path: root/Documentation/eisa.txt
2017-07-14eisa.txt: standardize document formatMauro Carvalho Chehab
Each text file under Documentation follows a different format. Some doesn't even have titles! Change its representation to follow the adopted standard, using ReST markups for it to be parseable by Sphinx: - use ReST notation for titles; - identify literal blocks; - use :Author: for document authorship; - use the proper notation for tables; - adjust whitespaces where needed. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2012-05-17MCA: delete all remaining traces of microchannel bus support.Paul Gortmaker
Hardware with MCA bus is limited to 386 and 486 class machines that are now 20+ years old and typically with less than 32MB of memory. A quick search on the internet, and you see that even the MCA hobbyist/enthusiast community has lost interest in the early 2000 era and never really even moved ahead from the 2.4 kernels to the 2.6 series. This deletes anything remaining related to CONFIG_MCA from core kernel code and from the x86 architecture. There is no point in carrying this any further into the future. One complication to watch for is inadvertently scooping up stuff relating to machine check, since there is overlap in the TLA name space (e.g. arch/x86/boot/mca.c). Cc: Thomas Gleixner <tglx@linutronix.de> Cc: James Bottomley <JBottomley@Parallels.com> Cc: x86@kernel.org Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-02-05doc: fix Defaultd -> Defaults typo in EISA docThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-11-30Fix typos in /Documentation : 'U-Z'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letters 'U-Z'. Looks like I made it through the alphabet...just in time to start over again +too! Maybe I can fit more profound fixes into the next round...? Time will +tell. :) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
