path: root/Documentation/feature-removal-schedule.txt
2008-05-14m68knommu: add info about removing mcfserialSebastian Siewior
Schedule a removal for this driver. Alternative driver is available for a while now. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Deprecate find_task_by_pid()Pavel Emelyanov
There are some places that are known to operate on tasks' global pids only: * the rest_init() call (called on boot) * the kgdb's getthread * the create_kthread() (since the kthread is run in init ns) So use the find_task_by_pid_ns(..., &init_pid_ns) there and schedule the find_task_by_pid for removal. [sukadev@us.ibm.com: Fix warning in kernel/pid.c] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: remove nopageNick Piggin
Nothing in the tree uses nopage any more. Remove support for it in the core mm code and documentation (and a few stray references to it in comments). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Remove SunOS and Solaris binary support.
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-21[SPARC]: Remove SunOS and Solaris binary support.David S. Miller
As per Documentation/feature-removal-schedule.txt Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19Deprecate the asm/semaphore.h files in feature-removal-schedule.Matthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-19x86: merge iommu initialization parametersGlauber Costa
we merge the iommu initialization parameters in pci-dma.c Nice thing, that both architectures at least recognize the same parameters. usedac i386 parameter is marked for deprecation Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-18Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (64 commits) ocfs2/net: Add debug interface to o2net ocfs2: Only build ocfs2/dlm with the o2cb stack module ocfs2/cluster: Get rid of arguments to the timeout routines ocfs2: Put tree in MAINTAINERS ocfs2: Use BUG_ON ocfs2: Convert ocfs2 over to unlocked_ioctl ocfs2: Improve rename locking fs/ocfs2/aops.c: test for IS_ERR rather than 0 ocfs2: Add inode stealing for ocfs2_reserve_new_inode ocfs2: Add ac_alloc_slot in ocfs2_alloc_context ocfs2: Add a new parameter for ocfs2_reserve_suballoc_bits ocfs2: Enable cross extent block merge. ocfs2: Add support for cross extent block ocfs2: Move /sys/o2cb to /sys/fs/o2cb sysfs: Allow removal of symlinks in the sysfs root ocfs2: Reconnect after idle time out. ocfs2/dlm: Cleanup lockres print ocfs2/dlm: Fix lockname in lockres print function ocfs2/dlm: Move dlm_print_one_mle() from dlmmaster.c to dlmdebug.c ocfs2/dlm: Dumps the purgelist into a debugfs file ...
2008-04-18ocfs2: Move /sys/o2cb to /sys/fs/o2cbMark Fasheh
/sys/fs is where we really want file system specific sysfs objects. Ocfs2-tools has been updated to look in /sys/fs/o2cb. We can maintain backwards compatibility with old ocfs2-tools by using a sysfs symlink. After some time (2 years), the symlink can be safely removed. This patch also adds documentation to make it easier for people to figure out what /sys/fs/o2cb is used for. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-17x86: extend the scheduled bzImage symlinks removalIngo Molnar
use of the bzImage symlinks in developer scripts is still widespread, so lets extend the removal period by 2 years. These symlinks cost us near nothing. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-03Merge branch 'master' of ↵David S. Miller
2008-03-22Merge branch 'upstream-net26' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 Conflicts: drivers/s390/net/qeth_main.c
2008-03-22Revert "ide-tape: schedule driver for removal after 6 months"Bartlomiej Zolnierkiewicz
This reverts commit d48567dd43868b3d2e1fcc33ee76dc2d38a1ddeb. Borislav is working on ide-tape "light" version instead. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-17sk98lin: remove obsolete driverStephen Hemminger
All the hardware supported by this driver is now supported by the skge driver. The last remaining issue was support for ancient dual port SysKonnect fiber boards, and the skge driver now does these correctly (p.s. sk98lin was always broken on these old dual port boards anyway). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-13the scheduled rc80211-simple.c removalAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13the scheduled ieee80211 softmac removalAdrian Bunk
2008-03-13the scheduled bcm43xx removalAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <Larry.Finger@lwfinger.net> Cc: <stefano.brivio@polimi.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29x86: delay the export removal of init_mmIngo Molnar
delay the removal of this symbol export by one more kernel release, giving external modules such as VirtualBox a chance to stop using it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-26ide-tape: schedule driver for removal after 6 monthsBorislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: (32 commits) x86: cpa, strict range check in try_preserve_large_page() x86: cpa, enable CONFIG_DEBUG_PAGEALLOC on 64-bit x86: cpa, use page pool x86: introduce page pool in cpa x86: DEBUG_PAGEALLOC: enable after mem_init() brk: help text typo fix lguest: accept guest _PAGE_PWT page table entries x86 PM: update stale comments x86 PM: consolidate suspend and hibernation code x86 PM: rename 32-bit files in arch/x86/power x86 PM: move 64-bit hibernation files to arch/x86/power x86: trivial printk optimizations x86: fix early_ioremap pagetable ops x86: construct 32-bit boot time page tables in native format. x86, core: remove CONFIG_FORCED_INLINING x86: avoid unused variable warning in mm/init_64.c x86: fixup more paravirt fallout brk: document randomize_va_space and CONFIG_COMPAT_BRK (was Re: x86: fix sparse warnings in acpi/bus.c x86: fix sparse warning in topology.c ...
2008-02-09[SPARC]: Add solaris/sunos binary support to feature removal schedule.David S. Miller
2008-02-09x86, core: remove CONFIG_FORCED_INLININGHarvey Harrison
Other than the defconfigs, remove the entry in compiler-gcc4.h, Kconfig.debug and feature-removal-schedule.txt. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08Remove a.out interpreter support in ELF loaderAndi Kleen
Following the deprecation schedule the a.out ELF interpreter support is removed now with this patch. a.out ELF interpreters were an transition feature for moving a.out systems to ELF, but they're unlikely to be still needed. Pure a.out systems will still work of course. This allows to simplify the hairy ELF loader. Signed-off-by: Andi Kleen <ak@suse.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08The scheduled 'time' option removalAdrian Bunk
The scheduled removal of the 'time' option. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: mxser, remove itJiri Slaby
(Old) mxser is obsoleted by mxser_new and scheduled for removal on Dec 2007. Remove it by renaming mxser_new to mxser. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reviewed-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06scheduled OSS driver removalAdrian Bunk
This patch contains the scheduled removal of OSS drivers whose config options have been removed in 2.6.23. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01USB: mark USB drivers as being GPL onlyGreg Kroah-Hartman
Over two years ago, the Linux USB developers stated that they believed there was no way to create a USB kernel driver that was not under the GPL. This patch moves the USB apis to enforce that decision. There are no known closed source USB drivers in the wild, so this patch should cause no problems. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28b43: Add support for new firmwareMichael Buesch
This patch adds support for new firmware. Old firmware is still supported until July 2008. To get new firmware, go to ftp://ftp.linksys.com/opensourcecode/wrt150nv11/1.51.3/ and download the tarball. We don't have a smaller tarball, yet. That will be fixed later. You can extract firmware out of the "wl_ap.o" file contained in this tarball using latest fwcutter. You must pass the option --unsupported to fwcutter. Fwcutter-010 with official support for a new firmware image will be released soon. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Update feature-removal-schedule.txtJan Engelhardt
With all the newly introduced features, there is a lot to remove later on after a compatibility grace period of 2 years. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SHAPER]: The scheduled shaper removal.Adrian Bunk
This patch contains the scheduled removal of the shaper driver. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28doc: fix typo in feature-removal-scheduleStefano Brivio
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: make PID rate control algorithm the defaultStefano Brivio
This makes the new PID TX rate control algorithm the default instead of the rc80211_simple rate control algorithm. The simple algorithm was flawed in several ways: it wasn't responsive at all and didn't age the information it was relying on properly. The PID algorithm allows us to tune characteristics such as responsiveness by adjusting parameters and was found to generally behave better. The default algorithm can be overridden to select simple instead. Which ever algorithm is the default is included as part of the mac80211 module automatically. The other algorithm (simple vs. pid) can be selected for inclusion as well. If EMBEDDED is selected then the choice is available to have no default specified and neither algorithm included in mac80211. The default algorithm can be set through a modparam. While at it, mark rc80211-simple as deprecated, and schedule it for removal. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: ip_tables: remove obsolete SAME targetPatrick McHardy
Remove the ipt_SAME target as scheduled in feature-removal-schedule. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28softmac: mark as obsolete and schedule for removalJohn W. Linville
Schedule softmac for for removal in the 2.6.26 development window. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28bcm43xx: mark as obsolete and schedule for removalJohn W. Linville
Schedule bcm43xx for for removal in the 2.6.26 development window. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-27i2c: Drop redundant i2c_adapter.listJean Delvare
i2c_adapter.list is superfluous, this list duplicates the one maintained by the driver core. Drop it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-01-27i2c: Deprecate drivers for I2C buses on video adaptersJean Delvare
The framebuffer drivers for these pieces of hardware include support for the DDC/I2C buses, so there is no need for separate drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: some overdue driver removalAdrian Bunk
This patch contains the overdue removal of three I2C drivers. [JD: In fact only i2c-ixp4xx can be removed at the moment, the other two platforms don't implement the generic GPIO layer yet.] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: the scheduled I2C RTC driver removalAdrian Bunk
This patch contains the scheduled removal of legacy I2C RTC drivers with replacement drivers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-25IB/mthca: Remove MSI support as scheduledAdrian Bunk
Remove MSI support from the mthca driver, as scheduled. There is no reason to use MSI instead of MSI-X, since MSI-X performs better. No one has spoken up since MSI support was deprecated in commit f6be6fbe ("IB/mthca: Schedule MSI support for removal"), so apparently the MSI support is unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-11-14feature-removal-schedule: remove SA_* flags entryAdrian Bunk
No reason to keep the feature-removal-schedule.txt entry after the code was removed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22V4L/DVB (6378b): Updates info about the removal of V4L1 at ↵Mauro Carvalho Chehab
feature-removal-schedule.txt Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6378a): Removal of VIDIOC_[G|S]_MPEGCOMP from ↵Mauro Carvalho Chehab
2007-10-18The next round of scheduled OSS code removalAdrian Bunk
This patch contains the next round of scheduled OSS code removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: deprecate sys_sysctl in a user space visible fashion.Eric W. Biederman
After adding checking to register_sysctl_table and finding a whole new set of bugs. Missed by countless code reviews and testers I have finally lost patience with the binary sysctl interface. The binary sysctl interface has been sort of deprecated for years and finding a user space program that uses the syscall is more difficult then finding a needle in a haystack. Problems continue to crop up, with the in kernel implementation. So since supporting something that no one uses is silly, deprecate sys_sysctl with a sufficient grace period and notice that the handful of user space applications that care can be fixed or replaced. The /proc/sys sysctl interface that people use will continue to be supported indefinitely. This patch moves the tested warning about sysctls from the path where sys_sysctl to a separate path called from both implementations of sys_sysctl, and it adds a proper entry into Documentation/feature-removal-schedule. Allowing us to revisit this in a couple years time and actually kill sys_sysctl. [lethal@linux-sh.org: sysctl: Fix syscall disabled build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Deprecate a.out ELF interpretersAndi Kleen
The Linux ELF loader is quite complicated and messy code (that could probably need a rewrite, but that's a different chapter). One particular messy part in it is the support for non ELF a.out ld.sos. This was originally added to make transition from a.out to ELF easier because an a.out ELF ld.so could be still build using an older a.out toolkit. But by now that should be fully obsolete and removing it would clean up binfmt_elf.c up a bit. I propose to deprecate this support and remove for 2.6.25. Drawback is that someone still runs their system with a.out ld.so they would need to update the ld.so when updating to a new kernel. This patch just adds an entry to the deprecation file and a printk warning users. [akpm@linux-foundation.org: better warning message] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13Input: remove tsdev interfaceRichard Purdie
Remove the obsolete tsdev.c driver as scheduled. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
