Add clock binding information for primecell peripherals. For most, a
clock input name of "apb_pclk" is required. Any primecell peripherals
which are different will need to be documented separately.
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Add a function to create amba_devices (i.e. primecell peripherals)
from device tree nodes. The device tree scanning is done by the
of_platform_populate() function which can call of_amba_device_create
based on a match table entry.
Nodes with a "arm,primecell-periphid" property can override the h/w
peripheral id value.
Based on the original work by Jeremy Kerr.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[grant.likely: add Jeremy's original s-o-b line, changes from review
comments, and moved all code to drivers/of/platform.c]
