path: root/Documentation/devicetree
2012-10-31ARM: at91/tc: fix typo in the DT documentJosh Wu
commit 11930c530f3edf81160e4962e363d579f5cdce7e upstream. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-05Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound sound fixes from Takashi Iwai: "As good as nothing exciting here; just a few trivial fixes for various ASoC stuff." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: omap-pcm: Free dma buffers in case of error. ASoC: s3c2412-i2s: Fix dai registration ASoC: wm8350: Don't use locally allocated codec struct ASoC: tlv312aic23: unbreak resume ASoC: bf5xx-ssm2602: Set DAI format ASoC: core: check of_property_count_strings failure ASoC: dt: sgtl5000.txt: Add description for 'reg' field ASoC: wm_hubs: Make sure we don't disable differential line outputs
2012-05-03ata: ahci_platform: Add synopsys ahci controller in DT's compatible listViresh Kumar
SPEAr13xx series of SoCs contain Synopsys AHCI SATA Controller which shares ahci_platform driver with other controller versions. This patch updates DT compatible list for ahci_platform. It also updates and renames binding documentation to more generic name. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-04-24ASoC: dt: sgtl5000.txt: Add description for 'reg' fieldFabio Estevam
Add description for 'reg' field. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-05Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: SoC fixes: from Olof Johansson: "A bunch of fixes for regressions (and a few other problems) in 3.4-rc1: - Fix for regression of mach/io.h cleanup on platforms with PCI or PCMCIA (adding back the include file on those for now) - AT91 fixes for usb and spi - smsc911x ethernet fixes for i.MX - smsc911x fixes for OMAP - gpio fixes for Tegra - A handful of build error and warning fixes for various platforms - cpufreq kconfig dependencies, build and lowlevel debug fixes for Samsung platforms In other words, more or less the regular collection of -rc1/2 type material. A few of them, in particular the smsc911x for OMAP series, aren't technically regressions for 3.4, but they're valid fixes and we're still relatively early in the rc cycle so it seems appropriate to include them." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: fix __io macro for PCMCIA ARM: EXYNOS: Fix compiler warning in dma.c file ARM: EXYNOS: fix ISO C90 warning ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status ARM: OMAP2+: hwmod: Restore sysc after a reset ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules ARM: OMAP3: clock data: fill in some missing clockdomains ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch() gpio: tegra: Iterate over the correct number of banks gpio: tegra: fix register address calculations for Tegra30 EXYNOS: fix dependency for EXYNOS_CPUFREQ ARM: at91: dt: remove unit-address part for memory nodes ARM: at91: fix check of valid GPIO for SPI and USB USB: ehci-atmel: add needed of.h header file ARM: at91/NAND DT bindings: add comments ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file USB: ohci-at91: trivial return code name change ...
2012-04-04Merge tag 'regulator-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "A bunch of smallish fixes that came up during the merge window as things got more testing - even more fixes from Axel, a fix for error handling in more complex systems using -EPROBE_DEFER and a couple of small fixes for the new dummy regulators." * tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: Remove non-existent parameter from fixed-helper.c kernel doc regulator: Fix setting new voltage in s5m8767_set_voltage regulator: fix sysfs name collision between dummy and fixed dummy regulator regulator: Fix deadlock on removal of regulators with supplies regulator: Fix comments in include/linux/regulator/machine.h regulator: Only update [LDOx|DCx]_HIB_MODE bits in wm8350_[ldo|dcdc]_set_suspend_disable regulator: Fix setting low power mode for wm831x aldo regulator: Return microamps in wm8350_isink_get_current regulator: wm8350: Fix the logic to choose best current limit setting regulator: wm831x-isink: Fix the logic to choose best current limit setting regulator: wm831x-dcdc: Fix the logic to choose best current limit setting regulator: anatop: patching to device-tree property "reg". regulator: Do proper shift to set correct bit for DC[2|5]_HIB_MODE setting regulator: Fix restoring pmic.dcdcx_hib_mode settings in wm8350_dcdc_set_suspend_enable regulator: Fix unbalanced lock/unlock in mc13892_regulator_probe error path regulator: Fix set and get current limit for wm831x_buckv regulator: tps6586x: Fix list minimal voltage setting for LDO0
2012-04-04ARM: at91/NAND DT bindings: add commentsNicolas Ferre
Add comments to NAND "gpios" property to make it clearer. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-03-30Merge tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD changes from David Woodhouse: - Artem's cleanup of the MTD API continues apace. - Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst others. - More work on DiskOnChip G3, new driver for DiskOnChip G4. - Clean up debug/warning printks in JFFS2 to use pr_<level>. Fix up various trivial conflicts, largely due to changes in calling conventions for things like dmaengine_prep_slave_sg() (new inline wrapper to hide new parameter, clashing with rewrite of previously last parameter that used to be an 'append' flag, and is now a bitmap of 'unsigned long flags'). (Also some header file fallout - like so many merges this merge window - and silly conflicts with sparse fixes) * tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits) mtd: docg3 add protection against concurrency mtd: docg3 refactor cascade floors structure mtd: docg3 increase write/erase timeout mtd: docg3 fix inbound calculations mtd: nand: gpmi: fix function annotations mtd: phram: fix section mismatch for phram_setup mtd: unify initialization of erase_info->fail_addr mtd: support ONFI multi lun NAND mtd: sm_ftl: fix typo in major number. mtd: add device-tree support to spear_smi mtd: spear_smi: Remove default partition information from driver mtd: Add device-tree support to fsmc_nand mtd: fix section mismatch for doc_probe_device mtd: nand/fsmc: Remove sparse warnings and errors mtd: nand/fsmc: Add DMA support mtd: nand/fsmc: Access the NAND device word by word whenever possible mtd: nand/fsmc: Use dev_err to report error scenario mtd: nand/fsmc: Use devm routines mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform mtd: fsmc_nand: add pm callbacks to support hibernation ...
2012-03-30Merge tag 'for-v3.4-rc1' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "Various small bugfixes and enhancements, plus two new drivers: - A quite complex ab8500 charger driver, submitted by Arun Murthy @ ST-Ericsson; - Summit Microelectronics SMB347 Battery Charger, submitted by Bruce E Robertson and Alan Cox @ Intel. And that's all." * tag 'for-v3.4-rc1' of git://git.infradead.org/battery-2.6: (36 commits) max17042_battery: Clean up interrupt handling Revert "max8998_charger: Include linux/module.h just once" ab8500_fg: Fix some build warnings on x86_64 max17042_battery: Fix CHARGE_FULL representation. max8998_charger: Include linux/module.h just once power_supply: Convert i2c drivers to module_i2c_driver lp8727_charger: Add MODULE_DEVICE_TABLE charger-manager: Simplify charger_get_property(), get rid of a warning charger-manager: Clean up for better readability da9052-battery: Convert to use module_platform_driver da9052-battery: Fix a memory leak when unload the module da9052-battery: Add missing platform_set_drvdata ab8500: Turn unneeded global symbols into local ones ab8500_fg: Fix copy-paste error ab8500_fg: Get rid of 'struct battery_type' ab8500_fg: Get rid of 'struct v_to_cap' ab8500_btemp: Get rid of 'enum adc_therm' ab8500_charger: Convert to the new USB OTG calls ab8500-btemp: AB8500 battery temperature driver ab8500-fg: A8500 fuel gauge driver ...
2012-03-29Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull devicetree documentation update from Grant Likely. * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: dt: Linux DT usage model documentation mtd: Move fdt partition documentation to a seperate file
2012-03-29dt: Linux DT usage model documentationGrant Likely
v2: 2nd draft - Editorial cleanups (Randy Dunlap and Stephen Warren) - Added missing Microblaze reference (Stephen Neuendorffer) - Make example of platform_device creation clearer (Shawn Guo) - Expand on PowerPC history and mention i2c mess (David Gibson) - convert to plain text (remove bits of html formating) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-28Merge tag 'mmc-merge-for-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: Core: * Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices that support Data Tag will provide increased throughput for metadata. * Faster detection of card removal on I/O errors. Drivers: * dw_mmc now supports eMMC Power Off Notify, has PCI support, and implements pre_req and post_req for asynchronous requests. * omap_hsmmc now supports device tree. * esdhc now has power management support. * sdhci-tegra now supports Tegra30 devices. * sdhci-spear now supports hibernation. * tmio_mmc now supports using a GPIO for card detection. * Intel PCH now supports 8-bit bus transfers. * tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: sh_mmcif: simplify bitmask macros mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug mmc: sh_mobile_sdhi: add a callback for board specific init code mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function mmc: sh_mobile_sdhi: do not manage PM clocks manually mmc: tmio_mmc: remove unused sdio_irq_enabled flag mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper mmc: tmio: calculate the native hotplug condition only once mmc: simplify mmc_cd_gpio_request() by removing two parameters mmc: sdhci-pci: allow 8-bit bus width for Intel PCH mmc: sdhci: check interrupt flags in ISR again mmc: sdhci-pci: Add MSI support mmc: core: warn when card doesn't support HPI mmc: davinci: Poll status for small size transfers mmc: davinci: Eliminate spurious interrupts mmc: omap_hsmmc: Avoid a regulator voltage change with dt mmc: omap_hsmmc: Convert hsmmc driver to use device tree mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO ...
2012-03-28mtd: Move fdt partition documentation to a seperate fileJamie Lentin
Partitions are described in the same way for all mtd devices when using devicetree, move the documentation to a separate file and add references to it. Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-28Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO changes for v3.4 from Grant Likely: "Primarily gpio device driver changes with some minor side effects under arch/arm and arch/x86. Also includes a few core changes such as explicitly supporting (electrical) open source and open drain outputs and some help for parsing gpio devicetree properties." Fix up context conflict due to Laxman Dewangan adding sleep control for the tps65910 driver separately for gpio's and regulators. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio/ep93xx: Remove unused inline function and useless pr_err message gpio/sodaville: Mark broken due to core irqdomain migration gpio/omap: fix redundant decoding of gpio offset gpio/omap: fix incorrect update to context.irqenable1 gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_* gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg gpio/omap: fix _set_gpio_irqenable implementation gpio/omap: fix trigger type to unsigned gpio/omap: fix wakeup_en register update in _set_gpio_wakeup() gpio: tegra: tegra_gpio_config shouldn't be __init gpio/davinci: fix enabling unbanked GPIO IRQs gpio/davinci: fix oops on unbanked gpio irq request gpio/omap: Fix section warning for omap_mpuio_alloc_gc() ARM: tegra: export tegra_gpio_{en,dis}able gpio/gpio-stmpe: Fix the value returned by _get_value routine Documentation/gpio.txt: Explain expected pinctrl interaction GPIO: LPC32xx: Add output reading to GPO P3 GPIO: LPC32xx: Fix missing bit selection mask gpio/omap: fix wakeups on level-triggered GPIOs gpio/omap: Fix IRQ handling for SPARSE_IRQ ...
2012-03-28Merge tag 'mfd_3.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: - 4 new drivers: Freescale i.MX on-chip Anatop, Ricoh's RC5T583 and TI's TPS65090 and TPS65217. - New variants support (8420, 8520 ab9540), cleanups and bug fixes for the abx500 and db8500 ST-E chipsets. - Some minor fixes and update for the wm8994 from Mark. - The beginning of a long term TWL cleanup effort coming from the TI folks. - Various fixes and cleanups for the s5m, TPS659xx, pm860x, and MAX8997 drivers. Fix up trivial conflicts due to duplicate patches and header file cleanups (<linux/device.h> removal etc). * tag 'mfd_3.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (97 commits) gpio/twl: Add DT support to gpio-twl4030 driver gpio/twl: Allocate irq_desc dynamically for SPARSE_IRQ support mfd: Detach twl6040 from the pmic mfd driver mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanups mfd: Micro-optimization on twl4030 IRQ handler mfd: Make twl4030 SIH SPARSE_IRQ capable mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq files mfd: Remove references already defineid in header file from twl-core mfd: Remove unneeded header from twl-core mfd: Make twl-core not depend on pdata->irq_base/end ARM: OMAP2+: board-omap4-*: Do not use anymore TWL6030_IRQ_BASE in board files mfd: Return twl6030_mmc_card_detect IRQ for board setup Revert "mfd: Add platform data for MAX8997 haptic driver" mfd: Add support for TPS65090 mfd: Add some da9052-i2c section annotations mfd: Build rtc5t583 only if I2C config is selected to y. mfd: Add anatop mfd driver mfd: Fix compilation error in tps65910.h mfd: Add 8420 variant to db8500-prcmu mfd: Add 8520 PRCMU variant to db8500-prcmu ...
2012-03-28Merge tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More device tree support updates" from Olof Johansson: "This branch contains a number of updates for device tree support on several ARM platforms, in particular: * AT91 continues the device tree conversion adding support for a number of on-chip drivers and other functionality * ux500 adds probing of some of the core SoC blocks through device tree * Initial device tree support for ST SPEAr600 platforms * kirkwood continues the conversion to device-tree probing" Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and drivers/usb/gadget/at91_udc.c due to header file include cleanups. Also do an "evil merge" for the MACH_U8500 config option rename that the affected RMI4 touchscreen driver in staging. It's called MACH_MOP500 now, and it was missed during previous merges. * tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: SPEAr600: Add device-tree support to SPEAr600 boards ARM: ux500: Provide local timer support for Device Tree ARM: ux500: Enable PL022 SSP Controller in Device Tree ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree ARM: ux500: db8500: list most devices in the snowball device tree ARM: ux500: split dts file for snowball into generic part ARM: ux500: combine the board init functions for DT boot ARM: ux500: Initial Device Tree support for Snowball ARM: ux500: CONFIG: Enable Device Tree support for future endeavours ARM: kirkwood: use devicetree for rtc-mv ARM: kirkwood: rtc-mv devicetree bindings ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0 ARM: kirkwood: fdt: facilitate new boards during fdt migration ARM: kirkwood: fdt: absorb kirkwood_init() ARM: kirkwood: fdt: use mrvl ticker symbol ARM: orion: wdt: use resource vice direct access ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data. ARM: orion: spi: remove enable_clock_fix which is not used ...
2012-03-28regulator: anatop: patching to device-tree property "reg".Ying-Chun Liu (PaulLiu)
Change "reg" to "anatop-reg-offset" due to there is a warning of handling no size field in reg. This patch also adds the missing device-tree binding documentation. Signed-off-by: Ying-Chun Liu (PaulLiu) <paul.liu@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-27Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: device tree work" from Arnd Bergmann: "Most of these patches convert code from using static platform data to describing the hardware in the device tree. This is only the first half of the changes for v3.4 because a lot of patches for this topic came in the last week before the merge window. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h} * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits) Document: devicetree: add OF documents for arch-mmp ARM: dts: append DTS file of pxa168 ARM: mmp: append OF support on pxa168 ARM: mmp: enable rtc clk in pxa168 i2c: pxa: add OF support serial: pxa: add OF support arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board ARM: OMAP2+: Remove extra ifdefs for board-generic ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected ASoC: DT: Add digital microphone binding to PAZ00 board. ARM: dt: Add ARM PMU to tegra*.dtsi ARM: at91: at91sam9x5cm/dt: add leds support ARM: at91: usb_a9g20/dt: add gpio-keys support ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support ARM: at91: at91sam9m10g45ek/dt: add leds support ARM: at91: usb_a9g20/dt: add leds support ARM: at91/pio: add new PIO3 features ARM: at91: add sam9_smc.o to at91sam9x5 build ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter ARM: at91/tc: add device tree support to atmel_tclib ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-27Merge tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: timer cleanup work" from Arnd Bergmann: "These are split out from the generic soc and driver updates because there was a lot of conflicting work by multiple people. Marc Zyngier worked on simplifying the "localtimer" interfaces, and some of the platforms are touching the same code as they move to device tree based booting. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) ARM: tegra: select USB_ULPI if USB is selected arm/tegra: pcie: fix return value of function ARM: ux500: fix compilation after local timer rework ARM: shmobile: remove additional __io() macro use ARM: local timers: make the runtime registration interface mandatory ARM: local timers: convert MSM to runtime registration interface ARM: local timers: convert exynos to runtime registration interface ARM: smp_twd: remove old local timer interface ARM: imx6q: convert to twd_local_timer_register() interface ARM: highbank: convert to twd_local_timer_register() interface ARM: ux500: convert to twd_local_timer_register() interface ARM: shmobile: convert to twd_local_timer_register() interface ARM: tegra: convert to twd_local_timer_register() interface ARM: plat-versatile: convert to twd_local_timer_register() interface ARM: OMAP4: convert to twd_local_timer_register() interface ARM: smp_twd: add device tree support ARM: smp_twd: add runtime registration support ARM: local timers: introduce a new registration interface ARM: smp_twd: make local_timer_stop a symbol instead of a #define ARM: mach-shmobile: default to no earlytimer ...
2012-03-27mmc: omap_hsmmc: Convert hsmmc driver to use device treeRajendra Nayak
Define dt bindings for the ti-omap-hsmmc, and adapt the driver to extract data (which was earlier passed as platform_data) from device tree. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-27mtd: add device-tree support to spear_smiStefan Roese
This patch adds support to configure the SPEAr SMI driver via device-tree instead of platform_data. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-27mtd: Add device-tree support to fsmc_nandStefan Roese
This patch adds support to configure the FSMC NAND driver (used amongst others on SPEAr platforms) via device-tree instead of platform_data. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-26max17042_battery: Make it possible to instantiate driver from DTKarol Lewandowski
Allow both device tree (preferred) and platform data-based driver instantiation. Signed-off-by: Karol Lewandowski <k.lewandowsk@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-03-24Merge tag 'regulator-3.4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator into next/drivers The pxa regulator branch removes the bq24022 driver, while a lot of other regulator drivers got added in the regulator tree. This resolves the trivial conflicts by merging in the regulator patches that are already merged into v3.4. Conflicts: drivers/regulator/Kconfig drivers/regulator/Makefile Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-23Merge branch 'i2c-embedded/for-3.4' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull i2c embedded updates from Wolfram Sang: "Nothing special from i2c-embedded for this merge window. Two new drivers, minor feature additions, bugfixes, cleanups. All patches have been in linux-next for some time, too." * 'i2c-embedded/for-3.4' of git://git.pengutronix.de/git/wsa/linux: i2c-eg20t: Remove write-only variables i2c-eg20t: Rework pch_i2c_wait_for_bus_idle to reduce wait time i2c-s3c2410: Add stub runtime power management i2c-s3c2410: Convert to devm_kzalloc() i2c: add CSR SiRFprimaII on-chip I2C controllers driver i2c: tegra: Remove unnecessary write to INT_STATUS i2c: imx: fix imx driver to work though signal is pending i2c: designware: dw_i2c_init_driver as subsys initcall misc: at24: describe platform_data with kernel_doc i2c: Move I2C_EG20T option to the right place. i2c: Support for Netlogic XLR/XLS I2C controller. i2c: mpc: Add support for SMBUS_READ_BLOCK_DATA i2c: versatile: Add Device Tree support
2012-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "- we finally merged driver for USB version of Synaptics touchpads (I guess most commonly found in IBM/Lenovo keyboard/touchpad combo); - a bunch of new drivers for embedded platforms (Cypress touchscreens, DA9052 OnKey, MAX8997-haptic, Ilitek ILI210x touchscreens, TI touchscreen); - input core allows clients to specify desired clock source for timestamps on input events (EVIOCSCLOCKID ioctl); - input core allows querying state of all MT slots for given event code via EVIOCGMTSLOTS ioctl; - various driver fixes and improvements." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (45 commits) Input: ili210x - add support for Ilitek ILI210x based touchscreens Input: altera_ps2 - use of_match_ptr() Input: synaptics_usb - switch to module_usb_driver() Input: convert I2C drivers to use module_i2c_driver() Input: convert SPI drivers to use module_spi_driver() Input: omap4-keypad - move platform_data to <linux/platform_data> Input: kxtj9 - who_am_i check value and initial data rate fixes Input: add driver support for MAX8997-haptic Input: tegra-kbc - revise device tree support Input: of_keymap - add device tree bindings for simple key matrices Input: wacom - fix physical size calculation for 3rd-gen Bamboo Input: twl4030-vibra - really switch from #if to #ifdef Input: hp680_ts_input - ensure arguments to request_irq and free_irq are compatible Input: max8925_onkey - avoid accessing input device too early Input: max8925_onkey - allow to be used as a wakeup source Input: atmel-wm97xx - convert to dev_pm_ops Input: atmel-wm97xx - set driver owner Input: add cyttsp touchscreen maintainer entry Input: cyttsp - remove useless checks in cyttsp_probe() Input: usbtouchscreen - add support for Data Modul EasyTouch TP 72037 ...
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-22gpio/twl: Add DT support to gpio-twl4030 driverBenoit Cousson
Add the DT support for the I2C GPIO expander inside the twl4030. Note: The pdata parameters still have to be properly adapted using dedicated bindings. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-21Merge tag 'regulator-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates for 3.4 from Mark Brown: "This has been a fairly quiet release from a regulator point of view, the only real framework features added were devm support and a convenience helper for setting up fixed voltage regulators. We also added a couple of drivers (but will drop the BQ240022 driver via the arm-soc tree as it's been replaced by the more generic gpio-regulator driver) and Axel Lin continued his relentless and generally awesome stream of fixes and cleanups." * tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (93 commits) regulator: Fix up a confusing dev_warn when DT lookup fails regulator: Convert tps6507x to set_voltage_sel regulator: Refactor tps6507x to use one tps6507x_pmic_ops for all LDOs and DCDCs regulator: Make s5m8767_get_voltage_register always return correct register regulator: s5m8767: Check pdata->buck[2|3|4]_gpiodvs earlier regulator: tps65910: Provide settling time for DCDC voltage change regulator: Add Anatop regulator driver regulator: Simplify implementation of tps65912_get_voltage_dcdc regulator: Use tps65912_set_voltage_sel for both DCDCx and LDOx regulator: tps65910: Provide settling time for enabling rails regulator: max8925: Use DIV_ROUND_UP macro regulator: tps65912: Use simple equations to get register address regulator: Fix the logic of tps65910_get_mode regulator: Merge tps65217_pmic_ldo234_ops and tps65217_pmic_dcdc_ops to tps65217_pmic_ops regulator: Use DIV_ROUND_CLOSEST in wm8350_isink_get_current regulator: Use array to store dcdc_range settings for tps65912 regulator: Rename s5m8767_convert_voltage to s5m8767_convert_voltage_to_sel regulator: tps6524x: Remove unneeded comment for N_REGULATORS regulator: Rename set_voltage_sel callback function name to *_sel regulator: Fix s5m8767_set_voltage_time_sel calculation value ...
2012-03-21Merge tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull SPI changes for v3.4 from Grant Likely: "Mostly a bunch of new drivers and driver bug fixes; but this also includes a few patches that create a core message queue infrastructure for the spi subsystem instead of making each driver open code it." * tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/fsl-espi: Make sure pm is within 2..32 spi/fsl-espi: make the clock computation easier to read spi: sh-hspi: modify write/read method spi: sh-hspi: control spi clock more correctly spi: sh-hspi: convert to using core message queue spi: s3c64xx: Fix build spi: s3c64xx: remove unnecessary callback msg->complete spi: remove redundant variable assignment spi: release lock on error path in spi_pump_messages() spi: Compatibility with direction which is used in samsung DMA operation spi-topcliff-pch: add recovery processing in case wait-event timeout spi-topcliff-pch: supports a spi mode setup and bit order setup by IO control spi-topcliff-pch: Fix issue for transmitting over 4KByte spi-topcliff-pch: Modify pci-bus number dynamically to get DMA device info spi/imx: simplify error handling to free gpios spi: Convert to DEFINE_PCI_DEVICE_TABLE spi: add Broadcom BCM63xx SPI controller driver SPI: add CSR SiRFprimaII SPI controller driver spi-topcliff-pch: fix -Wuninitialized warning spi: Mark spi_register_board_info() __devinit ...
2012-03-21Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull core device tree changes for Linux v3.4 from Grant Likely: "This branch contains a minor documentation addition, a utility function for parsing string properties needed by some of the new ARM platforms, disables dynamic DT code that isn't used anywhere but on a few PPC machines, and exports DT node compatible data to userspace via UEVENT properties. Nothing earth shattering here." * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6: of: Only compile OF_DYNAMIC on PowerPC pseries and iseries arm/dts: OMAP3: Add omap3evm and am335xevm support drivercore: Output common devicetree information in uevent of: Add of_property_match_string() to find index into a string list
2012-03-21Merge tag 'pm-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates for 3.4 from Rafael Wysocki: "Assorted extensions and fixes including: * Introduction of early/late suspend/hibernation device callbacks. * Generic PM domains extensions and fixes. * devfreq updates from Axel Lin and MyungJoo Ham. * Device PM QoS updates. * Fixes of concurrency problems with wakeup sources. * System suspend and hibernation fixes." * tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits) PM / Domains: Check domain status during hibernation restore of devices PM / devfreq: add relation of recommended frequency. PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on() PM / shmobile: Make CMT driver use pm_genpd_dev_always_on() PM / shmobile: Make TMU driver use pm_genpd_dev_always_on() PM / Domains: Introduce "always on" device flag PM / Domains: Fix hibernation restore of devices, v2 PM / Domains: Fix handling of wakeup devices during system resume sh_mmcif / PM: Use PM QoS latency constraint tmio_mmc / PM: Use PM QoS latency constraint PM / QoS: Make it possible to expose PM QoS latency constraints PM / Sleep: JBD and JBD2 missing set_freezable() PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case PM / Freezer: Remove references to TIF_FREEZE in comments PM / Sleep: Add more wakeup source initialization routines PM / Hibernate: Enable usermodehelpers in hibernate() error path PM / Sleep: Make __pm_stay_awake() delete wakeup source timers PM / Sleep: Fix race conditions related to wakeup source timer function PM / Sleep: Fix possible infinite loop during wakeup source destruction PM / Hibernate: print physical addresses consistently with other parts of kernel ...
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20Merge branch 'next/fixes-non-critical' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-lpc32xx/clock.c arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c The conflicts with pxa are non-obvious, we have multiple branches adding and removing the same clock settings. According to Haojian Zhuang, removing the sa1100 rtc dummy clock is the correct fix here. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-20Merge tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/ttyLinus Torvalds
Pull TTY/serial patches from Greg KH: "tty and serial merge for 3.4-rc1 Here's the big serial and tty merge for the 3.4-rc1 tree. There's loads of fixes and reworks in here from Jiri for the tty layer, and a number of patches from Alan to help try to wrestle the vt layer into a sane model. Other than that, lots of driver updates and fixes, and other minor stuff, all detailed in the shortlog." * tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits) serial: pxa: add clk_prepare/clk_unprepare calls TTY: Wrong unicode value copied in con_set_unimap() serial: PL011: clear pending interrupts serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset. vt: NULL dereference in vt_do_kdsk_ioctl() tty: serial: vt8500: fix annotations for probe/remove serial: remove back and forth conversions in serial_out_sync serial: use serial_port_in/out vs serial_in/out in 8250 serial: introduce generic port in/out helpers serial: reduce number of indirections in 8250 code serial: delete useless void casts in 8250.c serial: make 8250's serial_in shareable to other drivers. serial: delete last unused traces of pausing I/O in 8250 pch_uart: Add module parameter descriptions pch_uart: Use existing default_baud in setup_console pch_uart: Add user_uartclk parameter pch_uart: Add Fish River Island II uart clock quirks pch_uart: Use uartclk instead of base_baud mpc5200b/uart: select more tolerant uart prescaler on low baudrates tty: moxa: fix bit test in moxa_start() ...
2012-03-20Merge branch 'renesas/timer' into next/timerArnd Bergmann
Conflicts: arch/arm/mach-shmobile/timer.c This resolves a nonobvious merge conflict between renesas timer changes in the global timer changes with those from the renesas soc branch and last minute bug fixes that went into v3.3. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-19Merge branch 'for-3.4/dt' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra into next/dt2 * 'for-3.4/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra: arm: tegra: dts: Mark USB1 as an OTG port on Seaboard arm: tegra: dts: Add legacy mode support to Tegra2x USB1 port arm: tegra: dts: Support host/device selection and legacy mode
2012-03-16stmmac: Add device-tree supportStefan Roese
This patch adds support to configure the STMMAC ethernet driver via device-tree instead of platform_data. Currently, only the properties needed on SPEAr600 are provided. All other properties should be added once needed on other platforms. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-16powerpc: document the FSL MPIC message register bindingJia Hongtao
This binding documents how the message register blocks found in some FSL MPIC implementations shall be represented in a device tree. Signed-off-by: Meador Inge <meador_inge@mentor.com> Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/fsl: Added aliased MSIIR register address to MSI node in dtsDiana CRACIUN
The MSIIR register for each MSI bank is aliased to a different address. The MSI node reg property was updated to contain this address: e.g. reg = <0x41600 0x200 0x44140 4>; The first region contains the address and length of the MSI register set and the second region contains the address of the aliased MSIIR register at 0x44140. Signed-off-by: Diana CRACIUN <Diana.Craciun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16Merge branch 'spear/dt' into next/dt2Arnd Bergmann
* spear/dt: ARM: SPEAr600: Add device-tree support to SPEAr600 boards (update to v3.3-rc7) Conflicts: arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-vexpress/Kconfig The conflicts are between the previous contents of the next/dt2 branch and upstream changes from v3.3-rc7. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-16ARM: SPEAr600: Add device-tree support to SPEAr600 boardsStefan Roese
This patch adds a generic target for SPEAr600 board that can be configured via the device-tree. Currently the following devices are supported via the devicetree: - VIC interrupts - PL011 UART - PL061 GPIO - Synopsys DW I2C - Synopsys DW ethernet Other peripheral devices (e.g. SMI flash, FSMC NAND flash etc) will follow in later patches. Only the spear600-evb is currently supported. Other SPEAr600 based boards will follow later. Since the current mainline SPEAr600 code only supports the SPEAr600 evaluation board, with nearly zero peripheral devices (only UART and GPIO), it makes sense to switch over to DT based configuration completely now. So this patch also removes all non-DT stuff, mainly platform device data. The files spear600.c and spear600_evb.c are removed completely. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-16Merge branch 'ux500/dt' into next/dt2Arnd Bergmann
* ux500/dt: ARM: ux500: Provide local timer support for Device Tree ARM: ux500: Enable PL022 SSP Controller in Device Tree ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree ARM: ux500: db8500: list most devices in the snowball device tree ARM: ux500: split dts file for snowball into generic part ARM: ux500: combine the board init functions for DT boot ARM: ux500: Initial Device Tree support for Snowball ARM: ux500: CONFIG: Enable Device Tree support for future endeavours ARM: ux500: fix compilation after local timer rework (adds dependency on localtimer branch, irqdomain branch and ux500/soc branch) Conflicts: arch/arm/mach-ux500/devices-common.c This adds patches from Lee Jones, Niklas Hernaeus and myself to provide initial device tree support on the ux500 platform. The pull request from Lee contained some other changes, so I rebased the patches on top of the branches that are actually dependencies for this. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-16Merge branch 'at91-3.4-cleanup2-DT2+USB' of ↵Arnd Bergmann
git://github.com/at91linux/linux-at91 into next/dt * 'at91-3.4-cleanup2-DT2+USB' of git://github.com/at91linux/linux-at91: ARM: at91: sam9g20 udc add dt support USB: at91: Device udc add dt support
2012-03-16Merge branch 'at91-3.4-cleanup2-DT2' of ↵Arnd Bergmann
git://github.com/at91linux/linux-at91 into next/dt * 'at91-3.4-cleanup2-DT2' of git://github.com/at91linux/linux-at91: (23 commits) ARM: at91: dt: enable usb ehci for sam9g45 and sam9x5 ARM: at91: usb ehci add dt support ARM: at91: dt: enable usb ohci for sam9g20, sam9g45 amd sam9x5 ARM: at91: usb ohci add dt support ARM: at91: add Shutdown Controller (SHDWC) DT support ARM: at91: add ram controller DT support ARM: at91: add RSTC (Reset Controller) dt support ARM: at91: always enable sam9 restart ARM: at91: add pmc DT support ARM: at91/dt: add specific DT soc init ARM: at91/dt: add Calao DAB-MMX daugther board support for USB-A9G20 ARM: at91: sam9x5 add i2c DT support ARM: at91: sam9g45 add i2c DT support ARM: at91: usb_a9g20 add DT i2c support ARM: at91: sam9g20 add i2c DT support i2c/gpio: add DT support ARM: at91: sam9x5 add nand support atmel/nand: add DT support of/mtd/nand: add generic bindings and helpers of: introduce helper to manage boolean ...
2012-03-16USB: at91: Device udc add dt supportJean-Christophe PLAGNIOL-VILLARD
Allow to compile it if AT91 is enable. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-16ARM: at91: usb ehci add dt supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
