git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: fdt: mark unflattened tree as detached
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of/irq: Mark initialised interrupt controllers as populated
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
Signed-off-by: Otto Kekäläinen <otto@seravo.fi>
Signed-off-by: Rob Herring <robh@kernel.org>
Add the new binding to the documentation of the existing binding.
Mark the old binding as deprecated.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Resetting the switch is something the driver does, not the framework.
So move the parsing of this property into the driver.
There are no in kernel users of this property, so moving it does not
break anything. There is however a board which will make use of this
property making its way into the kernel.
Some boards have a gpio line tied to the switch reset pin. Allow this
gpio to be retrieved from the device tree, and take the switch out of
reset before performing the probe.
With more than two switches in a hierarchy, it becomes necessary to
describe multi-hop routes between switches. The current binding does
not allow this, although the older platform_data did. Extend the link
property to be a list rather than a single phandle to a remote switch.
It is then possible to express that a port should be used to reach
more than one switch and the switch maybe more than one hop away.
When using a cluster of switches, some topologies will have an MDIO
bus per switch, not one for the whole cluster. Allow this to be
represented in the device tree, by adding an optional mii-bus property
at the switch level. The old platform_device method of instantiation
supports this already, so only the device tree binding needs extending
with an additional optional phandle.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
According to description in 'include/net/dsa.h', in cascade switches
configurations where there are more than one interconnected devices,
'rtable' array in 'dsa_chip_data' structure is used to indicate which
port on this switch should be used to send packets to that are destined
for corresponding switch.
However, dsa_of_setup_routing_table() fills 'rtable' with port numbers
of the _target_ switch, but not current one.
This commit removes redundant devicetree parsing and adds needed port
number as a function argument. So dsa_of_setup_routing_table() now just
looks for target switch number by parsing parent of 'link' device node.
To remove possible misunderstandings with the way of determining target
switch number, a corresponding comment was added to the source code and
to the DSA device tree bindings documentation file.
This was tested on a custom board with two Marvell 88E6095 switches with
following corresponding routing tables: { -1, 10 } and { 8, -1 }.
Signed-off-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The dsa core now supports reading from and writing to a switch EEPROM
if connected. Describe optional devicetree property indicating that
an EEPROM is present and its size.
Add documentation for a bunch of new optional properties described in
ethernet.txt and fixed-link.txt, this includes: 'phy-handle', 'phy-mode'
and the 'fixed-link' subnode.
The device tree binding documentation for dsa explicitely states that a
DSA node should have its #address-cells property set to 2, yet the
example still used 1, fix that typo.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This patch adds support for registering DSA switches using Device Tree
bindings. Note that we support programming the switch routing table even
though no in-tree user seems to require it. I tested this on Armada 370
with a Marvell 88E6172 (not supported by mainline yet).
