path: root/Documentation/filesystems/ext3.txt
2011-07-25ext3.txt: update the links in the section "useful links" to the latest onesWang Sheng-Hui
In Documentation/filesystems/ext3.txt, the section "useful links" provides two links which link to ibm developerworks articles. While the second one can be redirected to the latest one, the first one http://www.ibm.com/developerworks/library/l-fs7.html fails to be redirected. Update the 2 links to the latest ones. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3/ext4 Documentation: remove bh/nobh since it has been deprecatedLukas Czerner
Bh and nobh mount option has been deprecated in ext4 (206f7ab4f49a2021fcb8687f25395be77711ddee) and in ext3 (4c4d3901225518ed1a4c938ba15ba09842a00770) so remove those options from documentation. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: make barrier options consistent with ext4Eric Sandeen
ext4 was updated to accept barrier/nobarrier mount options in addition to the older barrier=0/1. The barrier story is complex enough, we should help people by making the options the same at least, even if the defaults are different. This patch allows the barrier/nobarrier mount options for ext3, while keeping nobarrier the default. It also unconditionally displays barrier status in show_options, and prints a message at mount time if barriers are not enabled, just as ext4 does. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext3: make "norecovery" an alias for "noload"Eric Sandeen
Users on the list recently complained about differences across filesystems w.r.t. how to mount without a journal replay. In the discussion it was noted that xfs's "norecovery" option is perhaps more descriptively accurate than "noload," so let's make that an alias for ext3. Also show this status in /proc/mounts Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-10-13ext3: Update documentation about ext3 quota mount optionsJan Kara
2009-03-30trivial: document ext3 semantics of 'ro' option a bit betterPavel Machek
ext3 has quite unexpected semantics or "ro" and defaults are not what they are documented to be, due to mkfs override. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-12trivial: fix bad links in the ext2 and ext3 documentationJody McIntyre
Trivial patch to fix bad links in the ext2 and ext3 documentation. Signed-off-by: Jody McIntyre <scjody@sun.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20ext3: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount a ext3 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's http://www.zip.com.au/~akpm/FD Cami
Remove Andrew Morton's http://www.zip.com.au/~akpm/ urls, update to new ones when necessary, delete references otherwise. There are still instances of that living in: Documentation/zh_CN/HOWTO Documentation/zh_CN/SubmittingPatches Documentation/ko_KR/HOWTO Documentation/ja_JP/SubmittingPatches Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20documentation/ext3: grammar fixesShaun Zinck
Fix some grammar in the explanation of the Journal Block Device layer. Signed-off-by: Shaun Zinck <shaun.zinck@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-06-26[PATCH] ext3: Add "-o bh" optionBadari Pulavarty
This patch adds "-o bh" option to force use of buffer_heads. This option is needed when we make "nobh" as default - and if we run into problems. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] ext3: fix documentation of online resizingTore Anderson
Undocument the non-working resize= mount option in ext3, and add some references to the ext2resize package instead, which appears to be the only proper way of doing online resizing of ext3 filesystems. Signed-off-by: Tore Anderson <tore@fud.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Docs update: small spelling, formating etc fixes for ↵Jesper Juhl
filesystems/ext3.txt Spelling fixes, formating changes and corrections for Documentation/filesystems/ext3.txt Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] ext3: external journal device as a mount optionJohann Lombardi
The patch below adds a new mount option to allow the external journal device to be specified. The syntax is as follows: # mount -t ext3 -o journal_dev=0x0820 ... where 0x0820 means major=8 and minor=32. Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] ext3: fix mount options documentationAndreas Gruenbacher
Reported by Jacques de Mer and Daniel Drake <dsd@gentoo.org>. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
