path: root/Documentation/devicetree/bindings/mipi
2013-12-17gpu: host1x: Add MIPI pad calibration DT bindingsThierry Reding
Introduce device tree bindings for the MIPI pad calibration controller found on Tegra SoCs. The controller can be used to perform calibration of pads used for DSI and CSI peripherals. Signed-off-by: Thierry Reding <treding@nvidia.com>
2013-12-17of: Add MIPI DSI bus device tree bindingsThierry Reding
Document the device tree bindings for the MIPI DSI bus. The MIPI Display Serial Interface specifies a serial bus and a protocol for communication between a host and up to four peripherals. Signed-off-by: Thierry Reding <treding@nvidia.com>
