Exception return implies context synchronization, so we can hook up the
SYNC_CORE option to sys_membarrier() simply by selecting the Kconfig option,
just like we've done for arm64 already.
Cc: Orion Hodson <oth@google.com>
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Now that the script 'features-refresh.sh' is available, uses this script
to refresh all the arch-support.txt files in place.
Signed-off-by: Andrea Parri <andrea.parri@amarulasolutions.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
A number of architecture ports are obsolete and getting dropped,
so we no longer want to track the respective features.
We already removed the lines for metag and mn10300, this does
the same edits for all the others.
For the remaining 21 architectures, this shows how many are known
to implement each given feature:
19 time/modern-timekeeping/arch-support.txt
19 time/clockevents/arch-support.txt
15 core/tracehook/arch-support.txt
14 core/generic-idle-thread/arch-support.txt
13 locking/lockdep/arch-support.txt
12 io/dma-api-debug/arch-support.txt
11 debug/kgdb/arch-support.txt
10 time/virt-cpuacct/arch-support.txt
9 debug/kretprobes/arch-support.txt
9 debug/kprobes/arch-support.txt
8 vm/THP/arch-support.txt
8 vm/pte_special/arch-support.txt
8 vm/numa-memblock/arch-support.txt
8 io/sg-chain/arch-support.txt
7 perf/kprobes-event/arch-support.txt
7 locking/rwsem-optimized/arch-support.txt
7 debug/gcov-profile-all/arch-support.txt
7 core/jump-labels/arch-support.txt
7 core/BPF-JIT/arch-support.txt
6 vm/ELF-ASLR/arch-support.txt
6 time/context-tracking/arch-support.txt
6 seccomp/seccomp-filter/arch-support.txt
6 debug/stackprotector/arch-support.txt
5 time/irq-time-acct/arch-support.txt
5 io/dma-contiguous/arch-support.txt
5 debug/uprobes/arch-support.txt
4 vm/ioremap_prot/arch-support.txt
4 time/arch-tick-broadcast/arch-support.txt
4 perf/perf-stackdump/arch-support.txt
4 perf/perf-regs/arch-support.txt
3 debug/KASAN/arch-support.txt
2 vm/PG_uncached/arch-support.txt
2 vm/huge-vmap/arch-support.txt
2 sched/numa-balancing/arch-support.txt
2 sched/membarrier-sync-core/arch-support.txt
2 locking/cmpxchg-local/arch-support.txt
2 debug/optprobes/arch-support.txt
2 debug/kprobes-on-ftrace/arch-support.txt
1 vm/TLB/arch-support.txt
1 locking/queued-spinlocks/arch-support.txt
1 locking/queued-rwlocks/arch-support.txt
1 debug/user-ret-profiler/arch-support.txt
0 lib/strncasecmp/arch-support.txt
Note that the list does not include riscv or nds32 yet, these still
need to be added.
Remove the MN10300 arch as the hardware is defunct.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
cc: Masahiro Yamada <yamada.masahiro@socionext.com>
cc: linux-am33-list@redhat.com
Remove any remaining references to the Meta architecture in
Documentation/, primarily from Documentation/features/.
Signed-off-by: James Hogan <jhogan@kernel.org>
Cc: linux-metag@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Ensure we gather architecture requirements about each architecture
supporting the "sync_core" membarrier command in a single file under
Documentation/features.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Andrea Parri <parri.andrea@gmail.com>
Cc: Andrew Hunter <ahh@google.com>
Cc: Avi Kivity <avi@scylladb.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Dave Watson <davejwatson@fb.com>
Cc: David Sehr <sehr@google.com>
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Maged Michael <maged.michael@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-api@vger.kernel.org
Link: http://lkml.kernel.org/r/1518208256-22034-1-git-send-email-mathieu.desnoyers@efficios.com
