Implements HS400 mode support for exynos host driver.
This also include some updates as new mode is added.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
[Alim: addressed review comments]
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The Exynos7 has a DWMMC controller (v2.70a) which is different from
prior versions. This patch adds new compatible strings for exynos7.
This patch also fixes the CLKSEL register offset on exynos7.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Tested-by: Vivek Gautam <gautam.vivek@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Almost all SoCs use one slot per host controller.
(Even if controller can support the multiple slot, Recommend to use one slot per host controller.)
Don't use the slot-node and deprecate the "supports-highspeed" property.
Instead, use the cap-mmc/sd-highspeed.
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
This patch adds the mmc device tree node entries for exynos5420 SOC.
Exynos5420 has a different version of DWMMC controller,so a new
compatible string is used to distinguish it from the prior SOC's.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
s/Synopsis/Synopsys
s/synopsis/synopsys
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Cc: Pavel Machek <pavel@denx.de>
CC: Arnd Bergmann <arnd@arndb.de>
CC: Olof Johansson <olof@lixom.net>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Seungwon Jeon <tgih.jun@samsung.com>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: devicetree@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
CC: linux-arm-kernel@lists.infradead.org
Acked-by: Olof Johansson <olof@lixom.net>
Fixed a typo in referenced file name.
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Correct spelling typos within Documentation/devicetree
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Samsung Exynos SoC's extend the dw-mshc controller for additional clock
and bus control. Add support for these extensions and include provide
device tree based discovery suppory as well.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Acked-by: Will Newton <will.newton@imgtec.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
