path: root/Documentation/filesystems/adfs.txt
2011-03-22adfs: add hexadecimal filetype suffix optionStuart Swales
ADFS (FileCore) storage complies with the RISC OS filetype specification (12 bits of file type information is stored in the file load address, rather than using a file extension). The existing driver largely ignores this information and does not present it to the end user. It is desirable that stored filetypes be made visible to the end user to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu) or to a network share which can be accessed by real Acorn systems. This patch implements a per-mount filetype suffix option (use -o ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each file. This type suffix is compatible with that used by RISC OS systems that access network servers using NFS client software and by RPCemu's host filing system. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30Fix typos in /Documentation : 'U-Z'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letters 'U-Z'. Looks like I made it through the alphabet...just in time to start over again +too! Maybe I can fit more profound fixes into the next round...? Time will +tell. :) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
