path: root/Documentation/driver-api
2016-09-06docs: Don't format internal MPT docsJonathan Corbet
This is the driver API document, so the internal stuff is just noise here. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-09-06docs: split up serial-interfaces.rstJonathan Corbet
It never made sense to keep these documents together; move each into its own file. Drop the section numbering on hsi.txt on its way to its own file. Suggested-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-09-06docs: Pull the HSI documentation togetherJonathan Corbet
The HSI subsystem documentation was split across hsi.txt and the device-drivers docbook. Now that the latter has been converted to Sphinx, pull in the HSI document so that it's all in one place. Acked-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-22docs: split up the driver bookJonathan Corbet
We don't need to keep it as a single large file anymore; split it up so that it is easier to manage and the individual sections can be read directly as plain files. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-22Docs: sphinxify device-drivers.tmplJonathan Corbet
Perform a basic sphinx conversion of the device-drivers docbook and move it to its own directory. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
