path: root/Documentation/features
2017-08-07docs/features: parisc implements tracehookJames Hogan
Since commit 64e2a42bca12 ("parisc: Add ARCH_TRACEHOOK and regset support") in v4.7, parisc selects HAVE_ARCH_TRACEHOOK, so update its entry in Documentation/features from TODO to ok. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-05-05Merge tag 'powerpc-4.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights include: - Larger virtual address space on 64-bit server CPUs. By default we use a 128TB virtual address space, but a process can request access to the full 512TB by passing a hint to mmap(). - Support for the new Power9 "XIVE" interrupt controller. - TLB flushing optimisations for the radix MMU on Power9. - Support for CAPI cards on Power9, using the "Coherent Accelerator Interface Architecture 2.0". - The ability to configure the mmap randomisation limits at build and runtime. - Several small fixes and cleanups to the kprobes code, as well as support for KPROBES_ON_FTRACE. - Major improvements to handling of system reset interrupts, correctly treating them as NMIs, giving them a dedicated stack and using a new hypervisor call to trigger them, all of which should aid debugging and robustness. - Many fixes and other minor enhancements. Thanks to: Alastair D'Silva, Alexey Kardashevskiy, Alistair Popple, Andrew Donnellan, Aneesh Kumar K.V, Anshuman Khandual, Anton Blanchard, Balbir Singh, Ben Hutchings, Benjamin Herrenschmidt, Bhupesh Sharma, Chris Packham, Christian Zigotzky, Christophe Leroy, Christophe Lombard, Daniel Axtens, David Gibson, Gautham R. Shenoy, Gavin Shan, Geert Uytterhoeven, Guilherme G. Piccoli, Hamish Martin, Hari Bathini, Kees Cook, Laurent Dufour, Madhavan Srinivasan, Mahesh J Salgaonkar, Mahesh Salgaonkar, Masami Hiramatsu, Matt Brown, Matthew R. Ochs, Michael Neuling, Naveen N. Rao, Nicholas Piggin, Oliver O'Halloran, Pan Xinhui, Paul Mackerras, Rashmica Gupta, Russell Currey, Sukadev Bhattiprolu, Thadeu Lima de Souza Cascardo, Tobin C. Harding, Tyrel Datwyler, Uma Krishnan, Vaibhav Jain, Vipin K Parashar, Yang Shi" * tag 'powerpc-4.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (214 commits) powerpc/64s: Power9 has no LPCR[VRMASD] field so don't set it powerpc/powernv: Fix TCE kill on NVLink2 powerpc/mm/radix: Drop support for CPUs without lockless tlbie powerpc/book3s/mce: Move add_taint() later in virtual mode powerpc/sysfs: Move #ifdef CONFIG_HOTPLUG_CPU out of the function body powerpc/smp: Document irq enable/disable after migrating IRQs powerpc/mpc52xx: Don't select user-visible RTAS_PROC powerpc/powernv: Document cxl dependency on special case in pnv_eeh_reset() powerpc/eeh: Clean up and document event handling functions powerpc/eeh: Avoid use after free in eeh_handle_special_event() cxl: Mask slice error interrupts after first occurrence cxl: Route eeh events to all drivers in cxl_pci_error_detected() cxl: Force context lock during EEH flow powerpc/64: Allow CONFIG_RELOCATABLE if COMPILE_TEST powerpc/xmon: Teach xmon oops about radix vectors powerpc/mm/hash: Fix off-by-one in comment about kernel contexts ids powerpc/pseries: Enable VFIO powerpc/powernv: Fix iommu table size calculation hook for small tables powerpc/powernv: Check kzalloc() return value in pnv_pci_table_alloc powerpc: Add arch/powerpc/tools directory ...
2017-05-01docs: remove all references to AVR32 architectureHans-Christian Noren Egtvedt
The AVR32 architecture support has been removed from the Linux kernel, hence remove all references to it from Documentation. Signed-off-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Håvard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2017-04-24powerpc/kprobes: Add support for KPROBES_ON_FTRACENaveen N. Rao
Allow kprobes to be placed on ftrace _mcount() call sites. This optimization avoids the use of a trap, by riding on ftrace infrastructure. This depends on HAVE_DYNAMIC_FTRACE_WITH_REGS which depends on MPROFILE_KERNEL, which is only currently enabled on powerpc64le with newer toolchains. Based on the x86 code by Masami. Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-12-23Merge tag 'arc-4.10-rc1-part2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull more ARC updates from Vineet Gupta: - Fix for aliasing VIPT dcache in old ARC700 cores - micro-optimization in ARC700 ProtV handler - Enable SG_CHAIN [Vladimir] - ARC HS38 core intc default to prio 1 * tag 'arc-4.10-rc1-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: mm: arc700: Don't assume 2 colours for aliasing VIPT dcache ARC: mm: No need to save cache version in @cpuinfo ARC: enable SG chaining ARCv2: intc: default all interrupts to priority 1 ARCv2: entry: document intr disable in hard isr ARC: ARCompact entry: elide re-reading ECR in ProtV handler
2016-12-18ARC: enable SG chainingVladimir Kondratiev
Signed-off-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-12-15xtensa: update DMA-related Documentation/features entriesMax Filippov
xtensa supports DMA API debug and contiguous DMA, mark it as such. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2016-10-13Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_APIRalf Baechle
This should have been part of 40e084a506eb ('MIPS: Add uprobes support.'). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Fixes: 40e084a506eb ("MIPS: Add uprobes support.") Acked-by: Jonathan Corbet <corbet@lwn.net> Cc: linux-mips@linux-mips.org Cc: linux-doc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14392/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-05-11powerpc: Add HAVE_PERF_USER_STACK_DUMP supportChandan Kumar
With perf regs support enabled for powerpc, in commit ed4a4ef85cf5 ("powerpc/perf: Add support for sampling interrupt register state"), the support for obtaining perf user stack dump is already enabled. This patch declares the support for same and also updates documentation to mark the support for perf-regs and perf-stackdump. Signed-off-by: Chandan Kumar <chandan.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-03-17Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: "Here are the main arm64 updates for 4.6. There are some relatively intrusive changes to support KASLR, the reworking of the kernel virtual memory layout and initial page table creation. Summary: - Initial page table creation reworked to avoid breaking large block mappings (huge pages) into smaller ones. The ARM architecture requires break-before-make in such cases to avoid TLB conflicts but that's not always possible on live page tables - Kernel virtual memory layout: the kernel image is no longer linked to the bottom of the linear mapping (PAGE_OFFSET) but at the bottom of the vmalloc space, allowing the kernel to be loaded (nearly) anywhere in physical RAM - Kernel ASLR: position independent kernel Image and modules being randomly mapped in the vmalloc space with the randomness is provided by UEFI (efi_get_random_bytes() patches merged via the arm64 tree, acked by Matt Fleming) - Implement relative exception tables for arm64, required by KASLR (initial code for ARCH_HAS_RELATIVE_EXTABLE added to lib/extable.c but actual x86 conversion to deferred to 4.7 because of the merge dependencies) - Support for the User Access Override feature of ARMv8.2: this allows uaccess functions (get_user etc.) to be implemented using LDTR/STTR instructions. Such instructions, when run by the kernel, perform unprivileged accesses adding an extra level of protection. The set_fs() macro is used to "upgrade" such instruction to privileged accesses via the UAO bit - Half-precision floating point support (part of ARMv8.2) - Optimisations for CPUs with or without a hardware prefetcher (using run-time code patching) - copy_page performance improvement to deal with 128 bytes at a time - Sanity checks on the CPU capabilities (via CPUID) to prevent incompatible secondary CPUs from being brought up (e.g. weird big.LITTLE configurations) - valid_user_regs() reworked for better sanity check of the sigcontext information (restored pstate information) - ACPI parking protocol implementation - CONFIG_DEBUG_RODATA enabled by default - VDSO code marked as read-only - DEBUG_PAGEALLOC support - ARCH_HAS_UBSAN_SANITIZE_ALL enabled - Erratum workaround Cavium ThunderX SoC - set_pte_at() fix for PROT_NONE mappings - Code clean-ups" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (99 commits) arm64: kasan: Fix zero shadow mapping overriding kernel image shadow arm64: kasan: Use actual memory node when populating the kernel image shadow arm64: Update PTE_RDONLY in set_pte_at() for PROT_NONE permission arm64: Fix misspellings in comments. arm64: efi: add missing frame pointer assignment arm64: make mrs_s prefixing implicit in read_cpuid arm64: enable CONFIG_DEBUG_RODATA by default arm64: Rework valid_user_regs arm64: mm: check at build time that PAGE_OFFSET divides the VA space evenly arm64: KVM: Move kvm_call_hyp back to its original localtion arm64: mm: treat memstart_addr as a signed quantity arm64: mm: list kernel sections in order arm64: lse: deal with clobbered IP registers after branch via PLT arm64: mm: dump: Use VA_START directly instead of private LOWEST_ADDR arm64: kconfig: add submenu for 8.2 architectural features arm64: kernel: acpi: fix ioremap in ACPI parking protocol cpu_postboot arm64: Add support for Half precision floating point arm64: Remove fixmap include fragility arm64: Add workaround for Cavium erratum 27456 arm64: mm: Mark .rodata as RO ...
2016-02-18arm64: add support for ioremap() block mappingsArd Biesheuvel
This wires up the existing generic huge-vmap feature, which allows ioremap() to use PMD or PUD sized block mappings. It also adds support to the unmap path for dealing with block mappings, which will allow us to unmap the __init region using unmap_kernel_range() in a subsequent patch. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2016-01-26Remove "arch" usage in Documentation/features/list-arch.shdcg
Commit 669f6f96c680a741257ada44a28b580df2e1fc25 introduced the script list-arch.sh, which uses the command "arch": ARCH=${1:-$(arch | sed 's/x86_64/x86/' | sed 's/i386/x86/')} It turns out that the "arch" command does not exist in my system (arch distro). Google found man pages which say "arch is deprecated command since release util-linux 2.13. Use uname -m" (util-linux 2.13 was released in 2007). I also found a debian bug reporting the lack of arch and being told to use uname -m https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=446023 But then, why it works in some distros? Apparently coreutils gained an optional arch command that needs to be explicitly enabled during compilation. Some distros enable it, others don't. Sigh. Signed-off-by: Diego Calleja <diegocg@gmail.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15mm, thp: remove infrastructure for handling splitting PMDsKirill A. Shutemov
With new refcounting we don't need to mark PMDs splitting. Let's drop code to handle this. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12Merge branch 'for-linus-4.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml Pull UML updates from Richard Weinberger: "This contains beside of random fixes/cleanups two bigger changes: - seccomp support by Mickaël Salaün - IRQ rework by Anton Ivanov" * 'for-linus-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: um: Use race-free temporary file creation um: Do not set unsecure permission for temporary file um: Fix build error and kconfig for i386 um: Add seccomp support um: Add full asm/syscall.h support selftests/seccomp: Remove the need for HAVE_ARCH_TRACEHOOK um: Fix ptrace GETREGS/SETREGS bugs um: link with -lpthread um: Update UBD to use pread/pwrite family of functions um: Do not change hard IRQ flags in soft IRQ processing um: Prevent IRQ handler reentrancy uml: flush stdout before forking uml: fix hostfs mknod()
2016-01-10um: Add seccomp supportMickaël Salaün
This brings SECCOMP_MODE_STRICT and SECCOMP_MODE_FILTER support through prctl(2) and seccomp(2) to User-mode Linux for i386 and x86_64 subarchitectures. secure_computing() is called first in handle_syscall() so that the syscall emulation will be aborted quickly if matching a seccomp rule. This is inspired from Meredydd Luff's patch (https://gerrit.chromium.org/gerrit/21425). Signed-off-by: Mickaël Salaün <mic@digikod.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Will Drewry <wad@chromium.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: James Hogan <james.hogan@imgtec.com> Cc: Meredydd Luff <meredydd@senatehouse.org> Cc: David Drysdale <drysdale@google.com> Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Kees Cook <keescook@chromium.org>
2015-12-03arm64: enable HAVE_IRQ_TIME_ACCOUNTINGWill Deacon
arm64 relies on the arm_arch_timer for sched_clock, so we can select HAVE_IRQ_TIME_ACCOUNTING and have the core sched-clock code enable the feature at runtime based on the rate. Reported-by: Mario Smarduch <m.smarduch@samsung.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-11-04Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: - "genirq: Introduce generic irq migration for cpu hotunplugged" patch merged from tip/irq/for-arm to allow the arm64-specific part to be upstreamed via the arm64 tree - CPU feature detection reworked to cope with heterogeneous systems where CPUs may not have exactly the same features. The features reported by the kernel via internal data structures or ELF_HWCAP are delayed until all the CPUs are up (and before user space starts) - Support for 16KB pages, with the additional bonus of a 36-bit VA space, though the latter only depending on EXPERT - Implement native {relaxed, acquire, release} atomics for arm64 - New ASID allocation algorithm which avoids IPI on roll-over, together with TLB invalidation optimisations (using local vs global where feasible) - KASan support for arm64 - EFI_STUB clean-up and isolation for the kernel proper (required by KASan) - copy_{to,from,in}_user optimisations (sharing the memcpy template) - perf: moving arm64 to the arm32/64 shared PMU framework - L1_CACHE_BYTES increased to 128 to accommodate Cavium hardware - Support for the contiguous PTE hint on kernel mapping (16 consecutive entries may be able to use a single TLB entry) - Generic CONFIG_HZ now used on arm64 - defconfig updates * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (91 commits) arm64/efi: fix libstub build under CONFIG_MODVERSIONS ARM64: Enable multi-core scheduler support by default arm64/efi: move arm64 specific stub C code to libstub arm64: page-align sections for DEBUG_RODATA arm64: Fix build with CONFIG_ZONE_DMA=n arm64: Fix compat register mappings arm64: Increase the max granular size arm64: remove bogus TASK_SIZE_64 check arm64: make Timer Interrupt Frequency selectable arm64/mm: use PAGE_ALIGNED instead of IS_ALIGNED arm64: cachetype: fix definitions of ICACHEF_* flags arm64: cpufeature: declare enable_cpu_capabilities as static genirq: Make the cpuhotplug migration code less noisy arm64: Constify hwcap name string arrays arm64/kvm: Make use of the system wide safe values arm64/debug: Make use of the system wide safe value arm64: Move FP/ASIMD hwcap handling to common code arm64/HWCAP: Use system wide safe values arm64/capabilities: Make use of system wide safe value arm64: Delay cpu feature capability checks ...
2015-10-17Documentation/features/vm: THP now supported by ARCVineet Gupta
2015-10-12Documentation/features/KASAN: arm64 supports KASAN nowAndrey Ryabinin
Signed-off-by: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-10-09Documentation/features/vm: pte_special now supported by ARCVineet Gupta
2015-09-09Merge tag 'metag-for-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag updates from James Hogan: "Metag architecture changes for v4.3. Just a couple of changes for v4.3-rc1. A preparatory IRQ patch to prepare for moving irq_data struct members, and a tweak to Documentation/features since Meta2 could support THP" * tag 'metag-for-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: Documentation/features/vm: Meta2 is capable of THP metag/irq: Use access helper irq_data_get_affinity_mask()
2015-09-07Documentation/features/vm: Meta2 is capable of THPJames Hogan
Change metag Transparent Huge Pages (THP) support from .. to TODO. Meta2 has variable sized pages, between 4KB and 4MB, specified at the 1st level page table level, and already supports hugetlbfs, so supporting THP is theoretically possible too. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: linux-metag@vger.kernel.org Cc: linux-doc@vger.kernel.org
2015-09-04Documentation/features/vm: add feature description and arch support status ↵Mel Gorman
for batched TLB flush after unmap Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull tile updates from Chris Metcalf: "This includes secure computing support as well as miscellaneous minor improvements" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: correct some typos in opcode type names tile/vdso: emit a GNU hash as well tile: Remove finish_arch_switch tile: enable full SECCOMP support tile/time: Migrate to new 'set-state' interface
2015-09-03Documentation: MIPS now supports uprobes.Ralf Baechle
2015-07-30tile: enable full SECCOMP supportChris Metcalf
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-06-03Documentation/features: Explain kernel feature descriptions and add ↵Ingo Molnar
visualization script The previous patches added arch support matrices for more than 40 generic kernel features that need per architecture support. The structure of the feature descriptions is the following: Each feature has its own directory under Documentation/features/subsystem_name/feature_name/, and the arch-support.txt file shows its current arch porting status. For example, lockdep support is shown the following way: triton:~/tip> cat Documentation/features/locking/lockdep/arch-support.txt # # Feature name: lockdep # Kconfig: LOCKDEP_SUPPORT # description: arch supports the runtime locking correctness debug facility # ----------------------- | arch |status| ----------------------- | alpha: | TODO | | arc: | ok | | arm: | ok | | arm64: | ok | | avr32: | ok | | blackfin: | ok | | c6x: | TODO | | cris: | TODO | | frv: | TODO | | h8300: | TODO | | hexagon: | ok | | ia64: | TODO | | m32r: | TODO | | m68k: | TODO | | metag: | ok | | microblaze: | ok | | mips: | ok | | mn10300: | TODO | | nios2: | TODO | | openrisc: | TODO | | parisc: | TODO | | powerpc: | ok | | s390: | ok | | score: | ok | | sh: | ok | | sparc: | ok | | tile: | ok | | um: | ok | | unicore32: | ok | | x86: | ok | | xtensa: | ok | ----------------------- For generic kernel features that need architecture support, the arch-support.txt file in each feature directory shows the arch support matrix, for all upstream Linux architectures. The meaning of entries in the tables is: | ok | # feature supported by the architecture |TODO| # feature not yet supported by the architecture | .. | # feature cannot be supported by the hardware This directory structure can be used in the future to add other files - such as porting guides, testing description, etc. The Documentation/features/ hierarchy may also include generic kernel features that works on every architecture, in that case the arch-support.txt file will list every architecture as supported. To list an architecture's unsupported features, just do something like: triton:~/tip> git grep -lE 'x86.*TODO' Documentation/features/*/*/arch-support.txt Documentation/features/lib/strncasecmp/arch-support.txt Documentation/features/time/arch-tick-broadcast/arch-support.txt which will print the list of not yet supported features. The Documentation/features/list-arch.sh script will print the current support matrix of one architecture: triton:~/tip> Documentation/features/list-arch.sh # # Kernel feature support matrix of the 'x86' architecture: # core/ BPF-JIT : ok | HAVE_BPF_JIT # arch supports BPF JIT optimizations core/ generic-idle-thread : ok | GENERIC_SMP_IDLE_THREAD # arch makes use of the generic SMP idle thread facility core/ jump-labels : ok | HAVE_ARCH_JUMP_LABEL # arch supports live patched, high efficiency branches core/ tracehook : ok | HAVE_ARCH_TRACEHOOK # arch supports tracehook (ptrace) register handling APIs debug/ gcov-profile-all : ok | ARCH_HAS_GCOV_PROFILE_ALL # arch supports whole-kernel GCOV code coverage profiling debug/ KASAN : ok | HAVE_ARCH_KASAN # arch supports the KASAN runtime memory checker debug/ kgdb : ok | HAVE_ARCH_KGDB # arch supports the kGDB kernel debugger debug/ kprobes : ok | HAVE_KPROBES # arch supports live patched kernel probe debug/ kprobes-on-ftrace : ok | HAVE_KPROBES_ON_FTRACE # arch supports combined kprobes and ftrace live patching debug/ kretprobes : ok | HAVE_KRETPROBES # arch supports kernel function-return probes debug/ optprobes : ok | HAVE_OPTPROBES # arch supports live patched optprobes debug/ stackprotector : ok | HAVE_CC_STACKPROTECTOR # arch supports compiler driven stack overflow protection debug/ uprobes : ok | ARCH_SUPPORTS_UPROBES # arch supports live patched user probes debug/ user-ret-profiler : ok | HAVE_USER_RETURN_NOTIFIER # arch supports user-space return from system call profiler io/ dma-api-debug : ok | HAVE_DMA_API_DEBUG # arch supports DMA debug facilities io/ dma-contiguous : ok | HAVE_DMA_CONTIGUOUS # arch supports the DMA CMA (continuous memory allocator) io/ dma_map_attrs : ok | HAVE_DMA_ATTRS # arch provides dma_*map*_attrs() APIs io/ sg-chain : ok | ARCH_HAS_SG_CHAIN # arch supports chained scatter-gather lists lib/ strncasecmp : TODO | __HAVE_ARCH_STRNCASECMP # arch provides an optimized strncasecmp() function locking/ cmpxchg-local : ok | HAVE_CMPXCHG_LOCAL # arch supports the this_cpu_cmpxchg() API locking/ lockdep : ok | LOCKDEP_SUPPORT # arch supports the runtime locking correctness debug facility locking/ queued-rwlocks : ok | ARCH_USE_QUEUED_RWLOCKS # arch supports queued rwlocks locking/ queued-spinlocks : ok | ARCH_USE_QUEUED_SPINLOCKS # arch supports queued spinlocks locking/ rwsem-optimized : ok | Optimized asm/rwsem.h # arch provides optimized rwsem APIs perf/ kprobes-event : ok | HAVE_REGS_AND_STACK_ACCESS_API # arch supports kprobes with perf events perf/ perf-regs : ok | HAVE_PERF_REGS # arch supports perf events register access perf/ perf-stackdump : ok | HAVE_PERF_USER_STACK_DUMP # arch supports perf events stack dumps sched/ numa-balancing : ok | ARCH_SUPPORTS_NUMA_BALANCING # arch supports NUMA balancing seccomp/ seccomp-filter : ok | HAVE_ARCH_SECCOMP_FILTER # arch supports seccomp filters time/ arch-tick-broadcast : TODO | ARCH_HAS_TICK_BROADCAST # arch provides tick_broadcast() time/ clockevents : ok | GENERIC_CLOCKEVENTS # arch support generic clock events time/ context-tracking : ok | HAVE_CONTEXT_TRACKING # arch supports context tracking for NO_HZ_FULL time/ irq-time-acct : ok | HAVE_IRQ_TIME_ACCOUNTING # arch supports precise IRQ time accounting time/ modern-timekeeping : ok | !ARCH_USES_GETTIMEOFFSET # arch does not use arch_gettimeoffset() anymore time/ virt-cpuacct : ok | HAVE_VIRT_CPU_ACCOUNTING # arch supports precise virtual CPU time accounting vm/ ELF-ASLR : ok | ARCH_HAS_ELF_RANDOMIZE # arch randomizes the stack, heap and binary images of ELF binaries vm/ huge-vmap : ok | HAVE_ARCH_HUGE_VMAP # arch supports the ioremap_pud_enabled() and ioremap_pmd_enabled() VM APIs vm/ ioremap_prot : ok | HAVE_IOREMAP_PROT # arch has ioremap_prot() vm/ numa-memblock : ok | HAVE_MEMBLOCK_NODE_MAP # arch supports NUMA aware memblocks vm/ PG_uncached : ok | ARCH_USES_PG_UNCACHED # arch supports the PG_uncached page flag vm/ pmdp_splitting_flush : ok | __HAVE_ARCH_PMDP_SPLITTING_FLUSH # arch supports the pmdp_splitting_flush() VM API vm/ pte_special : ok | __HAVE_ARCH_PTE_SPECIAL # arch supports the pte_special()/pte_mkspecial() VM APIs vm/ THP : ok | HAVE_ARCH_TRANSPARENT_HUGEPAGE # arch supports transparent hugepages Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/core: Add feature description and arch support status ↵Ingo Molnar
file for 'BPF-JIT' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/locking: Add feature description and arch support ↵Ingo Molnar
status file for 'queued-rwlocks' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'queued-spinlocks' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/debug: Add feature description and arch support ↵Ingo Molnar
status file for 'gcov-profile-all' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'cmpxchg-local' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/perf: Add feature description and arch support status ↵Ingo Molnar
file for 'perf-stackdump' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
file for 'perf-regs' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/io: Add feature description and arch support status ↵Ingo Molnar
file for 'dma-api-debug' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
file for 'kprobes-event' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
file for 'generic-idle-thread' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'user-ret-profiler' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'kretprobes' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'uprobes' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'kprobes-on-ftrace' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'optprobes' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'kprobes' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/time: Add feature description and arch support status ↵Ingo Molnar
file for 'arch-tick-broadcast' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/vm: Add feature description and arch support status ↵Ingo Molnar
file for 'ELF-ASLR' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
file for 'clockevents' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
status file for 'kgdb' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
file for 'context-tracking' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03Documentation/features/seccomp: Add feature description and arch support ↵Ingo Molnar
status file for 'seccomp-filter' Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
