path: root/Documentation/exception.txt
2009-07-10Doc: move Documentation/exception.txt into x86 subdirAmerigo Wang
exception.txt only explains the code on x86, so it's better to move it into Documentation/x86 directory. And also rename it to exception-tables.txt which looks much more reasonable. This patch is on top of the previous one. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10Doc: update Documentation/exception.txtAmerigo Wang
Update Documentation/exception.txt. Remove trailing whitespaces in it. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-09-07[PATCH] remove verify_area(): remove or edit references to verify_area in ↵Jesper Juhl
Documentation/ Remove (or edit) remaining references to the now dead verify_area() function from files in Documentation/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
