path: root/Documentation/fb/intelfb.txt
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16intelfb: support 945GME (as used in ASUS Eee 901)Phil Endecott
Add support for Intel's 945GME graphics chip to the intelfb driver. I have assumed that the 945GME is identical to the already-supported 945GM apart from its PCI IDs; this is based on a quick look at the X driver for these chips which seems to treat them identically. The 945GME is used in the ASUS Eee 901, and I coded this in the hope that I'd be able to use it to get a console at the native 1024x600 resolution which is not known to the BIOS. I realised too late that the intelfb driver does not support mode changing on laptops, so it won't be any use for me. Signed-off-by: Phil Endecott <spam_from_intelfb@chezphil.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: intelfb: add support for the Intel Integrated Graphics Controller ↵Maik Broemme
965G/965GM Add support for the 965G and 965GM graphic chipsets to the intelfb driver. I have a notebook with an Intel Mobile GM965/GL960 Integrated Graphics Controller and with the attached patch the framebuffer comes up. I have tested it a bit with DirectFB to make sure it is working stable. I also have an Intel Mobile GM945 and I compared the results, the programming interface of the 9xx series from Intel is mostly the same, so I think the patch should add all the functionality which the 945GM has. Signed-off-by: Maik Broemme <mbroemme@plusserver.de> Cc: Dave Airlie <airlied@linux.ie> Cc: Antonino Daplas <adaplas@pol.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] intelfb: Documentation updatePh. Marek
Correct sample boot line and add a remark on mode setting. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-22intelfb: update doc and Kconfig (supported devices)Christian Merkle
According to drivers/video/intelfb/intelfb.h, the intelfb driver supportes the following devices: 830M/845G/852GM/855GM/865G/915G/915GM/945G/945GM. So the description in drivers/video/Kconfig and the documentation in Documentation/fb/intelfb.txt is outdated. airlied: cleaned up some other obvious mistakes in intelfb.txt. Signed-off-by: Christian Merkle <mail@christian-merkle.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-21[PATCH] intelfb documentationSylvain Meyer
Add a small documentation of the driver parameters. Signed-off-by: Sylvain Meyer <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
