path: root/Documentation/devices.txt
2009-04-07lanana: assign a device name and numbering for MAX3100Alan Cox
This is a low density serial port so needs a real major/minor Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06LANANA: Fix datesAlan Cox
As noted by Janne Grunau it would be good if the date was also right. (Web site also resynched) Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03LANANA: Change of management and resyncAlan Cox
Bring the devices.txt back into some relationship with reality. Update the documentation a bit. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12[SCSI] major.h: char-major number for OSD device driverBoaz Harrosh
Allocate major 260 for osd. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Torben Mathiasen <device@lanana.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-17USB: add USB test and measurement class driverGreg Kroah-Hartman
This driver was originaly written by Stefan Kopp, but massively reworked by Greg for submission. Thanks to Felipe Balbi <me@felipebalbi.com> for lots of work in cleaning up this driver. Thanks to Oliver Neukum <oliver@neukum.org> for reviewing previous versions and pointing out problems. Cc: Stefan Kopp <stefan_kopp@agilent.com> Cc: Marcel Janssen <korgull@home.nl> Cc: Felipe Balbi <me@felipebalbi.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: auerswald: remove driver (obsolete)Wolfgang Mües
This patch removes the auerswald USB driver from the linux kernel 2.6.26. This driver was included into the kernel mainly to connect to the ISDN framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile and moving ISDN support, this connection was never realized, and the only use of this driver was for device configuration. In the age of DSL, the demand of ISDN support is getting very low. Meanwhile, with the advent of libusb, an userspace driver was done for the device configuration which works fine for linux and mac. (Thanks to the libusb developers!). The userspace driver is downloadable from the auerswald web site. So this driver is obsolete now and has to be removed. Many thanks to all developers which helped me to bring this driver up and working. Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-01Add /dev/oldmem to devices.txt documentationDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <device@lanana.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] New updated devices.txt - LANANATorben Mathiasen
[jengelh@linux01.gwdg.de: cleanups] Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: Torben Mathiasen <torben.mathiasen@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27USB: Add ADU support for Ontrak ADU devicesSteven Haigh
This patch adds support for Ontrak ADU USB devices. Fixed for printk issues by Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Steven Haigh <netwiz@crc.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] Typo in ub clause of devices.txtPete Zaitcev
Change "Thrid" into "Third", and realign similarly to other entries. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Cc: <device@lanana.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] update-devices.txtJan Engelhardt
Update Documentation/devices.txt with a new version from the LANANA site http://www.lanana.org/docs/device-list/devices-2.6+.txt Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Update devices.txtJan Engelhardt
Update Documentation/devices.txt with a new version from the LANANA site http://www.lanana.org/docs/device-list/devices-2.6+.txt Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Torben Mathiasen <device@lanana.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] devices.txt: remove pktcdvd entryPeter Osterlund
Changing the driver to use dynamic device numbers was one of the many changes that were made in order to have the driver accepted into the mainline kernel. Therefore I would say that the entry in devices.txt is obsolete. This patch removes it. Signed-off-by: Peter Osterlund <petero2@telia.com> Cc: Torben Mathiasen <device@lanana.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[PATCH] USB: Delete leftovers from bluetty driverMarcel Holtmann
This patch deletes the bluetooth.txt help file of the bluetty driver and hands over its major device nodes for character devices to the RFCOMM TTY implementation of the Bluetooth subsystem. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Accessing dump file in linear raw format (/dev/oldmem)Vivek Goyal
Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that enables us to access the previous kernel's memory as /dev/oldmem. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
