git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree updates from Grant Likely:
"A whole lot of bug fixes.
Nothing stands out here except the ability to enable CONFIG_OF on
every architecture, and an import of a newer version of dtc"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (22 commits)
of/irq: Rename "intc_desc" to "of_intc_desc" to fix OF on sh
of/irq: Fix pSeries boot failure
Documentation: DT: Fix a typo in the filename "lantiq,<chip>-pinumx.txt"
of: define of_find_node_by_phandle for !CONFIG_OF
of/address: use atomic allocation in pci_register_io_range()
of: Add vendor prefix for Zodiac Inflight Innovations
dt/fdt: add empty versions of early_init_dt_*_memory_arch
of: clean-up unnecessary libfdt include paths
of: make unittest select OF_EARLY_FLATTREE instead of depend on it
of: make CONFIG_OF user selectable
MIPS: prepare for user enabling of CONFIG_OF
of/fdt: fix argument name and add comments of unflatten_dt_node()
of: return NUMA_NO_NODE from fallback of_node_to_nid()
tps6507x.txt: Remove executable permission
of/overlay: Grammar s/an negative/a negative/
of/fdt: Make fdt blob input parameters of unflatten functions const
of: add helper function to retrive match data
of: Grammar s/property exist/property exists/
of: Move OF flags to be visible even when !CONFIG_OF
scripts/dtc: Update to upstream version 9d3649bd3be245c9
Pull ARM SoC DT updates from Kevin Hilman:
"As usual, quite a few device-tree updates in ARM land. There was one
minor churn in DTs due to relicensing under a dual-license, and lots
of little additions of new peripherals, features etc, but nothing
really exciting to call to your attention. Some higlights, focsuing
on support for new SoCs and boards:
- AT91: new boards: Overkiz, Acme Systems' Arietta G25
- tegra: HDA support
- bcm: new platforms: Buffalo WXR-1900DHP, SmartRG SR400ac, ASUS
RT-AC87U
- mvebu: new platforms: Compulab CM-A510, Armada 385-based Linksys
boards, DLink DNS-327L
- OMAP: new platforms: Baltos IR5221, LogicPD Torpedo, Toby-Churchill
SL50
- ARM: added support for Juno r1 board
- sunxi: A33 SoC support; new boards: A23 EVB, SinA33, GA10H-A33,
Mele A1000G
- imx: i.MX7D SoC support; new boards: Armadeus Systems APF6,
Gateworks GW5510, and aristainetos2 boards
- hisilicon: hi6220 SoC support; new boards: 96boards hikey"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (462 commits)
ARM: hisi: revert changes from hisi/hip04-dt branch
ARM: nomadik: set proper compatible for accelerometer
ARM64: juno: add GPIO keys
ARM: at91/dt: sama5d4: fix dma conf for aes, sha and tdes nodes
ARM: dts: Introduce STM32F429 MCU
ARM: socfpga: dts: enable ethernet for Arria10 devkit
ARM: dts: k2l: fix the netcp range size
ARM: dts: k2e: fix the netcp range size
ARM: dts: k2hk: fix the netcp range size
ARM: dts: k2l-evm: Add device bindings for netcp driver
ARM: dts: k2e-evm: Add device bindings for netcp driver
ARM: dts: k2hk-evm: Add device bindings for netcp driver
ARM: BCM5301X: Add DT for Asus RT-AC87U
ARM: BCM5301X: add IRQ numbers for PCIe controller
ARM: BCM5301X: add NAND flash chip description
arm64: dts: Add dts files for Hisilicon Hi6220 SoC
clk: hi6220: Document devicetree bindings for hi6220 clock
arm64: hi6220: Document devicetree bindings for Hisilicon hi6220 SoC
ARM: at91/dt: sama5d4ek: mci0 uses slot 0
ARM: at91/dt: kizbox: fix mismatch LED PWM device
To fix it, use the chance to rename according the compatible string,
which is "lantiq,pinctrl-falcon" and "lantiq,pinctrl-xway"
Signed-off-by: Thomas Langer <thomas.langer@lantiq.com>
Cc: John Crispin <blogic@openwrt.org>
Signed-off-by: Rob Herring <robh@kernel.org>
The rk3368 is the first ARM64 soc from Rockchip, but seems to share most
peripherals with the ARM32 soc, including the pinctrl functionality.
The only notable difference is - as with every Rockchip soc - that the
offsets in the General Register Files moved around and a split of the pmu
section of the rk3288 into pmu and pmugrf (pmu general register files)
sections. The pinctrl driver of course only needs the pmugrf registers
for controlling the pin settings.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Add PFC support for the R8A7794 SoC including pin groups for some
on-chip devices such as ETH, I2C, INTC, MSIOF, QSPI, [H]SCIF...
Sergei: squashed together several patches, fixed the MLB_CLK typo,
added IRQ4.. IRQ9 pin groups, fixed IRQn comments, added ETH B pin
group names, removed stray new line and fixed typos in the comments
in the pinmux_config_regs[] initializer, removed the platform device
ID, took into account limited number of signals in the GPIO1/5/6
controllers, added reasonable and removed unreasonable
copyrights, modified the bindings document, renamed, added changelog.
Changes in version 5:
- resolved rejects, refreshed the patch;
- added Laurent Pinchart's ACK.
Changes in version 4:
- reused the PORT_GP_26() macro to #define PORT_GP_28().
Changes in version 3:
- removed the platform device ID;
- added PORT_GP_26() and PORT_GP_28() macros, used them for GPIO1/5/6 in the
CPU_ALL_PORT() macro.
Changes in version 2:
- rebased the patch.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
The i.MX device tree changes for 4.2:
- Add device tree for i.MX7D SoC and imx7d-sdb board
- New i.MX6 board support: Armadeus Systems APF6, Gateworks GW5510,
- Change LVDS to use simple-panel for nitrogen6x and sabrelite boards
- Add Wifi/Bluetooth devices support for cubox-i board
- Remove unused regulators and correct OTG roles setting for
imx6sl-warp board
- Add I2C support for imx23-olinuxino board
- Move imx6qdl HDMI device to a better place
- Add power-domain for imx6qdl CODA device
* tag 'imx-dt-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (24 commits)
ARM: dts: imx6dl: add imx6dl gpt specific compatible string
ARM: dts: imx6: add DT for aristainetos2 board
ARM: dts: cubox-i/hummingboard: Fix the license text
ARM: dts: sabrelite: use simple-panel instead of display-timings for LVDS0
ARM: dts: nitrogen6x: use simple-panel instead of display-timings for LVDS0
ARM: dts: add imx7d-sdb support
ARM: dts: add imx7d soc dtsi file
ARM: dts: Armadeus Systems APF6 family support (i.MX6)
ARM: dts: vf610: Nomenclature fixup for PTC12 pin used in RMII mode.
ARM: dts: cubox-i: add support for Broadcom Wifi/Bluetooth devices
Document: dt: binding: imx: update document for imx7d support
ARM: dts: imx6qdl: Add power-domain phandle to CODA device node
ARM: dts: Gateworks GW5510 support (i.MX6)
ARM: dts: imx6sl-warp: Fix OTG roles
ARM: dts: imx6sl-warp: Remove USB regulators
ARM: dts: imx6sl-warp: Remove unused regulator
ARM: dts: add pinfunc include file to support imx7d
ARM: mxs: fix in tree users of ssd1306
ARM: dts: imx6qdl-hummingboard: Add PCIe support
ARM: dts: imx23-olinuxino: Add i2c support
The Armada 39x SoC family has grown a new variant, the Armada 395,
which sits between the Armada 390 and Armada 398 in terms of
features. This commit adds support for this additional variant to the
Armada 39x pinctrl driver.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The latest version of the Armada 39x datasheet documents several new
SATA related functions on various MPP pins. This commit adds the
description of these new functions to the Armada 39x pinctrl driver as
well as to its DT binding documentation.
PCIe related functions on various MPP pins. This commit adds the
The latest version of the Armada 38x datasheet documents several new
PTP related functions on various MPP pins. This commit adds the
description of these new functions to the Armada 38x pinctrl driver as
UART1 related functions on various MPP pins. This commit adds the
NAND related functions on various MPP pins. This commit adds the
The latest Armada XP datasheet documents several new DRAM related
functions on various MPPs. This commit adds the description of these
new functions in the Armada XP pinctrl driver and its DT binding
documentation.
The latest version of the Armada XP datasheet documents a new
NAND-related MPP function on MPP48, for which this commit adds
support.
The latest Armada XP datasheet documents that some of the MPP pins can
be used to access the second SPI bus, labelled 'spi1'. This commit
adds the corresponding pins in the pinctrl driver and its DT binding
documentation.
After updating to the latest Armada XP datasheet, we discovered that
there is a second SPI bus accessible from the MPP pins, called 'spi1'.
In order to be consistent with other SoCs having two SPI busses, this
commit renames the functions of the first SPI bus to 'spi0' instead of
just 'spi'.
This commit obviously breaks the DT backward compatibility for the
people using the "spi" function name in their Device Tree.
Across all SoCs, even on Armada 370 for SPI0, the clock pin uses the
'sck' subname and not 'clk', so this commit adjusts the code and
documentation accordingly.
Since this commit only changes the subname, DT backward compatibility
is not affected.
For consistency with the datasheet, this commit renames the VDD
function of the MPP4 pin.
While this changes the DT compatibility, it is not considered to be a
problem since this pin is unlikely to be used for anything but
debugging purposes.
There was an off-by-one in the documentation of the ge1(txd[0-3])
pins, which is fixed by this commit. Since the driver was correct, and
the subnames are anyway not used in the DT binding itself, there is no
need to push this documentation fix for stable.
This commit normalizes the naming of the Ethernet txclkout pin to be
the same accross Marvell SoCs. It is worth mentioning that the DT
binding documentation of the Armada XP was wrong for MPP12: it said
the function was ge1(txd0), while it is in fact ge1(txclkout). It is
however not really a fix worth sending to stable since it does not
change the behavior, and the driver itself was correct.
Since only the subnames are changed, DT backward compatibility is not
affected.
This commit aligns the naming of the audio 'lrclk' pin accross Marvell
SoCs.
Since only the subname is changed, the DT backward compatibility is
not affected.
This commit normalizes the naming of PCIe pins to use 'rstout' instead
of 'rstoutn' or 'rst-out'.
Since only the subnames are changed, DT compatibility is not affected.
This commit normalizes the naming of the TDM pins accross the
different Marvell SoCs. Mainly it consists in:
* Removing the 'n' from signal names: 'intn' becomes 'int' and 'rstn'
becomes 'rst'
* Renaming the main name 'tdm2c' to 'tdm' on Armada 38x.
* Change the main name 'tdm-1' to 'tdm' for one of the pins of the
Armada XP
The last two changes affect DT compatibility, but since the TDM
interface is nowhere near being supported in mainline, it should not
be considered to be a serious problem at this point.
All SoCs use "nand" to designate NAND pins, only Armada 39x is using
"nd", which is not consistent. This commit fixes that by renaming the
corresponding functions.
It also changes the subnames from rbn0/rbn1 to rb0/rb1, to respect the
convention used everywhere that we don't encode the 'n' part of signal
names.
While this commit changes the main name of function, therefore
potentially breaking the DT compatibility, this is not a problem since
Armada 39x is a brand new SoC which isn't used in production yet.
This commit modifies the definition of the Device Bus interface pins
to be consistent accross SoCs. Especially, it removes the 'n'
indicators that we don't encode in the subnames of pins:
'dev(wen0)' becomes 'dev(we0)'
'dev(wen1)' becomes 'dev(we1)'
'dev(oen)' becomes 'dev(oe)'
etc.
In addition, it fixes the Armada 375 DT binding documentation, which
forgot to document the 'dev' function for MPP46, MPP57 and MPP63.
Since only the subnames are changed, this commit does not affect DT
compatibility.
In order to be consistent with the datasheet and some other SoCs, this
commit renames the SDIO pins of the Armada 39x from "sd" to "sd0".
While this changes the DT binding, this is not a problem since Armada
39x is a brand new SoC which isn't used in production yet (so now is
the right time to fix such things).
This commit makes the naming of SATA related MPP functions consistent
accross SoCs by adjusting the Armada 39x definition to use "prsnt"
instead of "present".
Since only the subnames are changed, the DT binding is not modified at
all.
This commit makes the dram functions naming (both the name and
subname) consistent accross SoC, by using:
dram(vttctrl)
dram(deccerr)
in all Marvell SoCs.
Due to the change to the name, it changes the DT binding, but these
functions are not used by any in-tree Device Tree file, and are very
unlikely to be used by anyone.
The subnames are purely informative, but it's nicer when they match
accross SoCs. This commit adjusts the Armada 375, Armada 38x and
Armada 39x MPP definitions so that the subnames of the PTP pins match
the ones used on Armada XP and Kirkwood.
There was a mistake in the definition of the functions for MPP48 on
Marvell Armada XP. The second function is dev(clkout), and not tclk.
Cc: <stable@vger.kernel.org> # v3.7+
Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP")
The latest version of the Armada XP datasheet no longer documents the
VDD cpu_pd functions, which might indicate they are not working and/or
not supported. This commit ensures the pinctrl driver matches the
datasheet.
After updating to a more recent version of the Armada XP datasheet, we
realized that some of the pins documented as having a NAND-related
functionality in fact did not have such functionality. This commit
updates the pinctrl driver accordingly.
After updating to a more recent version of the Armada 375, we realized
Cc: <stable@vger.kernel.org> # v3.15+
Fixes: ce3ed59dcddd ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 375")
Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly
named "spi0-1" instead of just "spi0". This commit fixes that.
This DT binding change does not affect any of the in-tree users.
Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370")
A new revision of the Marvell Armada 38x hardware datasheet unveiled
that the definition of some of the PCIe functions were not
correct. This commit fixes the pinctrl driver accordingly.
Some PCIe functions simply do not exist, some of the PCIe functions in
fact were corresponding to other functions, and some PCIe functions
have been added.
Note: the seemingly unrelated removal of spi(cs2) on MPP47 is related:
this function is in fact implemented on MPP43, instead of a PCIe
function.
Fixes: ca6d9a084b56f ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 380/385")
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
A33 PIO has 7 ports which starts from PB and has two interrupt ports.
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This part just add necessary change to boot imx7d.
Update clock, pinctrl and gpt for imx7d
Signed-off-by: Frank Li <Frank.Li@freescale.com>
The Pinctrl module (ioc) controls the Pad's function select
(each pad can have 8 functions), Pad's Drive Strength, Pad's
Pull Select and Pad's Input Disable status.
The ioc has two modules, ioc_top & ioc_rtc. Both of these two
modules have function select/clear, Pull select and Drive
Strength registers. But only ioc_rtc has input-disable
registers. The Pads on ioc_top have to access ioc_rtc to set
their input-disable status and intpu-disable-value.
So have to use one ioc driver instance to drive these two
ioc modules at the same time, and each ioc module will be
treat as one bank on the "IOC Device".
The GPIO Controller controls the GPIO status if the Pad has
been config as GPIO by Pinctrl already. Includes the GPIO
Input/output, Interrupt type, Interrupt Status, and Set/Get
Values.
The GPIO pull up/down are controlled by Pinctrl.
There are 7 GPIO Groups and splited into 3 MACROs in atlas7.
The GPIO Groups in one MACRO share one GPIO controllers, each
GPIO Group are treated as one GPIO bank.
For example:
In VDIFM macro, there is one GPIO Controller, it has 3 banks
to control 3 gpio groups. Its gpio name space is from 0 to 95.
The Device Tree can be written as following:
gpio-ranges = <&pinctrl 0 0 0>,
<&pinctrl 32 0 0>,
<&pinctrl 64 0 0>;
gpio-ranges-group-names = "gnss_gpio_grp",
"lcd_vip_gpio_grp",
"sdio_i2s_gpio_grp";
bank#0 is from 0~31, the pins are from pinctrl's "gnss_gpio_grp".
bank#2 is from 32~63, the pins are from pinctrl's "lcd_vip_gpio_grp".
bank#3 is from 64~95, the pins are from pinctrl's "sdio_i2s_gpio_grp".
Signed-off-by: Wei Chen <Wei.Chen@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Since 6397 is no need to support interrupt controller,
moving interrupt controller relate property to optional list.
Also adding mt8173 and mt8127 to bindings.
Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
The Berlin pinctrl documentation was part of the Marvell Berlin SoC
documentation because the Berlin pinctrl configuration was inside the
chip and the system controllers. With the recent rework of the chip and
system controller handling (now an MFD driver registers all sub-devices
of the two soc and system controller nodes and each device has its own
sub-node), the documentation of the Berlin pinctrl driver can be moved
to the generic pinctrl documentation directory.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Also renames "R-Car M2" to "R-Car M2-W" to avoid confusion.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: devicetree@vger.kernel.org
Since SCLK, MISO and MOSI are the only mandatory signals at Zynq's SPI
interfaces, SS0, SS1 and SS2 have to be configured separately as they may
be used as simple GPIO lines.
This, of course, has to be considered in the devicetree, so pin controller
configuration for e.g. an SPI0 using SS0 and SS1 only might look like the
following snippet (derived from the example of chapter "17.5.3
MIO/EMIO" Routing of Zynq-7000 TRM UG585). So MIO20 can now be used
as GPIO instead of being occupied by SPI0 SS2 function. Note the separate
pinmux function for the slave select signals:
pinctrl_spi0_default: spi0-default {
mux_spi {
function = "spi0";
groups = "spi0_0_grp";
mux_ss {
function = "spi0_ss";
groups = "spi0_0_ss0_grp", "spi0_0_ss1_grp";
conf-output {
pins = "MIO16", "MIO21";
slew-rate = <0>;
bias-disable;
low-power-disable;
io-standard = <1>;
conf-input {
pins = "MIO17";
slew-rate = <0>;
bias-high-impedance;
low-power-disable;
io-standard = <1>;
conf-select {
pins = "MIO18", "MIO19";
slew-rate = <0>;
bias-pull-up;
low-power-disable;
io-standard = <1>;
pinctrl_gpio0_default {
mux {
function = "gpio0";
groups = "gpio0_20_grp"
conf {
pins = "MIO20";
slew-rate = <0>;
bias-pull-up;
low-power-disable;
io-standard = <1>;
Signed-off-by: Helmut Buchsbaum <helmut.buchsbaum@gmail.com>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Add a device-tree binding document for the pin controller present
on the IMG Pistachio SoC.
Signed-off-by: Damien Horsley <Damien.Horsley@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Add compatible string definitions and supported pin functions.
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Currently the "function" + "groups" combination is the only documented
format for pinmux nodes, although many drivers use "function" + "pins".
Update the generic pinctrl binding to include the "function" + "pins"
combination as well.
Add the compatible string for Meson8b in Meson pinctrl documentation
and add new information for Meson8b in source code comments.
Signed-off-by: Carlo Caione <carlo@endlessm.com>
Acked-by: Beniamino Galvani <b.galvani@gmail.com>
pinconf_generic_dt_node_to_map() scans only subnodes of the pinctrl-0 pahndle,
not the referenced node itself. Change the example nodes to match.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
