[ Upstream commit 22662f12768f971809b478386d9cc4947d00497a ]
The Allwinner Timings Controller has two, mutually exclusive, channels.
When the binding has been introduced, it was assumed that there would be
only a single user per channel in the system.
While this is likely for the channel 0 which only connects to LCD displays,
it turns out that the channel 1 can be connected to multiple controllers in
the SoC (HDMI and TV encoders for example). And while the simultaneous use
of HDMI and TV outputs cannot be achieved, switching from one to the other
at runtime definitely sounds plausible.
Add an extra property, allwinner,tcon-channel, to specify for a given
endpoint which TCON channel it is connected to, while falling back to the
previous mechanism if that property is missing.
Acked-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 93a5ec14da24a8abbac5bcb953b45cc7a5d0198a upstream.
The A31 TCON has mux controls for how TCON outputs are routed to the
HDMI and MIPI DSI blocks.
Since the A31s does not have MIPI DSI, it only has a mux for the HDMI
controller input.
This patch only adds support for the compatible strings. Actual support
for the mux controls should be added with HDMI and MIPI DSI support.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
commit 49c440e87cd6f547f93d0dc53571ae0e11d9ec8f upstream.
The A31's display pipeline has 2 frontends, 2 backends, and 2 TCONs. It
also has new display enhancement blocks, such as the DRC (Dynamic Range
Controller), the DEU (Display Enhancement Unit), and the CMU (Color
Management Unit). It supports HDMI, MIPI DSI, and 2 LCD/LVDS channels.
The A31s display pipeline is almost the same, just without MIPI DSI.
Only the TCON seems to be different, due to the missing mux for MIPI
DSI.
Add compatible strings for both of them.
The A33 pipeline also has a component called DRC. Even though its exact
features and programming model is not known (or documented), it needs to
be clocked for the pipeline to carry the video signal all the way.
Add a minimal driver for it that just claim the needed resources for the
pipeline to operate properly.
Acked-by: Peter Korsgaard <peter@korsgaard.com>
The A33 has an block called SAT that is part of the backend that needs to
be clocked and out of reset to be able for the backend to operate properly.
Extend the binding to have the SAT resources listed, and claim them when
the backend probes.
The A33 has a significantly different pipeline, with components that differ
too.
Make sure we had compatible for them.
The display pipeline of the Allwinner A10 is involving several loosely
coupled components.
Add a documentation for the bindings.
