Platform must register cpu power function that return power in
milliWatt seconds.
Change-Id: I1caa0335e316c352eee3b1ddf326fcd4942bcbe8
Signed-off-by: Mike Chan <mike@android.com>
Introduce new platform callback hooks for cpuacct for tracking CPU frequencies
Not all platforms / architectures have a set CPU_FREQ_TABLE defined
for CPU transition speeds. In order to track time spent in at various
CPU frequencies, we enable platform callbacks from cpuacct for this accounting.
Architectures that support overclock boosting, or don't have pre-defined
frequency tables can implement their own bucketing system that makes sense
given their cpufreq scaling abilities.
New file:
cpuacct.cpufreq reports the CPU time (in nanoseconds) spent at each CPU
frequency.
Change-Id: I10a80b3162e6fff3a8a2f74dd6bb37e88b12ba96
Some documentation to provide help with tunables.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Below you will find an updated version from the original series bunching all patches into one big patch
updating broken web addresses that are located in Documentation/*
Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult,
the best way to deal with these is to use web.archive.org to locate these addresses that are outdated.
Now there are also some addresses pointing to .spec files some are located, but some(after searching
on the companies site)where still no where to be found. In this case I just changed the address
to the company site this way the users can contact the company and they can locate them for the users.
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michael Neuling <mikey@neuling.org>
Some information are old, and I think current document doesn't work as "a
guide for users". We need summary of all of our controls, at least.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
This patch adds support for moving charge of file pages, which include
normal file, tmpfs file and swaps of tmpfs file. It's enabled by setting
bit 1 of <target cgroup>/memory.move_charge_at_immigrate.
Unlike the case of anonymous pages, file pages(and swaps) in the range
mmapped by the task will be moved even if the task hasn't done page fault,
i.e. they might not be the task's "RSS", but other task's "RSS" that maps
the same file. And mapcount of the page is ignored(the page can be moved
even if page_mapcount(page) > 1). So, conditions that the page/swap
should be met to be moved is that it must be in the range mmapped by the
target task and it must be charged to the old cgroup.
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This adds a feature to disable oom-killer for memcg, if disabled, of
course, tasks under memcg will stop.
But now, we have oom-notifier for memcg. And the world around memcg is
not under out-of-memory. memcg's out-of-memory just shows memcg hits
limit. Then, administrator or management daemon can recover the situation
by
- kill some process
- enlarge limit, add more swap.
- migrate some tasks
- remove file cache on tmps (difficult ?)
Unlike oom-killer, you can take enough information before killing tasks.
(by gcore, or, ps etc.)
Considering containers or other resource management softwares in userland,
event notification of OOM in memcg should be implemented. Now, memcg has
"threshold" notifier which uses eventfd, we can make use of it for oom
notification.
This patch adds oom notification eventfd callback for memcg. The usage is
very similar to threshold notifier, but control file is memory.oom_control
and no arguments other than eventfd is required.
% cgroup_event_notifier /cgroup/A/memory.oom_control dummy
(About cgroup_event_notifier, see Documentation/cgroup/)
Cc: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Cc: Paul Menage <menage@google.com>
fs/ext3/fsync.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
fs/block_dev.c
This patch fixes few usability and configurability issues.
o All the cgroup based controller options are configurable from
"Genral Setup/Control Group Support/" menu. blkio is the only exception.
Hence make this option visible in above menu and make it configurable from
there to bring it inline with rest of the cgroup based controllers.
o Get rid of CONFIG_DEBUG_CFQ_IOSCHED.
This option currently does two things.
- Enable printing of cgroup paths in blktrace
- Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat
files in cgroup.
If we are using group scheduling, blktrace data is of not really much use
if cgroup information is not present. To get this data, currently one has to
also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of
all the additional debug stat files which is not desired.
Hence, this patch moves printing of cgroup paths under
CONFIG_CFQ_GROUP_IOSCHED.
This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all
the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which
can be enabled through config menu.
Acked-by: Divyesh Shah <dpshah@google.com>
Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
Writing to cgroup.procs is not supported now.
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Ben Blum <bblum@andrew.cmu.edu>
Fix obvious cases of "it's" being used when "its" was meant.
Signed-off-by: Francis Galiegue <fgaliegue@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Here is the document for blkio.weight_device
Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
1) group_wait_time - This is the amount of time the cgroup had to wait to get a
timeslice for one of its queues from when it became busy, i.e., went from 0
to 1 request queued. This is different from the io_wait_time which is the
cumulative total of the amount of time spent by each IO in that cgroup waiting
in the scheduler queue. This stat is a great way to find out any jobs in the
fleet that are being starved or waiting for longer than what is expected (due
to an IO controller bug or any other issue).
2) empty_time - This is the amount of time a cgroup spends w/o any pending
requests. This stat is useful when a job does not seem to be able to use its
assigned disk share by helping check if that is happening due to an IO
controller bug or because the job is not submitting enough IOs.
3) idle_time - This is the amount of time spent by the IO scheduler idling
for a given cgroup in anticipation of a better request than the exising ones
from other queues/cgroups.
All these stats are recorded using start and stop events. When reading these
stats, we do not add the delta between the current time and the last start time
if we're between the start and stop events. We avoid doing this to make sure
that these numbers are always monotonically increasing when read. Since we're
using sched_clock() which may use the tsc as its source, it may induce some
inconsistency (due to tsc resync across cpus) if we included the current delta.
Signed-off-by: Divyesh Shah<dpshah@google.com>
These stats are useful for getting a feel for the queue depth of the cgroup,
i.e., how filled up its queues are at a given instant and over the existence of
the cgroup. This ability is useful when debugging problems in the wild as it
helps understand the application's IO pattern w/o having to read through the
userspace code (coz its tedious or just not available) or w/o the ability
to run blktrace (since you may not have root access and/or not want to disturb
performance).
This includes both the number of bios merged into requests belonging to this
cgroup as well as the number of requests merged together.
In the past, we've observed different merging behavior across upstream kernels,
some by design some actual bugs. This stat helps a lot in debugging such
problems when applications report decreased throughput with a new kernel
version.
This needed adding an extra elevator function to capture bios being merged as I
did not want to pollute elevator code with blkiocg knowledge and hence needed
the accounting invocation to come from CFQ.
that include some minor fixes and addresses all comments.
Changelog: (most based on Vivek Goyal's comments)
o renamed blkiocg_reset_write to blkiocg_reset_stats
o more clarification in the documentation on io_service_time and io_wait_time
o Initialize blkg->stats_lock
o rename io_add_stat to blkio_add_stat and declare it static
o use bool for direction and sync
o derive direction and sync info from existing rq methods
o use 12 for major:minor string length
o define io_service_time better to cover the NCQ case
o add a separate reset_stats interface
o make the indexed stats a 2d array to simplify macro and function pointer code
o blkio.time now exports in jiffies as before
o Added stats description in patch description and
Documentation/cgroup/blkio-controller.txt
o Prefix all stats functions with blkio and make them static as applicable
o replace IO_TYPE_MAX with IO_TYPE_TOTAL
o Moved #define constant to top of blk-cgroup.c
o Pass dev_t around instead of char *
o Add note to documentation file about resetting stats
o use BLK_CGROUP_MODULE in addition to BLK_CGROUP config option in #ifdef
statements
o Avoid struct request specific knowledge in blk-cgroup. blk-cgroup.h now has
rq_direction() and rq_sync() functions which are used by CFQ and when using
io-controller at a higher level, bio_* functions can be added.
Fix cpusets.txt documentation punctuation.
Signed-off-by: Greg Thelen <gthelen@google.com>
Acked-by: Paul Menage <menage@google.com>
Update memory.txt to be more consistent: s/swapiness/swappiness/
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Updated memory.txt to be more consistent: s/swapiness/swappiness/
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Decription of sanity check for memory thresholds.
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Dan Malek <dan@embeddedalley.com>
An example of cgroup notification API usage.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Presently, if panic_on_oom=2, the whole system panics even if the oom
happend in some special situation (as cpuset, mempolicy....). Then,
panic_on_oom=2 means painc_on_oom_always.
Now, memcg doesn't check panic_on_oom flag. This patch adds a check.
BTW, how it's useful ?
kdump+panic_on_oom=2 is the last tool to investigate what happens in
oom-ed system. When a task is killed, the sysytem recovers and there will
be few hint to know what happnes. In mission critical system, oom should
never happen. Then, panic_on_oom=2+kdump is useful to avoid next OOM by
knowing precise information via snapshot.
TODO:
- For memcg, it's for isolate system's memory usage, oom-notiifer and
freeze_at_oom (or rest_at_oom) should be implemented. Then, management
daemon can do similar jobs (as kdump) or taking snapshot per cgroup.
Cc: Nick Piggin <npiggin@suse.de>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Update memcg_test.txt to describe how to test the move-charge feature.
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
It allows to register multiple memory and memsw thresholds and gets
notifications when it crosses.
To register a threshold application need:
- create an eventfd;
- open memory.usage_in_bytes or memory.memsw.usage_in_bytes;
- write string like "<event_fd> <memory.usage_in_bytes> <threshold>" to
cgroup.event_control.
Application will be notified through eventfd when memory usage crosses
threshold in any direction.
It's applicable for root and non-root cgroup.
It uses stats to track memory usage, simmilar to soft limits. It checks
if we need to send event to userspace on every 100 page in/out. I guess
it's good compromise between performance and accuracy of thresholds.
[nishimura@mxp.nes.nec.co.jp: fix documentation merge issue]
Cc: Vladislav Buzov <vbuzov@embeddedalley.com>
Cc: Alexander Shishkin <virtuoso@slind.org>
This patchset introduces eventfd-based API for notifications in cgroups
and implements memory notifications on top of it.
It uses statistics in memory controler to track memory usage.
Output of time(1) on building kernel on tmpfs:
Root cgroup before changes:
make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total
Non-root cgroup before changes:
make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total
Root cgroup after changes (0 thresholds):
make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total
Non-root cgroup after changes (0 thresholds):
make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total
Root cgroup after changes (1 thresholds, never crossed):
make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total
Non-root cgroup after changes (1 thresholds, never crossed):
make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total
This patch:
Introduce the write-only file "cgroup.event_control" in every cgroup.
To register new notification handler you need:
- open a control file to be monitored. Callbacks register_event() and
unregister_event() must be defined for the control file;
- write "<event_fd> <control_fd> <args>" to cgroup.event_control.
Interpretation of args is defined by control file implementation;
eventfd will be woken up by control file implementation or when the
cgroup is removed.
To unregister notification handler just close eventfd.
If you need notification functionality for a control file you have to
implement callbacks register_event() and unregister_event() in the
struct cftype.
[kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix]
This patch is another core part of this move-charge-at-task-migration
feature. It enables moving charges of anonymous swaps.
To move the charge of swap, we need to exchange swap_cgroup's record.
In current implementation, swap_cgroup's record is protected by:
- page lock: if the entry is on swap cache.
- swap_lock: if the entry is not on swap cache.
This works well in usual swap-in/out activity.
But this behavior make the feature of moving swap charge check many
conditions to exchange swap_cgroup's record safely.
So I changed modification of swap_cgroup's recored(swap_cgroup_record())
to use xchg, and define a new function to cmpxchg swap_cgroup's record.
This patch also enables moving charge of non pte_present but not uncharged
swap caches, which can be exist on swap-out path, by getting the target
pages via find_get_page() as do_mincore() does.
[kosaki.motohiro@jp.fujitsu.com: fix ia64 build]
[akpm@linux-foundation.org: fix typos]
In current memcg, charges associated with a task aren't moved to the new
cgroup at task migration. Some users feel this behavior to be strange.
These patches are for this feature, that is, for charging to the new
cgroup and, of course, uncharging from the old cgroup at task migration.
This patch adds "memory.move_charge_at_immigrate" file, which is a flag
file to determine whether charges should be moved to the new cgroup at
task migration or not and what type of charges should be moved. This
patch also adds read and write handlers of the file.
This patch also adds no-op handlers for this feature. These handlers will
be implemented in later patches. And you cannot write any values other
than 0 to move_charge_at_immigrate yet.
Add a forgotten item into CONTENTS.
Provides support for unloading modular subsystems.
This patch adds a new function cgroup_unload_subsys which is to be used
for removing a loaded subsystem during module deletion. Reference
counting of the subsystems' modules is moved from once (at load time) to
once per attached hierarchy (in parse_cgroupfs_options and
rebind_subsystems) (i.e., 0 or 1).
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Add interface between cgroups subsystem management and module loading
This patch implements rudimentary module-loading support for cgroups -
namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a
module initcall, and a struct module pointer in struct cgroup_subsys.
Several functions that might be wanted by modules have had EXPORT_SYMBOL
added to them, but it's unclear exactly which functions want it and which
won't.
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach()
can be used when can_attach() operation prepares something for the subsys,
but we should rollback what can_attach() operation has prepared if attach
task fails after we've succeeded in can_attach().
Reviewed-by: Paul Menage <menage@google.com>
This patch is for modifying with correct cuset flag file. We need to update
current manual for cpuset. For example, before) cpus, cpu_exclusive, mems
after ) cpuset.cpus, cpuset.cpu_exclusive, cpuset.mems
Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com>
Update documentation of cgroups tasks and procs files
Document the cgroup.procs file.
Clarify the semantics of the cgroup.procs and tasks files. Although the
current cgroup.procs interface returns a sorted and uniqified list of
pids, potential future performance enhancements could result in those
properties being removed - explicitly document this aspect of the API.
There are no existing users of cgroup.procs, so compatibility isn't an
issue. There are users of the "tasks" file, but none that would appear to
break in the event of the sorted property being broken. The standard
"libcpuset" explicitly sorts the results of reading from the tasks file,
and "libcg" and other users don't appear to care about ordering.
Signed-off-by: Paul Menage <menage@google.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Soft limits is a new feature for the memory resource controller, something
similar has existed in the group scheduler in the form of shares. The CPU
controllers interpretation of shares is very different though.
Soft limits are the most useful feature to have for environments where the
administrator wants to overcommit the system, such that only on memory
contention do the limits become active. The current soft limits
implementation provides a soft_limit_in_bytes interface for the memory
controller and not for memory+swap controller. The implementation
maintains an RB-Tree of groups that exceed their soft limit and starts
reclaiming from the group that exceeds this limit by the maximum amount.
This patch:
Add documentation for soft limits
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Change the memory cgroup to remove the overhead associated with accounting
all pages in the root cgroup. As a side-effect, we can no longer set a
memory hard limit in the root cgroup.
A new flag to track whether the page has been accounted or not has been
added as well. Flags are now set atomically for page_cgroup,
pcg_default_flags is now obsolete and removed.
[akpm@linux-foundation.org: fix a few documentation glitches]
Alter the ss->can_attach and ss->attach functions to be able to deal with
a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a
pre-patch to cgroup-procs-writable.patch.)
Currently, new mode of the attach function can only tell the subsystem
about the old cgroup of the threadgroup leader. No subsystem currently
needs that information for each thread that's being moved, but if one were
to be added (for example, one that counts tasks within a group) this bit
would need to be reworked a bit to tell the subsystem the right
information.
[hidave.darkstar@gmail.com: fix build]
Signed-off-by: Ben Blum <bblum@google.com>
Reviewed-by: Matt Helsley <matthltc@us.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
To simplify referring to cgroup hierarchies in mount statements, and to
allow disambiguation in the presence of empty hierarchies and
multiply-bindable subsystems this patch adds support for naming a new
cgroup hierarchy via the "name=" mount option
A pre-existing hierarchy may be specified by either name or by subsystems;
a hierarchy's name cannot be changed by a remount operation.
Example usage:
# To create a hierarchy called "foo" containing the "cpu" subsystem
mount -t cgroup -oname=foo,cpu cgroup /mnt/cgroup1
# To mount the "foo" hierarchy on a second location
mount -t cgroup -oname=foo cgroup /mnt/cgroup2
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
By writing a tasks's pid to the file, a process adds that task to that
cgroup/cpuset. But to add a cpu/mem to a cpuset, the new list of cpus
should be written to the cpuset.mems file which would replace the old list
of cpus. Make this clearer in the documentation.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
We don't have an interface to reset mem.limit or memsw.limit now.
This patch allows to reset mem.limit or memsw.limit when they are being
set to -1.
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
A user can set memcg.limit_in_bytes == memcg.memsw.limit_in_bytes when the
user just want to limit the total size of applications, in other words,
not very interested in memory usage itself. In this case, swap-out will
be done only by global-LRU.
But, under current implementation, memory.limit_in_bytes is checked at
first and try_to_free_page() may do swap-out. But, that swap-out is
useless for memsw.limit_in_bytes and the thread may hit limit again.
This patch tries to fix the current behavior at memory.limit ==
memsw.limit case. And documentation is updated to explain the behavior of
this special case.
The description about various statistics from memory.stat is not accurate
and confusing at times.
Correct this along with a few other minor cleanups.
Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
After the introduction of resource counters hierarchies
(28dbc4b6a01fb579a9441c7b81e3d3413dc452df) the prototypes of
res_counter_init() and res_counter_charge() have been changed.
Keep the documentation consistent with the actual function prototypes.
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
