path: root/Documentation/dontdiff
2012-03-30Documentation: remove 'mach' from dontdiff fileH Hartley Sweeten
The mach entry in the dontdiff file causes all the arch/arm/mach-*/include/mach directories to be skipped. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-27[S390] Remove Kerntypes leftoversHeiko Carstens
Remove last traces of our kerntypes patch which was always an addon patch which never got upstream. Somehow a few bits got upstream anyway. Since kerntypes aren't used anymore and lcrash isn't maintained (for s390 at least) remove the last traces of kerntypes that somehow went upstream. Also remove the documentation that mentions lcrash. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23Documentation: update dontdiff fileRandy Dunlap
v2, updated based on comments from Joe and Paul. Update to Documentation/dontdiff, based on many updates to various .gitignore patches over the last 2 years. Initially begun by Michael Prokop <mika@grml.org>, with lots of changes by Randy Dunlap. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Michael Prokop <mika@grml.org> Cc: Joe Perches <joe@perches.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Documentation/dontdiff: add further autogenerated files to ignore listMichael Prokop
Mainly resulting from (but not limited to) autogenerated files of lib/raid6 and drivers/gpu/drm/radeon. List generated as result of a diff of a clean 2.6.36 tree against a built one. Signed-off-by: Michael Prokop <mika@grml.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-25Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig: kconfig: simplification of scripts/extract-ikconfig
2009-12-12dontdiff: add generatedSam Ravnborg
We move more and more stuff to include/generated - so lets ignore the content for users of plain diff. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-10-24SELinux: add .gitignore files for dynamic classesEric Paris
The SELinux dynamic class work in c6d3aaa4e35c71a32a86ececacd4eea7ecfc316c creates a number of dynamic header files and scripts. Add .gitignore files so git doesn't complain about these. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-07kconfig: simplification of scripts/extract-ikconfigDick Streefland
I've rewritten the extract-ikconfig script to extract the kernel configuration from a kernel compiled with CONFIG_IKCONFIG. The main motivation for the rewrite was to remove the dependency on the external C program binoffset.c, which is compiled on the initial run. The binoffset executable is invoked with a relative path, which means that the old script can only be run from the top of the kernel tree, and only when you have write permission in the scripts directory. The new script uses tr/grep/tail/zcat only, and can be invoked from anywhere. The binoffset.c program has been removed. This script requires GNU grep 2.5 (released 2002-03-13) or higher, because the -o option was introduced in that version. Signed-off-by: Dick Streefland <dick@streefland.net> LKML-Reference: <20091006203540.GA14634@streefland.net> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-15sparc: Kill PROM console driver.David S. Miller
Many years ago when this driver was written, it had a use, but these days it's nothing but trouble and distributions should not enable it in any situation. Pretty much every console device a sparc machine could see has a bonafide real driver, making the PROM console hack unnecessary. If any new device shows up, we should write a driver instead of depending upon this crutch to save us. We've been able to take care of this even when no chip documentation exists (sunxvr500, sunxvr2500) so there are no excuses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26dontdiff: Fix asm excludeAlan Cox
Now that the headers are in arch/foo/include/asm we don't want to exclude them when preparing diff files. Closes-bug: 12921 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16dontdiff: more updates to be closer to gitignoreRandy Dunlap
defkeymap.c_shipped should be diffed if it is changed. Reported-by: Mike Galbraith <efault@gmx.de> COPYING, CREDITS, .mailmap should be diffed if they are changed. keywords.c_shipped & lex.c_shipped should be diffed when changed. parse.[ch]_shipped should be diffed when changed. Reported-by: Sam Ravnborg <sam@ravnborg.org> vsyscall* updates from a .gitignore patch by "Denis V. Lunev" <den@openvz.org>. *.so.dbg from a .gitignore patch by Thomas Gleixner <tglx@linutronix.de>. binoffset from a .gitignore patch by Uwe Kleine-Koenig <Uwe.Kleine-Koenig@digi.com>. Module.markers from a .gitignore patch by Matthew Wilcox <willy@linux.intel.com>. vmlinux*.lds* should be diffed if changed. Reported-by: Etienne Lorrain <etienne_lorrain@yahoo.fr> vmlinux.lds from a .gitignore patch by Daniel Guilak <daniel@danielguilak.com>. *.scr should be diffed if changed. Lots of updates from http://lkml.org/lkml/2008/5/20/32 Reported-by: Bart Van Assche <bart.vanassche@gmail.com> Use ncscope.* instead of *cscope* since the latter may catch too many files. Add *.elf, from a .gitignore patch by Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>. Make firmware entries match .gitignore entries. Make some entries less greedy by removing trailing '*'. Remove "make_times_h" (no such file). Remove "filelist" (no such file). Remove "dummy_sym.c" (no such file). Remove "gen-kdb_cmds.c" (no such file). Remove "gentbl" (no such file). Remove "kconfig.tk" (no such file). Remove "tkparse" (no such file). Remove "sim710_d.h" (no such file). Remove "53c8xx_d.h" (no such file). Add "syscalltab.h" (generated file). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02don't diff generated firmware filesArjan van de Ven
With the new firmware infrastructure in 2.6.27, some files are generated and shouldn't be diffed; add these 2 to the "dontdiff" file Signed-off-by: Arjan van de Ven <arjan@Linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28dontdiff: ignore timeconst.hBen Dooks
Ignore the autobuilt kernel/timeconst.h when using diff on an built kernel tree. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28dontdiff: add modules.orderBen Dooks
Add modules.order to the list of files that shoud be ignored when using diff on a built kernel tree. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-21Documentation: Remove last references to BitKeeper.Cyril Brulebois
Remove BitKeeper from dontdiff. Point to the klibc git repository instead of old BitKeeper ones. Signed-off-by: Cyril Brulebois <cyril.brulebois@kerlabs.com> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-01-11[SCSI] 53c7xx: fix removal falloutAdrian Bunk
This patch does some additional cleanups after the 53c7xx removal. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-17dontdiff: update based on gitignore updatesRandy Dunlap
Update dontdiff, based on .gitignore patches from Pete Zaitcev and Adrian Bunk. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lk201: remove obsolete driverMaciej W. Rozycki
Remove the old-fashioned lk201 driver under drivers/tc/ that used to be used by the old dz.c and zs.c drivers, which is now orphan code referred to from nowhere and does not build anymore. A modern replacement is available as drivers/input/keyboard/lkkbd.c. There are no plans to do anything about this piece of code and it does not fit anywhere anymore, so it is not just a matter of maintenance or the lack of. There are still some bits that might be added to the new lkkbd.c driver based on the old code, and the embedded hardware documentation which is otherwise quite hard to get hold of might be useful to keep too. Both of these can be done separately though. RIP. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31update dontdiff fileRandy Dunlap
Updates based on recent .gitignore updates: *.o.*: Says Alexey Dobriyan: These are presumably temporary gcc files, which aren't interesting. setup.bin, setup.elf: new x86 boot code files (from Matthew Wilcox) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23update dontdiff fileRandy Dunlap
Update dontdiff file by adding entries from many .gitignore files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Don't exclude asm-offsets.c in Documentation/dontdiffAndi Kleen
asm-offsets.c is valid source code and needs to be diffed. Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-25dontdiff: add utsrelease.hRandy Dunlap
Add auto-generated utsrelease.h to dontdiff file. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-13[PATCH] dontdiff: add asm_offsetsMichal Piotrowski
We seem to use both asm-offsets.* and asm_offsets.* Signed-off-by: Michal K. K. Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-03[PATCH] ARM: 2840/1: Add mach-types to Documentation/dontdiffMichael Burian
Patch from Michael Burian This file is maintained by RMK's machine registry, it should not be patched. Signed-off-by: Michael Burian <dynmail1@gassner-waagen.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-16[PATCH] ARM: 2794/1: Add "Image" and "mach-types.h" to dontdiff listMichael Burian
Patch from Michael Burian comment in "mach-types.h" tells that it should not be patched "Image" is a binary, just as zImage, uImage and friends are Signed-off-by: Michael Burian <dynmail1@gassner-waagen.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] Add offset.h to dontdiffMichal Schmidt
include/asm/offset.h is a generated file on x86_64 and mips. Let's add it to Documentation/dontdiff. Signed-off-by: Michal Schmidt <xschmi00@stud.feec.vutbr.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] Update dontdiffMatt Porter
Additions to the dontdiff list. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] dontdiff file sorted in alphabet orderaquynh@gmail.com
Documentation/dontdiff is a little messy. Here is a patch to sort the content of that file in alphabetical Signed-off-by: Nguyen Anh Quynh <aquynh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Add dontdiff fileRandy.Dunlap
Add a current 'dontdiff' file for use with 'diff -X dontdiff'. Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
