path: root/Documentation/filesystems/relay.txt
2008-07-26relay: add buffer-only channels; useful for early loggingEduard - Gabriel Munteanu
Allows one to create and use a channel with no associated files. Files can be initialized later. This is useful in scenarios such as logging in early code, before VFS is up. Therefore, such channels can be created and used as soon as kmem_cache_init() completed. This is needed by kmemtrace to do tracing in early kernel code. [kosaki.motohiro@jp.fujitsu.com: build fix] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03doc: use correct debugfs mountpointRandy Dunlap
Use the normal, expected mountpoint in the relay(fs) example for debugfs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-11[PATCH] Relay: add CPU hotplug supportMathieu Desnoyers
Mathieu originally needed to add this for tracing Xen, but it's something that's needed for any application that can be tracing while cpus are added. unplug isn't supported by this patch. The thought was that at minumum a new buffer needs to be added when a cpu comes up, but it wasn't worth the effort to remove buffers on cpu down since they'd be freed soon anyway when the channel was closed. [zanussi@us.ibm.com: avoid lock_cpu_hotplug deadlock] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-08-27[PATCH] Documentation update for relay interfaceTom Zanussi
Here's updated documentation for the relay interface, rewritten to match the relayfs->relay changes. It also moves relayfs.txt to relay.txt in the process. It includes the changes to relayfs.txt previously posted by Randy Dunlap, thanks for those. The relay-apps examples have also been updated to match, and can be found on the sourceforge relayfs website. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
