path: root/Documentation/devicetree
2015-02-21Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS: - a number of fixes that didn't make the 3.19 release. - a number of cleanups. - preliminary support for Cavium's Octeon 3 SOCs which feature up to 48 MIPS64 R3 cores with FPU and hardware virtualization. - support for MIPS R6 processors. Revision 6 of the MIPS architecture is a major revision of the MIPS architecture which does away with many of original sins of the architecture such as branch delay slots. This and other changes in R6 require major changes throughout the entire MIPS core architecture code and make up for the lion share of this pull request. - finally some preparatory work for eXtendend Physical Address support, which allows support of up to 40 bit of physical address space on 32 bit processors" [ Ahh, MIPS can't leave the PAE brain damage alone. It's like every CPU architect has to make that mistake, but pee in the snow by changing the TLA. But whether it's called PAE, LPAE or XPA, it's horrid crud - Linus ] * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits) MIPS: sead3: Corrected get_c0_perfcount_int MIPS: mm: Remove dead macro definitions MIPS: OCTEON: irq: add CIB and other fixes MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs. MIPS: OCTEON: More OCTEONIII support MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits. MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup. MIPS: OCTEON: Update octeon-model.h code for new SoCs. MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h MIPS: OCTEON: Implement the core-16057 workaround MIPS: OCTEON: Delete unused COP2 saving code MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register MIPS: OCTEON: Save and restore CP2 SHA3 state MIPS: OCTEON: Fix FP context save. MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs MIPS: boot: Provide more uImage options MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h MIPS: ip22-gio: Remove legacy suspend/resume support mips: pci: Add ifdef around pci_proc_domain ...
2015-02-21Merge branch 'i2c/for-3.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Summary: - legacy PM code removed from the core, there were no users anymore (thanks to Lars-Peter Clausen) - new driver for Broadcom iProc - bigger driver updates for designware, rk3x, cadence, ocores - a bunch of smaller updates and bugfixes" * 'i2c/for-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (31 commits) i2c: ocores: rework clk code to handle NULL cookie i2c: designware-baytrail: another fixup for proper Kconfig dependencies i2c: fix reference to functionality constants definition i2c: iproc: Add Broadcom iProc I2C Driver i2c: designware-pci: update Intel copyright line i2c: ocores: add common clock support i2c: hix5hd2: add COMPILE_TEST i2c: clarify comments about the dev_released completion i2c: ocores: fix clock-frequency binding usage i2c: tegra: Maintain CPU endianness i2c: designware-baytrail: use proper Kconfig dependencies i2c: designware: Do not calculate SCL timing parameters needlessly i2c: do not try to load modules for of-registered devices i2c: designware: Add Intel Baytrail PMIC I2C bus support i2c: designware: Add i2c bus locking support of: i2c: Add i2c-mux-idle-disconnect DT property to PCA954x mux driver i2c: designware: use {readl|writel}_relaxed instead of readl/writel i2c: designware-pci: no need to provide clk_khz i2c: designware-pci: remove Moorestown support i2c: imx: whitespace and checkpatch cleanup ...
2015-02-21Merge tag 'clk-for-linus-3.20' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock framework updates from Mike Turquette: "The clock framework changes contain the usual driver additions, enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based devices. Additionally the framework core underwent a bit of surgery with two major changes: - The boundary between the clock core and clock providers (e.g clock drivers) is now more well defined with dedicated provider helper functions. struct clk no longer maps 1:1 with the hardware clock but is a true per-user cookie which helps us tracker users of hardware clocks and debug bad behavior. - The addition of rate constraints for clocks. Rate ranges are now supported which are analogous to the voltage ranges in the regulator framework. Unfortunately these changes to the core created some breakeage. We think we fixed it all up but for this reason there are lots of last minute commits trying to undo the damage" * tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits) clk: Only recalculate the rate if needed Revert "clk: mxs: Fix invalid 32-bit access to frac registers" clk: qoriq: Add support for the platform PLL powerpc/corenet: Enable CLK_QORIQ clk: Replace explicit clk assignment with __clk_hw_set_clk clk: Add __clk_hw_set_clk helper function clk: Don't dereference parent clock if is NULL MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr clkdev: Always allocate a struct clk and call __clk_get() w/ CCF clk: shmobile: div6: Avoid division by zero in .round_rate() clk: mxs: Fix invalid 32-bit access to frac registers clk: omap: compile legacy omap3 clocks conditionally clkdev: Export clk_register_clkdev clk: Add rate constraints to clocks clk: remove clk-private.h pci: xgene: do not use clk-private.h arm: omap2+ remove dead clock code clk: Make clk API return per-user struct clk instances clk: tegra: Define PLLD_DSI and remove dsia(b)_mux clk: tegra: Add support for the Tegra132 CAR IP block ...
2015-02-20MIPS: OCTEON: irq: add CIB and other fixesDavid Daney
- Use of_irq_init() to initialize interrupt controllers - Get rid of some unlikely() - Add CIB to support SATA and other interrupts - Add support for CIU SUM2 interrupt sources Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Leonid Rosenboim <lrosenboim@caviumnetworks.com> Signed-off-by: Aleksey Makarov <aleksey.makarov@auriga.com> Signed-off-by: Peter Swain <peter.swain@cavium.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: devicetree@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/8947/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-02-19Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal Pull more thermal managament updates from Zhang Rui: "Specifics: - Exynos thermal driver refactoring. Several cleanups, code optimization, unused symbols removal, and unused feature removal in Exynos thermal driver. Thanks Lukasz for this effort. - Exynos thermal driver support to OF thermal. After the code refactoring, the driver earned the support to OF thermal. Chip thermal data were moved from driver code to DTS, reducing the code footprint. Thanks Lukasz for this. - After receiving the OF thermal support, the exynos thermal driver now must allow modular build. Thanks Arnd for detecting, reporting and fixing this. - Exynos thermal driver support to Exynos 7 SoC. Thanks Abhilash for this. - Accurate temperature reporting on Rockchip thermal driver, thanks to Caesar. - Fix on how OF thermal enables its zones, thanks Lukasz for fixing. - Fixes in OF thermal examples under Documentation/. Thanks Srinivas for fixing" * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal: thermal: exynos: Add TMU support for Exynos7 SoC dts: Documentation: Add documentation for Exynos7 SoC thermal bindings cpufreq: exynos: allow modular build thermal: Fix examples in DT documentation thermal: exynos: Correct sanity check at exynos_report_trigger() function thermal: Kconfig: Remove config for not used EXYNOS_THERMAL_CORE thermal: exynos: Remove exynos_tmu_data.c file thermal: rockchip: make temperature reporting much more accurate thermal: exynos: Remove exynos_thermal_common.[c|h] files thermal: samsung: core: Exynos TMU rework to use device tree for configuration dts: Documentation: Update exynos-thermal.txt example for Exynos5440 dts: Documentation: Extending documentation entry for exynos-thermal cpufreq: exynos: Use device tree to determine if cpufreq cooling should be registered thermal: exynos: Modify exynos thermal code to use device tree for cpu cooling configuration thermal: exynos: Provide thermal_exynos.h file to be included in device tree files thermal: exynos: cosmetic: Correct comment format thermal: of: Enable thermal_zoneX when sensor is correctly added
2015-02-18Merge tag 'mfd-for-linus-3.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - fixr platform device collision; da9052, wm8994-core - regmap configuration amendments; tps65218 - fix runtime PM deadlock; rtsx_usb - remove unused/superfluous code; db8500-prcmu, omap-usb-host - enable watchdog timer; lpc_sch - add start/stop RX URBs helpers; dln2 - remove platform device (DT only); max77686, max77802 - support suspend and resume; dln2 - add Device Tree support; da9063 - extra error checking; intel_soc_pmic - const'ify all the things; 88pm860x, hi6421-pmic, intel_soc_pmic, max77686, lm3533, retu, pcf50633, davinci_voicecodec, smsc-ece1099, tps65218, mc13xxx, tps65217, twl-core, twl6040 New drivers/supported devices: - new driver for Richtek RT5033 - new driver for DA9150 Charger and FuelGauge - new driver for Qualcomm Resource Power Manager (RPM) - add support for the ir-clk into sun6i-prcm - add support for FuelGauge into axp20x" * tag 'mfd-for-linus-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (32 commits) mfd: intel_soc_pmic: Add missing error check for devm_kzalloc mfd: rtsx_usb: Defer autosuspend while card exists mfd: devicetree: Add bindings for DA9063 mfd: da9063: Add device tree support regulator: qcom-rpm: Add missing state flag in call to RPM mfd: qcom-rpm: Driver for the Qualcomm RPM mfd: devicetree: bindings: Add Qualcomm RPM DT binding mfd: max77686/802: Remove support for board files mfd: omap-usb-host: Remove some unused functions mfd: twl6040: Constify struct regmap_config and reg_default array mfd: twl-core: Constify struct regmap_config and reg_default array mfd: tps65217: Constify struct regmap_config mfd: mc13xxx: i2c/spi: Constify struct regmap_config mfd: tps65218: Constify struct regmap_config mfd: smsc-ece1099: Constify struct regmap_config mfd: davinci_voicecodec: Constify struct regmap_config mfd: pcf50633: Constify struct regmap_config mfd: retu: Constify struct regmap_config mfd: lm3533: Constify struct regmap_config mfd: max77686: Constify struct regmap_config ...
2015-02-18Merge tag 'pwm/for-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm updates from Thierry Reding: "This contains two new drivers, one for Allwinner SoCs and the other for Imagination Technologies' Pistachio SoC. Complementing this are a couple of fixes to the Atmel HLCDC PWM and STi PWM drivers as well as minor cleanups to the core and the Tegra driver" * tag 'pwm/for-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: tegra: Use NSEC_PER_SEC pwm: Remove unnecessary check before of_node_put() pwm: Add device tree binding document for IMG PWM DAC pwm: Imagination Technologies PWM DAC driver pwm: sti: Maintain a bitmap of configured devices pwm: sunxi: document OF bindings pwm: Add Allwinner SoC support pwm: atmel-hlcdc: Prevent division by zero pwm: atmel-hlcdc: Depend on HAVE_CLK
2015-02-18Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This update brings: - the big cleanup up by Maxime for device control and slave capabilities. This makes the API much cleaner. - new IMG MDC driver by Andrew - new Renesas R-Car Gen2 DMA Controller driver by Laurent along with bunch of fixes on rcar drivers - odd fixes and updates spread over driver" * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (130 commits) dmaengine: pl330: add DMA_PAUSE feature dmaengine: pl330: improve pl330_tx_status() function dmaengine: rcar-dmac: Disable channel 0 when using IOMMU dmaengine: rcar-dmac: Work around descriptor mode IOMMU errata dmaengine: rcar-dmac: Allocate hardware descriptors with DMAC device dmaengine: rcar-dmac: Fix oops due to unintialized list in error ISR dmaengine: rcar-dmac: Fix spinlock issues in interrupt dmaenegine: edma: fix sparse warnings dmaengine: rcar-dmac: Fix uninitialized variable usage dmaengine: shdmac: extend PM methods dmaengine: shdmac: use SET_RUNTIME_PM_OPS() dmaengine: pl330: fix bug that cause start the same descs in cyclic dmaengine: at_xdmac: allow muliple dwidths when doing slave transfers dmaengine: at_xdmac: simplify channel configuration stuff dmaengine: at_xdmac: introduce save_cc field dmaengine: at_xdmac: wait for in-progress transaction to complete after pausing a channel ioat: fail self-test if wait_for_completion times out dmaengine: dw: define DW_DMA_MAX_NR_MASTERS dmaengine: dw: amend description of dma_dev field dmatest: move src_off, dst_off, len inside loop ...
2015-02-18Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This adds the following new drivers: - ImgTec PDC Watchdog Timer Driver, - Mediatek SoC integrated watchdog Add support for BCM5301X, IT8783, NCT6791 and NCT6792 WDT's Add bcm47xx_wdt and da9063 restart handlers and contains overall improvements and fixes" * git://www.linux-watchdog.org/linux-watchdog: watchdog: bcm47xx_wdt.c: allow enabling on BCM5301X arch watchdog: jz4740: Add DT support dt: watchdog: Add DT binding documentation for jz4740 watchdog timer watchdog: dw_wdt: Try to get a 30 second watchdog by default watchdog: dw_wdt: pat the watchdog before enabling it watchdog: w83627hf_wdt: Add support for NCT6791 and NCT6792 watchdog: bcm47xx_wdt.c: add restart handler support watchdog: gpio_wdt: Add "always_running" feature to GPIO watchdog watchdog: da9063: Add restart handler support ARM: mediatek: dts: Add bindings for watchdog watchdog: Add driver for Mediatek watchdog watchdog: Fix omap watchdogs to enable the magic close bit watchdog: rt2880_wdt: minor clean up watchdog: hpwdt: Fix initialization message in hpwdt.c watchdog: it87_wdt: add IT8783 ID watchdog: imx2: Constify struct regmap_config and watchdog_ops DT: watchdog: Add ImgTec PDC Watchdog Timer binding documentation watchdog: ImgTec PDC Watchdog Timer Driver
2015-02-18Merge tag 'for-linus-20150216' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "NAND: - Add new Hisilicon NAND driver for Hip04 - Add default reboot handler, to ensure all outstanding erase transactions complete in time - jz4740: convert to use GPIO descriptor API - Atmel: add support for sama5d4 - Change default bitflip threshold to 75% of correction strength - Miscellaneous cleanups and bugfixes SPI NOR: - Freescale QuadSPI: - Fix a few probe() and remove() issues - Add a MAINTAINERS entry for this driver - Tweak transfer size to increase read performance - Add suspend/resume support - Add Micron quad I/O support - ST FSM SPI: miscellaneous fixes JFFS2: - gracefully handle corrupted 'offset' field found on flash Other: - bcm47xxpart: add tweaks for a few new devices - mtdconcat: set return lengths properly for mtd_write_oob() - map_ram: enable use with mtdoops - maps: support fallback to ROM/UBI for write-protected NOR flash" * tag 'for-linus-20150216' of git://git.infradead.org/linux-mtd: (46 commits) mtd: hisilicon: && vs & typo jffs2: fix handling of corrupted summary length mtd: hisilicon: add device tree binding documentation mtd: hisilicon: add a new NAND controller driver for hisilicon hip04 Soc mtd: avoid registering reboot notifier twice mtd: concat: set the return lengths properly mtd: kconfig: replace PPC_OF with PPC mtd: denali: remove unnecessary stubs mtd: nand: remove redundant local variable MAINTAINERS: add maintainer entry for FREESCALE QUAD SPI driver mtd: fsl-quadspi: improve read performance by increase AHB transfer size mtd: fsl-quadspi: Remove unnecessary 'map_failed' label mtd: fsl-quadspi: Remove unneeded success/error messages mtd: fsl-quadspi: Fix the error paths mtd: nand: omap: drop condition with no effect mtd: nand: jz4740: Convert to GPIO descriptor API mtd: nand: Request strength instead of bytes for soft BCH mtd: nand: default bitflip-reporting threshold to 75% of correction strength mtd: atmel_nand: introduce a new compatible string for sama5d4 chip mtd: atmel_nand: return max bitflips in all sectors in pmecc_correction() ...
2015-02-17dt: watchdog: Add DT binding documentation for jz4740 watchdog timerZubair Lutfullah Kakakhel
Add binding for jz4740 watchdog timer. It is a simple watchdog timer. Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-02-17watchdog: gpio_wdt: Add "always_running" feature to GPIO watchdogMike Looijmans
On some chips, like the TPS386000, the trigger cannot be disabled and the CPU must keep toggling the line at all times. Add a switch "always_running" to keep toggling the GPIO line regardless of the state of the soft part of the watchdog. The "armed" member keeps track of whether a timeout must also cause a reset. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-02-17ARM: mediatek: dts: Add bindings for watchdogMatthias Brugger
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-02-17DT: watchdog: Add ImgTec PDC Watchdog Timer binding documentationNaidu Tellapati
Add the devicetree binding document for ImgTec PDC Watchdog Timer. Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Naidu Tellapati <Naidu.Tellapati@imgtec.com> Signed-off-by: Jude Abraham <Jude.Abraham@gmail.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@imgtec.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-02-17Merge tag '64bit-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC 64-bit changes and additions from Olof Johansson: "The 64-bit set of updates this release cycle adds support for three new platforms: - Samsunc Exynos 7 - Freescale LS2085a - Mediatek MT8173 For all these, the changes mostly consititude additions of DT contents, but also some Kconfig entries to allow dependency/selection of drivers per-platform, etc" * tag '64bit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: Kconfig: clean up two no-op Kconfig options from CONFIG_ARCH_TEGRA* arm64: Fix sort of platform Kconfig entries arm64: Add support for FSL's LS2085A SoC in Kconfig and defconfig arm64: Add DTS support for FSL's LS2085A SoC arm64: mediatek: Add MT8173 SoC Kconfig and defconfig arm64: dts: Add mediatek MT8173 SoC and evaluation board dts and Makefile Document: DT: Add bindings for mediatek MT8173 SoC Platform arm64: Add Tegra132 support arm64: Enable ARMv8 based exynos7 SoC support arm64: dts: Add nodes for mmc, i2c, rtc, watchdog, adc on exynos7 arm64: dts: Add PMU DT node for exynos7 SoC arm64: dts: Add initial pinctrl support to exynos7 arm64: dts: Add initial device tree support for exynos7
2015-02-17Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. This time around, much of this is for at91, with the bulk of it being syscon and udc drivers. Also, there's: - coupled cpuidle support for Samsung Exynos4210 - Renesas 73A0 common-clk work - of/platform changes to tear down DMA mappings on device destruction - a few updates to the TI Keystone knav code" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits) cpuidle: exynos: add coupled cpuidle support for exynos4210 ARM: EXYNOS: apply S5P_CENTRAL_SEQ_OPTION fix only when necessary soc: ti: knav_qmss_queue: change knav_range_setup_acc_irq to static soc: ti: knav_qmss_queue: makefile tweak to build as dynamic module pcmcia: at91_cf: depend on !ARCH_MULTIPLATFORM soc: ti: knav_qmss_queue: export API calls for use by user driver of/platform: teardown DMA mappings on device destruction usb: gadget: at91_udc: Allocate udc instance usb: gadget: at91_udc: Update DT binding documentation usb: gadget: at91_udc: Rework for multi-platform kernel support usb: gadget: at91_udc: Simplify probe and remove functions usb: gadget: at91_udc: Remove non-DT handling code usb: gadget: at91_udc: Document DT clocks and clock-names property usb: gadget: at91_udc: Drop uclk clock usb: gadget: at91_udc: Fix clock names mfd: syscon: Add Atmel SMC binding doc mfd: syscon: Add atmel-smc registers definition mfd: syscon: Add Atmel Matrix bus DT binding documentation mfd: syscon: Add atmel-matrix registers definition clk: shmobile: fix sparse NULL pointer warning ...
2015-02-17Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "DT changes continue to be the bulk of our merge window contents. We continue to have a large set of changes across the board as new platforms and drivers are added. Some of the new platforms are: - Alphascale ASM9260 - Marvell Armada 388 - CSR Atlas7 - TI Davinci DM816x - Hisilicon HiP01 - ST STiH418 There have also been some sweeping changes, including relicensing of DTS contents from GPL to GPLv2+/X11 so that the same files can be reused in other non-GPL projects more easily. There's also been changes to the DT Makefile to make it a little less conflict-ridden and churny down the road" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits) ARM: dts: Add PPMU node for exynos4412-trats2 ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato ARM: dts: Add PPMU dt node for exynos4 and exynos4210 ARM: dts: Add PPMU dt node for exynos3250 ARM: dts: add mipi dsi device node for exynos4415 ARM: dts: add fimd device node for exynos4415 ARM: dts: Add syscon phandle to the video-phy node for Exynos4 ARM: dts: Add sound nodes for exynos4412-trats2 ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2 ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi ARM: dts: Add max77693 charger node for exynos4412-trats2 ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2 ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2 ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2 ARM: dts: am57xx-beagle-x15: Fix USB2 mode ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB ARM: dts: dra72-evm: Add extcon nodes for USB ARM: dts: dra7-evm: Add extcon nodes for USB ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb ...
2015-02-17Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New and updated SoC support. Also included are some cleanups where the platform maintainers hadn't separated cleanups from new developent in separate branches. Some of the larger things worth pointing out: - A large set of changes from Alexandre Belloni and Nicolas Ferre preparing at91 platforms for multiplatform and cleaning up quite a bit in the process. - Removal of CSR's "Marco" SoC platform that never made it out to the market. We love seeing these since it means the vendor published support before product was out, which is exactly what we want! New platforms this release are: - Conexant Digicolor (CX92755 SoC) - Hisilicon HiP01 SoC - CSR/sirf Atlas7 SoC - ST STiH418 SoC - Common code changes for Nvidia Tegra132 (64-bit SoC) We're seeing more and more platforms having a harder time labelling changes as cleanups vs new development -- which is a good sign that we've come quite far on the cleanup effort. So over time we might start combining the cleanup and new-development branches more" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits) ARM: at91/trivial: unify functions and machine names ARM: at91: remove at91_dt_initialize and machine init_early() ARM: at91: change board files into SoC files ARM: at91: remove at91_boot_soc ARM: at91: move alternative initial mapping to board-dt-sama5.c ARM: at91: merge all SOC_AT91SAM9xxx ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init() ARM: digicolor: select syscon and timer ARM: zynq: Simplify SLCR initialization ARM: zynq: PM: Fixed simple typo. ARM: zynq: Setup default gpio number for Xilinx Zynq ARM: digicolor: add low level debug support ARM: initial support for Conexant Digicolor CX92755 SoC ARM: OMAP2+: Add dm816x hwmod support ARM: OMAP2+: Add clock domain support for dm816x ARM: OMAP2+: Add board-generic.c entry for ti81xx ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage ARM: at91: remove unused mach/system_rev.h ARM: at91: stop using HAVE_AT91_DBGUx ARM: at91: fix ordering of SRAM and PM initialization ...
2015-02-17i2c: iproc: Add Broadcom iProc I2C DriverRay Jui
Add initial support to the Broadcom iProc I2C controller found in the iProc family of SoCs. The iProc I2C controller has separate internal TX and RX FIFOs, each has a size of 64 bytes. The iProc I2C controller supports two bus speeds including standard mode (100kHz) and fast mode (400kHz) Signed-off-by: Ray Jui <rjui@broadcom.com> Reviewed-by: Scott Branden <sbranden@broadcom.com> Reviewed-by: Kevin Cernekee <cernekee@chromium.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-02-16Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull, it has a shared branch with some alsa crossover but everything should be acked by relevant people. New drivers: - ATMEL HLCDC driver - designware HDMI core support (used in multiple SoCs). core: - lots more atomic modesetting work, properties and atomic ioctl (hidden under option) - bridge rework allows support for Samsung exynos chromebooks to work finally. - some more panels supported i915: - atomic plane update support - DSI uses shared DSI infrastructure - Skylake basic support is all merged now - component framework used for i915/snd-hda interactions - write-combine cpu memory mappings - engine init code refactored - full ppgtt enabled where execlists are enabled. - cherryview rps/gpu turbo and pipe CRC support. radeon: - indirect draw support for evergreen/cayman - SMC and manual fan control for SI/CI - Displayport audio support amdkfd: - SDMA usermode queue support - replace suballocator usage with more suitable one - rework for allowing interfacing to more than radeon nouveau: - major renaming in prep for later splitting work - merge arm platform driver into nouveau - GK20A reclocking support msm: - conversion to atomic modesetting - YUV support for mdp4/5 - eDP support - hw cursor for mdp5 tegra: - conversion to atomic modesetting - better suspend/resume support for child devices rcar-du: - interlaced support imx: - move to using dw_hdmi shared support - mode_fixup support sti: - DVO support - HDMI infoframe support exynos: - refactoring and cleanup, removed lots of internal unnecessary abstraction - exynos7 DECON display controller support Along with the usual bunch of fixes, cleanups etc" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (724 commits) drm/radeon: fix voltage setup on hawaii drm/radeon/dp: Set EDP_CONFIGURATION_SET for bridge chips if necessary drm/radeon: only enable kv/kb dpm interrupts once v3 drm/radeon: workaround for CP HW bug on CIK drm/radeon: Don't try to enable write-combining without PAT drm/radeon: use 0-255 rather than 0-100 for pwm fan range drm/i915: Clamp efficient frequency to valid range drm/i915: Really ignore long HPD pulses on eDP drm/exynos: Add DECON driver drm/i915: Correct the base value while updating LP_OUTPUT_HOLD in MIPI_PORT_CTRL drm/i915: Insert a command barrier on BLT/BSD cache flushes drm/i915: Drop vblank wait from intel_dp_link_down drm/exynos: fix NULL pointer reference drm/exynos: remove exynos_plane_dpms drm/exynos: remove mode property of exynos crtc drm/exynos: Remove exynos_plane_dpms() call with no effect drm/i915: Squelch overzealous uncore reset WARN_ON drm/i915: Take runtime pm reference on hangcheck_info drm/i915: Correct the IOSF Dev_FN field for IOSF transfers drm/exynos: fix DMA_ATTR_NO_KERNEL_MAPPING usage ...
2015-02-16Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull clocksource updates from Ingo Molnar: "The main change in this tree is the addition of various new SoC clocksource/clockevents drivers: Conexant Digicolor SoCs, rockchip rk3288 board, asm9260 for MIPS and versatile AB/PB boards" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: dts: versatile: Add sysregs node clocksource: versatile: Adapt for Versatile AB and PB boards dt/bindings: Add binding for Versatile system registers clocksource: Driver for Conexant Digicolor SoC timer clocksource: devicetree: Document Conexant Digicolor timer binding clockevents: rockchip: Add rockchip timer for rk3288 ARM: clocksource: Add asm9260_timer driver clocksource: marco: Rename marco to atlas7 clocksource: sirf: Remove unused variable
2015-02-16Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irqchip updates from Ingo Molnar: "Various irqchip driver updates, plus a genirq core update that allows the initial spreading of irqs amonst CPUs without having to do it from user-space" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Fix null pointer reference in irq_set_affinity_hint() irqchip: gic: Allow interrupt level to be set for PPIs irqchip: mips-gic: Handle pending interrupts once in __gic_irq_dispatch() irqchip: Conexant CX92755 interrupts controller driver irqchip: Devicetree: document Conexant Digicolor irq binding irqchip: omap-intc: Remove unused legacy interface for omap2 irqchip: omap-intc: Fix support for dm814 and dm816 irqchip: mtk-sysirq: Get irq number from register resource size irqchip: renesas-intc-irqpin: r8a7779 IRLM setup support genirq: Set initial affinity in irq_set_affinity_hint()
2015-02-15Merge tag 'tty-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver patches from Greg KH: "Here's the big tty/serial driver update for 3.20-rc1. Nothing huge here, just lots of driver updates and some core tty layer fixes as well. All have been in linux-next with no reported issues" * tag 'tty-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (119 commits) serial: 8250: Fix UART_BUG_TXEN workaround serial: driver for ETRAX FS UART tty: remove unused variable sprop serial: of-serial: fetch line number from DT serial: samsung: earlycon support depends on CONFIG_SERIAL_SAMSUNG_CONSOLE tty/serial: serial8250_set_divisor() can be static tty/serial: Add Spreadtrum sc9836-uart driver support Documentation: DT: Add bindings for Spreadtrum SoC Platform serial: samsung: remove redundant interrupt enabling tty: Remove external interface for tty_set_termios() serial: omap: Fix RTS handling serial: 8250_omap: Use UPSTAT_AUTORTS for RTS handling serial: core: Rework hw-assisted flow control support tty/serial: 8250_early: Add support for PXA UARTs tty/serial: of_serial: add support for PXA/MMP uarts tty/serial: of_serial: add DT alias ID handling serial: 8250: Prevent concurrent updates to shadow registers serial: 8250: Use canary to restart console after suspend serial: 8250: Refactor XR17V35X divisor calculation serial: 8250: Refactor divisor programming ...
2015-02-15Merge tag 'staging-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging drivers patches from Greg KH: "Here's the big staging driver tree update for 3.20-rc1. Lots of little things in here, adding up to lots of overall cleanups. The IIO driver updates are also in here as they cross the staging tree boundry a lot. I2O has moved into staging as well, as a plan to drop it from the tree eventually as that's a dead subsystem. All of this has been in linux-next with no reported issues for a while" * tag 'staging-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (740 commits) staging: lustre: lustre: libcfs: define symbols as static staging: rtl8712: Do coding style cleanup staging: lustre: make obd_updatemax_lock static staging: rtl8188eu: core: switch with redundant cases staging: rtl8188eu: odm: conditional setting with no effect staging: rtl8188eu: odm: condition with no effect staging: ft1000: fix braces warning staging: sm7xxfb: fix remaining CamelCase staging: sm7xxfb: fix CamelCase staging: rtl8723au: multiple condition with no effect - if identical to else staging: sm7xxfb: make smtc_scr_info static staging/lustre/mdc: Initialize req in mdc_enqueue for !it case staging/lustre/clio: Do not allow group locks with gid 0 staging/lustre/llite: don't add to page cache upon failure staging/lustre/llite: Add exception entry check after radix_tree staging/lustre/libcfs: protect kkuc_groups from write access staging/lustre/fld: refer to MDT0 for fld lookup in some cases staging/lustre/llite: Solve a race to access lli_has_smd in read case staging/lustre/ptlrpc: hold rq_lock when modify rq_flags staging/lustre/lnet: portal spreading rotor should be unsigned ...
2015-02-15Merge tag 'char-misc-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc patches from Greg KH: "Here's the big char/misc driver update for 3.20-rc1. Lots of little things in here, all described in the changelog. Nothing major or unusual, except maybe the binder selinux stuff, which was all acked by the proper selinux people and they thought it best to come through this tree. All of this has been in linux-next with no reported issues for a while" * tag 'char-misc-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) coresight: fix function etm_writel_cp14() parameter order coresight-etm: remove check for unknown Kconfig macro coresight: fixing CPU hwid lookup in device tree coresight: remove the unnecessary function coresight_is_bit_set() coresight: fix the debug AMBA bus name coresight: remove the extra spaces coresight: fix the link between orphan connection and newly added device coresight: remove the unnecessary replicator property coresight: fix the replicator subtype value pdfdocs: Fix 'make pdfdocs' failure for 'uio-howto.tmpl' mcb: Fix error path of mcb_pci_probe virtio/console: verify device has config space ti-st: clean up data types (fix harmless memory corruption) mei: me: release hw from reset only during the reset flow mei: mask interrupt set bit on clean reset bit extcon: max77693: Constify struct regmap_config extcon: adc-jack: Release IIO channel on driver remove extcon: Remove duplicated include from extcon-class.c Drivers: hv: vmbus: hv_process_timer_expiration() can be static Drivers: hv: vmbus: serialize Offer and Rescind offer ...
2015-02-15Merge tag 'usb-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg KH: "Here's the big pull request for the USB driver tree for 3.20-rc1. Nothing major happening here, just lots of gadget driver updates, new device ids, and a bunch of cleanups. All of these have been in linux-next for a while with no reported issues" * tag 'usb-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (299 commits) usb: musb: fix device hotplug behind hub usb: dwc2: Fix a bug in reading the endpoint directions from reg. staging: emxx_udc: fix the build error usb: Retry port status check on resume to work around RH bugs Revert "usb: Reset USB-3 devices on USB-3 link bounce" uhci-hub: use HUB_CHAR_* usb: kconfig: replace PPC_OF with PPC ehci-pci: disable for Intel MID platforms (update) usb: gadget: Kconfig: use bool instead of boolean usb: musb: blackfin: remove incorrect __exit_p() USB: fix use-after-free bug in usb_hcd_unlink_urb() ehci-pci: disable for Intel MID platforms usb: host: pci_quirks: joing string literals USB: add flag for HCDs that can't receive wakeup requests (isp1760-hcd) USB: usbfs: allow URBs to be reaped after disconnection cdc-acm: kill unnecessary messages cdc-acm: add sanity checks usb: phy: phy-generic: Fix USB PHY gpio reset usb: dwc2: fix USB core dependencies usb: renesas_usbhs: fix NULL pointer dereference in dma_release_channel() ...
2015-02-13rtc: armada38x: add the device tree binding documentationGregory CLEMENT
The Marvell Armada 38x SoCs contains an RTC which differs from the RTC used in the other mvebu SoCs until now. This forth version of the patch set adds support for this new IP and enable it in the Device Tree of the Armada 38x SoC. This patch (of 5): The Armada 38x SoCs come with a new RTC which differs from the one used in the other mvebu SoCs until now. This patch describes the binding of this RTC. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Arnaud Ebalard <arno@natisbad.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Boris BREZILLON <boris.brezillon@free-electrons.com> Cc: Lior Amsalem <alior@marvell.com> Cc: Tawfik Bayouk <tawfik@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13rtc: add support for Abracon AB-RTCMC-32.768kHz-B5ZE-S3 I2C RTC chipArnaud Ebalard
This patch adds support for Abracon AB-RTCMC-32.768kHz-B5ZE-S3 RTC/Calendar module w/ I2C interface. This support includes RTC time reading and setting, Alarm (1 minute accuracy) reading and setting, and battery low detection. The device also supports frequency adjustment and two timers but those features are currently not implemented in this driver. Due to alarm accuracy limitation (and current lack of timer support in the driver), UIE mode is not supported. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Peter Huewe <peter.huewe@infineon.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Thierry Reding <treding@nvidia.com> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Landley <rob@landley.net> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13of: add vendor prefix for Abracon CorporationArnaud Ebalard
This series adds support for Abracon AB-RTCMC-32.768kHz-B5ZE-S3 I2C RTC chip. Unlike many RTC chips, it includes an internal oscillator which spares room on the PCB. It also has some interesting features, like battery low detection (which the driver in this series supports). The only small "limitation" (mainly due to what RTC subsystem expects from RTC chips) is the fact that its alarm is accurate to the second. This series provides a solution (described below) for that limitation using another mechanism of the chip. I decided to split support between three different patches for this v0: - Patch 1/3: it simply references Abracon Corporation in vendor-prefixes documentation file. As Abracon has no NASDAQ ticker symbol; I have decided to use "abcn" (I initially started my work w/ "ab" but later changed for "abcn" which looked more meaningful) - Patch 2/3: it adds initial support for the chip and provides the ability to read/write time and also read/write alarm. As the alarm the chip provides is accurate to the minute, the support provided by this patch also has this limitation (e.g. UIE mode is not supported). - Patch 3/3: the chip supports a watchdog timer which can be used to extend the alarm mechanism in patch 2/3 in order to provide support for alarms under one minute (e.g. support UIE mode). In practice, the logic I implemented is to use the watchdog timer for alarms which are at most 4 minutes in the future and use the common alarm mechanism for alarms which are set to larger values. With that additional patch the device fully passes the rtctest.c program. I decided to split the driver between two patches (2 and 3 of 3) in order to ease review: patch 2 should be pretty straightforward to read for someone familiar w/ RTC subsystem. Patch 3 only extends what is in patch 2 regarding alarms. This patch (of 3): Documentation/devicetree/bindings/vendor-prefixes.txt: add vendor prefix for Abracon Corporation Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Peter Huewe <peter.huewe@infineon.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Thierry Reding <treding@nvidia.com> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Landley <rob@landley.net> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13rtc: rtc-isl12057: add isil,irq2-can-wakeup-machine property for in-tree usersArnaud Ebalard
Current in-tree users of ISL12057 RTC chip (NETGEAR ReadyNAS 102, 104 and 2120) do not have the IRQ#2 pin of the chip (associated w/ the Alarm1 mechanism) connected to their SoC, but to a PMIC (TPS65251 FWIW). This specific hardware configuration allows the NAS to wake up when the alarms rings. Recently introduced alarm support for ISL12057 relies on the provision of an "interrupts" property in system .dts file, which previous three users will never get. For that reason, alarm support on those devices is not function. To support this use case, this patch adds a new DT property for ISL12057 (isil,irq2-can-wakeup-machine) to indicate that the chip is capable of waking up the device using its IRQ#2 pin (even though it does not have its IRQ#2 pin connected directly to the SoC). This specific configuration was tested on a ReadyNAS 102 by setting an alarm, powering off the device and see it reboot as expected when the alarm rang w/: # echo `date '+%s' -d '+ 1 minutes'` > /sys/class/rtc/rtc0/wakealarm # shutdown -h now As a side note, the ISL12057 remains in the list of trivial devices, because the property is not per se required by the device to work but can help handle system w/ specific requirements. In exchange, the new feature is described in details in a specific documentation file. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Peter Huewe <peter.huewe@infineon.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Thierry Reding <treding@nvidia.com> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Darshana Padmadas <darshanapadmadas@gmail.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Landley <rob@landley.net> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Kumar Gala <galak@codeaurora.org> Cc: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13drivers/rtc/rtc-pcf2123.c: add support for devicetreeJoshua Clayton
Add compatible string "nxp,rtc-pcf2123" Document the binding Signed-off-by: Joshua Clayton <stillcompiling@gmail.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu: "The big change of LED subsystem is introducing a new LED class for Flash type LEDs which will be used for V4L2 subsystem. Also we got some cleanup and fixes" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: leds-gpio: Pass on error codes unmodified DT: leds: Add led-sources property leds: Add LED Flash class extension to the LED subsystem leds: leds-mc13783: Use of_get_child_by_name() instead of refcount hack leds: Use setup_timer leds: Don't allow brightness values greater than max_brightness DT: leds: Add flash LED devices related properties
2015-02-12Merge tag 'iommu-updates-v3.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "This time with: - Generic page-table framework for ARM IOMMUs using the LPAE page-table format, ARM-SMMU and Renesas IPMMU make use of it already. - Break out the IO virtual address allocator from the Intel IOMMU so that it can be used by other DMA-API implementations too. The first user will be the ARM64 common DMA-API implementation for IOMMUs - Device tree support for Renesas IPMMU - Various fixes and cleanups all over the place" * tag 'iommu-updates-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (36 commits) iommu/amd: Convert non-returned local variable to boolean when relevant iommu: Update my email address iommu/amd: Use wait_event in put_pasid_state_wait iommu/amd: Fix amd_iommu_free_device() iommu/arm-smmu: Avoid build warning iommu/fsl: Various cleanups iommu/fsl: Use %pa to print phys_addr_t iommu/omap: Print phys_addr_t using %pa iommu: Make more drivers depend on COMPILE_TEST iommu/ipmmu-vmsa: Fix IOMMU lookup when multiple IOMMUs are registered iommu: Disable on !MMU builds iommu/fsl: Remove unused fsl_of_pamu_ids[] iommu/fsl: Fix section mismatch iommu/ipmmu-vmsa: Use the ARM LPAE page table allocator iommu: Fix trace_map() to report original iova and original size iommu/arm-smmu: add support for iova_to_phys through ATS1PR iopoll: Introduce memory-mapped IO polling macros iommu/arm-smmu: don't touch the secure STLBIALL register iommu/arm-smmu: make use of generic LPAE allocator iommu: io-pgtable-arm: add non-secure quirk ...
2015-02-12Merge tag 'devicetree-for-3.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree changes from Rob Herring: - DT unittests for I2C probing and overlays from Pantelis Antoniou - Remove DT unittest dependency on OF_DYNAMIC from Gaurav Minocha - Add Tegra compatible strings missing for newer parts from Paul Walmsley - Various vendor prefix additions * tag 'devicetree-for-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of: Add vendor prefix for OmniVision Technologies of: Use ovti for Omnivision of: Add vendor prefix for Truly Semiconductors Limited of: Add vendor prefix for Himax Technologies Inc. of/fdt: fix sparse warning of: unitest: Add I2C overlay unit tests. Documentation: DT: document compatible string existence requirement Documentation: DT bindings: add nvidia, tegra132-denver compatible string Documentation: DT bindings: add more Tegra chip compatible strings of: EXPORT_SYMBOL_GPL of_property_read_u64_array of: Fix brace position for struct of_device_id definition of/unittest: Remove obsolete code dt-bindings: use isil prefix for Intersil in vendor-prefixes.txt Add AD Holdings Plc. to vendor-prefixes. dt-bindings: Add Silicon Mitus vendor prefix Removes OF_UNITTEST dependency on OF_DYNAMIC config symbol pinctrl: fix up device tree bindings DT: Vendors: Add Everspin doc: add bindings document for altera fpga manager drivers: of: Export of_reserved_mem_device_{init,release}
2015-02-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - clang assembly fixes from Ard - optimisations and cleanups for Aurora L2 cache support - efficient L2 cache support for secure monitor API on Exynos SoCs - debug menu cleanup from Daniel Thompson to allow better behaviour for multiplatform kernels - StrongARM SA11x0 conversion to irq domains, and pxa_timer - kprobes updates for older ARM CPUs - move probes support out of arch/arm/kernel to arch/arm/probes - add inline asm support for the rbit (reverse bits) instruction - provide an ARM mode secondary CPU entry point (for Qualcomm CPUs) - remove the unused ARMv3 user access code - add driver_override support to AMBA Primecell bus * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits) ARM: 8256/1: driver coamba: add device binding path 'driver_override' ARM: 8301/1: qcom: Use secondary_startup_arm() ARM: 8302/1: Add a secondary_startup that assumes ARM mode ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip ARM: kprobes: Fix compilation error caused by superfluous '*' ARM: 8297/1: cache-l2x0: optimize aurora range operations ARM: 8296/1: cache-l2x0: clean up aurora cache handling ARM: 8284/1: sa1100: clear RCSR_SMR on resume ARM: 8283/1: sa1100: collie: clear PWER register on machine init ARM: 8282/1: sa1100: use handle_domain_irq ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver ARM: 8280/1: sa1100: switch to irq_domain_add_simple() ARM: 8279/1: sa1100: merge both GPIO irqdomains ARM: 8278/1: sa1100: split irq handling for low GPIOs ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code ARM: 8290/1: decompressor: fix a wrong comment ARM: 8286/1: mm: Fix dma_contiguous_reserve comment ARM: 8248/1: pm: remove outdated comment ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X) ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX ...
2015-02-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "Highlights: - Smack adds secmark support for Netfilter - /proc/keys is now mandatory if CONFIG_KEYS=y - TPM gets its own device class - Added TPM 2.0 support - Smack file hook rework (all Smack users should review this!)" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (64 commits) cipso: don't use IPCB() to locate the CIPSO IP option SELinux: fix error code in policydb_init() selinux: add security in-core xattr support for pstore and debugfs selinux: quiet the filesystem labeling behavior message selinux: Remove unused function avc_sidcmp() ima: /proc/keys is now mandatory Smack: Repair netfilter dependency X.509: silence asn1 compiler debug output X.509: shut up about included cert for silent build KEYS: Make /proc/keys unconditional if CONFIG_KEYS=y MAINTAINERS: email update tpm/tpm_tis: Add missing ifdef CONFIG_ACPI for pnp_acpi_device smack: fix possible use after frees in task_security() callers smack: Add missing logging in bidirectional UDS connect check Smack: secmark support for netfilter Smack: Rework file hooks tpm: fix format string error in tpm-chip.c char/tpm/tpm_crb: fix build error smack: Fix a bidirectional UDS connect check typo smack: introduce a special case for tmpfs in smack_d_instantiate() ...
2015-02-11Merge tag 'powerpc-3.20-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - Update of all defconfigs - Addition of a bunch of config options to modernise our defconfigs - Some PS3 updates from Geoff - Optimised memcmp for 64 bit from Anton - Fix for kprobes that allows 'perf probe' to work from Naveen - Several cxl updates from Ian & Ryan - Expanded support for the '24x7' PMU from Cody & Sukadev - Freescale updates from Scott: "Highlights include 8xx optimizations, some more work on datapath device tree content, e300 machine check support, t1040 corenet error reporting, and various cleanups and fixes" * tag 'powerpc-3.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (102 commits) cxl: Add missing return statement after handling AFU errror cxl: Fail AFU initialisation if an invalid configuration record is found cxl: Export optional AFU configuration record in sysfs powerpc/mm: Warn on flushing tlb page in kernel context powerpc/powernv: Add OPAL soft-poweroff routine powerpc/perf/hv-24x7: Document sysfs event description entries powerpc/perf/hv-gpci: add the remaining gpci requests powerpc/perf/{hv-gpci, hv-common}: generate requests with counters annotated powerpc/perf/hv-24x7: parse catalog and populate sysfs with events perf: define EVENT_DEFINE_RANGE_FORMAT_LITE helper perf: add PMU_EVENT_ATTR_STRING() helper perf: provide sysfs_show for struct perf_pmu_events_attr powerpc/kernel: Avoid initializing device-tree pointer twice powerpc: Remove old compile time disabled syscall tracing code powerpc/kernel: Make syscall_exit a local label cxl: Fix device_node reference counting powerpc/mm: bail out early when flushing TLB page powerpc: defconfigs: add MTD_SPI_NOR (new dependency for M25P80) perf/powerpc: reset event hw state when adding it to the PMU powerpc/qe: Use strlcpy() ...
2015-02-11Merge tag 'docs-for-linus' of git://git.lwn.net/linux-2.6Linus Torvalds
Pull documentation updates from Jonathan Corbet: "Highlights this time around include: - A thrashing of SubmittingPatches to bring it out of the "send everything to Linus" era of kernel development. - A new document on completions from Nicholas McGuire - Lots of typo fixes, formatting improvements, corrections, build fixes, and more" * tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (35 commits) Documentation: Fix the wrong command `echo -1 > set_ftrace_pid` for cleaning the filter. can-doc: Fixed a wrong filepath in can.txt Documentation: Fix trivial typo in comment. kgdb,docs: Fix typo and minor style issues Documentation: add description for FTRACE probe status doc: brief user documentation for completion Documentation/misc-devices/mei: Fix indentation of embedded code. Documentation/misc-devices/mei: Fix indentation of enumeration. Documentation/misc-devices/mei: Fix spacing around parentheses. Documentation/misc-devices/mei: Fix formatting of headings. Documentation: devicetree: Fix double words in Doumentation/devicetree Documentation: mm: Fix typo in vm.txt lockstat: Add documentation on contention and contenting points Documentation: fix blackfin gptimers-example build errors Fixes column alignment in table of contents entry 1.9 in Documentation/filesystems/proc.txt CodingStyle: enable emacs display of trailing whitespace DocBook: Do not exceed argument list limit gpio: board.txt: Fix the gpio name example Documentation/SubmittingPatches: unify whitespace/tabs for the DCO MAINTAINERS: Add the docs-next git tree to the maintainer entry ...
2015-02-11Merge branch 'mailbox-devel' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox framework updates from Jassi Brar. * 'mailbox-devel' of git://git.linaro.org/landing-teams/working/fujitsu/integration: mailbox: Add Altera mailbox driver mailbox: check for bit set before polling Mailbox: Fix return value check in pcc_init()
2015-02-11Merge tag 'pinctrl-v3.20-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pincontrol updates from Linus Walleij: :This is the bulk of pin control changes for the v3.20 cycle: Framework changes and enhancements: - Passing -DDEBUG recursively to subdir drivers so we get debug messages properly turned on. - Infer map type from DT property in the groups parsing code in the generic pinconfig code. - Support for custom parameter passing in generic pin config. This is used when you are using the generic pin config, but want to add a few custom properties that no other driver will use. New drivers: - Driver for the Xilinx Zynq - Driver for the AmLogic Meson SoCs New features in drivers: - Sleep support (suspend/resume) for the Cherryview driver - mvebeu a38x can now mux a UART on pins MPP19 and MPP20 - Migrated the qualcomm driver to generic pin config handling of extended config options in the core code. - Support BUS1 and AUDIO in the Exynos pin controller. - Add some missing functions in the sun6i driver. - Add support for the A31S variant in the sun6i driver. - EMEv2 support in the Renesas PFC driver. - Add support for Qualcomm MSM8916 in the qcom driver. Deleted features - Drop support for the SiRF Marco that was never released to the market. - Drop SH7372 support as the support for this platform is removed from the kernel" * tag 'pinctrl-v3.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (40 commits) sh-pfc: emev2 - Fix mangled author name pinctrl: cherryview: Configure HiZ pins to be input when requested as GPIOs pinctrl: imx25: fix numbering for pins pinctrl: pinctrl-imx: don't use invalid value of conf_reg pinctrl: qcom: delete pin_config_get/set pinconf operations pinctrl: qcom: Add msm8916 pinctrl driver DT: pinctrl: Document Qualcomm MSM8916 pinctrl binding pinctrl: qcom: increase variable size for register offsets pinctrl: hide PCONFDUMP in #ifdef pinctrl: rockchip: Only mask interrupts; never disable pinctrl: zynq: Fix usb0 pins pinctrl: sh-pfc: sh7372: Remove DT binding documentation pinctrl: sh-pfc: sh7372: Remove PFC support sh-pfc: Add emev2 pinmux support sh-pfc: add macro to define pinmux without function pinctrl: add driver for Amlogic Meson SoCs staging: drivers: pinctrl: Fixed checkpatch.pl warnings pinctrl: exynos: Add AUDIO pin controller for exynos7 sh-pfc: r8a7790: add MLB+ pin group sh-pfc: r8a7791: add MLB+ pin group ...
2015-02-11Merge tag 'gpio-v3.20-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "This is the GPIO bulk changes for the v3.20 series: GPIOLIB core changes: - Create and use of_mm_gpiochip_remove() for removing memory-mapped OF GPIO chips - GPIO MMIO library suppports bgpio_set_multiple for switching several lines at once, a feature merged in the last cycle. New drivers: - New driver for the APM X-gene standby GPIO controller - New driver for the Fujitsu MB86S7x GPIO controller Cleanups: - Moved rcar driver to use gpiolib irqchip - Moxart converted to the GPIO MMIO library - GE driver converted to GPIO MMIO library - Move sx150x to irqdomain - Move max732x to irqdomain - Move vx855 to use managed resources - Move dwapb to use managed resources - Clean tc3589x from platform data - Clean stmpe driver to use device tree only probe New subtypes: - sx1506 support in the sx150x driver - Quark 1000 SoC support in the SCH driver - Support X86 in the Xilinx driver - Support PXA1928 in the PXA driver Extended drivers: - max732x supports device tree probe - sx150x supports device tree probe Various minor cleanups and bug fixes" * tag 'gpio-v3.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (61 commits) gpio: kconfig: replace PPC_OF with PPC gpio: pxa: add PXA1928 gpio type support dt/bindings: gpio: add compatible string for marvell,pxa1928-gpio gpio: pxa: remove mach IRQ includes gpio: max732x: use an inline function for container cast gpio: use sizeof() instead of hardcoded values gpio: max732x: add set_multiple function gpio: sch: Consolidate similar algorithms gpio: tz1090-pdc: Use resource_size to fix off-by-one resource size calculation gpio: ge: Convert to use devm_kstrdup gpio: correctly use const char * const gpio: sx150x: fixup OF support gpio: mpc8xxx: Use of_mm_gpiochip_remove gpio: Add Fujitsu MB86S7x GPIO driver gpio: mpc8xxx: Convert to platform device interface. gpio: zevio: Use of_mm_gpiochip_remove gpio: gpio-mm-lantiq: Use of_mm_gpiochip_remove gpio: gpio-mm-lantiq: Use of_property_read_u32 gpio: gpio-mm-lantiq: Do not replicate code gpio :gpio-mm-lantiq: Use devm_kzalloc ...
2015-02-11Merge tag 'mmc-v3.20-1' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "MMC core: - Support for MMC power sequences. - SDIO function devicetree subnode parsing. - Refactor the hardware reset routines and enable it for SD cards. - Various code quality improvements, especially for slot-gpio. MMC host: - dw_mmc: Various fixes and cleanups. - dw_mmc: Convert to mmc_send_tuning(). - moxart: Fix probe logic. - sdhci: Various fixes and cleanups - sdhci: Asynchronous request handling support. - sdhci-pxav3: Various fixes and cleanups. - sdhci-tegra: Fixes for T114, T124 and T132. - rtsx: Various fixes and cleanups. - rtsx: Support for SDIO. - sdhi/tmio: Refactor and cleanup of header files. - omap_hsmmc: Use slot-gpio and common MMC DT parser. - Make all hosts to deal with errors from mmc_of_parse(). - sunxi: Various fixes and cleanups. - sdhci: Support for Fujitsu SDHCI controller f_sdh30" * tag 'mmc-v3.20-1' of git://git.linaro.org/people/ulf.hansson/mmc: (117 commits) mmc: sdhci-s3c: solve problem with sleeping in atomic context mmc: pwrseq: add driver for emmc hardware reset mmc: moxart: fix probe logic mmc: core: Invoke mmc_pwrseq_post_power_on() prior MMC_POWER_ON state mmc: pwrseq_simple: Add optional reference clock support mmc: pwrseq: Document optional clock for the simple power sequence mmc: pwrseq_simple: Extend to support more pins mmc: pwrseq: Document that simple sequence support more than one GPIO mmc: Add hardware dependencies for sdhci-pxav3 and sdhci-pxav2 mmc: sdhci-pxav3: Modify clock settings for the SDR50 and DDR50 modes mmc: sdhci-pxav3: Extend binding with SDIO3 conf reg for the Armada 38x mmc: sdhci-pxav3: Fix Armada 38x controller's caps according to erratum ERR-7878951 mmc: sdhci-pxav3: Fix SDR50 and DDR50 capabilities for the Armada 38x flavor mmc: sdhci: switch voltage before sdhci_set_ios in runtime resume mmc: tegra: Write xfer_mode, CMD regs in together mmc: Resolve BKOPS compatability issue mmc: sdhci-pxav3: fix setting of pdata->clk_delay_cycles mmc: dw_mmc: rockchip: remove incorrect __exit_p() mmc: dw_mmc: exynos: remove incorrect __exit_p() mmc: Fix menuconfig alignment of MMC_SDHCI_* options ...
2015-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "The first round of updates for the input subsystem. A few new drivers (power button handler for AXP20x PMIC, tps65218 power button driver, sun4i keys driver, regulator haptic driver, NI Ettus Research USRP E3x0 button, Alwinner A10/A20 PS/2 controller). Updates to Synaptics and ALPS touchpad drivers (with more to come later), brand new Focaltech PS/2 support, update to Cypress driver to handle Gen5 (in addition to Gen3) devices, and number of other fixups to various drivers as well as input core" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (54 commits) Input: elan_i2c - fix wrong %p extension Input: evdev - do not queue SYN_DROPPED if queue is empty Input: gscps2 - fix MODULE_DEVICE_TABLE invocation Input: synaptics - use dmax in input_mt_assign_slots Input: pxa27x_keypad - remove unnecessary ARM includes Input: ti_am335x_tsc - replace delta filtering with median filtering ARM: dts: AM335x: Make charge delay a DT parameter for TSC Input: ti_am335x_tsc - read charge delay from DT Input: ti_am335x_tsc - remove udelay in interrupt handler Input: ti_am335x_tsc - interchange touchscreen and ADC steps Input: MT - add support for balanced slot assignment Input: drv2667 - remove wrong and unneeded drv2667-haptics modalias Input: drv260x - remove wrong and unneeded drv260x-haptics modalias Input: cap11xx - remove wrong and unneeded cap11xx modalias Input: sun4i-ts - add support for touchpanel controller on A31 Input: serio - add support for Alwinner A10/A20 PS/2 controller Input: gtco - use sign_extend32() for sign extension Input: elan_i2c - verify firmware signature applying it Input: elantech - remove stale comment from Kconfig Input: cyapa - off by one in cyapa_update_fw_store() ...
2015-02-11Merge tag 'fbdev-3.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev changes from Tomi Valkeinen: - omapdss: add DRA7xxx SoC support - fbdev: support DMT (Display Monitor Timing) calculation * tag 'fbdev-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (40 commits) omapfb: Return error code when applying overlay settings fails OMAPDSS: DPI: DRA7xx support OMAPDSS: HDMI: Add DRA7xx support OMAPDSS: DISPC: program dispc polarities to control module OMAPDSS: DISPC: Add DRA7xx support OMAPDSS: Add Video PLLs for DRA7xx OMAPDSS: Add functions for external control of PLL OMAPDSS: DSS: Add DRA7xx base support Doc/DT: Add DT binding doc for DRA7xx DSS OMAPDSS: add define for DRA7xx HW version OMAPDSS: encoder-tpd12s015: Fix race issue with LS_OE OMAPDSS: OMAP5: fix digit output's allowed mgrs OMAPDSS: constify port arrays OMAPDSS: PLL: add dss_pll_wait_reset_done() OMAPDSS: Add enum dss_pll_id video: fbdev: fix sys_copyarea video/mmpfb: allow modular build fb: via: turn gpiolib and i2c selects into dependencies fbdev: ssd1307fb: return proper error code if write command fails fbdev: fix CVT vertical front and back porch values ...
2015-02-11Merge tag 'sound-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "In this batch, you can find lots of cleanups through the whole subsystem, as our good New Year's resolution. Lots of LOCs and commits are about LINE6 driver that was promoted finally from staging tree, and as usual, there've been widely spread ASoC changes. Here some highlights: ALSA core changes - Embedding struct device into ALSA core structures - sequencer core cleanups / fixes - PCM msbits constraints cleanups / fixes - New SNDRV_PCM_TRIGGER_DRAIN command - PCM kerneldoc fixes, header cleanups - PCM code cleanups using more standard codes - Control notification ID fixes Driver cleanups - Cleanups of PCI PM callbacks - Timer helper usages cleanups - Simplification (e.g. argument reduction) of many driver codes HD-audio - Hotkey and LED support on HP laptops with Realtek codecs - Dock station support on HP laptops - Toshiba Satellite S50D fixup - Enhanced wallclock timestamp handling for HD-audio - Componentization to simplify the linkage between i915 and hd-audio drivers for Intel HDMI/DP USB-audio - Akai MPC Element support - Enhanced timestamp handling ASoC - Lots of refactoringin ASoC core, moving drivers to more data driven initialization and rationalizing a lot of DAPM usage - Much improved handling of CDCLK clocks on Samsung I2S controllers - Lots of driver specific cleanups and feature improvements - CODEC support for TI PCM514x and TLV320AIC3104 devices - Board support for Tegra systems with Realtek RT5677 - New driver for Maxim max98357a - More enhancements / fixes for Intel SST driver Others - Promotion of LINE6 driver from staging along with lots of rewrites and cleanups - DT support for old non-ASoC atmel driver - oxygen cleanups, XIO2001 init, Studio Evolution SE6x support - Emu8000 DRAM size detection fix on ISA(!!) AWE64 boards - A few more ak411x fixes for ice1724 boards" * tag 'sound-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (542 commits) ALSA: line6: toneport: Use explicit type for firmware version ALSA: line6: Use explicit type for serial number ALSA: line6: Return EIO if read/write not successful ALSA: line6: Return error if device not responding ALSA: line6: Add delay before reading status ASoC: Intel: Clean data after SST fw fetch ALSA: hda - Add docking station support for another HP machine ALSA: control: fix failure to return new numerical ID in 'replace' event data ALSA: usb: update trigger timestamp on first non-zero URB submitted ALSA: hda: read trigger_timestamp immediately after starting DMA ALSA: pcm: allow for trigger_tstamp snapshot in .trigger ALSA: pcm: don't override timestamp unconditionally ALSA: off by one bug in snd_riptide_joystick_probe() ASoC: rt5670: Set use_single_rw flag for regmap ASoC: rt286: Add rt288 codec support ASoC: max98357a: Fix build in !CONFIG_OF case ASoC: Intel: fix platform_no_drv_owner.cocci warnings ARM: dts: Switch Odroid X2/U2 to simple-audio-card ARM: dts: Exynos4 and Odroid X2/U3 sound device nodes update ALSA: control: fix failure to return numerical ID in 'add' event ...
2015-02-11Merge tag 'media/v3.20-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some documentation updates and a few new pixel formats - Stop btcx-risc abuse by cx88 and move it to bt8xx driver - New platform driver: am437x - New webcam driver: toptek - New remote controller hardware protocols added to img-ir driver - Removal of a few very old drivers that relies on old kABIs and are for very hard to find hardware: parallel port webcam drivers (bw-qcam, c-cam, pms and w9966), tlg2300, Video In/Out for SGI (vino) - Removal of the USB Telegent driver (tlg2300). The company that developed this driver has long gone and the hardware is hard to find. As it relies on a legacy set of kABI symbols and nobody seems to care about it, remove it. - several improvements at rtl2832 driver - conversion on cx28521 and au0828 to use videobuf2 (VB2) - several improvements, fixups and board additions * tag 'media/v3.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (321 commits) [media] dvb_net: Convert local hex dump to print_hex_dump_debug [media] dvb_net: Use standard debugging facilities [media] dvb_net: Use vsprintf %pM extension to print Ethernet addresses [media] staging: lirc_serial: adjust boolean assignments [media] stb0899: use sign_extend32() for sign extension [media] si2168: add support for 1.7MHz bandwidth [media] si2168: return error if set_frontend is called with invalid parameters [media] lirc_dev: avoid potential null-dereference [media] mn88472: simplify bandwidth registers setting code [media] dvb: tc90522: re-add symbol-rate report [media] lmedm04: add read snr, signal strength and ber call backs [media] lmedm04: Create frontend call back for read status [media] lmedm04: create frontend callbacks for signal/snr/ber/ucblocks [media] lmedm04: Fix usb_submit_urb BOGUS urb xfer, pipe 1 != type 3 in interrupt urb [media] lmedm04: Increase Interupt due time to 200 msec [media] cx88-dvb: whitespace cleanup [media] rtl28xxu: properly initialize pdata [media] rtl2832: declare functions as static [media] rtl2830: declare functions as static [media] rtl2832_sdr: add kernel-doc comments for platform_data ...
2015-02-11Merge tag 'for-v3.20' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset changes from Sebastian Reichel: "New drivers: - charger driver for Maxim 77693 - battery gauge driver for LTC 2941/2943 - battery gauge driver for RT5033 - reset driver for R-Mobile platforms Convert drivers to restart handler framework: - arm-versatile - at91 - st-poweroff Misc: - remove deprecated sun6i reboot driver - use alarmtimer instead of rtc in charger-manager - misc fixes" * tag 'for-v3.20' of git://git.infradead.org/battery-2.6: (48 commits) power_supply: 88pm860x: Fix leaked power supply on probe fail power/reset: restart-poweroff: Remove arm dependencies power/reset: st-poweroff: Fix misleading Kconfig description power/reset: st-poweroff: Register with kernel restart handler power/reset: Remove sun6i reboot driver power/reset: at91: Register with kernel restart handler power/reset: arm-versatile: Register with kernel restart handler power: test_power: Use enum as index for array of supplies Add devicetree binding documentation for the LTC2941/LTC2943 driver Add LTC2941/LTC2943 Battery Gauge Driver power/reset: brcmstb: Add support for old 65nm chips power/reset: brcmstb: Use the DT "compatible" string to indicate bit positions power/reset: brcmstb: Make the driver buildable on MIPS power: charger-manager: Use alarmtimer for battery monitoring in suspend. power/reset: at91-poweroff: Fix error handling and other compiler warnings bq27x00_battery: Call power_supply_changed only when capacity changed bq27x00_battery: fix register offset for bq27425 power: max14577: Remove SYSFS dependency from Kconfig power: bq24190_charger: suppress build warning power: reset: Add reset driver for R-Mobile platforms ...
2015-02-11drm/exynos: Add DECON driverAjay Kumar
This patch is based on exynos-drm-next branch of Inki Dae's tree at: git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos.git DECON(Display and Enhancement Controller) is the new IP in exynos7 SOC for generating video signals using pixel data. DECON driver can be used to drive 2 different interfaces on Exynos7: DECON-INT(video controller) and DECON-EXT(Mixer for HDMI) The existing FIMD driver code was used as a template to create DECON driver. Only DECON-INT is supported as of now, and DECON-EXT support will be added later. The current version of the driver supports video mode displays. Changelog v2: - Change config name, DRM_EXYNOS_DECON to DRM_EXYNOS7_DECON. Signed-off-by: Akshu Agrawal <akshua@gmail.com> Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2015-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) More iov_iter conversion work from Al Viro. [ The "crypto: switch af_alg_make_sg() to iov_iter" commit was wrong, and this pull actually adds an extra commit on top of the branch I'm pulling to fix that up, so that the pre-merge state is ok. - Linus ] 2) Various optimizations to the ipv4 forwarding information base trie lookup implementation. From Alexander Duyck. 3) Remove sock_iocb altogether, from CHristoph Hellwig. 4) Allow congestion control algorithm selection via routing metrics. From Daniel Borkmann. 5) Make ipv4 uncached route list per-cpu, from Eric Dumazet. 6) Handle rfs hash collisions more gracefully, also from Eric Dumazet. 7) Add xmit_more support to r8169, e1000, and e1000e drivers. From Florian Westphal. 8) Transparent Ethernet Bridging support for GRO, from Jesse Gross. 9) Add BPF packet actions to packet scheduler, from Jiri Pirko. 10) Add support for uniqu flow IDs to openvswitch, from Joe Stringer. 11) New NetCP ethernet driver, from Muralidharan Karicheri and Wingman Kwok. 12) More sanely handle out-of-window dupacks, which can result in serious ACK storms. From Neal Cardwell. 13) Various rhashtable bug fixes and enhancements, from Herbert Xu, Patrick McHardy, and Thomas Graf. 14) Support xmit_more in be2net, from Sathya Perla. 15) Group Policy extensions for vxlan, from Thomas Graf. 16) Remove Checksum Offload support for vxlan, from Tom Herbert. 17) Like ipv4, support lockless transmit over ipv6 UDP sockets. From Vlad Yasevich. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1494+1 commits) crypto: fix af_alg_make_sg() conversion to iov_iter ipv4: Namespecify TCP PMTU mechanism i40e: Fix for stats init function call in Rx setup tcp: don't include Fast Open option in SYN-ACK on pure SYN-data openvswitch: Only set TUNNEL_VXLAN_OPT if VXLAN-GBP metadata is set ipv6: Make __ipv6_select_ident static ipv6: Fix fragment id assignment on LE arches. bridge: Fix inability to add non-vlan fdb entry net: Mellanox: Delete unnecessary checks before the function call "vunmap" cxgb4: Add support in cxgb4 to get expansion rom version via ethtool ethtool: rename reserved1 memeber in ethtool_drvinfo for expansion ROM version net: dsa: Remove redundant phy_attach() IB/mlx4: Reset flow support for IB kernel ULPs IB/mlx4: Always use the correct port for mirrored multicast attachments net/bonding: Fix potential bad memory access during bonding events tipc: remove tipc_snprintf tipc: nl compat add noop and remove legacy nl framework tipc: convert legacy nl stats show to nl compat tipc: convert legacy nl net id get to nl compat tipc: convert legacy nl net id set to nl compat ...
2015-02-10Merge tag 'pm+acpi-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "We have a few new features this time, including a new SFI-based cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new devfreq class for providing its governors with raw utilization data and a new ACPI driver for AMD SoCs. Still, the majority of changes here are reworks of existing code to make it more straightforward or to prepare it for implementing new features on top of it. The primary example is the rework of ACPI resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with support for IOAPIC hotplug implemented on top of it, but there is quite a number of changes of this kind in the cpufreq core, ACPICA, ACPI EC driver, ACPI processor driver and the generic power domains core code too. The most active developer is Viresh Kumar with his cpufreq changes. Specifics: - Rework of the core ACPI resources parsing code to fix issues in it and make using resource offsets more convenient and consolidation of some resource-handing code in a couple of places that have grown analagous data structures and code to cover the the same gap in the core (Jiang Liu, Thomas Gleixner, Lv Zheng). - ACPI-based IOAPIC hotplug support on top of the resources handling rework (Jiang Liu, Yinghai Lu). - ACPICA update to upstream release 20150204 including an interrupt handling rework that allows drivers to install raw handlers for ACPI GPEs which then become entirely responsible for the given GPE and the ACPICA core code won't touch it (Lv Zheng, David E Box, Octavian Purdila). - ACPI EC driver rework to fix several concurrency issues and other problems related to events handling on top of the ACPICA's new support for raw GPE handlers (Lv Zheng). - New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power Subsystem) driver for Intel chips (Ken Xue). - Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko Nikula). - Two new blacklist entries for machines (Samsung 730U3E/740U3E and 510R) where the native backlight interface doesn't work correctly while the ACPI one does (Hans de Goede). - Rework of the ACPI processor driver's handling of idle states to make the code more straightforward and less bloated overall (Rafael J Wysocki). - Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht, Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei Bai). - PCI core power management modification to avoid resuming (some) runtime-suspended devices during system suspend if they are in the right states already (Rafael J Wysocki). - New SFI-based cpufreq driver for Intel platforms using SFI (Srinidhi Kasagar). - cpufreq core fixes, cleanups and simplifications (Viresh Kumar, Doug Anderson, Wolfram Sang). - SkyLake CPU support and other updates for the intel_pstate driver (Kristen Carlson Accardi, Srinivas Pandruvada). - cpufreq-dt driver cleanup (Markus Elfring). - Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla). - Generic power domains core code fixes and cleanups (Ulf Hansson). - Operating Performance Points (OPP) core code cleanups and kernel documentation update (Nishanth Menon). - New dabugfs interface to make the list of PM QoS constraints available to user space (Nishanth Menon). - New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso). - New devfreq class (devfreq_event) to provide raw utilization data to devfreq governors (Chanwoo Choi). - Assorted minor fixes and cleanups related to power management (Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel Machek, Todd E Brandt, Wonhong Kwon). - turbostat updates (Len Brown) and cpupower Makefile improvement (Sriram Raghunathan)" * tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits) tools/power turbostat: relax dependency on APERF_MSR tools/power turbostat: relax dependency on invariant TSC Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS tools/power turbostat: relax dependency on root permission ACPI / video: Add disable_native_backlight quirk for Samsung 510R ACPI / PM: Remove unneeded nested #ifdef USB / PM: Remove unneeded #ifdef and associated dead code intel_pstate: provide option to only use intel_pstate with HWP ACPI / EC: Add GPE reference counting debugging messages ACPI / EC: Add query flushing support ACPI / EC: Refine command storm prevention support ACPI / EC: Add command flushing support. ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag ACPI: add AMD ACPI2Platform device support for x86 system ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse() ACPI / EC: Update revision due to raw handler mode. ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp. ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode. ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model ...
