commit 3397c2c45b1b6f54834dfeae30a73046f33ca943 upstream.
A new element got inserted into enum mx35_clks with commit 3713e3f5e927
("clk: imx35: define two clocks for rtc"). This insertion shifted most
nummerical clock assignments to a new nummerical value which in turn
rendered most hardcoded nummeric values in imx35.dtsi incorrect.
Restore the existing order by moving the newly introduced clock to the
end of the enum. Update the dts documentation accordingly.
Signed-off-by: Alexander Kurz <akurz@blala.de>
Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc")
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream.
On some SOCs PORTS_IMPL register value is never programmed by the
firmware and left at zero value. Which means that no sata ports are
available for software. AHCI driver used to cope up with this by
fabricating the port_map if the PORTS_IMPL register is read zero,
but recent patch broke this workaround as zero value was valid for
NVMe disks.
This patch adds ports-implemented DT bindings as workaround for this issue
in a way that DT can can override the PORTS_IMPL register in cases where
the firmware did not program it already.
Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3")
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream.
mfio 84 to 89 are described wrongly, fix it to describe
the right pin and add them to right pin-mux group.
The correct order is:
pll1_lock => mips_pll -- MFIO_83
pll2_lock => audio_pll -- MFIO_84
pll3_lock => rpu_v_pll -- MFIO_85
pll4_lock => rpu_l_pll -- MFIO_86
pll5_lock => sys_pll -- MFIO_87
pll6_lock => wifi_pll -- MFIO_88
pll7_lock => bt_pll -- MFIO_89
Cc: linux-gpio@vger.kernel.org
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: James Hartley <James.Hartley@imgtec.com>
Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver")
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
Acked-by: Rob Herring <robh@kernel.org>
commit 2e18f5a1bc18e8af7031b3b26efde25307014837 upstream.
Introduce a dt property, ti,no-idle, that prevents an IP to idle at any
point. This is to handle Errata i877, which tells that GMAC clocks
cannot be disabled.
Acked-by: Roger Quadros <rogerq@ti.com>
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Pull networking fixes from David Miller:
1) Prevent XFRM per-cpu counter updates for one namespace from being
applied to another namespace. Fix from DanS treetman.
2) Fix RCU de-reference in iwl_mvm_get_key_sta_id(), from Johannes
Berg.
3) Remove ethernet header assumption in nft_do_chain_netdev(), from
Pablo Neira Ayuso.
4) Fix cpsw PHY ident with multiple slaves and fixed-phy, from Pascal
Speck.
5) Fix use after free in sixpack_close and mkiss_close.
6) Fix VXLAN fw assertion on bnx2x, from Yuval Mintz.
7) natsemi doesn't check for DMA mapping errors, from Alexey
Khoroshilov.
8) Fix inverted test in ip6addrlbl_get(), from ANdrey Ryabinin.
9) Missing initialization of needed_headroom in geneve tunnel driver,
from Paolo Abeni.
10) Fix conntrack template leak in openvswitch, from Joe Stringer.
11) Mission initialization of wq->flags in sock_alloc_inode(), from
Nicolai Stange.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits)
sctp: sctp should release assoc when sctp_make_abort_user return NULL in sctp_close
net, socket, socket_wq: fix missing initialization of flags
drivers: net: cpsw: fix error return code
openvswitch: Fix template leak in error cases.
sctp: label accepted/peeled off sockets
sctp: use GFP_USER for user-controlled kmalloc
qlcnic: fix a loop exit condition better
net: cdc_ncm: avoid changing RX/TX buffers on MTU changes
geneve: initialize needed_headroom
ipv6: honor ifindex in case we receive ll addresses in router advertisements
addrconf: always initialize sysctl table data
ipv6/addrlabel: fix ip6addrlbl_get()
switchdev: bridge: Pass ageing time as clock_t instead of jiffies
sh_eth: fix 16-bit descriptor field access endianness too
veth: don’t modify ip_summed; doing so treats packets with bad checksums as good.
net: usb: cdc_ncm: Adding Dell DW5813 LTE AT&T Mobile Broadband Card
net: usb: cdc_ncm: Adding Dell DW5812 LTE Verizon Mobile Broadband Card
natsemi: add checks for dma mapping errors
rhashtable: Kill harmless RCU warning in rhashtable_walk_init
openvswitch: correct encoding of set tunnel action attributes
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"Just a few assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elants_i2c - fix wake-on-touch
Input: elan_i2c - set input device's vendor and product IDs
Input: sun4i-lradc-keys - fix typo in binding documentation
Input: atmel_mxt_ts - add maxtouch to I2C table for module autoload
Input: arizona-haptic - fix disabling of haptics device
Input: aiptek - fix crash on detecting device without endpoints
Input: atmel_mxt_ts - add generic platform data for Chromebooks
Input: parkbd - clear unused function pointers
Input: walkera0701 - clear unused function pointers
Input: turbografx - clear unused function pointers
Input: gamecon - clear unused function pointers
Input: db9 - clear unused function pointers
Commit 1f71e8c96fc654724723ce987e0a8b2aeb81746d ("drivers: net: cpsw: Add
support for fixed-link PHY") did not parse the "phy-mode" property in
the case of a fixed-link PHY, leaving slave_data->phy_if with its default
of PHY_INTERFACE_MODE_NA(0). This later gets passed to phy_connect() in
cpsw_slave_open(), and eventually to cpsw_phy_sel() where it hits a default
case that configures the MAC for MII mode.
The user visible symptom is that while kernel log messages seem to indicate
that the interface is set up, there is no network communication. Eventually
a watchdog error occurs:
NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
Fixes: 1f71e8c96fc6 ("drivers: net: cpsw: Add support for fixed-link PHY")
Signed-off-by: David Rivshin <drivshin@allworx.com>
Pull MTD fixes from Brian Norris:
"I was holding out on this pull request for a bit, since there are a
few other small issues being discussed that look like 4.4-rc
regressions. Hopefully I can get those stabilized soon, but these are
ready at any rate:
- A little bit of a last-minute change for the device tree "fixed
partition" binding. This is needed because we might want to reuse
the 'partitions' subnode for other sorts of partitioning
descriptions -- e.g., for describing which on-flash partition
format(s) might be used on the system.
- Also tone down a warning message, since it is probably going to
show up on a lot of systems where it should just be ignored"
* tag 'for-linus-20151217' of git://git.infradead.org/linux-mtd:
doc: dt: mtd: partitions: add compatible property to "partitions" node
mtd: ofpart: don't complain about missing 'partitions' node too loudly
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"This has fixes spread thru driver, notably among them:
- edma fixes for recent edma DT changes which went into 4.4
- odd fixes for at_hdmac
- minor fixes on bc dma and mic dma"
* tag 'dmaengine-fix-4.4-rc6' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: at_xdmac: fix at_xdmac_prep_dma_memcpy()
dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type
dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type
dmaengine: mic_x100: add missing spin_unlock
dmaengine: bcm2835-dma: Convert to use DMA pool
dmaengine: at_xdmac: fix bad behavior in interleaved mode
dmaengine: at_xdmac: fix false condition for memset_sg transfers
dmaengine: at_xdmac: fix macro typo
Pull ARM SoC fixes from Arnd Bergmann:
"Here are a bunch of small bug fixes for various ARM platforms, nothing
really sticks out this week, most of either fixes bugs in code that
was just added in 4.4, or that has been broken for many years without
anyone noticing.
at91/sama5d2:
- fix sama5de hardware setup of sd/mmc interface
- proper selection of pinctrl drivers. PIO4 is necessary for sama5d2
berlin:
- fix incorrect clock input for SDIO
exynos:
- Fix potential NULL pointer dereference in Exynos PMU driver.
imx:
- Fix vf610 SAI clock configuration bug which is discovered by the
newly added master mode support in SAI audio driver.
- Fix buggy L2 cache latency values in vf610 device trees, which may
cause system hang when cpu runs at a higher frequency.
ixp4xx:
- fix prototypes for readl/writel functions
ls2080a:
- use little-endian register access for GPIO and SDHCI
omap:
- Fix clock source for ARM TWD and global timers on am437x
- Always select REGULATOR_FIXED_VOLTAGE for omap2+ instead of when
MACH_OMAP3_PANDORA is selected
- Fix SPI DMA handles for dm816x as only some were mapped
- Fix up mbox cells for dm816x to make mailbox usable
pxa:
- use PWM lookup table for all ezx machines
s3c24xx:
- Remove incorrect __init annotation from s3c24xx cpufreq driver
structures.
versatile:
- fix PCI IRQ mapping on Versatile PB"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ls2080a/dts: Add little endian property for GPIO IP block
dt-bindings: define little-endian property for QorIQ GPIO
ARM64: dts: ls2080a: fix eSDHC endianness
ARM: dts: vf610: use reset values for L2 cache latencies
ARM: pxa: use PWM lookup table for all machines
ARM: dts: berlin: add 2nd clock for BG2Q sdhci0 and sdhci1
ARM: dts: berlin: correct BG2Q's sdhci2 2nd clock
ARM: dts: am4372: fix clock source for arm twd and global timers
ARM: at91: fix pinctrl driver selection
ARM: at91/dt: add always-on to 1.8V regulator
ARM: dts: vf610: fix clock definition for SAI2
ARM: imx: clk-vf610: fix SAI clock tree
ARM: ixp4xx: fix read{b,w,l} return types
irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB
ARM: OMAP2+: enable REGULATOR_FIXED_VOLTAGE
ARM: dts: add dm816x missing spi DT dma handles
ARM: dts: add dm816x missing #mbox-cells
cpufreq: s3c24xx: Do not mark s3c2410_plls_add as __init
ARM: EXYNOS: Fix potential NULL pointer access in exynos_sys_powerdown_conf
Trivial typo fix ("mut" -> "must") in the sunxi LRADC-keys binding
documentation.
Signed-off-by: Karsten Merker <merker@debian.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The GPIO block on different QorIQ chips could have registers in different
endianess. Define the property to specify which endian is used by the
hardware.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
This change makes the DT file to be easier to read since the reserved slots
array does not need the '/bits/ 16' to be specified, which might confuse
some people.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This change makes the DT file to be easier to read since the memcpy
channels array does not need the '/bits/ 16' to be specified, which might
confuse some people.
As noted here [1], there are potentially future conflicts if we try to
use MTD's "partitions" subnode to describe anything besides just the
fixed-in-the-device-tree partitions currently described in this
document. Particularly, there was a proposal to use this node for the
AFS parser too.
It can pose a (small) problem to try to differentiate the following
nodes:
// using binding as currently specified
partitions {
#address-cells = <x>;
#size-cells = <y>;
partition@0 {
and
// proposed future binding
partitions {
compatible = "arm,arm-flash-structure";
It's especially difficult if other uses of this node start having
subnodes.
So, since the "partitions" node is new in v4.4, let's fixup the binding
before release so that it requires a compatible property, so it's much
clearer to distinguish. e.g.:
// proposed
partitions {
compatible = "fixed-partitions";
#size-cells = <y>;
partition@0 {
[1] Subject: "mtd: create a partition type device tree binding"
http://lkml.kernel.org/g/20151113220039.GA74382@google.com
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063355.html
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063364.html
Cc: Michal Suchanek <hramrach@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
"A lot of Thanksgiving turkey leftovers accumulated, here goes:
1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg.
2) IDs for some new iwlwifi chips, from Oren Givon.
3) Fix rtlwifi lockups on boot, from Larry Finger.
4) Fix memory leak in fm10k, from Stephen Hemminger.
5) We have a route leak in the ipv6 tunnel infrastructure, fix from
Paolo Abeni.
6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim.
7) Wrong lockdep annotations in tcp md5 support, fix from Eric
Dumazet.
8) Work around some middle boxes which prevent proper handling of TCP
Fast Open, from Yuchung Cheng.
9) TCP repair can do huge kmalloc() requests, build paged SKBs
instead. From Eric Dumazet.
10) Fix msg_controllen overflow in scm_detach_fds, from Daniel
Borkmann.
11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from
Nikolay Aleksandrov.
12) Fix use after free in epoll with AF_UNIX sockets, from Rainer
Weikusat.
13) Fix double free in VRF code, from Nikolay Aleksandrov.
14) Fix skb leaks on socket receive queue in tipc, from Ying Xue.
15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian.
16) Fix clearing of persistent array maps in bpf, from Daniel
Borkmann.
17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq
early enough. From Eric Dumazet.
18) Fix out of bounds accesses in bpf array implementation when
updating elements, from Daniel Borkmann.
19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric
Dumazet.
20) When dumping proxy neigh entries, we have to accomodate NULL
device pointers properly, from Konstantin Khlebnikov.
21) SCTP doesn't release all ipv6 socket resources properly, fix from
Eric Dumazet.
22) Prevent underflows of sch->q.qlen for multiqueue packet
schedulers, also from Eric Dumazet.
23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey
Huang and Michael Chan.
24) Don't actively scan radar channels, from Antonio Quartulli"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits)
net: phy: reset only targeted phy
bnxt_en: Setup uc_list mac filters after resetting the chip.
bnxt_en: enforce proper storing of MAC address
bnxt_en: Fixed incorrect implementation of ndo_set_mac_address
net: lpc_eth: remove irq > NR_IRQS check from probe()
net_sched: fix qdisc_tree_decrease_qlen() races
openvswitch: fix hangup on vxlan/gre/geneve device deletion
ipv4: igmp: Allow removing groups from a removed interface
ipv6: sctp: implement sctp_v6_destroy_sock()
arm64: bpf: add 'store immediate' instruction
ipv6: kill sk_dst_lock
ipv6: sctp: add rcu protection around np->opt
net/neighbour: fix crash at dumping device-agnostic proxy entries
sctp: convert sack_needed and sack_generation to bits
ipv6: add complete rcu protection around np->opt
bpf: fix allocation warnings in bpf maps and integer overflow
mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0
net: mvneta: enable setting custom TX IP checksum limit
net: mvneta: fix error path for building skb
Since Armada 38x SoC can support IP checksum for jumbo frames only on
a single port, it means that this feature should be enabled per-port,
rather than for the whole SoC.
This patch enables setting custom TX IP checksum limit by adding new
optional property to the mvneta device tree node. If not used, by
default 1600B is set for "marvell,armada-370-neta" and 9800B for other
strings, which ensures backward compatibility. Binding documentation
is updated accordingly.
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management fixes from Zhang Rui:
"Specifics:
- several fixes and cleanups on Rockchip thermal drivers.
- add the missing support of RK3368 SoCs in Rockchip driver.
- small fixes on of-thermal, power_allocator, rcar driver, IMX, and
QCOM drivers, and also compilation fixes, on thermal.h, when thermal
is not selected"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
imx: thermal: use CPU temperature grade info for thresholds
thermal: fix thermal_zone_bind_cooling_device prototype
Revert "thermal: qcom_spmi: allow compile test"
thermal: rcar_thermal: remove redundant operation
thermal: of-thermal: Reduce log level for message when can't fine thermal zone
thermal: power_allocator: Use temperature reading from tz
thermal: rockchip: Support the RK3368 SoCs in thermal driver
thermal: rockchip: consistently use int for temperatures
thermal: rockchip: Add the sort mode for adc value increment or decrement
thermal: rockchip: improve the conversion function
thermal: rockchip: trivial: fix typo in commit
thermal: rockchip: better to compatible the driver for different SoCs
dt-bindings: rockchip-thermal: Support the RK3368 SoCs compatible
Pull MIPS updates from Ralf Baechle:
"These are the highlists of the main MIPS pull request for 4.4:
- Add latencytop support
- Support appended DTBs
- VDSO support and initially use it for gettimeofday.
- Drop the .MIPS.abiflags and ELF NOTE sections from vmlinux
- Support for the 5KE, an internal test core.
- Switch all MIPS platfroms to libata drivers.
- Improved support, cleanups for ralink and Lantiq platforms.
- Support for the new xilfpga platform.
- A number of DTB improvments for BMIPS.
- Improved support for CM and CPS.
- Minor JZ4740 and BCM47xx enhancements"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (120 commits)
MIPS: idle: add case for CPU_5KE
MIPS: Octeon: Support APPENDED_DTB
MIPS: vmlinux: create a section for appended DTB
MIPS: Clean up compat_siginfo_t
MIPS: Fix PAGE_MASK definition
MIPS: BMIPS: Enable GZIP ramdisk and timed printks
MIPS: Add xilfpga defconfig
MIPS: xilfpga: Add mipsfpga platform code
MIPS: xilfpga: Add xilfpga device tree files.
dt-bindings: MIPS: Document xilfpga bindings and boot style
MIPS: Make MIPS_CMDLINE_DTB default
MIPS: Make the kernel arguments from dtb available
MIPS: Use USE_OF as the guard for appended dtb
MIPS: BCM63XX: Use pr_* instead of printk
MIPS: Loongson: Cleanup CONFIG_LOONGSON_SUSPEND.
MIPS: lantiq: Disable xbar fpi burst mode
MIPS: lantiq: Force the crossbar to big endian
MIPS: lantiq: Initialize the USB core on boot
MIPS: lantiq: Return correct value for fpi clock on ar9
MIPS: ralink: Add missing clock on rt305x
Pull more input updates from Dmitry Torokhov:
"An update to the tsc2005 driver that allows it to also support tsc2004
(basically the same controller, but uses i2c instead of spi bus), and
a couple of bug fixes"
Input: parkbd - drop bogus __init from parkbd_allocate_serio()
Input: elantech - add Fujitsu Lifebook U745 to force crc_enabled
Input: tsc2004 - add support for tsc2004
Input: tsc200x-core - rename functions and variables
Input: tsc2005 - separate SPI and core functions
Pull final round of SCSI updates from James Bottomley:
"Sorry for the delay in this patch which was mostly caused by getting
the merger of the mpt2/mpt3sas driver, which was seen as an essential
item of maintenance work to do before the drivers diverge too much.
Unfortunately, this caused a compile failure (detected by linux-next),
which then had to be fixed up and incubated.
In addition to the mpt2/3sas rework, there are updates from pm80xx,
lpfc, bnx2fc, hpsa, ipr, aacraid, megaraid_sas, storvsc and ufs plus
an assortment of changes including some year 2038 issues, a fix for a
remove before detach issue in some drivers and a couple of other minor
issues"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (141 commits)
mpt3sas: fix inline markers on non inline function declarations
sd: Clear PS bit before Mode Select.
ibmvscsi: set max_lun to 32
ibmvscsi: display default value for max_id, max_lun and max_channel.
mptfusion: don't allow negative bytes in kbuf_alloc_2_sgl()
scsi: pmcraid: replace struct timeval with ktime_get_real_seconds()
mvumi: 64bit value for seconds_since1970
be2iscsi: Fix bogus WARN_ON length check
scsi_scan: don't dump trace when scsi_prep_async_scan() is called twice
mpt3sas: Bump mpt3sas driver version to 09.102.00.00
mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs
mpt2sas, mpt3sas: Update the driver versions
mpt3sas: setpci reset kernel oops fix
mpt3sas: Added OEM Gen2 PnP ID branding names
mpt3sas: Refcount fw_events and fix unsafe list usage
mpt3sas: Refcount sas_device objects and fix unsafe list usage
mpt3sas: sysfs attribute to report Backup Rail Monitor Status
mpt3sas: Ported WarpDrive product SSS6200 support
mpt3sas: fix for driver fails EEH, recovery from injected pci bus error
mpt3sas: Manage MSI-X vectors according to HBA device type
This patchset attempts to new compatible for thermal founding
on RK3368 SoCs.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- Add empty of_translate_address needed for HiSilicon network driver.
- Fix alignment requirements for CMA regions in DT.
- Fix booting on PPC systems which can't do WARN() early.
- Rename ak4554 binding doc from .c to .txt.
* tag 'devicetree-fixes-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: Provide static inline function for of_translate_address if needed
drivers: of: of_reserved_mem: fixup the alignment with CMA setup
of: Print rather than WARN'ing when overlap check fails
dt-bindings: ak4554: extension should be .txt
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This round contains a couple of new drivers for the Marvell Berlin
family of SoCs, various SoCs from Renesas and Broadcom as well as the
backlight PWM present on MediaTek SoCs.
Further existing drivers are extended to support a wider range of
hardware.
The remaining patches are minor fixes and cleanups across the board.
Note that one of the patches included in this pull request is against
arch/unicore32. I've included it here because I couldn't get a
response from Guan Xuetao and I consider the change low-risk.
Equivalent patches have been merged and tested in Samsung and PXA
trees. The goal is to finally get rid of legacy code paths that have
repeatedly been causing headaches"
* tag 'pwm/for-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (24 commits)
pwm: sunxi: Fix whitespace issue
pwm: sysfs: Make use of the DEVICE_ATTR_[RW][WO] macro's
pwm: sysfs: Remove unnecessary temporary variable
unicore32: nb0916: Use PWM lookup table
pwm: pwm-rcar: Revise the device tree binding document about compatible
pwm: Return -ENODEV if no PWM lookup match is found
pwm: sun4i: Add support for PWM controller on sun5i SoCs
pwm: Set enable state properly on failed call to enable
pwm: lpss: Add support for runtime PM
pwm: lpss: Add more Intel Broxton IDs
pwm: lpss: Support all four PWMs on Intel Broxton
pwm: lpss: Add support for multiple PWMs
pwm-pca9685: enable ACPI device found on Galileo Gen2
pwm: Add MediaTek display PWM driver support
dt-bindings: pwm: Add MediaTek display PWM bindings
pwm: tipwmss: Enable on TI DRA7x and AM437x
pwm: atmel-hlcdc: add sama5d2 SoC support.
pwm: Add Broadcom BCM7038 PWM controller support
Documentation: dt: add Broadcom BCM7038 PWM controller binding
pwm: Add support for R-Car PWM Timer
Pull thermal updates from Zhang Rui:
- Implement generic devfreq cooling mechanism through frequency
reduction for devices using devfreq. From Ørjan Eide and Javi
Merino.
- Introduce OMAP3 support on TI SoC thermal driver. From Pavel Mack
and Eduardo Valentin.
- A bounch of small fixes on devfreq_cooling, Exynos, IMX, Armada, and
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (24 commits)
thermal: exynos: Directly return 0 instead of using local ret variable
thermal: exynos: Remove unneeded semicolon
thermal: exynos: Use IS_ERR() because regulator cannot be NULL
thermal: exynos: Fix first temperature read after registering sensor
thermal: exynos: Fix unbalanced regulator disable on probe failure
devfreq_cooling: return on allocation failure
thermal: rockchip: support the sleep pinctrl state to avoid glitches in s2r
dt-bindings: rockchip-thermal: Add the pinctrl states in this document
thermal: devfreq_cooling: Make power a u64
thermal: devfreq_cooling: use a thermal_cooling_device for register and unregister
thermal: underflow bug in imx_set_trip_temp()
thermal: armada: Fix possible overflow in the Armada 380 thermal sensor formula
thermal: imx: register irq handler later in probe
thermal: rockhip: fix setting thermal shutdown polarity
thermal: rockchip: fix handling of invalid readings
devfreq_cooling: add trace information
thermal: Add devfreq cooling
PM / OPP: get the voltage for all OPPs
tools/thermal: tmon: use pkg-config also for CFLAGS
linux/thermal.h: rename KELVIN_TO_CELSIUS to DECI_KELVIN_TO_CELSIUS
Xilfpga boots only with device-tree. Document the required properties
and the unique boot style
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Cc: robh+dt@kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/11361/
1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet.
2) Several spots need to get to the original listner for SYN-ACK
packets, most spots got this ok but some were not. Whilst covering
the remaining cases, create a helper to do this. From Eric Dumazet.
3) Missiing check of return value from alloc_netdev() in CAIF SPI code,
from Rasmus Villemoes.
4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich.
5) Use after free in mvneta driver, from Justin Maggard.
6) Fix race on dst->flags access in dst_release(), from Eric Dumazet.
7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd
Bergmann.
8) Fix multicast getsockopt deadlock, from WANG Cong.
9) Fix deadlock in btusb, from Kuba Pawlak.
10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6
counter state. From Sabrina Dubroca.
11) Fix packet_bind() race, which can cause lost notifications, from
Francesco Ruggeri.
12) Fix MAC restoration in qlcnic driver during bonding mode changes,
from Jarod Wilson.
13) Revert bridging forward delay change which broke libvirt and other
userspace things, from Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
Revert "bridge: Allow forward delay to be cfgd when STP enabled"
bpf_trace: Make dependent on PERF_EVENTS
qed: select ZLIB_INFLATE
net: fix a race in dst_release()
net: mvneta: Fix memory use after free.
net: Documentation: Fix default value tcp_limit_output_bytes
macvtap: Resolve possible __might_sleep warning in macvtap_do_read()
mvneta: add FIXED_PHY dependency
net: caif: check return value of alloc_netdev
net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA
drivers: net: xgene: fix RGMII 10/100Mb mode
netfilter: nft_meta: use skb_to_full_sk() helper
net_sched: em_meta: use skb_to_full_sk() helper
sched: cls_flow: use skb_to_full_sk() helper
netfilter: xt_owner: use skb_to_full_sk() helper
smack: use skb_to_full_sk() helper
net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid()
bpf: doc: correct arch list for supported eBPF JIT
dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put"
bonding: fix panic on non-ARPHRD_ETHER enslave failure
Signed-off-by: Raphaël Poggi <poggi.raph@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Pull ARM DT updates from Olof Johansson:
"As usual, this is the massive branch we have for each release. Lots
of various updates and additions of hardware descriptions on existing
hardware, as well as the usual additions of new boards and SoCs.
This is also the first release where we've started mixing 64- and
32-bit DT updates in one branch.
(Specific details on what's actually here and new is pretty easy to
tell from the diffstat, so there's little point in duplicating listing
it here)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (499 commits)
ARM: dts: uniphier: add system-bus-controller nodes
ARM64: juno: disable NOR flash node by default
ARM: dts: uniphier: add outer cache controller nodes
arm64: defconfig: Enable PCI generic host bridge by default
arm64: Juno: Add support for the PCIe host bridge on Juno R1
Documentation: of: Document the bindings used by Juno R1 PCIe host bridge
ARM: dts: uniphier: add I2C aliases for ProXstream2 boards
dts/Makefile: Add build support for LS2080a QDS & RDB board DTS
dts/ls2080a: Add DTS support for LS2080a QDS & RDB boards
dts/ls2080a: Update Simulator DTS to add support of various peripherals
dts/ls2080a: Remove text about writing to Free Software Foundation
dts/ls2080a: Update DTSI to add support of various peripherals
doc: DTS: Update DWC3 binding to provide reference to generic bindings
doc/bindings: Update GPIO devicetree binding documentation for LS2080A
Documentation/dts: Move FSL board-specific bindings out of /powerpc
Documentation: DT: Add entry for FSL LS2080A QDS and RDB boards
arm64: Rename FSL LS2085A SoC support code to LS2080A
arm64: Use generic Layerscape SoC family naming
ARM: dts: uniphier: add ProXstream2 Vodka board support
ARM: dts: uniphier: add ProXstream2 Gentil board support
Pull ARM SoC driver updates from Olof Johansson:
"As we've enabled multiplatform kernels on ARM, and greatly done away
with the contents under arch/arm/mach-*, there's still need for
SoC-related drivers to go somewhere.
Many of them go in through other driver trees, but we still have
drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code
that might be shared between ARM and ARM64 (or just in general makes
sense to not have under the architecture directory).
This branch contains mostly such code:
- Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to
communicate with power management blocks on these SoCs for use by
clock, regulator and bus frequency drivers.
- Allwinner Reduced Serial Bus driver, again used to communicate with
PMICs.
- Drivers for ARM's SCPI (System Control Processor). Not to be
confused with PSCI (Power State Coordination Interface). SCPI is
used to communicate with the assistant embedded cores doing power
management, and we have yet to see how many of them will implement
this for their hardware vs abstracting in other ways (or not at all
like in the past).
- To make confusion between SCPI and PSCI more likely, this release
also includes an update of PSCI to interface version 1.0.
- Rockchip support for power domains.
- A driver to talk to the firmware on Raspberry Pi"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits)
soc: qcom: smd-rpm: Correct size of outgoing message
bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus
bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings
ARM: bcm2835: add mutual inclusion protection
drivers: psci: make PSCI 1.0 functions initialization version dependent
dt-bindings: Correct paths in Rockchip power domains binding document
soc: rockchip: power-domain: don't try to print the clock name in error case
soc: qcom/smem: add HWSPINLOCK dependency
clk: berlin: add cpuclk
ARM: berlin: dts: add CLKID_CPU for BG2Q
ARM: bcm2835: Add the Raspberry Pi firmware driver
soc: qcom: smem: Move RPM message ram out of smem DT node
soc: qcom: smd-rpm: Correct the active vs sleep state flagging
soc: qcom: smd: delete unneeded of_node_put
firmware: qcom-scm: build for correct architecture level
soc: qcom: smd: Correct SMEM items for upper channels
qcom-scm: add missing prototype for qcom_scm_is_available()
qcom-scm: fix endianess issue in __qcom_scm_is_call_available
soc: qcom: smd: Reject send of too big packets
soc: qcom: smd: Handle big endian CPUs
Pull ARM SoC platform updates from Olof Johansson:
"New and/or improved SoC support for this release:
Marvell Berlin:
- Enable standard DT-based cpufreq
- Add CPU hotplug support
Freescale:
- Ethernet init for i.MX7D
- Suspend/resume support for i.MX6UL
Allwinner:
- Support for R8 chipset (used on NTC's $9 C.H.I.P board)
Mediatek:
- SMP support for some platforms
Uniphier:
- L2 support
- Cleaned up SMP support, etc.
plus a handful of other patches around above functionality, and a few
other smaller changes"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM: uniphier: rework SMP operations to use trampoline code
ARM: uniphier: add outer cache support
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: mvebu: add broken-idle option
ARM: orion5x: use mac_pton() helper
ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned
ARM: sunxi: Add R8 support
ARM: digicolor: select pinctrl/gpio driver
arm: berlin: add CPU hotplug support
arm: berlin: use non-self-cleared reset register to reset cpu
ARM: mediatek: add smp bringup code
ARM: mediatek: enable gpt6 on boot up to make arch timer working
soc: mediatek: Fix random hang up issue while kernel init
soc: ti: qmss: make acc queue support optional in the driver
soc: ti: add firmware file name as part of the driver
Documentation: dt: soc: Add description for knav qmss driver
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
Pull ARM SoC cleanups from Olof Johansson:
"Again we have a sizable (but not huge) cleanup branch with a net delta
of about -3k lines.
Main contents here is:
- A bunch of development/cleanup of a few PXA boards
- Removal of bockw platforms on shmobile, since the platform has now
gone completely multiplatform. Whee!
- move of the 32kHz timer on OMAP to a proper timesource
- Misc cleanup of older OMAP material (incl removal of one board
file)
- Switch over to new common PWM lookup support for several platforms
There's also a handful of other cleanups across the tree, but the
above are the major pieces"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (103 commits)
ARM: OMAP3: hwmod data: Remove legacy mailbox data and addrs
ARM: DRA7: hwmod data: Remove spinlock hwmod addrs
ARM: OMAP4: hwmod data: Remove spinlock hwmod addrs
ARM: DRA7/AM335x/AM437x: hwmod: Remove gpmc address space from hwmod data
ARM: Remove __ref on hotplug cpu die path
ARM: Remove open-coded version of IRQCHIP_DECLARE
arm: omap2: board-generic: use omap4_local_timer_init for AM437x
ARM: DRA7/AM335x/AM437x: hwmod: Remove elm address space from hwmod data
ARM: OMAP: Remove duplicated operand in OR operation
clocksource: ti-32k: make it depend on GENERIC_CLOCKSOURCE
ARM: pxa: remove incorrect __init annotation on pxa27x_set_pwrmode
ARM: pxa: raumfeld: make some variables static
ARM: OMAP: Change all cpu_is_* occurences to soc_is_* for id.c
ARM: OMAP2+: Rename cpu_is macros to soc_is
arm: omap2: timer: limit hwmod usage to non-DT boots
arm: omap2+: select 32k clocksource driver
clocksource: add TI 32.768 Hz counter driver
arm: omap2: timer: rename omap_sync32k_timer_init()
arm: omap2: timer: always call clocksource_of_init() when DT
arm: omap2: timer: move realtime_counter_init() around
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- New drivers: UniPhier (with and without FIFO)
- some drivers got some bigger rework: ismt, designware, img-scb (rcar
had to be reverted because issues were showing up just lately)
- ACPI: reworked the device scanning and added support for muxes
... and quite a lot of driver bugfixes and cleanups this time. All
files touched outside of the i2c realm have proper acks.
* 'i2c/for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (70 commits)
i2c: rcar: Revert the latest refactoring series
i2c: pnx: remove superfluous assignment
MAINTAINERS: i2c: drop i2c-pnx maintainer
MAINTAINERS: i2c: mark also subdirectories as maintained
i2c: cadence: enable driver for ARM64
i2c: i801: Document Intel DNV and Broxton
i2c: at91: manage unexpected RXRDY flag when starting a transfer
i2c: pnx: Use setup_timer instead of open coding it
i2c: add ACPI support for I2C mux ports
acpi: add acpi_preset_companion() stub
i2c: pxa: Add support for pxa910/988 & new configuration features
i2c: au1550: Convert to devm_kzalloc and devm_ioremap_resource
i2c-dev: Fix I2C_SLAVE ioctl comment
i2c-dev: Fix typo in ioctl name reference
i2c: sirf: tune the divider to make i2c bus freq more accurate
i2c: imx: Use -ENXIO as error in the NACK case
i2c: i801: Add support for Intel Broxton
i2c: i801: Add support for Intel DNV
i2c: mediatek: add i2c resume support
i2c: imx: implement bus recovery
Pull watchdog update from Wim Van Sebroeck:
- New driver for Broadcom 7038 Set-Top Box
- imx2_wdt: Use register definition in regmap_write()
- intel-mid: add Magic Closure flag
- watchdog framework improvements:
- Use device tree alias for naming watchdogs
- propagate ping error code to the user space
- Always evaluate new timeout against min_timeout
- Use single variable name for struct watchdog_device
- include clean-ups
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: include: add units for timeout values in kerneldoc
watchdog: include: fix some typos
watchdog: core: propagate ping error code to the user space
watchdog: watchdog_dev: Use single variable name for struct watchdog_device
watchdog: Always evaluate new timeout against min_timeout
watchdog: intel-mid: add Magic Closure flag
watchdog: imx2_wdt: Use register definition in regmap_write()
watchdog: watchdog_dev: Use device tree alias for naming watchdogs
watchdog: Watchdog driver for Broadcom Set-Top Box
watchdog: bcm7038: add device tree binding documentation
Pull dmaengine updates from Vinod Koul:
"This time we have a very typical update which is mostly fixes and
updates to drivers and no new drivers.
- the biggest change is coming from Peter for edma cleanup which even
caused some last minute regression, things seem settled now
- idma64 and dw updates
- iotdma updates
- module autoload fixes for various drivers
- scatter gather support for hdmac"
* tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits)
dmaengine: edma: Add dummy driver skeleton for edma3-tptc
Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3"
Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3"
dmaengine: dw: some Intel devices has no memcpy support
dmaengine: dw: platform: provide platform data for Intel
dmaengine: dw: don't override platform data with autocfg
dmaengine: hdmac: Add scatter-gathered memset support
dmaengine: hdmac: factorise memset descriptor allocation
dmaengine: virt-dma: Fix kernel-doc annotations
dmaengine: edma: New device tree binding
dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP
dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx
dmaengine: edma: Merge the of parsing functions
dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot
dmaengine: edma: Refactor the dma device and channel struct initialization
dmaengine: edma: Get qDMA channel information from HW also
dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq
dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_)
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"Core:
- Fix rtctest error path
New drivers:
- Microcrystal RV8803
Subsystem wide cleanups:
- remove misuse of IRQF_NO_SUSPEND flag
Drivers:
- at91rm9200: clear RTC alarm status flag prior to suspending
- davinci: remove incorrect reference to probe function
- ds1307: Fix alarm programming for mcp794xx
- ds1390: trickle charger support, fix ds1390_get_reg
- isl1208: Pass the IRQF_ONESHOT flag
- opal: fix type of token
- pcf2127: fix RTC_READ_VL, remove useless driver version
- pcf85063: return an error when date is invalid
- pcf8563: add CLKOUT to common clock framework
- rx8025: remove unnecessary braces
- s3c: Set year, month, day value for setting alarm
- stmp3xxx: unify register access macros
- License fixes: pcf2127, da9063
- wakeup-source support for isl12057 and opal"
* tag 'rtc-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (23 commits)
rtc: Add a driver for Micro Crystal RV8803
rtc: s3c: Set year, month, day value for setting alarm
rtc: ds1307: Fix alarm programming for mcp794xx
rtc: isl12057: enable support for the standard "wakeup-source" property
rtc: opal: enable support for the stardard "wakeup-source" property
rtc: isl1208: Pass the IRQF_ONESHOT flag
rtc: pcf8563: add CLKOUT to common clock framework
rtc: davinci: remove incorrect reference to probe function
rtc: at91rm9200: clear RTC alarm status flag prior to suspending
rtc: pcf2127: remove useless driver version
rtc: pcf2127: fix reading uninitialized value on RTC_READ_VL ioctl
rtc: stmp3xxx: unify register access macros
rtc: da9063: GPL copyright inconsistency fix
rtc: pcf85063: return an error when date is invalid
rtc: rx8025: remove unnecessary braces
rtc: ds1343: remove misuse of IRQF_NO_SUSPEND flag
rtc: ab8500: remove misuse of IRQF_NO_SUSPEND flag
rtc: pl031: remove misuse of IRQF_NO_SUSPEND flag
rtc: opal: fix type of token
rtc: ds1390: Add trickle charger device tree binding
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
- omap: fix hdmi audio configuration issue
- ssd1307fb: add ssd1309 support
- tridentfb: support DDC
- gxt4500: enable support for non-PPC platforms
* tag 'fbdev-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
radeonfb: Deinline large functions
gxt4500: enable panning
gxt4500: Use arch_phys_wc_* for framebuffer
gxt4500: fix color order
gxt4500: fix 16bpp 565 mode
gxt4500: enable on non-PPC architectures
tridentfb: Add DDC support
fb_ddc: Allow I2C adapters without SCL read capability
fbdev: ssd1307fb: add ssd1309 support
fbdev: ssd1307fb: alphabetize headers
video/omap: remove invalid check
OMAPDSS: hdmi: Reconfigure and restart audio when display is enabled
Pull drm updates from Dave Airlie:
"I Was Almost Tempted To Capitalise Every Word, but then I decided I
couldn't read it myself!
I've also got one pull request for the sti driver outstanding. It
relied on a commit in Greg's tree and I didn't find out in time, that
commit is in your tree now so I might send that along once this is
merged.
I also had the accidental misfortune to have access to a Skylake on my
desk for a few days, and I've had to encourage Intel to try harder,
which seems to be happening now.
Here is the main drm-next pull request for 4.4.
Highlights:
New driver:
vc4 driver for the Rasberry Pi VPU.
(From Eric Anholt at Broadcom.)
Core:
Atomic fbdev support
Atomic helpers for runtime pm
dp/aux i2c STATUS_UPDATE handling
struct_mutex usage cleanups.
Generic of probing support.
Documentation:
Kerneldoc for VGA switcheroo code.
Rename to gpu instead of drm to reflect scope.
i915:
Skylake GuC firmware fixes
HPD A support
VBT backlight fallbacks
Fastboot by default for some systems
FBC work
BXT/SKL workarounds
Skylake deeper sleep state fixes
amdgpu:
Enable GPU scheduler by default
New atombios opcodes
GPUVM debugging options
Stoney support.
Fencing cleanups.
radeon:
More efficient CS checking
nouveau:
gk20a instance memory handling improvements.
Improved PGOB detection and GK107 support
Kepler GDDR5 PLL statbility improvement
G8x/GT2xx reclock improvements
new userspace API compatiblity fixes.
virtio-gpu:
Add 3D support - qemu 2.5 has it merged for it's gtk backend.
msm:
Initial msm88896 (snapdragon 8200)
exynos:
HDMI cleanups
Enable mixer driver byt default
Add DECON-TV support
vmwgfx:
Move to using memremap + fixes.
rcar-du:
Add support for R8A7793/4 DU
armada:
Remove support for non-component mode
Improved plane handling
Power savings while in DPMS off.
tda998x:
Remove unused slave encoder support
Use more HDMI helpers
Fix EDID read handling
dwhdmi:
Interlace video mode support for ipu-v3/dw_hdmi
Hotplug state fixes
Audio driver integration
imx:
More color formats support.
tegra:
Minor fixes/improvements"
[ Merge fixup: remove unused variable 'dev' that had all uses removed in
commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from
drm_gem_mmap_obj" ]
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits)
drm/vmwgfx: Relax irq locking somewhat
drm/vmwgfx: Properly flush cursor updates and page-flips
drm/i915/skl: disable display side power well support for now
drm/i915: Extend DSL readout fix to BDW and SKL.
drm/i915: Do graphics device reset under forcewake
drm/i915: Skip fence installation for objects with rotated views (v4)
vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT
drm/amdgpu: group together common fence implementation
drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE
drm/amdgpu: remove now unused fence functions
drm/amdgpu: fix fence fallback check
drm/amdgpu: fix stoping the scheduler timeout
drm/amdgpu: cleanup on error in amdgpu_cs_ioctl()
drm/i915: Fix locking around GuC firmware load
drm/amdgpu: update Fiji's Golden setting
drm/amdgpu: update Fiji's rev id
drm/amdgpu: extract common code in vi_common_early_init
drm/amd/scheduler: don't oops on failure to load
drm/amdgpu: don't oops on failure to load (v2)
drm/amdgpu: don't VT switch on suspend
The compatible should be "renesas,pwm-rcar", and one the the SoC
specific string. So, this patch revises the documentation.
Reported-by: Rob Herring <robh+dt@kernel.org>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
The PWM controller on sun5i SoCs is identical to the one found on sun7i
SoCs. On the A13 package only one of the 2 pins is routed to the outside,
so only advertise one PWM channel there.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Merging in the few patches I had kept separate from main next/dt, since others
got merged here directly.
* next/arm64:
arm64: dts: mt8173: Add clocks for SCPSYS unit
arm64: dts: mt8173: Add subsystem clock controller device nodes
+ Linux 4.3-rc5
This change turns the UFS variant (SCSI_UFS_QCOM) into a UFS
a platform device.
In order to do so a few additional changes are required:
1. The ufshcd-pltfrm is no longer serves as a platform device.
Now it only serves as a group of platform APIs such as PM APIs
(runtime suspend/resume, system suspend/resume etc), parsers of
clocks, regulators and pm_levels from DT.
2. What used to be the old platform "probe" is now "only"
a pltfrm_init() routine, that does exactly the same, but only
being called by the new probe function of the UFS variant.
Reviewed-by: Rob Herring <robherring2@gmail.com>
Reviewed-by: Gilad Broner <gbroner@codeaurora.org>
Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org>
Tested-by: Alim Akhtar <alim.akhtar@samsung.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Add the clkout output clk to the common clock framework.
Disable the CLKOUT of the RTC after power-up.
After power-up/reset of the RTC, CLKOUT is enabled by default,
with CLKOUT enabled the RTC chip has 2-3 times higher power
consumption.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Introduce a device tree binding for specifying the trickle charger
configuration for ds1390.
Signed-off-by: Ivan Grimaldi <grimaldi.ivan@gmail.com>
Pull DeviceTree updates from Rob Herring:
"A fairly large (by DT standards) pull request this time with the
majority being some overdue moving DT binding docs around to
consolidate similar bindings.
- DT binding doc consolidation moving similar bindings to common
locations. The majority of these are display related which were
scattered in video/, fb/, drm/, gpu/, and panel/ directories.
- Add new config option, CONFIG_OF_ALL_DTBS, to enable building all
dtbs in the tree for most arches with dts files (except powerpc for
now).
- OF_IRQ=n fixes for user enabled CONFIG_OF.
- of_node_put ref counting fixes from Julia Lawall.
- Common DT binding for wakeup-source and deprecation of all similar
bindings.
- DT binding for PXA LCD controller.
- Allow ignoring failed PCI resource translations in order to ignore
64-bit addresses on non-LPAE 32-bit kernels.
- Support setting the NUMA node from DT instead of only from parent
device.
- Couple of earlycon DT parsing fixes for address and options"
* tag 'devicetree-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits)
MAINTAINERS: update DT binding doc locations
devicetree: add Sigma Designs vendor prefix
of: simplify arch_find_n_match_cpu_physical_id() function
Documentation: arm: Fixed typo in socfpga fpga mgr example
Documentation: devicetree: fix reference to legacy wakeup properties
Documentation: devicetree: standardize/consolidate on "wakeup-source" property
drivers: of: removing assignment of 0 to static variable
xtensa: enable building of all dtbs
mips: enable building of all dtbs
metag: enable building of all dtbs
metag: use common make variables for dtb builds
h8300: enable building of all dtbs
arm64: enable building of all dtbs
arm: enable building of all dtbs
arc: enable building of all dtbs
arc: use common make variables for dtb builds
of: add config option to enable building of all dtbs
of/fdt: fix error checking for earlycon address
of/overlay: add missing of_node_put
of/platform: add missing of_node_put
Pull input updates from Dmitry Torokhov:
"Items of note:
- evdev users can now limit or mask the kind of events they will
receive. This will allow applications such as power manager or
network manager to only be woken when user presses special keys
such as KEY_POWER or KEY_WIFI and not be bothered with ordinary
key presses coming from keyboard
- support for FocalTech FT6236 touchscreen controller
- support for ROHM BU21023/24 touchscreen controller
- edt-ft5x06 touchscreen driver got a face lift and can now be used
with FT5506
- support for Google Fiber TV Box remote controls
- improvements in xpad driver (with more to come)
- several parport-based drivers have been switched to the new device
model
- other miscellaneous driver improvements"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (70 commits)
HID: hid-gfrm: avoid warning for input_configured API change
HID: hid-input: allow input_configured callback return errors
Input: evdev - fix bug in checking duplicate clock change request
Input: add userio module
Input: evdev - add event-mask API
Input: snvs_pwrkey - remove duplicated semicolon
HID: hid-gfrm: Google Fiber TV Box remote controls
Input: e3x0-button - update Kconfig description
Input: tegra-kbc - drop use of IRQF_NO_SUSPEND flag
Input: tegra-kbc - enable support for the standard "wakeup-source" property
Input: xen - check return value of xenbus_printf
Input: hp_sdc_rtc - fix y2038 problem in proc_show
Input: nomadik-ske-keypad - fix a trivial typo
Input: xpad - fix clash of presence handling with LED setting
Input: edt-ft5x06 - work around FT5506 firmware bug
Input: edt-ft5x06 - add support for FT5506
Input: edt-ft5x06 - add support for different max support points
Input: edt-ft5x06 - use max support points to determine how much to read
Input: rotary-encoder - add support for quarter-period mode
Input: rotary-encoder - use of_property_read_bool
Pull MTD updates from Brian Norris:
"Core:
- WARN (in some cases) when a struct mtd_info is registered multiple
times; in the past this was "supported", but it's still error prone
for future development. There's only one ugly case of this left in
the tree (that we're aware of) and the owners are aware of the
problems there.
- fix potential deadlock in the blkdev removal path NOTE: the
(potential) deadlock was introduced in a for-stable patch. This
one is also marked for -stable.
- ioctl(BLKPG) compat_ioctl support; resolves issues with 32-bit user
space vs 64-bit kernel space
- Set MTD parent device correctly throughout the tree, so the tree
structure appears correctly in sysfs; many drivers were missing
this (soft) requirement
- Move device tree partitions (ofpart) into a dedicated 'partitions'
subnode; this helps to disambiguate whether a node is a partition
or some other auxiliary data
- Improve error handling for partitioning failures
NAND:
- General: Increase timeout period, for corner-case systems with
less-than-accurate jiffies
- Fix OF-based autoloading of several NAND drivers when built as
modules
- pxa3xx_nand:
- Rework timing configuration to be more dynamic
- Refactor PM support
- brcmnand: prepare for NorthStar 2 support (ARM64, 16-bit NAND
chips)
- sunxi_nand: refactoring and a few bug fixes
- vf610: new NAND driver
- FSMC: add SW BCH support; support common NAND DT bindings
- lpc32xx_slc: refactor and improve timing calculations logic
- denali: support for rev 5.1
SPI NOR:
- Layering improvements
- Added Winbond lock/unlock support
- Added mtd_is_locked() (i.e., ioctl(MEMISLOCKED)) support
- Increase full-chip-erase timeout linearly with flash size
- fsl-quadspi: fix compile for non-ARM architectures
- New flash support"
* tag 'for-linus-20151106' of git://git.infradead.org/linux-mtd: (169 commits)
mtd: don't WARN about overloaded users of mtd->reboot_notifier.notifier_call
mtd: nand: sunxi: avoid retrieving data before ECC pass
mtd: nand: sunxi: fix sunxi_nfc_hw_ecc_read/write_chunk()
mtd: blkdevs: fix potential deadlock + lockdep warnings
mtd: ofpart: move ofpart partitions to a dedicated dt node
doc: dt: mtd: support partitions in a special 'partitions' subnode
mtd: brcmnand: Force 8bit mode before doing nand_scan_ident()
mtd: brcmnand: factor out CFG and CFG_EXT bitfields
mtd: mtdpart: Do not fail mtd probe when parsing partitions fails
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
mtd: warn when registering the same master many times
mtd: fixup corner case error handling in mtd_device_parse_register()
mtd: tests: Replace timeval with ktime_t
mtd: fsmc_nand: Add BCH4 SW ECC support for SPEAr600
mtd: nand: vf610_nfc: use nand_check_erased_ecc_chunk() helper
mtd: nand: increase ready wait timeout and report timeouts
mtd: docg3: off by one in doc_register_sysfs()
mtd: pxa3xx_nand: clean up the pxa3xx timings
mtd: pxa3xx_nand: rework flash detection and timing setup
mtd: pxa3xx_nand: add helpers to setup the timings
git://git.linaro.org/landing-teams/working/fujitsu/integration
Pull mailbox updates from Jassi Brar:
- a TI specific quirk to get CPU control working via remote master.
- a new mailbox driver for an ST platform.
- a generic test driver to aid new driver development. And a couple of
fixes to make that really clean.
* 'mailbox-for-next' of git://git.linaro.org/landing-teams/working/fujitsu/integration:
mailbox: mailbox-test: avoid reading iomem twice
mailbox: Off by one in mbox_test_message_read()
mailbox/omap: Add ti,mbox-send-noirq quirk to fix AM33xx CPU Idle
mailbox: mailbox-test: Correctly repair Sparse warnings
mailbox: Fix a couple of trivial static checker issues
mailbox: Add generic mechanism for testing Mailbox Controllers
mailbox: Add support for ST's Mailbox IP
mailbox: dt: Supply bindings for ST's Mailbox IP
PCC: fix dereference of ERR_PTR
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Resource management:
- Add support for Enhanced Allocation devices (Sean O. Stalley)
- Add Enhanced Allocation register entries (Sean O. Stalley)
- Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney)
- Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney)
- Handle Enhanced Allocation capability for SR-IOV devices (David Daney)
- Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas)
- Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas)
- Expand Enhanced Allocation BAR output (Bjorn Helgaas)
- Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier)
- Fix lookup of linux,pci-probe-only property (Marc Zyngier)
- Add sparc mem64 resource parsing for root bus (Yinghai Lu)
PCI device hotplug:
- pciehp: Queue power work requests in dedicated function (Guenter Roeck)
Driver binding:
- Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker)
Virtualization:
- Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck)
- Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck)
- Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck)
- Reorder pcibios_sriov_disable() (Alexander Duyck)
- Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck)
- Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck)
- Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton)
- Don't try to restore VF BARs (Wei Yang)
MSI:
- Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel)
- Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach)
- Export all remapped MSIs to sysfs attributes (Romain Bezut)
- Disable MSI on SiS 761 (Ondrej Zary)
AER:
- Clear error status registers during enumeration and restore (Taku Izumi)
Generic host bridge driver:
- Allow multiple hosts with different map_bus() methods (David Daney)
- Pass starting bus number to pci_scan_root_bus() (David Daney)
- Fix address window calculation for non-zero starting bus (David Daney)
Altera host bridge driver:
- Add msi.h to ARM Kbuild (Ley Foon Tan)
- Add Altera PCIe host controller driver (Ley Foon Tan)
- Add Altera PCIe MSI driver (Ley Foon Tan)
APM X-Gene host bridge driver:
- Remove msi_controller assignment (Duc Dang)
Broadcom iProc host bridge driver:
- Fix header comment "Corporation" misspelling (Florian Fainelli)
- Fix code comment to match code (Ray Jui)
- Remove unused struct iproc_pcie.irqs[] (Ray Jui)
- Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui)
- Fix PCIe reset logic (Ray Jui)
- Improve link detection logic (Ray Jui)
- Update PCIe device tree bindings (Ray Jui)
- Add outbound mapping support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Return real error code from imx6_add_pcie_port() (Fabio Estevam)
- Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam)
Freescale Layerscape host bridge driver:
- Remove ls_pcie_establish_link() (Minghuan Lian)
- Ignore PCIe controllers in Endpoint mode (Minghuan Lian)
- Factor out SCFG related function (Minghuan Lian)
- Update ls_add_pcie_port() (Minghuan Lian)
- Remove unused fields from struct ls_pcie (Minghuan Lian)
- Add support for LS1043a and LS2080a (Minghuan Lian)
- Add ls_pcie_msi_host_init() (Minghuan Lian)
HiSilicon host bridge driver:
- Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang)
Marvell MVEBU host bridge driver:
- Return zero for reserved or unimplemented config space (Russell King)
- Use exact config access size; don't read/modify/write (Russell King)
- Use of_get_available_child_count() (Russell King)
- Use for_each_available_child_of_node() to walk child nodes (Russell King)
- Report full node name when reporting a DT error (Russell King)
- Use port->name rather than "PCIe%d.%d" (Russell King)
- Move port parsing and resource claiming to separate function (Russell King)
- Fix memory leaks and refcount leaks (Russell King)
- Split port parsing and resource claiming from port setup (Russell King)
- Use gpio_set_value_cansleep() (Russell King)
- Use devm_kcalloc() to allocate an array (Russell King)
- Use gpio_desc to carry around gpio (Russell King)
- Improve clock/reset handling (Russell King)
- Add PCI Express root complex capability block (Russell King)
- Remove code restricting accesses to slot 0 (Russell King)
NVIDIA Tegra host bridge driver:
- Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel)
Renesas R-Car host bridge driver:
- Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven)
- Build pcie-rcar.c only on ARM (Geert Uytterhoeven)
- Make PCI aware of the I/O resources (Phil Edworthy)
- Remove dependency on ARM-specific struct hw_pci (Phil Edworthy)
- Set root bus nr to that provided in DT (Phil Edworthy)
- Fix I/O offset for multiple host bridges (Phil Edworthy)
ST Microelectronics SPEAr13xx host bridge driver:
- Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni)
Synopsys DesignWare host bridge driver:
- Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma)
- Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni)
- Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni)
- Require config accesses to be naturally aligned (Gabriele Paoloni)
- Make "num-lanes" an optional DT property (Gabriele Paoloni)
- Move calculation of bus addresses to DRA7xx (Gabriele Paoloni)
- Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni)
- Factor out MSI msg setup (Lucas Stach)
- Implement multivector MSI IRQ setup (Lucas Stach)
- Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach)
- Set up high part of MSI target address (Lucas Stach)
- Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang)
- Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang)
- Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang)
- Make driver arch-agnostic (Zhou Wang)
Miscellaneous:
- Make x86 pci_subsys_init() static (Alexander Kuleshov)
- Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)"
* tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: altera: Add Altera PCIe MSI driver
PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver
PCI: layerscape: Add ls_pcie_msi_host_init()
PCI: layerscape: Add support for LS1043a and LS2080a
PCI: layerscape: Remove unused fields from struct ls_pcie
PCI: layerscape: Update ls_add_pcie_port()
PCI: layerscape: Factor out SCFG related function
PCI: layerscape: Ignore PCIe controllers in Endpoint mode
PCI: layerscape: Remove ls_pcie_establish_link()
PCI: designware: Make "clocks" and "clock-names" optional DT properties
PCI: designware: Make driver arch-agnostic
ARM/PCI: Replace pci_sys_data->align_resource with global function pointer
PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT
PCI: designware: Move calculation of bus addresses to DRA7xx
PCI: designware: Make "num-lanes" an optional DT property
PCI: designware: Require config accesses to be naturally aligned
PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces
PCI: designware: Use exact access size in dw_pcie_cfg_read()
PCI: spear: Fix dw_pcie_cfg_read/write() usage
