path: root/Documentation/filesystems
2010-06-04Merge branch 'master' into for-linusAlex Elder
2010-06-03xfs: remove done roadmap item from xfs-delayed-logging-design.txtChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27Documentation/filesystems/Locking: update documentation on llseek() wrt BKLJan Blunck
The inode's i_size is not protected by the big kernel lock. Therefore it does not make sense to recommend taking the BKL in filesystems llseek operations. Instead it should use the inode's mutex or use just use i_size_read() instead. Add a note that this is not protecting file->f_pos. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: John Kacur <jkacur@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: squashfs: update documentation to include description of xattr layout squashfs: fix name reading in squashfs_xattr_get squashfs: constify xattr handlers squashfs: xattr fix sparse warnings squashfs: xattr_lookup sparse fix squashfs: add xattr support configure option squashfs: add new extended inode types squashfs: add support for xattr reading squashfs: add xattr id support
2010-05-26squashfs: update documentation to include description of xattr layoutPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-25Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: Ensure inode allocation buffers are fully replayed xfs: enable background pushing of the CIL xfs: forced unmounts need to push the CIL xfs: Introduce delayed logging core code xfs: Delayed logging design documentation xfs: Improve scalability of busy extent tracking xfs: make the log ticket ID available outside the log infrastructure xfs: clean up log ticket overrun debug output xfs: Clean up XFS_BLI_* flag namespace xfs: modify buffer item reference counting xfs: allow log ticket allocation to take allocation flags xfs: Don't reuse the same transaction ID for duplicated transactions.
2010-05-25mempolicy: document cpuset interaction with tmpfs mpol mount optionLee Schermerhorn
Update Documentation/filesystems/tmpfs.txt to describe the interaction of tmpfs mount option memory policy with tasks' cpuset mems_allowed. Note: the mount(8) man page [in the util-linux-ng package] requires similiar updates. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24Merge branch 'delayed-logging-for-2.6.35' into for-linusAlex Elder
2010-05-24xfs: Delayed logging design documentationDave Chinner
Document the design of the delayed logging implementation. This includes assumptions made, dead ends followed, the reasoning behind the structuring of the code, the layout of various structures, how things fit together, traps and pit-falls avoided, etc. This is all too much to document in the code itself, so do it in a separate file. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-05-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (31 commits) dquot: Detect partial write error to quota file in write_blk() and add printk_ratelimit for quota error messages ocfs2: Fix lock inversion in quotas during umount ocfs2: Use __dquot_transfer to avoid lock inversion ocfs2: Fix NULL pointer deref when writing local dquot ocfs2: Fix estimate of credits needed for quota allocation ocfs2: Fix quota locking ocfs2: Avoid unnecessary block mapping when refreshing quota info ocfs2: Do not map blocks from local quota file on each write quota: Refactor dquot_transfer code so that OCFS2 can pass in its references quota: unify quota init condition in setattr quota: remove sb_has_quota_active in get/set_info quota: unify ->set_dqblk quota: unify ->get_dqblk ext3: make barrier options consistent with ext4 quota: Make quota stat accounting lockless. suppress warning: "quotatypes" defined but not used ext3: Fix waiting on transaction during fsync jbd: Provide function to check whether transaction will issue data barrier ufs: add ufs speciffic ->setattr call BKL: Remove BKL from ext2 filesystem ...
2010-05-21ext3: make barrier options consistent with ext4Eric Sandeen
ext4 was updated to accept barrier/nobarrier mount options in addition to the older barrier=0/1. The barrier story is complex enough, we should help people by making the options the same at least, even if the defaults are different. This patch allows the barrier/nobarrier mount options for ext3, while keeping nobarrier the default. It also unconditionally displays barrier status in show_options, and prints a message at mount time if barriers are not enabled, just as ext4 does. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21sysfs-namespaces: add a high-level Documentation fileSerge E. Hallyn
The first three paragraphs are almost verbatim taken from Eric's commit message on the patch introducing network ns tags. The next two paragraphs I wrote to be a brief high level overview. The last section is taken from the commit message on "Implement sysfs tagged directory support", but updated. Hopefully correctly. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (23 commits) nilfs2: disallow remount of snapshot from/to a regular mount nilfs2: use huge_encode_dev/huge_decode_dev nilfs2: update comment on deactivate_super at nilfs_get_sb nilfs2: replace MS_VERBOSE with MS_SILENT nilfs2: add missing initialization of s_mode nilfs2: fix misuse of open_bdev_exclusive/close_bdev_exclusive nilfs2: enlarge s_volume_name member in nilfs_super_block nilfs2: use checkpoint number instead of timestamp to select super block nilfs2: add missing endian conversion on super block magic number nilfs2: make nilfs_sc_*_ops static nilfs2: add kernel doc comments to persistent object allocator functions nilfs2: change sc_timer from a pointer to an embedded one in struct nilfs_sc_info nilfs2: remove nilfs_segctor_init() in segment.c nilfs2: insert checkpoint number in segment summary header nilfs2: add a print message after loading nilfs2 nilfs2: cleanup multi kmem_cache_{create,destroy} code nilfs2: move out checksum routines to segment buffer code nilfs2: move pointer to super root block into logs nilfs2: change default of 'errors' mount option to 'remount-ro' mode nilfs2: Combine nilfs_btree_release_path() and nilfs_btree_free_path() ...
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: GFS2: Fix typo GFS2: stuck in inode wait, no glocks stuck GFS2: Eliminate useless err variable GFS2: Fix writing to non-page aligned gfs2_quota structures GFS2: Add some useful messages GFS2: fix quota state reporting GFS2: Various gfs2_logd improvements GFS2: glock livelock GFS2: Clean up stuffed file copying GFS2: docs update GFS2: Remove space from slab cache name
2010-05-21Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (47 commits) ocfs2: Silence a gcc warning. ocfs2: Don't retry xattr set in case value extension fails. ocfs2:dlm: avoid dlm->ast_lock lockres->spinlock dependency break ocfs2: Reset xattr value size after xa_cleanup_value_truncate(). fs/ocfs2/dlm: Use kstrdup fs/ocfs2/dlm: Drop memory allocation cast Ocfs2: Optimize punching-hole code. Ocfs2: Make ocfs2_find_cpos_for_left_leaf() public. Ocfs2: Fix hole punching to correctly do CoW during cluster zeroing. Ocfs2: Optimize ocfs2 truncate to use ocfs2_remove_btree_range() instead. ocfs2: Block signals for mkdir/link/symlink/O_CREAT. ocfs2: Wrap signal blocking in void functions. ocfs2/dlm: Increase o2dlm lockres hash size ocfs2: Make ocfs2_extend_trans() really extend. ocfs2/trivial: Code cleanup for allocation reservation. ocfs2: make ocfs2_adjust_resv_from_alloc simple. ocfs2: Make nointr a default mount option ocfs2/dlm: Make o2dlm domain join/leave messages KERN_NOTICE o2net: log socket state changes ocfs2: print node # when tcp fails ...
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-19Merge branch 'for-2.6.35' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.35' of git://linux-nfs.org/~bfields/linux: (45 commits) Revert "nfsd4: distinguish expired from stale stateids" nfsd: safer initialization order in find_file() nfs4: minor callback code simplification, comment NFSD: don't report compiled-out versions as present nfsd4: implement reclaim_complete nfsd4: nfsd4_destroy_session must set callback client under the state lock nfsd4: keep a reference count on client while in use nfsd4: mark_client_expired nfsd4: introduce nfs4_client.cl_refcount nfsd4: refactor expire_client nfsd4: extend the client_lock to cover cl_lru nfsd4: use list_move in move_to_confirmed nfsd4: fold release_session into expire_client nfsd4: rename sessionid_lock to client_lock nfsd4: fix bare destroy_session null dereference nfsd4: use local variable in nfs4svc_encode_compoundres nfsd: further comment typos sunrpc: centralise most calls to svc_xprt_received nfsd4: fix unlikely race in session replay case nfsd4: fix filehandle comment ...
2010-05-19Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Clear CPU mask in affinity_hint when none is provided genirq: Add CPU mask affinity hint genirq: Remove IRQF_DISABLED from core code genirq: Run irq handlers with interrupts disabled genirq: Introduce request_any_context_irq() genirq: Expose irq_desc->node in proc/irq Fixed up trivial conflicts in Documentation/feature-removal-schedule.txt
2010-05-13nfsd4: implement reclaim_completeJ. Bruce Fields
This is a mandatory operation. Also, here (not in open) is where we should be committing the reboot recovery information. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-05-11revert "procfs: provide stack information for threads" and its fixup commitsRobin Holt
Originally, commit d899bf7b ("procfs: provide stack information for threads") attempted to introduce a new feature for showing where the threadstack was located and how many pages are being utilized by the stack. Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was applied to fix the NO_MMU case. Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on 64-bit") was applied to fix a bug in ia32 executables being loaded. Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel threads") was applied to fix a bug which had kernel threads printing a userland stack address. Commit 1306d603f ('proc: partially revert "procfs: provide stack information for threads"') was then applied to revert the stack pages being used to solve a significant performance regression. This patch nearly undoes the effect of all these patches. The reason for reverting these is it provides an unusable value in field 28. For x86_64, a fork will result in the task->stack_start value being updated to the current user top of stack and not the stack start address. This unpredictability of the stack_start value makes it worthless. That includes the intended use of showing how much stack space a thread has. Other architectures will get different values. As an example, ia64 gets 0. The do_fork() and copy_process() functions appear to treat the stack_start and stack_size parameters as architecture specific. I only partially reverted c44972f1 ("procfs: disable per-task stack usage on NOMMU") . If I had completely reverted it, I would have had to change mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is configured. Since I could not test the builds without significant effort, I decided to not change mm/Makefile. I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on 64-bit") . I left the KSTK_ESP() change in place as that seemed worthwhile. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Stefani Seibold <stefani@seibold.net> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-10doc: inode uses a mutex instead of a semaphore.Thadeu Lima de Souza Cascardo
Replace the introduced i_sem by an i_mutex in the filesystem locking documentation. This was introduced [1] after all occurrences were already replaced in the same text [2]. However, the term "inode semaphore" has not been replaced then, and it's replaced now. [1] afddba49d18f346e5cc2938b6ed7c512db18ca68 [2] a7bc02f4f47fd0e7860c6589f0ad000d1476f7a3 Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-10fix "seperate" typos in commentsAnand Gadiyar
s/seperate/separate Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-10nilfs2: change default of 'errors' mount option to 'remount-ro' modeRyusuke Konishi
Like ext3, nilfs has 'errors' mount option to allow specifying desired behavior on severe errors. Currently, the default action is 'errors=continue' and has potential to advance filesystem corruption for severe errors. This will change the action to 'errors=remount-ro' to avoid the issue. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-05ocfs2: Add dir_resv_level mount optionMark Fasheh
The default behavior for directory reservations stays the same, but we add a mount option so people can tweak the size of directory reservations according to their workloads. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-05ocfs2: change default reservation window sizesMark Fasheh
The default reservation size of 4 (32-bit windows) is a bit too ambitious. Scale it back to 16 bits (resv_level=2). I have been testing various sizes on a 4-node cluster which runs a mixed workload that is heavily threaded. With a 256MB local alloc, I get *roughly* the following levels of average file fragmentation: resv_level=0 70% resv_level=1 21% resv_level=2 23% resv_level=3 24% resv_level=4 60% resv_level=5 did not test resv_level=6 60% resv_level=2 seemed like a good compromise between not letting windows be too small, but not so big that heavier workloads will immediately suffer without tuning. This patch also change the behavior of directory reservations - they now track file reservations. The previous compromise of giving directory windows only 8 bits wound up fragmenting more at some window sizes because file allocations had smaller unused windows to poach from. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-05ocfs2: allocation reservationsMark Fasheh
This patch improves Ocfs2 allocation policy by allowing an inode to reserve a portion of the local alloc bitmap for itself. The reserved portion (allocation window) is advisory in that other allocation windows might steal it if the local alloc bitmap becomes full. Otherwise, the reservations are honored and guaranteed to be free. When the local alloc window is moved to a different portion of the bitmap, existing reservations are discarded. Reservation windows are represented internally by a red-black tree. Within that tree, each node represents the reservation window of one inode. An LRU of active reservations is also maintained. When new data is written, we allocate it from the inodes window. When all bits in a window are exhausted, we allocate a new one as close to the previous one as possible. Should we not find free space, an existing reservation is pulled off the LRU and cannibalized. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-04-13Merge branch 'linus' into irq/coreThomas Gleixner
Reason: Get the upstream IRQF_DISABLED related changes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-04-059p: documentation updateSripathi Kodi
This patch adds documentation for new 9P options introduced in 2.6.34. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits) ceph: update discussion list address in MAINTAINERS ceph: some documentations fixes ceph: fix use after free on mds __unregister_request ceph: avoid loaded term 'OSD' in documention ceph: fix possible double-free of mds request reference ceph: fix session check on mds reply ceph: handle kmalloc() failure ceph: propagate mds session allocation failures to caller ceph: make write_begin wait propagate ERESTARTSYS ceph: fix snap rebuild condition ceph: avoid reopening osd connections when address hasn't changed ceph: rename r_sent_stamp r_stamp ceph: fix connection fault con_work reentrancy problem ceph: prevent dup stale messages to console for restarting mds ceph: fix pg pool decoding from incremental osdmap update ceph: fix mds sync() race with completing requests ceph: only release unused caps with mds requests ceph: clean up handle_cap_grant, handle_caps wrt session mutex ceph: fix session locking in handle_caps, ceph_check_caps ceph: drop unnecessary WARN_ON in caps migration ...
2010-03-29ceph: some documentations fixesCheng Renquan
New documentation should have an entry in the 00-INDEX. Correct git urls. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-03-29GFS2: docs updateAndrea Gelmini
Now http://sources.redhat.com/cluster/ is redirected to http://sources.redhat.com/cluster/wiki/ Also fixed tabs in the end. Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-03-24doc: add the documentation for mpol=localKOSAKI Motohiro
commit 3f226aa1c (mempolicy: support mpol=local tmpfs mount option) added new mpol=local mount option. but it didn't add a documentation. This patch does it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24genirq: Expose irq_desc->node in proc/irqDimitri Sivanich
Expose irq_desc->node as /proc/irq/*/node. This file provides device hardware locality information for apps desiring to include hardware locality in irq mapping decisions. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-23ceph: avoid loaded term 'OSD' in documentionSage Weil
'OSD' means different things to different people; avoid it here to avoid confusion. Signed-off-by: Sage Weil <sage@newdream.net>
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2010-03-15Documentation/filesystems/proc.txt typo fix.Rob Landley
Typo fix for a filename in procfs documentation. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12Documentation/fs/: split txt and source filesRandy Dunlap
Make dnotify_test.c source file and add it to Makefile so that bitrot can be prevented. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2010-03-06Merge branch 'for-2.6.34' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd4: fix minor memory leak svcrpc: treat uid's as unsigned nfsd: ensure sockets are closed on error Revert "sunrpc: move the close processing after do recvfrom method" Revert "sunrpc: fix peername failed on closed listener" sunrpc: remove unnecessary svc_xprt_put NFSD: NFSv4 callback client should use RPC_TASK_SOFTCONN xfs_export_operations.commit_metadata commit_metadata export operation replacing nfsd_sync_dir lockd: don't clear sm_monitored on nsm_reboot_lookup lockd: release reference to nsm_handle in nlm_host_rebooted nfsd: Use vfs_fsync_range() in nfsd_commit NFSD: Create PF_INET6 listener in write_ports SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found" SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt() NFSD: Support AF_INET6 in svc_addsock() function SUNRPC: Use rpc_pton() in ip_map_parse() nfsd: 4.1 has an rfc number nfsd41: Create the recovery entry for the NFSv4.1 client nfsd: use vfs_fsync for non-directories ...
2010-03-06mm: document /proc/pagetypeinfoMel Gorman
Add documentation for /proc/pagetypeinfo. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: count swap usageKAMEZAWA Hiroyuki
A frequent questions from users about memory management is what numbers of swap ents are user for processes. And this information will give some hints to oom-killer. Besides we can count the number of swapents per a process by scanning /proc/<pid>/smaps, this is very slow and not good for usual process information handler which works like 'ps' or 'top'. (ps or top is now enough slow..) This patch adds a counter of swapents to mm_counter and update is at each swap events. Information is exported via /proc/<pid>/status file as [kamezawa@bluextal memory]$ cat /proc/self/status Name: cat State: R (running) Tgid: 2910 Pid: 2910 PPid: 2823 TracerPid: 0 Uid: 500 500 500 500 Gid: 500 500 500 500 FDSize: 256 Groups: 500 VmPeak: 82696 kB VmSize: 82696 kB VmLck: 0 kB VmHWM: 432 kB VmRSS: 432 kB VmData: 172 kB VmStk: 84 kB VmExe: 48 kB VmLib: 1568 kB VmPTE: 40 kB VmSwap: 0 kB <=============== this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: avoid false sharing of mm_counterKAMEZAWA Hiroyuki
Considering the nature of per mm stats, it's the shared object among threads and can be a cache-miss point in the page fault path. This patch adds per-thread cache for mm_counter. RSS value will be counted into a struct in task_struct and synchronized with mm's one at events. Now, in this patch, the event is the number of calls to handle_mm_fault. Per-thread value is added to mm at each 64 calls. rough estimation with small benchmark on parallel thread (2threads) shows [before] 4.5 cache-miss/faults [after] 4.0 cache-miss/faults Anyway, the most contended object is mmap_sem if the number of threads grows. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
