The references to drivers/base/power/main.c and
drivers/acpi/scan.c from Documentation/driver-api/infrastructure.rst
are confusing. They both cause descriptions of functions that are
not relevant to device drivers at all to be generated and none of
them is sufficient to cover the API in a meaningful way.
Drop them for now.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Just prep work to polish and consolidate all the dma-buf related
documenation.
Unfortunately I didn't discover a way to both integrate this new file
into the overall toc while keeping it at the current place. Work
around that by moving it into the overall driver-api/index.rst.
Cc: linux-doc@vger.kernel.org
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Few files under dma-buf/ changed their names but the changes didn't
applied to a document that referencing them. It is causing few
documentation build warnings. This commit fixes the problems by
applying changed file names on the document.
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
We don't need to keep it as a single large file anymore; split it up so
that it is easier to manage and the individual sections can be read
directly as plain files.
