki
Writing to cgroup.procs is not supported now. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ben Blum <bblum@andrew.cmu.edu> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-13io-controller: Document for blkio.weight_deviceGui Jianfeng
Here is the document for blkio.weight_device Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add more debug-only per-cgroup statsDivyesh Shah
1) group_wait_time - This is the amount of time the cgroup had to wait to get a timeslice for one of its queues from when it became busy, i.e., went from 0 to 1 request queued. This is different from the io_wait_time which is the cumulative total of the amount of time spent by each IO in that cgroup waiting in the scheduler queue. This stat is a great way to find out any jobs in the fleet that are being starved or waiting for longer than what is expected (due to an IO controller bug or any other issue). 2) empty_time - This is the amount of time a cgroup spends w/o any pending requests. This stat is useful when a job does not seem to be able to use its assigned disk share by helping check if that is happening due to an IO controller bug or because the job is not submitting enough IOs. 3) idle_time - This is the amount of time spent by the IO scheduler idling for a given cgroup in anticipation of a better request than the exising ones from other queues/cgroups. All these stats are recorded using start and stop events. When reading these stats, we do not add the delta between the current time and the last start time if we're between the start and stop events. We avoid doing this to make sure that these numbers are always monotonically increasing when read. Since we're using sched_clock() which may use the tsc as its source, it may induce some inconsistency (due to tsc resync across cpus) if we included the current delta. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_queued and avg_queue_size statsDivyesh Shah
These stats are useful for getting a feel for the queue depth of the cgroup, i.e., how filled up its queues are at a given instant and over the existence of the cgroup. This ability is useful when debugging problems in the wild as it helps understand the application's IO pattern w/o having to read through the userspace code (coz its tedious or just not available) or w/o the ability to run blktrace (since you may not have root access and/or not want to disturb performance). Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_merged statDivyesh Shah
This includes both the number of bios merged into requests belonging to this cgroup as well as the number of requests merged together. In the past, we've observed different merging behavior across upstream kernels, some by design some actual bugs. This stat helps a lot in debugging such problems when applications report decreased throughput with a new kernel version. This needed adding an extra elevator function to capture bios being merged as I did not want to pollute elevator code with blkiocg knowledge and hence needed the accounting invocation to come from CFQ. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Changes to IO controller additional stats patchesDivyesh Shah
that include some minor fixes and addresses all comments. Changelog: (most based on Vivek Goyal's comments) o renamed blkiocg_reset_write to blkiocg_reset_stats o more clarification in the documentation on io_service_time and io_wait_time o Initialize blkg->stats_lock o rename io_add_stat to blkio_add_stat and declare it static o use bool for direction and sync o derive direction and sync info from existing rq methods o use 12 for major:minor string length o define io_service_time better to cover the NCQ case o add a separate reset_stats interface o make the indexed stats a 2d array to simplify macro and function pointer code o blkio.time now exports in jiffies as before o Added stats description in patch description and Documentation/cgroup/blkio-controller.txt o Prefix all stats functions with blkio and make them static as applicable o replace IO_TYPE_MAX with IO_TYPE_TOTAL o Moved #define constant to top of blk-cgroup.c o Pass dev_t around instead of char * o Add note to documentation file about resetting stats o use BLK_CGROUP_MODULE in addition to BLK_CGROUP config option in #ifdef statements o Avoid struct request specific knowledge in blk-cgroup. blk-cgroup.h now has rq_direction() and rq_sync() functions which are used by CFQ and when using io-controller at a higher level, bio_* functions can be added. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-25cpuset: Fix documentation punctuationGreg Thelen
Fix cpusets.txt documentation punctuation. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-24memcg: fix typo in memcg documentationGreg Thelen
Update memory.txt to be more consistent: s/swapiness/swappiness/ Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-19memcg: fix typo in memcg documentationGreg Thelen
Updated memory.txt to be more consistent: s/swapiness/swappiness/ Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-16Fix typos in commentsThomas Weber
[Ss]ytem => [Ss]ystem udpate => update paramters => parameters orginal => original Signed-off-by: Thomas Weber <swirl@gmx.li> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12memcg: fix typos in memcg_test.txtKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: update memcg_test.txt to describe memory thresholdsKirill A. Shutemov
Decription of sanity check for memory thresholds. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: add simple listener of cgroup events to documentationKirill A. Shutemov
An example of cgroup notification API usage. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: handle panic_on_oom=always caseKAMEZAWA Hiroyuki
Presently, if panic_on_oom=2, the whole system panics even if the oom happend in some special situation (as cpuset, mempolicy....). Then, panic_on_oom=2 means painc_on_oom_always. Now, memcg doesn't check panic_on_oom flag. This patch adds a check. BTW, how it's useful ? kdump+panic_on_oom=2 is the last tool to investigate what happens in oom-ed system. When a task is killed, the sysytem recovers and there will be few hint to know what happnes. In mission critical system, oom should never happen. Then, panic_on_oom=2+kdump is useful to avoid next OOM by knowing precise information via snapshot. TODO: - For memcg, it's for isolate system's memory usage, oom-notiifer and freeze_at_oom (or rest_at_oom) should be implemented. Then, management daemon can do similar jobs (as kdump) or taking snapshot per cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: update memcg_test.txtDaisuke Nishimura
Update memcg_test.txt to describe how to test the move-charge feature. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: implement memory thresholdsKirill A. Shutemov
It allows to register multiple memory and memsw thresholds and gets notifications when it crosses. To register a threshold application need: - create an eventfd; - open memory.usage_in_bytes or memory.memsw.usage_in_bytes; - write string like "<event_fd> <memory.usage_in_bytes> <threshold>" to cgroup.event_control. Application will be notified through eventfd when memory usage crosses threshold in any direction. It's applicable for root and non-root cgroup. It uses stats to track memory usage, simmilar to soft limits. It checks if we need to send event to userspace on every 100 page in/out. I guess it's good compromise between performance and accuracy of thresholds. [akpm@linux-foundation.org: coding-style fixes] [nishimura@mxp.nes.nec.co.jp: fix documentation merge issue] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: implement eventfd-based generic API for notificationsKirill A. Shutemov
This patchset introduces eventfd-based API for notifications in cgroups and implements memory notifications on top of it. It uses statistics in memory controler to track memory usage. Output of time(1) on building kernel on tmpfs: Root cgroup before changes: make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total Non-root cgroup before changes: make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total Root cgroup after changes (0 thresholds): make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total Non-root cgroup after changes (0 thresholds): make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total Root cgroup after changes (1 thresholds, never crossed): make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total Non-root cgroup after changes (1 thresholds, never crossed): make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total This patch: Introduce the write-only file "cgroup.event_control" in every cgroup. To register new notification handler you need: - create an eventfd; - open a control file to be monitored. Callbacks register_event() and unregister_event() must be defined for the control file; - write "<event_fd> <control_fd> <args>" to cgroup.event_control. Interpretation of args is defined by control file implementation; eventfd will be woken up by control file implementation or when the cgroup is removed. To unregister notification handler just close eventfd. If you need notification functionality for a control file you have to implement callbacks register_event() and unregister_event() in the struct cftype. [kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: move charges of anonymous swapDaisuke Nishimura
This patch is another core part of this move-charge-at-task-migration feature. It enables moving charges of anonymous swaps. To move the charge of swap, we need to exchange swap_cgroup's record. In current implementation, swap_cgroup's record is protected by: - page lock: if the entry is on swap cache. - swap_lock: if the entry is not on swap cache. This works well in usual swap-in/out activity. But this behavior make the feature of moving swap charge check many conditions to exchange swap_cgroup's record safely. So I changed modification of swap_cgroup's recored(swap_cgroup_record()) to use xchg, and define a new function to cmpxchg swap_cgroup's record. This patch also enables moving charge of non pte_present but not uncharged swap caches, which can be exist on swap-out path, by getting the target pages via find_get_page() as do_mincore() does. [kosaki.motohiro@jp.fujitsu.com: fix ia64 build] [akpm@linux-foundation.org: fix typos] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: add interface to move charge at task migrationDaisuke Nishimura
In current memcg, charges associated with a task aren't moved to the new cgroup at task migration. Some users feel this behavior to be strange. These patches are for this feature, that is, for charging to the new cgroup and, of course, uncharging from the old cgroup at task migration. This patch adds "memory.move_charge_at_immigrate" file, which is a flag file to determine whether charges should be moved to the new cgroup at task migration or not and what type of charges should be moved. This patch also adds read and write handlers of the file. This patch also adds no-op handlers for this feature. These handlers will be implemented in later patches. And you cannot write any values other than 0 to move_charge_at_immigrate yet. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: fix CONTENTS in cgroups documentationKirill A. Shutemov
Add a forgotten item into CONTENTS. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module unloadingBen Blum
Provides support for unloading modular subsystems. This patch adds a new function cgroup_unload_subsys which is to be used for removing a loaded subsystem during module deletion. Reference counting of the subsystems' modules is moved from once (at load time) to once per attached hierarchy (in parse_cgroupfs_options and rebind_subsystems) (i.e., 0 or 1). Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module loading interfaceBen Blum
Add interface between cgroups subsystem management and module loading This patch implements rudimentary module-loading support for cgroups - namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a module initcall, and a struct module pointer in struct cgroup_subsys. Several functions that might be wanted by modules have had EXPORT_SYMBOL added to them, but it's unclear exactly which functions want it and which won't. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: introduce cancel_attach()Daisuke Nishimura
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach() can be used when can_attach() operation prepares something for the subsys, but we should rollback what can_attach() operation has prepared if attach task fails after we've succeeded in can_attach(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-24doc: cpuset: Update the cpuset flag fileGeunSik Lim
This patch is for modifying with correct cuset flag file. We need to update current manual for cpuset. For example, before) cpus, cpu_exclusive, mems after ) cpuset.cpus, cpuset.cpu_exclusive, cpuset.mems Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03blkio: DocumentationVivek Goyal
Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-08cgroups: update documentation of cgroups tasks and procs filesPaul Menage
Update documentation of cgroups tasks and procs files Document the cgroup.procs file. Clarify the semantics of the cgroup.procs and tasks files. Although the current cgroup.procs interface returns a sorted and uniqified list of pids, potential future performance enhancements could result in those properties being removed - explicitly document this aspect of the API. There are no existing users of cgroup.procs, so compatibility isn't an issue. There are users of the "tasks" file, but none that would appear to break in the event of the sorted property being broken. The standard "libcpuset" explicitly sorts the results of reading from the tasks file, and "libcg" and other users don't appear to care about ordering. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24memory controller: soft limit documentationBalbir Singh
Soft limits is a new feature for the memory resource controller, something similar has existed in the group scheduler in the form of shares. The CPU controllers interpretation of shares is very different though. Soft limits are the most useful feature to have for environments where the administrator wants to overcommit the system, such that only on memory contention do the limits become active. The current soft limits implementation provides a soft_limit_in_bytes interface for the memory controller and not for memory+swap controller. The implementation maintains an RB-Tree of groups that exceed their soft limit and starts reclaiming from the group that exceeds this limit by the maximum amount. This patch: Add documentation for soft limits Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24memcg: remove the overhead associated with the root cgroupBalbir Singh
Change the memory cgroup to remove the overhead associated with accounting all pages in the root cgroup. As a side-effect, we can no longer set a memory hard limit in the root cgroup. A new flag to track whether the page has been accounted or not has been added as well. Flags are now set atomically for page_cgroup, pcg_default_flags is now obsolete and removed. [akpm@linux-foundation.org: fix a few documentation glitches] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: let ss->can_attach and ss->attach do whole threadgroups at a timeBen Blum
Alter the ss->can_attach and ss->attach functions to be able to deal with a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a pre-patch to cgroup-procs-writable.patch.) Currently, new mode of the attach function can only tell the subsystem about the old cgroup of the threadgroup leader. No subsystem currently needs that information for each thread that's being moved, but if one were to be added (for example, one that counts tasks within a group) this bit would need to be reworked a bit to tell the subsystem the right information. [hidave.darkstar@gmail.com: fix build] Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: support named cgroups hierarchiesPaul Menage
To simplify referring to cgroup hierarchies in mount statements, and to allow disambiguation in the presence of empty hierarchies and multiply-bindable subsystems this patch adds support for naming a new cgroup hierarchy via the "name=" mount option A pre-existing hierarchy may be specified by either name or by subsystems; a hierarchy's name cannot be changed by a remount operation. Example usage: # To create a hierarchy called "foo" containing the "cpu" subsystem mount -t cgroup -oname=foo,cpu cgroup /mnt/cgroup1 # To mount the "foo" hierarchy on a second location mount -t cgroup -oname=foo cgroup /mnt/cgroup2 Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30cpusets: document adding/removing cpus to cpuset elaboratelyNikanth Karthikesan
By writing a tasks's pid to the file, a process adds that task to that cgroup/cpuset. But to add a cpu/mem to a cpuset, the new list of cpus should be written to the cpuset.mems file which would replace the old list of cpus. Make this clearer in the documentation. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: add interface to reset limitsDaisuke Nishimura
We don't have an interface to reset mem.limit or memsw.limit now. This patch allows to reset mem.limit or memsw.limit when they are being set to -1. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: fix behavior under memory.limit equals to memsw.limitKAMEZAWA Hiroyuki
A user can set memcg.limit_in_bytes == memcg.memsw.limit_in_bytes when the user just want to limit the total size of applications, in other words, not very interested in memory usage itself. In this case, swap-out will be done only by global-LRU. But, under current implementation, memory.limit_in_bytes is checked at first and try_to_free_page() may do swap-out. But, that swap-out is useless for memsw.limit_in_bytes and the thread may hit limit again. This patch tries to fix the current behavior at memory.limit == memsw.limit case. And documentation is updated to explain the behavior of this special case. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13memcg: fix documentationBharata B Rao
The description about various statistics from memory.stat is not accurate and confusing at times. Correct this along with a few other minor cleanups. Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13res_counter: update documentationAndrea Righi
After the introduction of resource counters hierarchies (28dbc4b6a01fb579a9441c7b81e3d3413dc452df) the prototypes of res_counter_init() and res_counter_charge() have been changed. Keep the documentation consistent with the actual function prototypes. Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08Merge commit 'v2.6.30-rc1' into sched/urgentIngo Molnar
Merge reason: update to latest upstream to queue up fix Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-02memcg: fix OOM killer under memcgKAMEZAWA Hiroyuki
This patch tries to fix OOM Killer problems caused by hierarchy. Now, memcg itself has OOM KILL function (in oom_kill.c) and tries to kill a task in memcg. But, when hierarchy is used, it's broken and correct task cannot be killed. For example, in following cgroup /groupA/ hierarchy=1, limit=1G, 01 nolimit 02 nolimit All tasks' memory usage under /groupA, /groupA/01, groupA/02 is limited to groupA's 1Gbytes but OOM Killer just kills tasks in groupA. This patch provides makes the bad process be selected from all tasks under hierarchy. BTW, currently, oom_jiffies is updated against groupA in above case. oom_jiffies of tree should be updated. To see how oom_jiffies is used, please check mem_cgroup_oom_called() callers. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: const fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: more documentation for remount and release_agentLi Zefan
This won't remove cpuacct from the mounted hierachy: # mount -t cgroup -o cpu,cpuacct xxx /mnt # mount -o remount,cpu /mnt Because for this usage mount(8) will append the new options to the original options. And this will get you right: # mount [-t cgroup] -o remount,cpu xxx /mnt Also document how to specify or change release_agent. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
