The proper way to add additional contraints to an existing json-schema
is using 'allOf' to reference the base schema. Using just '$ref' doesn't
work. Fix this for the 'st,syscfg' property.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: linux-gpio@vger.kernel.org
Cc: linux-stm32@st-md-mailman.stormreply.com
Signed-off-by: Rob Herring <robh@kernel.org>
Now that examples are validated against the DT schema, an error with
required 'clocks' property missing is exposed:
Documentation/devicetree/bindings/pinctrl/st,stm32-pinctrl.example.dt.yaml: \
pinctrl@40020000: gpio@0: 'clocks' is a required property
pinctrl@50020000: gpio@1000: 'clocks' is a required property
pinctrl@50020000: gpio@2000: 'clocks' is a required property
Add the missing 'clocks' properties to the examples to fix the errors.
Fixes: 2c9239c125f0 ("dt-bindings: pinctrl: Convert stm32 pinctrl bindings to json-schema")
Cc: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Alexandre TORGUE <alexandre.torgue@st.com>
Properties which are child node definitions need to have an explict
type. Otherwise, a matching (DT) property can silently match when an
error is desired. Fix this up tree-wide. Once this is fixed, the
meta-schema will enforce this on any child node definitions.
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Vignesh Raghavendra <vigneshr@ti.com>
Cc: linux-mtd@lists.infradead.org
Cc: linux-spi@vger.kernel.org
Acked-by: Miquel Raynal <miquel.raynal@bootlin.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Acked-by: Mark Brown <broonie@kernel.org>
Convert the STM32 pinctrl binding to DT schema format using json-schema.
Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
Reviewed-by: Rob Herring <robh@kernel.org>
