path: root/Documentation/dvb
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-04Documentation: fix minor typos/spellingSylvestre Ledru
Fix some minor typos: * informations => information * there own => their own * these => this Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22[media] DM04 LME2510(C) Sharp BS2F7HZ0194 Firmware InformationMalcolm Priestley
DM04 LME2510(C) Sharp BS2F7HZ0194 Firmware Information Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] get_dvb_firmware: ngene_18.fw addedOliver Endriss
Add download link for ngene firmware rev 18. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Documentation/lmedm04: Fix firmware extract informationMalcolm Priestley
Corrected Firmware Information for LG on LME2510. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] lmedm04: driver for DM04/QQBOX updated to version 1.60Malcolm Priestley
These include -later kill of usb_buffer to avoid kernel crash on hot unplugging. -DiSEqC functions. -LNB Power switch -Faster channel change. -support for LG tuner on LME2510C. -firmware switching for LG tuner. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: Support or LME2510(C) DM04/QQBOX USB DVB-S BOXESMalcolm Priestley
DM04/QQBOX DVB-S USB BOX with LME2510C+SHARP:BS2F7HZ7395 or LME2510+LGTDQT-P001F tuner. [mchehab@redhat.com: Fix merge conflicts/compilation and CodingStyle issues] Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-02V4L/DVB: get_dvb_firmware: update af9015Antti Palosaari
New driver contains new firmware 5.1.0.0. Fix script to get that. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: Retrieve firmware for az6027Renzo Dani
Signed-off-by: Renzo Dani <arons7@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-26V4L/DVB: get_dvb_firmware: Fix typo, sort list of componentsOliver Endriss
Commiter: Oliver Endriss <o.endriss@gmx.de> Fix typo. Sort list of components for better readability. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: get_dvb_firmware: Add function to retrieve nGene firmwaresOliver Endriss
Commiter: Oliver Endriss <o.endriss@gmx.de> Use 'get_dvb_firmware ngene' to download 'ngene_15.fw' and 'ngene_17.fw'. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19V4L/DVB (12902): Documentation: synchronize documentation for Technisat cardsUwe Bugla
The patch does the following: a. it synchronizes /Documentation/dvb/technisat.txt to the current kernel design b. it syncs Trent Piepho' s latest changes to the flexcop driver concept: implementation of the dvb pll library for some cards that need it Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-18V4L/DVB (12752): get_dvb_firmware: add af9015 firmwareAntti Palosaari
Add af9015 firmware to get_dvb_firmware script. Firmware version is 4.95.0.0. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-05V4L/DVB (12206): get_dvb_firmware: Correct errors in MPC718 firmware ↵Andy Walls
extraction logic The extraction routine for the MPC718 "firmware" had 2 bugs in it, where one bug masked the effect of the other. The loop iteration should have set $prevlen = $currlen at the end of the loop, and the if() check should have used && instead of || for deciding if the firmware length is reasonable. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-05V4L/DVB (12181): get_dvb_firmware: Add Yuan MPC718 MT352 DVB-T "firmware" ↵Andy Walls
extraction Add routine to support extracting the MT352 DVB-T demodulator initialization sequence for Yuan MPC718 cards for use by the cx18 driver. This routine uses a hueristic for extracting a good sequence. It should work on all different versions of the "yuanrap.sys" file, given the way the MT352 tuning sequences are stored in all versions of that file I have seen so far. However, the current patch simply looks for one specific archive URL. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11962): dvb: Fix broken link in get_dvb_firmware for nxt2004 (A180)Jan Ceuleers
Due to a reorganisation of AVermedia's websites, get_dvb_firmware no longer works for nxt2004. Fix it. Signed-off-by: Jan Ceuleers <jan.ceuleers@computer.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11488): get_dvb_firmware: trivial url changeJoseba Goitia Gandiaga
Trivial url changes in script Signed-off-by: Joseba Goitia Gandiaga <josebagg@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11138): get_dvb_firmware: add support for downloading the cx2584x ↵Mauro Carvalho Chehab
firmware for pvrusb2 Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11137): get_dvb_firmware: add cx23885 firmwaresMauro Carvalho Chehab
2009-03-30V4L/DVB (11136): get_dvb_firmware: Add download code for cx18 firmwaresMauro Carvalho Chehab
2009-03-30V4L/DVB (11108): get_dvb_firmware: Add option to download firmware for cx231xxMauro Carvalho Chehab
2009-02-26V4L/DVB (10696): Remove outdated README for the flexcop-driverUwe Bugla
This patch removes an outdated README for the flexcop-driver. Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-02-26V4L/DVB (10695): Update Technisat card documentationUwe Bugla
Fixes for documentation of Technisat-based cards Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9812): [PATCH] short help for Technisat cards to select the right ↵Patrick Boettcher
configuration This patch adds a short help for Technisat cards to help the user selecting the right configuration for his card(s). Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-01-25V4L/DVB (7077): bt878: remove handcrafted PCI subsystem ID checkAkinobu Mita
This patch moves the subsystem ID and subsystem vendor ID check from probing function to the PCI generic function by describing subsystem IDs in pci_device_id table. This enables to add new PCI IDs to a device driver pci_ids table at runtime by new_id file in sysfs pci driver tree. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6252): Adapt drivers to use the newer videobuf modulesMauro Carvalho Chehab
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo. Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct. So, to access it, a subroutine call is needed. This patch renames all occurences of those function calls to be consistent with the video-buf split. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
2007-08-20V4L/DVB (6016): get_dvb_firmware: update script for new location of tda10046 ↵Andreas Arens
firmware Update get_dvb_firmware script for the new location of the tda10046 firmware. The old location doesn't work anymore. Signed-off-by: Andreas Arens <ari@goron.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5829): Firmware extract and loading for opera dvb-usb updateMarco Gittler
Better way of creating and loading the firmware used. Update for get_dvb_firmware script to extract the files for opera usb-box Help file for creating the firmware added Signed-off-by: Marco Gittler <g.marco@freenet.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5771): Get_dvb_firmware: update script for new locationMichael Krufky
Get_dvb_firmware: update script for new location of sp8870 firmware This url is no longer valid: http://www.technotrend.de/new/217g/tt_Premium_217g.zip Replace with: http://www.softwarepatch.pl/9999ccd06a4813cb827dbb0005071c71/tt_Premium_217g.zip Thanks-to: Tobias Stoeber <tobi@to-st.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5701): Documentation/dvb/bt8xx.txt updateUwe Bugla
This patch synchronizes the Documentation for bt8xx-based cards to the actual state of kernel 2.6.22-rc1. Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10V4L/DVB (4813): Added information about Technisat Sky2Pc cardsPaolo Ciarrocchi
Acked-by: Daniele Vallini <vallinidaniele@libero.it> Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-30Fix typos in /Documentation : 'U-Z'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letters 'U-Z'. Looks like I made it through the alphabet...just in time to start over again +too! Maybe I can fit more profound fixes into the next round...? Time will +tell. :) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-12V4L/DVB (3832): Get_dvb_firmware: download nxt2002 firmware from new driver ↵Michael Krufky
location BBTI has updated their driver, and removed the old one from their website. This patch updates the get_dvb_firmware script to download the firmware from the new driver location. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-22Documentation/dvb/get_dvb_firmware: fix firmware URLAdrian Bunk
This patch fixes a wrong URL in Documentation/dvb/get_dvb_firmware. This patch fixes kernel Bugzilla #4301. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-21V4L/DVB (3538): Bt8xx documentation updateUwe Bugla
Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27V4L/DVB (3391): Documentation updateUwe Bugla
2006-02-27V4L/DVB (3336): Bt8xx documentation authors fixMichael Krufky
- use one Author per line, which allows us to add more authors later without creating a mess. - Add Michael Krufky due to -git commit 2cbeddc976645262dbe036d6ec0825f96af70da3 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3302): Added support for the LifeView FlyDVB-T LR301 cardGiampiero Giancipoli
Additionally to the card support, this changeset adds the option tda10046lifeview to get_dvb_firmware to download tda10046 firmware from LifeView's site. Signed-off-by: Giampiero Giancipoli <gianci@libero.it> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3336): Bluebird firmware hosting moved to common dvb firmware dir ↵Michael Krufky
on linuxtv.org - Get_dvb_firmware script updated accordingly: - my $url = "http://www.linuxtv.org/~mkrufky/dvb-usb-bluebird-01.fw"; + my $url = "http://www.linuxtv.org/download/dvb/firmware/dvb-usb-blue$ Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
