path: root/Documentation/email-clients.txt
2016-09-21Documentation/email-clients.txt: convert it to ReST markupMauro Carvalho Chehab
As this file is mentioned at the development-process/ book, let's convert it to ReST markup. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-11-13Merge tag '4.4-additional' of git://git.lwn.net/linuxLinus Torvalds
Pull more documentation updates from Jon Corbet: "A few more documentation patches that wandered in and have no reason to wait; these include some improvements to the suggestions for email clients and patch submission" * tag '4.4-additional' of git://git.lwn.net/linux: Documentation: Add minimal Mutt config for using Gmail Documentation: Add note on sending files directly with Mutt Documentation: dontdiff: remove media from dontdiff Documentation/SubmittingPatches: discuss In-Reply-To Remove email address from Documentation/filesystems/overlayfs.txt can-doc: Add missing semicolon to example
2015-11-11Documentation: Add minimal Mutt config for using GmailEddie Kovsky
This patch provides a minimal configuration to set up Mutt for submitting plain text patches using Gmail. Signed-off-by: Eddie Kovsky <ewk@edkovsky.org> Reviewed-by: Darren Hart <dvhart@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-11-11Documentation: Add note on sending files directly with MuttEddie Kovsky
Like 'git send-email', Mutt can also be used to send patches generated with 'git format-patch'. This works regardless of the editor the contributor has set up to use with Mutt. Signed-off-by: Eddie Kovsky <ewk@edkovsky.org> Reviewed-by: Darren Hart <dvhart@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-10-11Documentation/email-clients.txt: remove trailing whitespaceLuis de Bethencourt
Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-07-24fix Evolution submenu name in email-clients.txtAhmed Mohamed Abd EL Mawgood
I have noticed that there is no submenu in Evolution called Heading instead there is Paragraph style Signed-off-by: Ahmed Mohamed <ahmedsoliman0x666@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-03-20Documentation/email-clients.txt: Fix one grammar mistake, add extra info ↵Giedrius Statkevičius
about TB Fix one grammar mistake (Allows->Allow) and add extra information about the external editor add-on of Thunderbird: the developer must make sure that their editor doesn't fork (IOW it mustn't return before closing) thus they should be careful how they configure the addon. Furthermore, add a tip how to do it with gvim. Signed-off-by: Giedrius Statkevičius <giedrius.statkevicius@gmail.com> [jc: some minor wording/formatting tweaks] Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2014-12-02Documentation/email-clients.txt: add info about Claws MailRichard Leitner
Claws Mail GUI client works. The client is available at http://www.claws-mail.org Signed-off-by: Richard Leitner <dev@g0hl1n.net> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2014-06-29Documentation: add section about git to email-clients.txtDan Carpenter
These days most people use git to send patches so I have added a section about that. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-25Documentation: update thunderbird email client settingsPaul McQuade
Added setting to email-clients that is easier to read and is easier to setup thunderbird. Removed config settings and added GUI settings. Signed-off-by: Paul McQuade <paulmcquad@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-02doc: fix some typosXishi Qiu
Fix some typos in three documentations. Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-13Documentation: email-clients: Add better Thunderbird informationPaul Mcquade
Add better Thunderbird information. Add Thunderbird Registry instructions to: Enable UTF8 & Preformat mode Disable HTML mode Signed-off-by: Paul McQuade <paulmcquad@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Documentation/email-clients.txt: update Thunderbird docs with wordwrap pluginRob Landley
Show how to install the "toggle wordwrap" extension in thunderbird. Signed-off-by: Rob Landley <rlandley@parallels.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Documentation/email-clients.txt: warn about word wrap bug in KMailLasse Collin
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Documentation/email-clients.txt: update gmail informationDave Young
Gmail web gui does not work for sending patches now even with firefox "view source with" extension. It will use windows style line breaks to wrap lines automatically when sening email. Rewrite the gmail web gui part of email client documentation. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Martin Bligh <mbligh@mbligh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06Documentation/email-clients.txt: add some info about gmailTim Hockin
Signed-off-by: Tim Hockin <thockin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07email-clients.txt: sylpheed is OK at IMAPRandy Dunlap
This comment is not helpful (no reason given) and is incorrect. Just stick to facts that are useful regarding working on Linux. (akpm: I've used sylpheed+imap for years) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17doc: about email clients for Linux patchesRandy Dunlap
Requested by Jeff Garzik. v3, updated from lkml comments. Add info about various email clients and their applicability in being used to send Linux kernel patches. Some notes takes from http://mbligh.org/linuxdocs/Email/Clients Portions used with permission. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Martin Bligh <mbligh@mbligh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
