path: root/Documentation/filesystems
2011-01-31NTFS: Fix invalid pointer dereference in ntfs_mft_record_alloc().Anton Altaparmakov
In ntfs_mft_record_alloc() when mapping the new extent mft record with map_extent_mft_record() we overwrite @m with the return value and on error, we then try to use the old @m but that is no longer there as @m now contains an error code instead so we crash when dereferencing the error code as if it were a pointer. The simple fix is to use a temporary variable to store the return value thus preserving the original @m for later use. This is a backport from the commercial Tuxera-NTFS driver and is well tested... Thanks go to Julia Lawall for pointing this out (whilst I had fixed it in the commercial driver I had failed to fix it in the Linux kernel). Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-17fallocate should be a file operationChristoph Hellwig
Currently all filesystems except XFS implement fallocate asynchronously, while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC I/O we really want our allocation on disk, especially for the !KEEP_SIZE case where we actually grow the file with user-visible zeroes. On the other hand always commiting the transaction is a bad idea for fast-path uses of fallocate like for example in recent Samba versions. Given that block allocation is a data plane operation anyway change it from an inode operation to a file operation so that we have the file structure available that lets us check for O_SYNC. This also includes moving the code around for a few of the filesystems, and remove the already unnedded S_ISDIR checks given that we only wire up fallocate for regular files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) sanitize vfsmount refcounting changes fix old umount_tree() breakage autofs4: Merge the remaining dentry ops tables Unexport do_add_mount() and add in follow_automount(), not ->d_automount() Allow d_manage() to be used in RCU-walk mode Remove a further kludge from __do_follow_link() autofs4: Bump version autofs4: Add v4 pseudo direct mount support autofs4: Fix wait validation autofs4: Clean up autofs4_free_ino() autofs4: Clean up dentry operations autofs4: Clean up inode operations autofs4: Remove unused code autofs4: Add d_manage() dentry operation autofs4: Add d_automount() dentry operation Remove the automount through follow_link() kludge code from pathwalk CIFS: Use d_automount() rather than abusing follow_link() NFS: Use d_automount() rather than abusing follow_link() AFS: Use d_automount() rather than abusing follow_link() Add an AT_NO_AUTOMOUNT flag to suppress terminal automount ...
2011-01-15Unexport do_add_mount() and add in follow_automount(), not ->d_automount()David Howells
Unexport do_add_mount() and make ->d_automount() return the vfsmount to be added rather than calling do_add_mount() itself. follow_automount() will then do the addition. This slightly complicates things as ->d_automount() normally wants to add the new vfsmount to an expiration list and start an expiration timer. The problem with that is that the vfsmount will be deleted if it has a refcount of 1 and the timer will not repeat if the expiration list is empty. To this end, we require the vfsmount to be returned from d_automount() with a refcount of (at least) 2. One of these refs will be dropped unconditionally. In addition, follow_automount() must get a 3rd ref around the call to do_add_mount() lest it eat a ref and return an error, leaving the mount we have open to being expired as we would otherwise have only 1 ref on it. d_automount() should also add the the vfsmount to the expiration list (by calling mnt_set_expiry()) and start the expiration timer before returning, if this mechanism is to be used. The vfsmount will be unlinked from the expiration list by follow_automount() if do_add_mount() fails. This patch also fixes the call to do_add_mount() for AFS to propagate the mount flags from the parent vfsmount. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Allow d_manage() to be used in RCU-walk modeDavid Howells
Allow d_manage() to be called from pathwalk when it is in RCU-walk mode as well as when it is in Ref-walk mode. This permits __follow_mount_rcu() to call d_manage() directly. d_manage() needs a parameter to indicate that it is in RCU-walk mode as it isn't allowed to sleep if in that mode (but should return -ECHILD instead). autofs4_d_manage() can then be set to retain RCU-walk mode if the daemon accesses it and otherwise request dropping back to ref-walk mode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to allow processes to be held during pathwalk transitDavid Howells
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it sleep when it tries to transit away from one of that filesystem's directories during a pathwalk. The operation is keyed off a new dentry flag (DCACHE_MANAGE_TRANSIT). The filesystem is allowed to be selective about which processes it holds and which it permits to continue on or prohibits from transiting from each flagged directory. This will allow autofs to hold up client processes whilst letting its userspace daemon through to maintain the directory or the stuff behind it or mounted upon it. The ->d_manage() dentry operation: int (*d_manage)(struct path *path, bool mounting_here); takes a pointer to the directory about to be transited away from and a flag indicating whether the transit is undertaken by do_add_mount() or do_move_mount() skipping through a pile of filesystems mounted on a mountpoint. It should return 0 if successful and to let the process continue on its way; -EISDIR to prohibit the caller from skipping to overmounted filesystems or automounting, and to use this directory; or some other error code to return to the user. ->d_manage() is called with namespace_sem writelocked if mounting_here is true and no other locks held, so it may sleep. However, if mounting_here is true, it may not initiate or wait for a mount or unmount upon the parameter directory, even if the act is actually performed by userspace. Within fs/namei.c, follow_managed() is extended to check with d_manage() first on each managed directory, before transiting away from it or attempting to automount upon it. follow_down() is renamed follow_down_one() and should only be used where the filesystem deliberately intends to avoid management steps (e.g. autofs). A new follow_down() is added that incorporates the loop done by all other callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS and CIFS do use it, their use is removed by converting them to use d_automount()). The new follow_down() calls d_manage() as appropriate. It also takes an extra parameter to indicate if it is being called from mount code (with namespace_sem writelocked) which it passes to d_manage(). follow_down() ignores automount points so that it can be used to mount on them. __follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have that determine whether to abort or not itself. That would allow the autofs daemon to continue on in rcu-walk mode. Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't required as every tranist from that directory will cause d_manage() to be invoked. It can always be set again when necessary. ========================== WHAT THIS MEANS FOR AUTOFS ========================== Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to trigger the automounting of indirect mounts, and both of these can be called with i_mutex held. autofs knows that the i_mutex will be held by the caller in lookup(), and so can drop it before invoking the daemon - but this isn't so for d_revalidate(), since the lock is only held on _some_ of the code paths that call it. This means that autofs can't risk dropping i_mutex from its d_revalidate() function before it calls the daemon. The bug could manifest itself as, for example, a process that's trying to validate an automount dentry that gets made to wait because that dentry is expired and needs cleaning up: mkdir S ffffffff8014e05a 0 32580 24956 Call Trace: [<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897 [<ffffffff80127f7d>] avc_has_perm+0x46/0x58 [<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e [<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b [<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149 [<ffffffff80036d96>] __lookup_hash+0xa0/0x12f [<ffffffff80057a2f>] lookup_create+0x46/0x80 [<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4 versus the automount daemon which wants to remove that dentry, but can't because the normal process is holding the i_mutex lock: automount D ffffffff8014e05a 0 32581 1 32561 Call Trace: [<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b [<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1 [<ffffffff80063c89>] .text.lock.mutex+0xf/0x14 [<ffffffff800e6d55>] do_rmdir+0x77/0xde [<ffffffff8005d229>] tracesys+0x71/0xe0 [<ffffffff8005d28d>] tracesys+0xd5/0xe0 which means that the system is deadlocked. This patch allows autofs to hold up normal processes whilst the daemon goes ahead and does things to the dentry tree behind the automouter point without risking a deadlock as almost no locks are held in d_manage() and none in d_automount(). Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to handle automounting rather than abusing follow_link()David Howells
Add a dentry op (d_automount) to handle automounting directories rather than abusing the follow_link() inode operation. The operation is keyed off a new dentry flag (DCACHE_NEED_AUTOMOUNT). This also makes it easier to add an AT_ flag to suppress terminal segment automount during pathwalk and removes the need for the kludge code in the pathwalk algorithm to handle directories with follow_link() semantics. The ->d_automount() dentry operation: struct vfsmount *(*d_automount)(struct path *mountpoint); takes a pointer to the directory to be mounted upon, which is expected to provide sufficient data to determine what should be mounted. If successful, it should return the vfsmount struct it creates (which it should also have added to the namespace using do_add_mount() or similar). If there's a collision with another automount attempt, NULL should be returned. If the directory specified by the parameter should be used directly rather than being mounted upon, -EISDIR should be returned. In any other case, an error code should be returned. The ->d_automount() operation is called with no locks held and may sleep. At this point the pathwalk algorithm will be in ref-walk mode. Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is added to handle mountpoints. It will return -EREMOTE if the automount flag was set, but no d_automount() op was supplied, -ELOOP if we've encountered too many symlinks or mountpoints, -EISDIR if the walk point should be used without mounting and 0 if successful. The path will be updated to point to the mounted filesystem if a successful automount took place. __follow_mount() is replaced by follow_managed() which is more generic (especially with the patch that adds ->d_manage()). This handles transits from directories during pathwalk, including automounting and skipping over mountpoints (and holding processes with the next patch). __follow_mount_rcu() will jump out of RCU-walk mode if it encounters an automount point with nothing mounted on it. follow_dotdot*() does not handle automounts as you don't want to trigger them whilst following "..". I've also extracted the mount/don't-mount logic from autofs4 and included it here. It makes the mount go ahead anyway if someone calls open() or creat(), tries to traverse the directory, tries to chdir/chroot/etc. into the directory, or sticks a '/' on the end of the pathname. If they do a stat(), however, they'll only trigger the automount if they didn't also say O_NOFOLLOW. I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their inodes as automount points. This flag is automatically propagated to the dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could save AFS a private flag bit apiece, but is not strictly necessary. It would be preferable to do the propagation in d_set_d_op(), but that doesn't normally have access to the inode. [AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu() succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after that, rather than just returning with ungrabbed *path] Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-13Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: fs: fix do_last error case when need_reval_dot nfs: add missing rcu-walk check fs: hlist UP debug fixup fs: fix dropping of rcu-walk from force_reval_path fs: force_reval_path drop rcu-walk before d_invalidate fs: small rcu-walk documentation fixes Fixed up trivial conflicts in Documentation/filesystems/porting
2011-01-14fs: small rcu-walk documentation fixesNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-13oom: allow a non-CAP_SYS_RESOURCE proces to oom_score_adj downMandeep Singh Baines
We'd like to be able to oom_score_adj a process up/down as it enters/leaves the foreground. Currently, it is not possible to oom_adj down without CAP_SYS_RESOURCE. This patch allows a task to decrease its oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to or its inherited value at fork. Assuming the thread that has forked it has oom_score_adj of 0, each process could decrease it back from 0 upon activation unless a CAP_SYS_RESOURCE thread elevated it to something higher. Alternative considered: * a setuid binary * a daemon with CAP_SYS_RESOURCE Since you don't wan't all processes to be able to reduce their oom_adj, a setuid or daemon implementation would be complex. The alternatives also have much higher overhead. This patch updated from original patch based on feedback from David Rientjes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: smaps: export mlock informationNikanth Karthikesan
Currently there is no way to find whether a process has locked its pages in memory or not. And which of the memory regions are locked in memory. Add a new field "Locked" to export this information via the smaps file. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-12fs: add documentation on fallocate hole punchingJosef Bacik
This patch simply adds documentation on how to handle the hole punching mode of fallocate for any filesystem wishing to use it. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12NTFS: writev() fix and maintenance/contact details updateAnton Altaparmakov
Fix writev() to not keep writing the first segment over and over again instead of moving onto subsequent segments and update the NTFS entry in MAINTAINERS to reflect that Tuxera Inc. now supports the NTFS driver. Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-11Documentation: fl_mylease no longer existsJ. Bruce Fields
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-04remove trim_fs method from Documentation/filesystems/LockingChristoph Hellwig
The ->trim_fs has been removed meanwhile, so remove it from the documentation as well. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-30update Documentation/filesystems/LockingChristoph Hellwig
Mostly inspired by all the recent BKL removal changes, but a lot of older updates also weren't properly recorded. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Fix panic after nfs_umount() nfs: remove extraneous and problematic calls to nfs_clear_request nfs: kernel should return EPROTONOSUPPORT when not support NFSv4 NFS: Fix fcntl F_GETLK not reporting some conflicts nfs: Discard ACL cache on mode update NFS: Readdir cleanups NFS: nfs_readdir_search_for_cookie() don't mark as eof if cookie not found NFS: Fix a memory leak in nfs_readdir Call the filesystem back whenever a page is removed from the page cache NFS: Ensure we use the correct cookie in nfs_readdir_xdr_filler
2010-12-02Documentation/filesystems/vfs.txt: fix ->repeasepage() descriptionAndrew Morton
->releasepage() does not remove the page from the mapping. Acked-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02Call the filesystem back whenever a page is removed from the page cacheLinus Torvalds
NFS needs to be able to release objects that are stored in the page cache once the page itself is no longer visible from the page cache. This patch adds a callback to the address space operations that allows filesystems to perform page cleanups once the page has been removed from the page cache. Original patch by: Linus Torvalds <torvalds@linux-foundation.org> [trondmy: cover the cases of invalidate_inode_pages2() and truncate_inode_pages()] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-18Documentation: make configfs example code simpler, clearerDan Carpenter
If "p" is NULL then it will cause an oops when we pass it to simple_strtoul(). In this case "p" can not be NULL so I removed the check. I also changed the check a little to make it more explicit that we are testing whether p points to the NUL char. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16console: add /proc/consolesJiri Slaby
It allows users to see what consoles are currently known to the system and with what flags. It is based on Werner's patch, the part about traversing fds was removed, the code was moved to kernel/printk.c, where consoles are handled and it makes more sense to me. Signed-off-by: Jiri Slaby <jslaby@suse.cz> [cleanups] Signed-off-by: "Dr. Werner Fink" <werner@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-10xfs: remove experimental tag from the delaylog optionChristoph Hellwig
We promised to do this for 2.6.37, and the code looks stable enough to keep that promise. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-31locks: remove fl_copy_lock lock_manager operationChristoph Hellwig
This one was only used for a nasty hack in nfsd, which has recently been removed. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (841 commits) Staging: brcm80211: fix usage of roundup in structures Staging: bcm: fix up network device reference counting Staging: keucr: fix up US_ macro change staging: brcm80211: brcmfmac: Removed codeversion from firmware filenames. staging: brcm80211: Remove unnecessary header files. staging: brcm80211: Remove unnecessary includes from bcmutils.c staging: brcm80211: Removed unnecessary pktsetprio() function. Staging: brcm80211: remove typedefs.h Staging: brcm80211: remove uintptr typedef usage Staging: hv: remove struct vmbus_channel_interface Staging: hv: remove Open from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_open directly Staging: hv: netvsc: call vmbus_open directly Staging: hv: channel: export vmbus_open to modules Staging: hv: remove Close from struct vmbus_channel_interface Staging: hv: netvsc: call vmbus_close directly Staging: hv: storvsc: call vmbus_close directly Staging: hv: channel: export vmbus_close to modules Staging: hv: remove SendPacket from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_sendpacket directly ... Fix up conflicts in drivers/staging/cx25821/cx25821-audio-upstream.c drivers/staging/cx25821/cx25821-audio.h due to warring whitespace cleanups (neither of which were all that great)
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28fs/9p: Add access = client option to opt in acl evaluation.Aneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27ext4: add support for lazy inode table initializationLukas Czerner
When the lazy_itable_init extended option is passed to mke2fs, it considerably speeds up filesystem creation because inode tables are not zeroed out. The fact that parts of the inode table are uninitialized is not a problem so long as the block group descriptors, which contain information regarding how much of the inode table has been initialized, has not been corrupted However, if the block group checksums are not valid, e2fsck must scan the entire inode table, and the the old, uninitialized data could potentially cause e2fsck to report false problems. Hence, it is important for the inode tables to be initialized as soon as possble. This commit adds this feature so that mke2fs can safely use the lazy inode table initialization feature to speed up formatting file systems. This is done via a new new kernel thread called ext4lazyinit, which is created on demand and destroyed, when it is no longer needed. There is only one thread for all ext4 filesystems in the system. When the first filesystem with inititable mount option is mounted, ext4lazyinit thread is created, then the filesystem can register its request in the request list. This thread then walks through the list of requests picking up scheduled requests and invoking ext4_init_inode_table(). Next schedule time for the request is computed by multiplying the time it took to zero out last inode table with wait multiplier, which can be set with the (init_itable=n) mount option (default is 10). We are doing this so we do not take the whole I/O bandwidth. When the thread is no longer necessary (request list is empty) it frees the appropriate structures and exits (and can be created later later by another filesystem). We do not disturb regular inode allocations in any way, it just do not care whether the inode table is, or is not zeroed. But when zeroing, we have to skip used inodes, obviously. Also we should prevent new inode allocations from the group, while zeroing is on the way. For that we take write alloc_sem lock in ext4_init_inode_table() and read alloc_sem in the ext4_claim_inode, so when we are unlucky and allocator hits the group which is currently being zeroed, it just has to wait. This can be suppresed using the mount option no_init_itable. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27/proc/pid/pagemap: document in Documentation/filesystems/proc.txtNikanth Karthikesan
Document /proc/pid/pagemap in Documentation/filesystems/proc.txt Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Cc: Richard Guenther <rguenther@suse.de> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27/proc/pid/smaps: export amount of anonymous memory in a mappingNikanth Karthikesan
Export the number of anonymous pages in a mapping via smaps. Even the private pages in a mapping backed by a file, would be marked as anonymous, when they are modified. Export this information to user-space via smaps. Exporting this count will help gdb to make a better decision on which areas need to be dumped in its coredump; and should be useful to others studying the memory usage of a process. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: rename nfs.upcall -> nfs.idmap NFS: Fix a compile issue in nfs_root
2010-10-26Documentation/filesystems/proc.txt: improve smaps field documentationMatt Mackall
Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Nikanth Karthikesan <knikanth@suse.de> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26NFS: rename nfs.upcall -> nfs.idmapBryan Schumaker
This patch renames the idmapper upcall program from nfs.upcall to nfs.idmap in the NFS documentation. This is because the program has been renamed in the nfs-utils source. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: net/sunrpc: Use static const char arrays nfs4: fix channel attribute sanity-checks NFSv4.1: Use more sensible names for 'initialize_mountpoint' NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO infrastructure NFSv4.1: pnfs: add LAYOUTGET and GETDEVICEINFO infrastructure NFS: client needs to maintain list of inodes with active layouts NFS: create and destroy inode's layout cache NFSv4.1: pnfs: filelayout: introduce minimal file layout driver NFSv4.1: pnfs: full mount/umount infrastructure NFS: set layout driver NFS: ask for layouttypes during v4 fsinfo call NFS: change stateid to be a union NFSv4.1: pnfsd, pnfs: protocol level pnfs constants SUNRPC: define xdr_decode_opaque_fixed NFSD: remove duplicate NFS4_STATEID_SIZE
2010-10-25update block_device_operations documentationChristoph Hellwig
Updated Documentation/filesystems/Locking to match the code. Signed-off-by: Christoph Hellwig <hch@lst.de>
2010-10-25Documentation: Fix trivial typo in filesystems/sharedsubtree.txtValerie Aurora
Documentation: Fix trivial typo in filesystems/sharedsubtree.txt This typo is easy to ignore unless you have spent a great deal of time thinking about how to eliminate duplicate dentries in unions. Signed-off-by: Valerie Aurora <vaurora@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits) SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred nfs: fix unchecked value Ask for time_delta during fsinfo probe Revalidate caches on lock SUNRPC: After calling xprt_release(), we must restart from call_reserve NFSv4: Fix up the 'dircount' hint in encode_readdir NFSv4: Clean up nfs4_decode_dirent NFSv4: nfs4_decode_dirent must clear entry->fattr->valid NFSv4: Fix a regression in decode_getfattr NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer NFS: Ensure we check all allocation return values in new readdir code NFS: Readdir plus in v4 NFS: introduce generic decode_getattr function NFS: check xdr_decode for errors NFS: nfs_readdir_filler catch all errors NFS: readdir with vmapped pages NFS: remove page size checking code NFS: decode_dirent should use an xdr_stream SUNRPC: Add a helper function xdr_inline_peek NFS: remove readdir plus limit ...
2010-10-24NFSv4.1: pnfs: full mount/umount infrastructureFred Isaman
Allow a module implementing a layout type to register, and have its mount/umount routines called for filesystems that the server declares support it. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Bian Naimeng <biannm@cn.fujitsu.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
