path: root/Documentation/dvb/get_dvb_firmware
2007-08-20V4L/DVB (6016): get_dvb_firmware: update script for new location of tda10046 ↵Andreas Arens
firmware Update get_dvb_firmware script for the new location of the tda10046 firmware. The old location doesn't work anymore. Signed-off-by: Andreas Arens <ari@goron.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5829): Firmware extract and loading for opera dvb-usb updateMarco Gittler
Better way of creating and loading the firmware used. Update for get_dvb_firmware script to extract the files for opera usb-box Help file for creating the firmware added Signed-off-by: Marco Gittler <g.marco@freenet.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5771): Get_dvb_firmware: update script for new locationMichael Krufky
Get_dvb_firmware: update script for new location of sp8870 firmware This url is no longer valid: http://www.technotrend.de/new/217g/tt_Premium_217g.zip Replace with: http://www.softwarepatch.pl/9999ccd06a4813cb827dbb0005071c71/tt_Premium_217g.zip Thanks-to: Tobias Stoeber <tobi@to-st.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-12V4L/DVB (3832): Get_dvb_firmware: download nxt2002 firmware from new driver ↵Michael Krufky
location BBTI has updated their driver, and removed the old one from their website. This patch updates the get_dvb_firmware script to download the firmware from the new driver location. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-22Documentation/dvb/get_dvb_firmware: fix firmware URLAdrian Bunk
This patch fixes a wrong URL in Documentation/dvb/get_dvb_firmware. This patch fixes kernel Bugzilla #4301. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-07V4L/DVB (3302): Added support for the LifeView FlyDVB-T LR301 cardGiampiero Giancipoli
Additionally to the card support, this changeset adds the option tda10046lifeview to get_dvb_firmware to download tda10046 firmware from LifeView's site. Signed-off-by: Giampiero Giancipoli <gianci@libero.it> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3336): Bluebird firmware hosting moved to common dvb firmware dir ↵Michael Krufky
on linuxtv.org - Get_dvb_firmware script updated accordingly: - my $url = "http://www.linuxtv.org/~mkrufky/dvb-usb-bluebird-01.fw"; + my $url = "http://www.linuxtv.org/download/dvb/firmware/dvb-usb-blue$ Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3287): Add DViCO Bluebird firmware to dvb_get_firmware scriptMichael Krufky
- Add DViCO Bluebird firmware to dvb_get_firmware script, for FusionHDTV USB devices. - Use usb alt setting 0 for EP4 transfer (dvb-t), - Use usb alt setting 7 for EP2 transfer (atsc) - Added comment to lgdt330x.c to indicate support for DViCO FusionHDTV5 USB Gold. Thanks to: Jeff Lee <JeffLee@dvico.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3242): make the firmware dir docs consistent in the v4l-dvb tree.Ville Skytt\ä
- make the firmware dir documentation and comments consistent in the v4l-dvb tree. Signed-off-by: Ville Skyttä <ville.skytta@iki.fi> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3218): Whitespace cleanupsMichael Krufky
- minor whitespace cleanups Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-09[PATCH] dvb: add nxt200x frontend moduleKirk Lapray
* nxt200x.c, nxt200x.h - New frontend module that supports both NXT2002 and NXT2004. So far, only tested on NXT2004. After testing on NXT2002, we should deprecate the nxt2002 module, and implement this one instead on the applicable cards. * get_dvb_firmware: - Added support for the NXT2004 firmware. This firmware works with both the ATI HDTV Wonder and the AVerTVHD MCE a180. This was originally written by Jean-Francois Thibert * dvb-pll.c - Fixed minimum frequency for tuv1236d. It seems that the data sheets are wrong. Signed-off-by: Kirk Lapray <kirk.lapray@gmail.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Cc: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: tda10046: support for different firmware versionsJohannes Stezenbach
added support for different tda10046 firmware versions. tested with v20, v21 and v25. (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
