path: root/Documentation/fault-injection
2015-12-03net: Add support for CHANGEUPPER notifier error injectionIdo Schimmel
Since CHANGEUPPER can now fail, add support for it in the newly introduced netdev notifier error injection infrastructure. Signed-off-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: Jiri Pirko <jiri@mellanox.com> Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01net: add support for netdev notifier error injectionNikolay Aleksandrov
This module allows to insert errors in some of netdevice's notifier events. All network drivers use these notifiers to signal various events and to check if they are allowed, e.g. PRECHANGEMTU and CHANGEMTU afterwards. Until recently I had to run failure tests by injecting a custom module, but now this infrastructure makes it trivial to test these failure paths. Some of the recent bugs I fixed were found using this module. Here's an example: $ cd /sys/kernel/debug/notifier-error-inject/netdev $ echo -22 > actions/NETDEV_CHANGEMTU/error $ ip link set eth0 mtu 1024 RTNETLINK answers: Invalid argument CC: Akinobu Mita <akinobu.mita@gmail.com> CC: "David S. Miller" <davem@davemloft.net> CC: netdev <netdev@vger.kernel.org> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-20futex: Fault/error injection capabilitiesDavidlohr Bueso
Although futexes are well known for being a royal pita, we really have very little debugging capabilities - except for relying on tglx's eye half the time. By simply making use of the existing fault-injection machinery, we can improve this situation, allowing generating artificial uaddress faults and deadlock scenarios. Of course, when this is disabled in production systems, the overhead for failure checks is practically zero -- so this is very cheap at the same time. Future work would be nice to now enhance trinity to make use of this. There is a special tunable 'ignore-private', which can filter out private futexes. Given the tsk->make_it_fail filter and this option, pi futexes can be narrowed down pretty closely. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Link: http://lkml.kernel.org/r/1435645562-975-3-git-send-email-dave@stgolabs.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-11-19doc: fix quite a few typos within DocumentationMasanari Iida
Correct spelling typo in Documentations Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-30fault-injection: add tool to run command with failslab or fail_page_allocAkinobu Mita
This adds tools/testing/fault-injection/failcmd.sh to run a command while injecting slab/page allocation failures via fault injection. Example: Run a command "make -C tools/testing/selftests/ run_tests" with injecting slab allocation failure. # ./tools/testing/fault-injection/failcmd.sh \ -- make -C tools/testing/selftests/ run_tests Same as above except to specify 100 times failures at most instead of one time at most by default. # ./tools/testing/fault-injection/failcmd.sh --times=100 \ -- make -C tools/testing/selftests/ run_tests Same as above except to inject page allocation failure instead of slab allocation failure. # env FAILCMD_TYPE=fail_page_alloc \ ./tools/testing/fault-injection/failcmd.sh --times=100 \ -- make -C tools/testing/selftests/ run_tests Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30fault-injection: notifier error injectionAkinobu Mita
This patchset provides kernel modules that can be used to test the error handling of notifier call chain failures by injecting artifical errors to the following notifier chain callbacks. * CPU notifier * PM notifier * memory hotplug notifier * powerpc pSeries reconfig notifier Example: Inject CPU offline error (-1 == -EPERM) # cd /sys/kernel/debug/notifier-error-inject/cpu # echo -1 > actions/CPU_DOWN_PREPARE/error # echo 0 > /sys/devices/system/cpu/cpu1/online bash: echo: write error: Operation not permitted The patchset also adds cpu and memory hotplug tests to tools/testing/selftests These tests first do simple online and offline test and then do fault injection tests if notifier error injection module is available. This patch: The notifier error injection provides the ability to inject artifical errors to specified notifier chain callbacks. It is useful to test the error handling of notifier call chain failures. This adds common basic functions to define which type of events can be fail and to initialize the debugfs interface to control what error code should be returned and which event should be failed. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-26fault-injection: update documentation with the mmc module paramPer Forlin
Signed-off-by: Per Forlin <per.forlin@linaro.org> Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26fault-inject: add documentation on MMC IO fault injectionPer Forlin
Add description on how to enable random fault injection for MMC IO. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-08-03fault-injection: add ability to export fault_attr in arbitrary directoryAkinobu Mita
init_fault_attr_dentries() is used to export fault_attr via debugfs. But it can only export it in debugfs root directory. Per Forlin is working on mmc_fail_request which adds support to inject data errors after a completed host transfer in MMC subsystem. The fault_attr for mmc_fail_request should be defined per mmc host and export it in debugfs directory per mmc host like /sys/kernel/debug/mmc0/mmc_fail_request. init_fault_attr_dentries() doesn't help for mmc_fail_request. So this introduces fault_create_debugfs_attr() which is able to create a directory in the arbitrary directory and replace init_fault_attr_dentries(). [akpm@linux-foundation.org: extraneous semicolon, per Randy] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Tested-by: Per Forlin <per.forlin@linaro.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06lkdtm: add debugfs access and loosen KPROBE tiesSimon Kagstrom
Add adds a debugfs interface and additional failure modes to LKDTM to provide similar functionality to the provoke-crash driver submitted here: http://lwn.net/Articles/371208/ Crashes can now be induced either through module parameters (as before) or through the debugfs interface as in provoke-crash. The patch also provides a new "direct" interface, where KPROBES are not used, i.e., the crash is invoked directly upon write to the debugfs file. When built without KPROBES configured, only this mode is available. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Cc: M. Mohan Kumar <mohan@in.ibm.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Eric W. Biederman" <ebiederm@xmission.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02fault injection: correct function names in documentationAnton Blanchard
init_fault_attr_entries() should be init_fault_attr_dentries(). cleanup_fault_attr_entries() should be cleanup_fault_attr_dentries(). Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-16fault-injection: fix example scripts in documentationAkinobu Mita
Fix and cleanup example scripts in fault injection documentation. 1. Eliminate broken oops() shell function. 2. Fold failcmd.sh and failmodule.sh into example scripts. It makes the example scripts work independent of current working directory. 3. Set "space" parameter to 0 to start injecting errors immediately. 4. Use /sys/module/<modulename>/sections/.data as upper bound of .text section. Because some module doesn't have .exit.text section. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fault-injection: add min-order parameter to fail_page_allocAkinobu Mita
Limiting smaller allocation failures by fault injection helps to find real possible bugs. Because higher order allocations are likely to fail and zero-order allocations are not likely to fail. This patch adds min-order parameter to fail_page_alloc. It specifies the minimum page allocation order to be injected failures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] fault-injection: Correct, disambiguate, and reformat documentationDon Mullis
Correct, disambiguate, and reformat documentation. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: stacktrace filteringAkinobu Mita
This patch provides stacktrace filtering feature. The stacktrace filter allows failing only for the caller you are interested in. For example someone may want to inject kmalloc() failures into only e100 module. they want to inject not only direct kmalloc() call, but also indirect allocation, too. - e100_poll --> netif_receive_skb --> packet_rcv_spkt --> skb_clone --> kmem_cache_alloc This patch enables to detect function calls like this by stacktrace and inject failures. The script Documentaion/fault-injection/failmodule.sh helps it. The range of text section of loaded e100 is expected to be [/sys/module/e100/sections/.text, /sys/module/e100/sections/.exit.text) So failmodule.sh stores these values into /debug/failslab/address-start and /debug/failslab/address-end. The maximum stacktrace depth is specified by /debug/failslab/stacktrace-depth. Please see the example that demonstrates how to inject slab allocation failures only for a specific module in Documentation/fault-injection/fault-injection.txt [dwm@meer.net: reject failure if any caller lies within specified range] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for kmallocAkinobu Mita
This patch provides fault-injection capability for kmalloc. Boot option: failslab=<interval>,<probability>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where memory can be allocated safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/failslab/interval /debug/failslab/probability /debug/failslab/specifies /debug/failslab/times /debug/failslab/ignore-gfp-highmem /debug/failslab/ignore-gfp-wait Example: failslab=10,100,0,-1 slab allocation (kmalloc(), kmem_cache_alloc(),..) fails once per 10 times. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: documentation and scriptsAkinobu Mita
This patch set provides some fault-injection capabilities. - kmalloc() failures - alloc_pages() failures - disk IO errors We can see what really happens if those failures happen. In order to enable these fault-injection capabilities: 1. Enable relevant config options (CONFIG_FAILSLAB, CONFIG_PAGE_ALLOC, CONFIG_MAKE_REQUEST) and if you want to configure them via debugfs, enable CONFIG_FAULT_INJECTION_DEBUG_FS. 2. Build and boot with this kernel 3. Configure fault-injection capabilities behavior by boot option or debugfs - Boot option failslab= fail_page_alloc= fail_make_request= - Debugfs /debug/failslab/* /debug/fail_page_alloc/* /debug/fail_make_request/* Please refer to the Documentation/fault-injection/fault-injection.txt for details. 4. See what really happens. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
