path: root/Documentation/fault-injection
2007-07-16fault-injection: fix example scripts in documentationAkinobu Mita
Fix and cleanup example scripts in fault injection documentation. 1. Eliminate broken oops() shell function. 2. Fold failcmd.sh and failmodule.sh into example scripts. It makes the example scripts work independent of current working directory. 3. Set "space" parameter to 0 to start injecting errors immediately. 4. Use /sys/module/<modulename>/sections/.data as upper bound of .text section. Because some module doesn't have .exit.text section. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fault-injection: add min-order parameter to fail_page_allocAkinobu Mita
Limiting smaller allocation failures by fault injection helps to find real possible bugs. Because higher order allocations are likely to fail and zero-order allocations are not likely to fail. This patch adds min-order parameter to fail_page_alloc. It specifies the minimum page allocation order to be injected failures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] fault-injection: Correct, disambiguate, and reformat documentationDon Mullis
Correct, disambiguate, and reformat documentation. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: stacktrace filteringAkinobu Mita
This patch provides stacktrace filtering feature. The stacktrace filter allows failing only for the caller you are interested in. For example someone may want to inject kmalloc() failures into only e100 module. they want to inject not only direct kmalloc() call, but also indirect allocation, too. - e100_poll --> netif_receive_skb --> packet_rcv_spkt --> skb_clone --> kmem_cache_alloc This patch enables to detect function calls like this by stacktrace and inject failures. The script Documentaion/fault-injection/failmodule.sh helps it. The range of text section of loaded e100 is expected to be [/sys/module/e100/sections/.text, /sys/module/e100/sections/.exit.text) So failmodule.sh stores these values into /debug/failslab/address-start and /debug/failslab/address-end. The maximum stacktrace depth is specified by /debug/failslab/stacktrace-depth. Please see the example that demonstrates how to inject slab allocation failures only for a specific module in Documentation/fault-injection/fault-injection.txt [dwm@meer.net: reject failure if any caller lies within specified range] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for kmallocAkinobu Mita
This patch provides fault-injection capability for kmalloc. Boot option: failslab=<interval>,<probability>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where memory can be allocated safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/failslab/interval /debug/failslab/probability /debug/failslab/specifies /debug/failslab/times /debug/failslab/ignore-gfp-highmem /debug/failslab/ignore-gfp-wait Example: failslab=10,100,0,-1 slab allocation (kmalloc(), kmem_cache_alloc(),..) fails once per 10 times. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: documentation and scriptsAkinobu Mita
This patch set provides some fault-injection capabilities. - kmalloc() failures - alloc_pages() failures - disk IO errors We can see what really happens if those failures happen. In order to enable these fault-injection capabilities: 1. Enable relevant config options (CONFIG_FAILSLAB, CONFIG_PAGE_ALLOC, CONFIG_MAKE_REQUEST) and if you want to configure them via debugfs, enable CONFIG_FAULT_INJECTION_DEBUG_FS. 2. Build and boot with this kernel 3. Configure fault-injection capabilities behavior by boot option or debugfs - Boot option failslab= fail_page_alloc= fail_make_request= - Debugfs /debug/failslab/* /debug/fail_page_alloc/* /debug/fail_make_request/* Please refer to the Documentation/fault-injection/fault-injection.txt for details. 4. See what really happens. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
