path: root/Documentation/fb
2008-12-29[ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devicesEric Miao
PXA27x and later processors support overlay1 and overlay2 on-top of the base framebuffer (although under-neath the base is also possible). They support palette and no-palette RGB formats, as well as YUV formats (only available on overlay2). These overlays have dedicated DMA channels and behave in a similar way as a framebuffer. This heavily simplified and re-structured work is based on the original pxafb_overlay.c (which is pending for mainline merge for a long time). The major problems with this pxafb_overlay.c are (if you are interested in the history): 1. heavily redundant (the control logics for overlay1 and overlay2 are actually identical except for some small operations, which are now abstracted into a 'pxafb_layer_ops' structure) 2. a lot of useless and un-tested code (two workarounds which are now fixed on mature silicons) 3. cursorfb is actually useless, hardware cursor should not be used this way, and the code was actually un-tested for a long time. The code in this patch should be self-explanatory, I tried to add minimum comments. As said, this is basically simplified, there are several things still on the pending list: 1. palette mode is un-supported and un-tested (although re-using the palette code of the base framebuffer is actually very easy now with previous clean-up patches) 2. fb_pan_display for overlay(s) is un-supported 3. the base framebuffer can actually be abstracted by 'pxafb_layer' as well, which will help further re-use of the code and keep a better and consistent structure. (This is the reason I named it 'pxafb_layer' instead of 'pxafb_overlay' or something alike) See Documentation/fb/pxafb.txt for additional usage information. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Eric Miao <ycmiao@ycmiao-hp520.(none)>
2008-12-29[ARM] pxafb: allow video memory size to be configurableEric Miao
The amount of video memory size is decided according to the following order: 1. <xres> x <yres> x <bits_per_pixel> by default, which is the backward compatible way 2. size specified in platform data 3. size specified in module parameter 'options' string or specified in kernel boot command line (see updated Documentation/fb/pxafb.txt) And now since the memory is allocated from system memory, the pxafb_mmap can be removed and the default fb_mmap() should be working all right. Also, since we now have introduced the 'struct pxafb_dma_buff' for DMA descriptors and palettes, the allocation can be separated cleanly. NOTE: the LCD DMA actually supports chained transfer (i.e. page-based transfers), to simplify the logic and keep the performance (with less TLB misses when accessing from memory mapped user space), the memory is allocated by alloc_pages_*() to ensures it's physical contiguous. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Eric Miao <ycmiao@ycmiao-hp520.(none)>
2008-10-16uvesafb: document mode to mode_option parameter changeMike Pagano
Document the change from the old "mode" parameter to the "mode_option" parameter. Signed-off-by: Mike Pagano <mpagano@gentoo.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16intelfb: support 945GME (as used in ASUS Eee 901)Phil Endecott
Add support for Intel's 945GME graphics chip to the intelfb driver. I have assumed that the 945GME is identical to the already-supported 945GM apart from its PCI IDs; this is based on a quick look at the X driver for these chips which seems to treat them identically. The 945GME is used in the ASUS Eee 901, and I coded this in the hope that I'd be able to use it to get a console at the native 1024x600 resolution which is not known to the BIOS. I realised too late that the intelfb driver does not support mode changing on laptops, so it won't be any use for me. Signed-off-by: Phil Endecott <spam_from_intelfb@chezphil.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16viafb: viafb.modes, viafb.txtJoseph Chan
Correct via_fb_ to viafb_ and remove the Kconfig part in viafb.txt. viafb.modes: supported mode table viafb.txt: documentation of viafb driver Signed-off-by: Joseph Chan <josephchan@via.com.tw> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24video: sh7760fb: SH7760/SH7763 LCDC framebuffer driverNobuhiro Iwamatsu
Framebuffer driver for the SH7760/SH7763 integrated LCD controller. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Siegfried Schaefer <s.schaefer@schaefer-edv.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: documentation updateKrzysztof Helt
Make the tridentfb documentation closer to current state of the tridentfb driver. Fix also some formatting. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: intelfb: add support for the Intel Integrated Graphics Controller ↵Maik Broemme
965G/965GM Add support for the 965G and 965GM graphic chipsets to the intelfb driver. I have a notebook with an Intel Mobile GM965/GL960 Integrated Graphics Controller and with the attached patch the framebuffer comes up. I have tested it a bit with DirectFB to make sure it is working stable. I also have an Intel Mobile GM945 and I compared the results, the programming interface of the 9xx series from Intel is mostly the same, so I think the patch should add all the functionality which the 945GM has. Signed-off-by: Maik Broemme <mbroemme@plusserver.de> Cc: Dave Airlie <airlied@linux.ie> Cc: Antonino Daplas <adaplas@pol.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: platforming metronomefb and am200epdJaya Kumar
This patch splits metronomefb into the platform independent metronomefb and the platform dependent am200epd. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28lxfb: disable suspend VT switch by defaultAndres Salomon
By default disable VT switch, but allow it to be overridden via the 'vt_switch' module arg. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28lxfb: rename kernel arg fbsize to vramAndres Salomon
Match other fb drivers (including gxfb). Also, document the current boot arguments in Documentation/fb/lxfb.txt. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28update modedb.txt documentation about mode_option parameter changeKrzysztof Helt
Add names of drivers converted to "mode_option" parameter. This is one step toward changing all fb drivers to have common "mode_option" parameter. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28PM/gxfb: add hook to PM console layer that allows disabling of suspend VT switchAndres Salomon
Prior to suspend, we allocate and switch to a new VT; after suspend, we switch back to the original VT. This can be slow, and is completely unnecessary if the framebuffer we're using can restore video properly. This adds a hook that allows drivers to select whether or not to do this vt switch, and changes the gxfb driver to call this hook. It also adds a module param to gxfb to allow controlling of the vt switch (defaulting to no switch). (Note: I'm not convinced that console_sem is the best way to protect this, but we should probably have some form of locking..) [akpm@linux-foundation.org: build fix] Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: replace FBSIZE config option with a module parameterAndres Salomon
Use a command line option (vram) rather than hardcoding the vram size. LxFB already does this; it's useful for machines that can't query the BIOS for fb size. This patch originated from David Woodhouse, was modified by Jordan Crouse, and was then modified further by me. This also adds some gxfb documentation in Documentation/fb. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19fbdev: defio and MetronomefbJaya Kumar
Implement support for the E-Ink Metronome controller. It provides an mmapable interface to the controller using defio support. It was tested with a gumstix pxa255 with Vizplex media using Xfbdev and various X clients such as xeyes, xpdf, xloadimage. This patch also fixes the following bug: Defio would cause a hang on write access to the framebuffer as the page fault would be called ad-infinitum. It fixes fb_defio by setting the mapping to be used by page_mkclean. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fb: defio nopageNick Piggin
Convert fb defio from nopage to fault. Switch from OOM to SIGBUS if the resource is not available. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16fbdev: Update Documentation/fb/00-INDEXJesper Juhl
An update to Documentation/fb/00-INDEX is long overdue. This patch adds entries for new files in the directory and removes entries for files that no longer exist. The files are now also sorted alphabetically. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uvesafb: documentationMichal Januszewski
Documentation for the uvesafb driver. Signed-off-by: Michal Januszewski <spock@gentoo.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11pvr2fb: update Documentation/fb/pvr2fb.txtAdrian McMenamin
The current version is very old and does not correctly specify how to set the video mode. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09arkfb: new framebuffer driver for ARK Logic cardsOndrej Zajicek
This patch adds fbdev driver for graphics cards with ARK Logic 2000PV graphics chip with ICS 5342 ramdac. [adaplas@gmail.com: build fixes] Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09vt8623fb: new framebuffer driver for VIA VT8623Ondrej Zajicek
This patch adds fbdev driver for graphics core in VIA VT8623 [adaplas@gmail.com: build fixes] Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix more "deprecated" spellos.Randy Dunlap
Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08s3fb: driver fixesOndrej Zajicek
This fixes broken fbcon on Virge VX in 24 bpp mode, and contains several other small updates. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: mm: Deferred IO supportJaya Kumar
This implements deferred IO support in fbdev. Deferred IO is a way to delay and repurpose IO. This implementation is done using mm's page_mkwrite and page_mkclean hooks in order to detect, delay and then rewrite IO. This functionality is used by hecubafb. [adaplas] This is useful for graphics hardware with no directly addressable/mappable framebuffer. Implementing this will allow the "framebuffer" to be accesible from user space via mmap(). Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fbdev driver for S3 Trio/VirgeOndrej Zajicek
Add a driver for S3 Trio / S3 Virge. Driver is tested with most versions of S3 Trio and with S3 Virge/DX, on i386. (akpm: We kind-of have support for this hardware already, but... virgefb.c - amiga/zorro specific, - broken (according to Kconfig), - uses obsolete/nonexistent interface (struct display_switch) - recent Adrian Bunk's patch removes this driver S3triofb.c - ppc/openfirmware specific - minimal functionality - broken (according to Kconfig), - uses obsolete/nonexistent interface (struct display_switch) ) Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] Documentation fixes in intel810.txtReiner Herrmann
Signed-off-by: Reiner Herrmann <reiner@reiner-h.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] intelfb: Documentation updatePh. Marek
Correct sample boot line and add a remark on mode setting. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30Merge branch 'intelfb-patches' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6 * 'intelfb-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6: intelfbhw.c: intelfbhw_get_p1p2 defined but not used intelfb: fix mtrr_reg signedness intelfb: update doc and Kconfig (supported devices) intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support
2006-08-22intelfb: update doc and Kconfig (supported devices)Christian Merkle
According to drivers/video/intelfb/intelfb.h, the intelfb driver supportes the following devices: 830M/845G/852GM/855GM/865G/915G/915GM/945G/945GM. So the description in drivers/video/Kconfig and the documentation in Documentation/fb/intelfb.txt is outdated. airlied: cleaned up some other obvious mistakes in intelfb.txt. Signed-off-by: Christian Merkle <mail@christian-merkle.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-08-14[PATCH] add imacfb documentation and detectionEdgar Hucek
Add basic Machine detection to imacfb and some Ducumentation bits for imacfb. Signed-off-by: Edgar Hucek <hostmaster@ed-soft.at> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] VT binding: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt and Documentatin/console/console.txt to reflect the following changes: 1. sysfs attributes are relocated to /sys/class/vtconsole 2. feature is selectable in Kconfig 3. add sample scripts to fbcon.txt Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] VT binding: fbcon: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt to reflect the following changes: 1. Simple illustration of the binding of the console down to individual framebuffer drivers 2. Usage of userspace tools to help with recovery of text console 3. How to use the attributes in /sys/class/tty/console to unload fbcon and the framebuffer drivers Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Detaching fbcon: update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt on the following: 1. sysfs attributes are now located in class/graphics/fbcon 2. instructions on how to attach, detach and/or unload fbcon Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] Update cyblafb driverKnut Petersen
This is a major update to the cyblafb framebuffer driver. Most of the stuff has been tested in the mm tree. Main advantages: ============ - vxres > xres support - ywrap and xpan support - much faster for almost all modes (e.g. 1280x1024-16bpp draws more than 41 full screens of text instead of about 25 full screens of text per second on authors Epia 5000) - module init/exit code fixed - bugs triggered by console rotation fixed - lots of minor improvements - startup modes suitable for high performance scrolling in all directions This diff also contains a lot of white space fixes. No side effects are possible, only one single graphics core is affected. Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] fbcon: Console Rotation - Add framebuffer console documentationAntonino A. Daplas
Add documentation as Documentation/fb/fbcon.txt describing the framebuffer console and its boot options. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] vesafb: Disable mtrr as the defaultAntonino A. Daplas
vesafb occassionally gets the size wrong when setting the mtrr. When X or DRI attempts to set the mtrr, it will fail due to range overlap significantly affecting their performance. Disable mtrr and let the user explicitly enable it with the mtrr:n option. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] i810fb: Update i810fb documentationAntonino A. Daplas
Update i810fb documentation to describe new features and configuration changes. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbdev: Add VESA Coordinated Video Timings (CVT) supportAntonino A. Daplas
The Coordinated Video Timings (CVT) is the latest standard approved by VESA concerning video timings generation. It addresses the limitation of GTF which is designed mainly for CRT displays. CRT's have a high blanking requirement (as much as 25% of the horizontal frame length) which artificially increases the pixelclock. Digital displays, on the other hand, needs to conserve the pixelclock as much as possible. The GTF also does not take into account the different aspect ratios in its calculation. The new function added is fb_find_mode_cvt(). It is called by fb_find_mode() if it recognizes a mode option string formatted for CVT. The format is: <xres>x<yres>[M][R][-<bpp>][<at-sign><refresh>][i][m] The 'M' tells the function to calculate using CVT. On it's own, it will compute a timing for CRT displays at 60Hz. If the 'R' is specified, 'reduced blanking' computation will be used, best for flatpanels. The 'i' and the 'm' is for 'interlaced mode' and 'with margins' respectively. To determine if CVT was used, check for dmesg for something like this: CVT Mode - <pix>M<n>[-R], ie: .480M3-R (800x600 reduced blanking) where: pix - product of xres and yres, in MB M - is a CVT mode n - the aspect ratio (3 - 4:3; 4 - 5:4; 9 - 16:9, 15:9; A - 16:10) -R - reduced blanking Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] framebuffer: new driver for cyberblade/i1 graphics coreKnut Petersen
This is a framebuffer driver for the Cyberblade/i1 graphics core. Currently tridenfb claims to support the cyberblade/i1 graphics core. This is of very limited truth. Even vesafb is faster and provides more working modes and a much better quality of the video signal. There is a great number of bugs in tridentfb ... but most often it is impossible to decide if these bugs are real bugs or if fixing them for the cyberblade/i1 core would break support for one of the other supported chips. Tridentfb seems to be unmaintained,and documentation for most of the supported chips is not available. So "fixing" cyberblade/i1 support inside of tridentfb was not an option, it would have caused numerous if(CYBERBLADEi1) else ... cases and would have rendered the code to be almost unmaintainable. A first version of this driver was published on 2005-07-31. A fix for a bug reported by Jochen Hein was integrated as well as some changes requested by Antonino A. Daplas. A message has been added to tridentfb to inform current users of tridentfb to switch to cyblafb if the cyberblade/i1 graphics core is detected. This patch is one logical change, but because of the included documentation it is bigger than 70kb. Therefore it is not sent to lkml and linux-fbdev-devel, Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de> Cc: Muli Ben-Yehuda <mulix@mulix.org> Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-30[PATCH] vesafb: Document mtrr boot option usageAntonino A. Daplas
Document mtrr boot option usage to Documentation/fb/vesafb.txt. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
